long vs. short intake?
Old Oct 23, 2002 | 10:44 PM
Sukebei Oni's Avatar
Default long vs. short intake?
why is it that i get a better low end with a long cold air intake and a better high end from have a short ram intake? how does the longer intake give the engine better low end? i have some idea but not sure why.
Old Oct 23, 2002 | 10:59 PM
popxpop22's Avatar
Default Re: long vs. short intake? (Sukebei Oni)
cold air intake raises the AIR induction to start out but take longer to suck it in but it is better for you on the HIGH END...plus you'll need better fuel injectors to balance it out.......short ram is constant sucking in air from the same place not neccessarily better on highends most likely better on LOW END
I believe you got it backwards
Old Oct 23, 2002 | 11:19 PM
but at high rpms don't you want as much air as possible and a shorter intake makes it easier for the moter to breath. if long is better for high end then why is the type R manifold like it is and not more like the gsr where is loops around?
Old Oct 24, 2002 | 06:04 AM
lsteggy's Avatar
Default Re: long vs. short intake? (popxpop22)
nope man your wrong
short ram=better highend
cai=more midrange and lower intake tempatures which could inturn make more hp all together.
o ya you dont need bigger injectors for intake your ecu will reset itself. that is what mass air flow sensors are for.
Old Oct 24, 2002 | 06:11 AM
tilt's Avatar
Short intakes are better for high end... better air flow at WOT.
Old Oct 24, 2002 | 09:43 AM
Default Re: long vs. short intake? (tilt)
but why do long cold air intake give better low end?
lilj95
Jul 12, 2009 04:07 PM
shutuprichard551
14
Oct 29, 2008 05:33 AM
ILS_09
Aug 14, 2008 03:32 PM
jdmludeaz
Jul 3, 2007 11:14 AM
MrIllegalX
66
Nov 24, 2003 08:21 PM
