View Full Version : Acura Integra
- LS all motor questions...
- 88 Acura Integra 1.6 DOHC, erratic idle, exhaust vapor and more...
- AC problems...
- Fuel filter - Something wrong? (Pic link inside)
- Pic Request - White Slipstreams -
- How much oil?
- A/C R- 134a Recharge kits/Do they work?
- 2002 civic si shift knob interchangable?
- When to replace distributor?
- is there any way to get a HP/TQ reading on a car w/out use of a dyno machine?
- koni yellows and gc short review and minor problem
- GSR Performance Upgrades
- I'm getting ready for nos
- Adjusting Koni Yellows (rear)
- Problem
- **just picked my head up from the machine shop (pics)**
- Replacing the Vent???
- how to build for low end power
- Cutting valve cover for adj. cam gears?
- Driveshaft troubles....
- Rear sway bar question....
- Quick header question
- blue smoke and low oil
- wanker clutch problems...help!!
- I/H/E Setup on the Teg
- Rear Sway Bar install...
- Manual transmission Fluid change torque specs
- Got new 16" rims....need new tires....whats the best size to get to match my stock 15" tires?
- Question on Cam Gears & other performance "dress ups"
- Anyone fit a bigger K&N on their Iceman (shorty?)
- lllllllllll SMOG TEST TODAY lllllllllllllll
- OkHELP Car wont start !!!
- Looking to see how much my gsr is worth
- Best Cams for durability and engine life for a GSR?
- modified exhaust bill?
- Need an opinion in getting my next car
- VAFC Tuning on Stock GSR
- whats the difference............
- Annoying squeek in hatch
- wanna change ecu
- Exaust suggestions (need to know by Friday!)
- Worth keeping or just do swap?
- H22A
- im a n00b
- clicking noise while shifting..
- Skunk 2 Intake manifold user...
- Aftermarket PCV valve or factory OEM for my 94gsr?
- FLUIDYNE REVHARD FAL Fitment question. Thank you
- Need Carfax report...
- Anyone else have an annoying buzzing sound at 4300-4500 rpms?
- stock weight of a gsr
- thinking of getting a ls
- Went back to the track!
- what RPM to switch?
- anyone used greddy e-manage
- Will a Kenneth Meier...
- Time to replace the clutch...any pitfalls I should look out for?
- 1st -> 2nd grind...
- My Greddy SP crapped out on me again.
- 13's or lower all motor ls
- Grouchy First Gear
- clicking noise when turning
- Time for a new look for the FORMS
- Question about side trim on an integra
- how much gas does A/C and stop and go traffic use? damn!!!
- Are there any full 2.5" catbacks on the market?
- Do 2001 Type R shocks fit '97 GS-R?
- UPS just came with goodies.....gotta quick question first
- Skunk2 coilover kit VS Ground Control coilover kit
- racing hart's
- what do ya'll think of this simple contraption
- part #'s please?
- anyone need a vin number run.
- Taking Out A/C?????
- how to: dc2 oil filter change
- air condition belt
- Integra Forums
- 4dr rear bumper
- Help.....
- Hot Stall Problem 1990 Integra
- XS Chip for GSR? Anyone tried it before?
- which fuse is for ecu
- Chips, ECUs and the rev limiter
- Maint Req ligth
- H&R sport vs. Neuspeed sport springs
- has anyone modified their seat foam?
- Quick Headlight Question?
- How is the Gas milage w/ 403 CRowers?
- SAFC Install
- Help!! CEL Code...
- need a list of parts
- Valve adjustment
- Car cranks, but doesn't start..HELP!
- gsr aem fuel pressure regulator problems....
- Eibach Spring Rates
- Rattle in the back
- dust boots
- STRANGE radiator problem, help!!!
- IS 7700 rpm to high to rev a stock b20b bottom end ?
- got my gsr aligned, results inside..should I get a camber kit?
- 88 integra im lookin at
- Spoon Radiator Cap
- help! o2 sensor disconnect, dunno order to reconnect the wires.
- springs/shocks in the winter??
- Gas tank key locks
- airbag question
- Integra exhaust on Del Sol
- Engine's making noises.
- to anyone with crower 404s
- fender rub
- front bumper
- good shop in south orange county
- rpm problem..
- Will 4dr LS struts fit a 2 dr?
- Help
- GSR Dash Question
- Tanabe is starting to sound ricey
- sold my integra
- Help: Engine lossing power after dealer services
- typw one exhaust
- front strut tower brace
- Maint. Required
- Could somebody run this through carfax please?
- Eibach Sportline vs. H&R Race Springs
- Help!! Fuel Filter Washers?
- How are the Kumho 712 tires on wet roads?
- Worn Steering Column
- Just got my kyb agx shocks
- brakes on 98 gs-r
- BIG Dreams For Future GSR!!
