View Full Version : Acura Integra
- Anyone have the documented weight of a GSR transmission?
- need help
- NA question
- B18C4??
- thermal exhaust what brand of header
- Resettign ECU
- trunk widths
- HELP!!! Crank Bolt!
- KYB owners need help
- what is an all around good suspension setup
- Can I use stock type r spark plug wires on my 96 Gsr??
- How to fix broken lugs ?
- alright got my skunk2 coilovers now i need shocks...help?????
- Solid shops in the Minneapolis/St. Paul area or anywhere in MN
- Skunk2's + Konis, oR Skunk2's and Tokicos!?
- Comptech I/H/E vs. DC Sports??
- tranny swap
- Best pistons for B18A?
- Tenzo R Rally seat ?
- License Plate
- DC Header and Exhaust
- Help. VA People. Need to pass emissions ASAP!
- integra junkyark????
- Question RE: high flow cat.
- black deposit on exhaust tip
- Problem w/ A/F guage.
- OBD2--->OBD1 how much $
- Dyno tommorow
- tokico springs???
- oil
- Will a ls stock fuel regulator fit a gsr?
- integra 2 door carpet
- Lost power due to ECU reset???
- Who fixed their a-pipe rattling at the muffler shop?
- time for motor mount inserts?....
- simple maintance check like
- autometer fuel pressure gauge(install help)
- O2 sensor wire on 98 GSR ecu? which one?
- GSR flywheel suggestions.
- PLEASE - New product, need to determine tooling costs AFC+VAFC+AFC-R
- ANTI-THEFT methods
- turbo LS setups
- How do you pass the firewall?
- am I running rich??
- Alignment q's after a mild drop.
- JDM ITR pistons CR ratio? and ACT HDSS clutch opinion
- brand new je pistons 9:1
- What Rattles(ed)/Squeaks on your car, and how did (do) you fix it?
- !@#$!@# Axle nut!
- shifter bushings?
- is there anything you can do to stop all the noises?
- What's the Integra JDM code...the EK, EG stuff????
- My dash is cracked!! HELP!
- skunk2 coilovers?.....how are they?
- JDM center console question?
- looking to buy an integra, i need info on the different trim levels...rs,ls,and gs.
- Blinker Blinking fast? WTF?
- how to remove cluster needles...did search.
- A/F gauge install help!!
- Burning Oil
- fs 97 gsr + turbo and springs
- exhaust temp??
- any suggestions as to why......
- What's so special about RS Integra Door Handles?
- Just put in Exhaust and Header
- improving power on b18b
- speed and style
- ok i searched but couldn't find the weight of a g2 integra
- gsr intake manifold...
- JE/SRP pistons
- my cars messed up
- Where to order cat?
- How long to wait?
- Short Shifter Suggestions...
- sway bar link??
- NJ peeps: anyone get into an accident recently? need a little help
- Power Enterprise VTEC/fuel tachometer
- ABS Control Box on a G4 GS-R?
- how to get a good start with automatic
- Door Panel Removal
- Gsr swirlies?
- G3 ABS issues.....
- My tranny problems RESOLVED!!!! GOOOOOAAAAAAAA
- OMFG!!!??!!?! 30,000mi tune up...?'s....
- "check engine" light on for no apparent reason!?
- need to pass emissions
- New CV Half shaft.. QUESTION! Help please.
- Anti-lock brake light problem
- comptech icebox
- b18b + T3
- kyb vs. koni yellow..
- How much will it cost 2 rebuild this setup...
- Phillips HID owners!!!
- Anyone in No. VA know of a shop that installs timing belts for a good price???
- Dunlop D60 A2 vs Dunlop SP 5000
- How much is need to be shaved off b16a connecting rod to fit ctr wrist pins??? Going to shop today?
- Electrial wires? Need yellow & red
- Does anyone have a GSR thats been tuned using a Apex V-AFC?
- What type of headlight globes are in DC5?
- GSR brakes --> LS ?
- MY Parts are here!!!
- Integra Question
- Safe to go Turbo with 94'GSR w/ 100K?
- 0.25 overbored GSR block, need further modification to fit ?
- Air Suspension
- Trouble Installing Turbo
- Engine Computer Harness cooked???
- need help with a throttle body i just bought...
- Crower 62404's for a ls
- Anyone want to buy Toda Spec B's ?
- crankshaft
- Dash removal
- B18b with GSR/ITR internals?
- Header Help
- tien type HA coilovers
- How much will it cost to rebuild my motor??
- kyb agx's or the tokico blues
- Steering wheel adjustment
- Where can I buy Volk Centercap?
- used rsr exhaust
- My corner bulbs keep blowing out...why????!
- Would there be any benefit to putting a B16 head on a B18C block?
- ctr cams and springs
- time for new timing belt
- tire size????
