View Full Version : Acura Integra
- Need help with idle problem!
- RSX seats in DC2 Integra
- Rod bolt size
- manual to auto door panels... no such luck searching...
- vacuum diagram for skunk2 IM install on 95 gsr?
- Gsr Cluster Problem
- 91 da str8 up trade
- wtb a b17a or b18c1 long block
- A QU about the Rotor & Brake
- Climent control light electrical problems.
- Problems with my LS, HELP`
- 94' LS Transmission
- Removed Cat heat shield... Still hearing rattling noise
- my speedo cable broke now a cel???
- Short ram intake without a splash guard?
- engine shutting down on interstate
- color comparasion
- After market mounts questions.
- SeaFoam does work for passing emissions test
- car wont start! help
- ? about bumpers and hood
- quick quick release question
- how do i change out door lock mechanisms (dc4)
- WHERE DID YOU GET YOUR INTEGRA STOLEN?
- got Painted blades?
- heads up on itr stuff
- phantom grip question
- Are the Integra Ignition Lock Assembly and Steering Column the same as Honda?
- stock intake?
- 96 LS OEM Timing Belt and Water Pump fit a 90 LS? Also headgasket questions
- itr intake manifold.........
- tranny problems on my 2000 Integra GSR.. 4th gear grinding and rough pedal
- >Help HT bro Need Help Hood latch cable too short?
- where can i get motor mounts inserts for 94 and up integra
- Nissan Maxima HID's in 90-93 JDM 1 piece headlights?
- team help....
- Skunk2 knob vs. stock DC2 knob----which is lighter?
- will eg side mirrors fit on a DA teg??
- Question for the people with C/F hatchs
- hate to ask but another iab question.....little confused!!!!!!!!!! searched
- Help!Need some opnions in selecting rims for my gsr!
- Gsr head rust question?
- We just are finishing up our shop integra for next year car shows
- gsr oil and water pump in a b18b
- please transfer this message to the mods for me
- SPC camber kit
- Guage cluster light and Running light doesn't work when headlights are on.
- Nashville Area PEOPLE with a Timing GUN!
- !!!!HELP!!!!!
- GSR OIL PRESSURE
- ..... 96 LS altenator..... same thing as 94 gsr altenator or different PLUG?
- CAR STOLEN-Kennesaw GA
- b16 or gsr tranny ?
- gs-r oil pan on ls
- putting ground strap on, question
- How to repaint my 95 integra 4dr taillights to all red
- GSR block with b16 head
- how to fully built motor
- The Wierdest thing happened...AC fan spining by itself!!!!
- Own a 92 DA9, just purchased a wrecked 92 H23 Prelude, have swap questions....
- Deer Hunting?
- ITR console issue.
- Hi, I'm new, with 96 RS
- tune up
- dual din cover *searched*
- HELP B17 Compression???
- DA9- More than the lug nut came off.... Pics.
- Fourth leaking raditors..Help!
- Just ordered a new clutch wut u guys think?
- Car is acting up, I need help PLEASE. will bog down with more throttle... Civic LS swap
- ITR rear sway bar on a da??
- HELP- timing belt
- Help me out fellas...
- Has anyone repainted there Integra to Championship white
- Reffing an engine swap
- Wet floorboard?!
- Burning my clutch already?
- Koni Leak?
- autostart
- quick question.......
- strange smell at high rev?
- Is this an auto or manual ECU
- Question about a gsr da?
- HP Racing header any good?
- oil pan gasket leak ?
- Code 17 --> VSS
- PIC Request
- compression
- review: t1r axle back and dc jdm header
- obd1 injector help please!!!!!!!!!!!
- Difference between GS-R and Type R trannys?
- GSR halfshaft
- ...And she's back off the streets :sad: :(
- Topping off clutch master cylinder
- CTR Pistons/Rings?
- any one use a 1/2 rad?
- crower cam gears?
- What should I do? Just found out my car I just bought has an existing lien?
- Weird vtec problems...
- obd0 to obd1 conversion wiring help
- Help. deciding Clutches for JDM B18C
- Can anyone decipher auto zone engine codes? Car throwing 6 codes
- please help...last piece to finish the BITCHIN CAMARO
- need help passing emissions
- need engine torque specs!
- Wanting to mod my GSR
- PROBLEM! HELP PLZ!
- are 90-91 integra rear bumpers the...
- Car wont start after theft!!! Help an integra out!
- Quick tranny question
- BRAKE light problem
- Integra newbie - power lock related...
- GSR VANDALIZED, MISSING PARTS, WIRES CUT, PLEASE HELP!!!
- any good body shops in san jose/bay area?
- Anyone heard of AEBS Professional Products "Typhoon" “Power+Plus” Intake Manifold?
- Taillight problem...please help.
- 90-93 Integra owners w/auto seatbelts.. how did you put in your aftermarket seats???
- How to fix CEL code#9 cylinder sensor??
- WTB: 98 integra 2 door rear stock bumper asap!
