Koni Regulars vs. Neuspeed Konis
Old Oct 24, 2002 | 09:47 AM
Aaron M's Avatar
Default Koni Regulars vs. Neuspeed Konis
I found neuspeed konis for $575, and there not much more than regulars. Are there any other differences between the 2 besides the additional perches on the neuspeeds. Also those of you with the neuspeed versions. what are the additional perch measurments? i know the regulars is 25mm lower on the front and 15mm on the rears. What are they for neuspeeds? I will be pairing either of the 2 with H&R sports. Thanks.
Old Oct 24, 2002 | 10:06 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Koni Regulars vs. Neuspeed Konis (SilverB18C1)
It has more slots which are closer together, so you can't go any lower than w/ the regular Koni adjustables, but you do have more options in between. Also the shock body is 20mm shorter, which gives you that much more suspension travel.
Old Oct 24, 2002 | 10:11 AM
Aaron M's Avatar
Default Re: Koni Regulars vs. Neuspeed Konis (PatrickGSR94)
i must be a newbie, but how exactly does a shorter shock body help?
Old Oct 24, 2002 | 11:00 AM
Vu's Avatar
Vu
I believe the stroke(rod, shaft) is shortening by 20mm, not the the body(casing)
Old Oct 24, 2002 | 12:18 PM
Community Builder
Default Re: Koni Regulars vs. Neuspeed Konis (Vu)
If the rod was shorter, suspension travel would remain the same or actually be less.
By having a shorter casing, you get more suspension travel. Think about when the shock is fully compressed, on the bumpstop. Take away 20mm from the top of the casing, and you can compress the shock another 20mm. That's how it works.
Old Oct 24, 2002 | 12:27 PM
Aaron M's Avatar
so the neuspeed konis have more perches and performs better?
Old Oct 24, 2002 | 12:40 PM
Aaron M's Avatar
i believe its the shaft that is 20mm shorter
http://www.gprparts.com/neuspeed/koinishock_price.html
Old Oct 24, 2002 | 09:16 PM
Aaron M's Avatar
dont you guys think that its kinda scary knowing the only thing holding your car up is that little c clip?
Old Nov 19, 2002 | 07:35 AM
Creep's Avatar
Yeah that adjustable perch thing thing scares me too... will it ever rust out and give?
Oh yeah 545 at tornactive shipped....
Old Nov 19, 2002 | 09:56 AM
Community Builder
Default Re: Koni Regulars vs. Neuspeed Konis (Creep)
Been on my car for 9 months now, other people have had them for years, no problems.
Old Nov 19, 2002 | 11:10 AM
GSRaCeRbOI's Avatar
I've had my Eibach Sportlines for 5+ years going on 6... and my Koni Yellows for 3+ years (going on 4 years this summer)... never had any problems w/ the perches rusting out, or the C-clip failing and dropping the vehicle or anything... no problems at all
Old Nov 19, 2002 | 12:14 PM
Dirty GS-R's Avatar
New User
year and a half here with no problems.
Old Nov 19, 2002 | 12:19 PM
Aaron M's Avatar
Default Re: Koni Regulars vs. Neuspeed Konis (Dirty GS-R)
3 weeks no problem here
MartyMarGSR
May 22, 2003 10:07 AM
neo1z
Apr 5, 2003 12:38 PM
DOHCTOR
Jan 14, 2003 06:55 PM
integranator
Nov 15, 2002 01:05 PM
00VTEC
Oct 26, 2001 08:41 AM