- Any tear outs with BSQ kit?
- b17a help
- Which AEM CAI do I use w/skunk2 mani?
- 60,000 mile repairs ??????????????
- brake fluid leak @ master cylinder?
- Is this normal???
- Has anyone have or heard about the new Skunk 2 cat-back exhaust???
- 5th Gen Civic exhaust on 94 GSR??
- Apex-i N1 vs. Greddy Evo??
- Diagnosing a bent rod? Possible water damage.
- whose done modding their tegs
- Aftermarket Sway Bars vs. ITR rear sway
- pulley suggestions?
- Possible future GSR owner, what mods should I do...
- Whats a worthy replacement/alternative for the GSR?
- Who likes MINI's?
- Track question . tire pressure?
- porting intake manifold???
- will an axle-back exhaust from a 97 GSR fit an 01 LS??
- Front seat differences between integra coupe and sedan?
- backseat burden
- bought a clutch master cylinder today, but....
- 2000 SI rims on 98 GS-R???
- intake
- Pics of my Exhaust....
- Tranny question on Gen2 tegs
- CEL code 71 and 73?
- Carbon Buildup
- whats involoved in a regular tune up?
- Does anyone make SuperCharger for 2nd gens?
- just dropped my car engine light???????help please
- next mod
- sparg plug installation.
- Bad brakes after a hard run?
- 1994 GSR what type of mileage should I be looking at?
- Wanna buy JDM accessory for 96 4 door Integra....
- Automatic motor, manual trans question?
- P28
- SSB with White TE37's
- unknown noise under right fender???
- hydrolocked???
- Integra fuel injectors
- 1G head torque specs
- Airbag Steering wheel Q
- How Can I be Loud - Part 2
- 97 gsr brakes vs 98
- CTR strut bar on an LS
- Notice: ITR 01-0907 up For Sale
- Brake Ticking
- 1996 JDM B18B into 1990 Integra RS
- Upgraded Ignition Question
- exhaust rattle- is it the heatshields?
- Impression of Redline MTL
- New starter and car still wont start!
- ABS light is on...code 1-3 help!!
- how do I fix this?
- type R exhaust
- Hey has anybody tried the e-ram/electric supercharger?????????
- 90,000 miles maintenance requirements
- Apex V-AFC...cheapest place to buy?
- suspension help please
- how to clean leather with holes????
- anyone put on an oil pressure gauge?
- Interesting, need advice
- what springs have good launching spring rates?
- Transverse exhaust vs. Straight
- Alignment with ITR sway bar with BSQ kit...
- camber kit opinions
- Skunk2 header vs. Comptech header
- what kind of lights go in the back of the Guage cluster???
- Blinker Harness Question (HELP)
- Skunk2 Intake manifold and ITR/CTR cams with stock ECU? Thoughts needed.
- k&n
- ok to run gs-r w/ top of airbox lid off?????
- How Can I be LOUD???
- drag gen III e.t.'s
- Worth it to buy a 92 ls with 210k? - Part 2
- McGard Spline Drive Lugnuts????
- NEED Help asap :
- Estimate on shipping charges for teg seats??
- Tips for taking sound deadening out
- Gas tank will not fill up to full?
- ~~~the orange county help me reinstall my timing belt...??????i need help~~~
- lost key to wheel locks! HELP!
- Wrecked my Gs-r, anybody have theirs totaled
- Help! Drag 3 GSR running crappy ET's.
- URGENT - NEED HELP: Oil Drain Plug -> CCW to loosen?
- GSR Axle Differences?
- Good Shops In Jax, FL?
- i changed my springs...........
- Car shipping help
- HP gains, differences in US to JDM
- clicking noise....???
- Do i need 2 o2 sensors or 1?
- Help??
- tire pressure on stock michees for street drag
- Can I use OBD0 distributor with OBD1 ECU?
- SiR tranny vs LS tranny
- Code 9???
- B18A1 rebuild
- For the people with G2 Tegs
- coilovers vs springs
- Anyone using the suspension techniques front and rear sway bar. Do you like it?
- Suspension techniques front and rear sway bar
- Water leaking onto floorboard
- I am installing a CTR intake cam on my brother's 99 Gsr. Do I need to adjust valve lash or anything?
- Removing passenger seat.
- Whats a good deal?
- did i mess up sis car??
- 5W30 or 10W30 motor oil for low mile CA GS-R???
- I bought a new toy
- Regarding the FAQ list...
- b20/b16 Highend laagggggg
- exhaust rattle/buzz at certain rpms
- best headers for a gs-r
- why is my damn gsr lacking?
- What exactly does ecu chip do?
- What is the stock Cylinder Compression for a '92 teg?
- I love my new integra...