- recomended springs
- GS-R Transmission
- b20z help
- Camber Kit Help!
- Car Overheating HELP!!!!!!!!!
- WILL I GET MORE $$$
- how to recognize bad valve seals
- itr lip
- 97 teg ls automatic up for trade...
- LS/TURBO RELIABILITY AND GAS MILEAGE?
- question about side mirrors
- $225 a ripp off to paint bumper and ITR lip?
- Link to type r rear seats and jdm front end VIS CF hood
- oem integra color?
- need help from auto to manual
- anyone have pics or video of a greddy SP on a gsr?!?!
- Power Steering Removal for DA's *please read*
- Dropzone suspension Yeh or Neh??
- reliability: ls vs. lsvtec
- Car stalls as soon as I give it gas
- 01 gsr v. 01 is300
- porting my head
- how much Laminex?
- my head blew
- Icebox Hydrolocked? (searched)
- Finding a manual integra after auto teg
- 3 inch cat converter
- head gasket
- i need a door
- The noise at 3400
- NGK Spark Plugs
- heat?
- How can you tell stock GSR cams from AEM ones
- exactly how safe are aftermarket seats?
- Strange clicking noise
- 2000 Integra ECU for sale **Obd2**
- Sup INtegra "drivers" new to HT , have an LS B-18, soon to be LSVTEC
- Losing power b/c I need a valve adj. ?
- Someone help please!!! my da is smoking bad!!!
- Quick question about hoods..
- good shock/strut match for eibach pro kit?
- Foglight and switch harness Civic si to Teg?
- Quick Question
- itr lip/cwest ss
- how do you remove the integras front bumper?
- GSR for LS hatch.
- need help with gs-r swap.
- Slight ticking coming from valves on 97 GSR.....what could it be???
- Ebay muffler w/ silencer + w/ 2 1/4 piping and resonator done by shop.. loud? or quiet?
- Car sometimes doesnt start what could it be?
- car makes clink noice when I turn the wheel all the way.. normal?
- Sunroof motor and switch, which ones work.
- What is honing?
- 94-95 gsr
- exhaust question, pictures
- Crv/vtec in Teggy, need some info please.
- cel 9 cylinder sensor? how to bypass the cel? is msd causing the cel?
- DC2 GSR Motor Mount Question.
- Quick question
- abs code 74 R abs solenoid? i have no idea what or where it is
- what does the egr valve do?
- reasons to get a code 43 "fuel supply system" ???
- Thieves suck
- where to jack?
- I <3 MY HONDUH! (New proud owner!)
- 94-01 integra LS vs GS-R: a debate for the consumer
- do you view you dc2 as a coupe or hatch?
- noob question.. i think
- fuel pump installation
- Tsudo cat-back, need some answers
- JDM or USDM?
- question of height.
- yellow high beams on the integra
- Ignition problem, trouble shooters welcomed!
- Does anyone have a cabron fiber hood for a DA Integra for sale
- need some help with oil pan
- What are the Limited Edition Integra rims
- Why am I getting code 92 Evaporative Emission Control System insufficient purge flow
- 93 teg hatch removal
- ECU question
- how to recognize a blown head gasket
- HELP ME MY SRS LIGHT IS COMING ON!!!
- Who makes the quietest exhaust system?
- Maintenance Free Battery - does it carry any warranty?
- Couple of quick questions...
- where i can buy a DC4 radiator core support?
- Strut torque specs
- Are gsr seats and type R similar different??
- am i suppose to drill a hole in the pcv valve?
- Lug Nuts Keep Gettin Loose
- need help wit rare dc part
- Picked up a Honda Fuel filter, am I missing something?
- HELP! Integra won't start!
- my tranny is shot...
- timing belt?
- Oil filter blk adapter
- code 4
- I need a crankshaft for my gsr block
- obd1 pr3 ecu pinouts??
- SOMEBODY HELP!!!!!!!!!!
- I was sent wrong coilovers. Will these fit?
- OBDI LS ECU CHIPPED
- black and white painted teg
- Need To Know If These Are A Good Website To Buy Off Of!!!
- How exactly do you bleed the clutch?
- Clutch related problem.
- new to thu h-tec
- is it worth it???
- car idles then dies randomly
- 94-97 ABS modulator coversion to 98-01 ABS modulator has anyone done this before?
- anyone ever use honda insight seats?
- p30 or p72 Ecu to run Ls vtec motor?
- Sittin' low...er
- G3 White Gauge cluster bulbs
- 3inch+ drop support Camber Kit
- were can i find s2000 hid
- coolant resovoir is boiling and temp gauge rise
- ne1 need skunk2 manifold for gsr? comes with chip p28 also
- hondata or vtec controller ??
- dot 3 or 4
- D-Series turbo kit
- DC rear wiper delete plug rubber
- pissing me off!!!!
- leaky hatchback
- Championship white
- b18b question
- Black interior
- ecu problems
- Eractic idle
- question about oil pressure reading