- Rex isn't doing quite that well... He needs help!
- Need help! What's wrong with it?!
- Static electricity
- throw out bearing and clutch feel
- ATTN: All Michigan HT memebers...
- Just got my 5zigen fireball.....ugh:(
- HOW: do i take off my front bumper 94-97 teggy??
- Closure of the Broken JUN 3 cam story - Large pics - dialups beware
- Pics of a USDM ITR Exhaust Catback?
- wheels?
- Vtec RS??
- headers
- I need TRANNY help.
- Harbor Freight tools any good?
- which strut/tie/sway bar will make the most difference in handling for auto x?
- Compression?
- OT: Suggestions on replacing MR2 engine.
- the tornado
- Benen Strong Bar Brace
- Breaking in a new engine??
- Props to GS-Rs!!
- OT: my ImportBuilder's block. what should i do? 82mm or 84mm bored?
- any1 interested in TYPER T.B.?
- how much do OEM GSR timing belts cost?
- What all do i do for 90,000 miles
- front liscense plate..
- should i get an LS or GSR?
- What's the going rate on an OEM rebuild of a GS-R motor?
- Need help installing the RSX billet shift knob on a GSR
- Which is better?
- What oil for my 205,000 mile Integ?
- Go for toda a or skunk2 stage 1?
- has anyone used the new zex cam for b series?
- spark plugs
- tokiko sport shocks????????good or bad
- What to spend my money on...94 gsr.
- is it possible to move the driver's seat past its limit??
- Which one of these B18B + JRSC would produce more power
- oem fog light switch
- new clutch n' flywheel vs. auto tegs...
- What to do with my LS??????NEED HELP!!!!
- Does a GSR fuel rail work on an LS?
- Can you put Skunk2 Coilovers on ITR Shocks?
- Once again This SORRY Ls integra needs help
- bought an R-spec vtec controller..what to set it at?
- should I have a V-AFC AND a Fuel pressure riser?
- Door Ajar light in dash.......a quick ?
- If I remove my spoiler (gsr), am I required to get a new brake light?
- eek! water leak (?)
- B20B....what the....
- need ASAP pic of white teg with gunmetal te37
- Toronto meet check in thread
- Cold Air Intake
- all you FI peeps out there
- question about tokico illumina?
- Removing the instrumental cluster apart
- anyone add an extra resonator to a custom exhaust?
- Man't Required Light (answer not found in search)
- torque wrench tirerack
- 8000 rpm with an LS..
- AEM pads squeak like hell, what to do?
- offset?
- When buying USED shocks and springs how can you tell they are okay?
- Good shop in OC, Maryland?
- Any San Diego muffler shops that do custom piping?
- spark plugs??????????
- what do you guys think about this suspension setup?
- Where can I find SS Cat-Back (HKS, Tanabe, Greddy, Dc sports) For the best price?
- How to Roll Fenders?
- Fastbrakes!
- How high is your oil pressure?
- I need some help ;[
- skunk 2 cams
- Just lowered G2
- how much should i sell these wheels for???
- 4dr and 2dr sides
- Short sHIfter question
- What would be more economical?
- what is the easiest way to......
- CAMSHAFT Comparisons!
- CC (exhaust question)
- Drag radials
- short shifters (what do you have?)
- This is for those who post the licence plate numbers!
- Honda Integra Si supercharged AWD - From the factory!
- b18c1 dyno results
- Who said nonvtec are slow?
- Body Kit Shop In Pennsylvania
- Short Shifter Vibration
- how much oil do you guys burn?
- Drivers side door locks....
- Just picked up these red ITR seats from a 2001 CW canadian ITR
- which tire/wheel combo is heavier? 15 or 16 inch
- another oil question...
- I have a cable tranny has "A3" on the lable, do you guys know what it is?
- B18c head & b17 bottom. Possible???
- What to look for when buying a used GSR?
- Bay Area Cali HT members... i need a favor
- akiebono brake pads??? ever hear of them??
- B18B Chip Installataion Question
- added 5hp according to butt dyno
- heater hose sizes?
- Steering Vibration
- Honda Tuner shop in LI, NY
- how to launch on an ls?
- Motor Mount insert question...
- Drag Gen III....?
- Attn: Comptech Rear Anti-Sway Bar Owners
- E-brake light stays on on cold mornings
- dents
- 45k service....and where in the bay area
- Opinions on Dunlop FM901's
- crankshaft
- How long will stock clutch last me?
- Skunk2 Manifold
- ITR Conversion
- car still bouncy with new suspension
- Apex'i N1 exhaust install
- obd2 to obd1
- are aftermarket fenders crap?
- Would you buy a GSR with 180,000 miles?
- short shifters
- 5.0 mustang injectors...
- GSR vtec pull
- vtec vs ivtec
