View Full Version : Acura Integra
- JDM ITR SRS steering wheel install for 94-95???
- So this is what happens when you spray a 200 shot on a stock gsr b18c1 motor with pics!!!!
- 90 teg 5spd conv.
- my tranny?
- Question about brakes...
- quick question about turbo setup
- I lost a lug???!!?!
- Coilovers
- smoke coming from radiator?????
- 1993 Integra Cable Tranny:: OBX LSD vs PHantom Grip LSD??
- Rebuilding B18C1 (GSR)
- Antenna has no power because a loose cable??
- messed up idle?
- [B] A/C PROBLEM? [/B]
- getting rid of gsr
- LSV BUILD INPUTS
- piston rings difference
- a/c removal problem
- Please help!!
- ABS hubs and non ABS hub compatablity
- gsr cams for gsr headers
- help with jdm conversion on a integra!!!!!!!
- STOLEN in CHICAGO: 99 INTEGRA LS Silver
- Are GSR and ITR axles the same?
- a/c removal
- HELP!!!!!!! NEED JG 301 value adjustment
- Integra Related
- thermostat issue?
- B18B to a B18C
- I want to ajust my valve lifters. What is the torque on each one?
- does anyone know much about this company and their header?
- swishing noise
- Hytech Replica Header
- cylinder misfire
- GSR Overheating
- mines ecu
- tradin my car in but........
- what year are these seats from?
- ECU Question! Please Help
- What year Integras will a 98 Integra intake fit?
- Hybrid wire harness question
- check engine light
- stock axleback
- turn signal arm dead? emergency light switch maybe?
- How do I remove the inner rod from the rack & pinion (94 integra ls)?
- *** STOLEN *** 93 Red Integra GSR in front of Nikko SF hotel, probably in Richmond
- :: Why is my suspension clicking/rattling?
- hyper blinker i must apologize for previous information please read
- cel question
- burning oil bit no smoke
- Idle problem after rebuild B18C1
- engine bay wiring harness fried........now what?
- 95 LS keeps cutting off.
- 1998 integra 4dr 5spd
- b20 vtec ???"s
- grounding points
- Camber kit for a 90 teg
- 1993 Acura Integra Ls Turbo Pics ::almost done::
- 93 Integra Cable Tranny... Quaife vs Phantom Grip vs OBX???
- Will the stock sleeves hold up???
- help me make my car fast (best engine for an integra)
- Knocking sound in suspension only in cold weather
- what to do about the pcv???
- LS/Vtec
- Integra Exhaust. Full system or universal muffler???
- having big clutch problem
- hasport v6 mounts available
- Dizzy, CKP porblem, OBD1 LS .. Searched and confused as F***
- Valve adjustment?
- Carbing Products
- Black stuff in exhaust tip.. Am I running rich? B18C1 with ITR Pistons..
- :: Manual Steering Rack VS Padawan's Removal Kit??
- head gasket problem. need help ASAP
- Stripped Bolt, Need some Advice
- I need Help!!!!!!!!!!!!!!!! Header?
- Transmission problem help
- Third brake light anyone?
- $8.50 a quart for MTF?
- gm 3 bar map sensor
- B16 head VS GSR head for and 2000 LS
- axle question
- trial users question?
- b18 gsr question? Is the bolt pattern the same on a gsr as a ls header?
- Prelude suspension mount on to integra?
- 99 integra with innovative mounts PROBLEM NEED HELP ASAP
- B series fan switch
- its that time.......header and test pipe
- koni life??
- ERL gsr block
- bent valves
- Quick A/C condenser question! =o
- block guard
- 93 Integra: Buzzing noise coming from behind Driver's Side Headlight & Low idle issue
- not really an integra question but i drive an integra so...
- dc2 jdm body conversion
- Are All B-series OiL Pan Gasket the same? Can i use 99-00 si gasket on gsr?
- fuel and brake lines question
- Help with obd1 b16 swap in obd2 98" integra
- OEM or Carbonfiber OEM JDM Hood?
- Pulling transmission??
- Seized up
- Ran new battery ground cable. Would using 4 gauge cable cause problems?
- im out of idea on my da!(need HELP)
- cant figure out where its leaking thru
- Maintanence Required????
- When to do valve adjustment??
- problem with my 5th gear????
- DA9 WITH B16A WITH GSR HEAD
- Is this from an Integra or a Civic Si?
- After Market Cams
- '94 LS flywheel alignment
- 94 integra ls dc sports header question
- Red S2000 seats in my DC
- 90 integra gs shifts really hard need help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Up Grades
- Our New Toy/Project =P
- Help, process of painting valve cover!!! Quick question...ASAP
- Wha'ts up Im a noob here
- My Throttle Body gaket does not fit pictures inside anyone know why
- Hello HT =]
- Options for warped block
- Starter issues
- timing belt cover
- pt3 ecu
- I NEED A RESPONSE ASAP PLEASE
- 2000 GS-R, shuts down randomly, as if the key is switched to the off position...
- DA -i hate koni yellows w/ eibach pro-kit springs
- What Octane do i use???? Please Help
- no one helped in the audio section, my sub isn't working need help
- NEED ADVICE FAST
- 95 GSR, newly rebuilt engine not running right?!?!
- ls/vtec head gasket
- Non-VTEC cam seals work on VTEC camshafts?
- ls-vtec
- Towing hitch for motorcycle trailer
- gsr not passing smog help?
- Integra GSR Head Dowels
- 90 integra headlight electrical problem need HELP!!!!!
- failed emissions... high HC
- Spoon Sports
- need help with my dd
- SAFC FS
- jhpusa?
- Help Exhaust problem
- Where can i get this from? And what is it called?
- ***STOLEN DB7*** 98 integra 4dr STOLEN BAYAREA
- worth it?
- Are all B-series crank keys the same ?
- Integra auto to manual conversion ?'s
- B20 dc2 specs??
- Headrests?
- Help in finding valves
- b18a1 pic
- Supercharging the real mans FI
- ***STOLEN*** 93 Red GS-R 9/27 around 12-12:30am in front of the Hotel-Nikko SF
- STOLEN 1995 JDM GSR SEDAN DFW AREA (SE ARLINGTON)
- tb and im brand
- Legend caliper swap problem. Help. Please
- head gasket ?? searched
- GSR rebuild
- hydro to cable conversion
- show your ricey tegs.[post your ricers]
- GSR STOLEN!!! SACRAMENTO
- How much weight can be takin out of a DA?
- Exhaust
- head lamp
- exhaust on 97 gsr
- my integra
- EM Racing Bars ?
- what type of axle back
- integra failed smog ..help me pass retest...!!!
- 98' GS-R Emissions fail?
- Integra Shell
- whos going to put a v6 in their tegs?
- probles with autometer tach reading after installing NEED HELP!
- ABS light flashes on and of during driving....whats could be wrong?
- Gauge Preferences?
- da problems
- torque specs
- 4x114 lug conversion on a DA chasis
- strup header review
- Problem starting...
- Transmission Parts Diagram
- DC moonroof on DA??
- Part # for Cam Seal/Pug
- OPINIONS MUCH NEEDED!
- Koyo radiator in a DD
- Need Transmission Bolts and Engine Mount bolts
- ls block
- Oil Leak coming from in between Block and Transmission. Need some more opinions.
- dead ecu.
- Tsudo exhaust on da9?
- Best way to clear up dirty head lights?
- 90 Integra GS Help
- itr rear sway without asr brace?
- Vacuum hoses!!!
- Just got rear ended? Have questions?
- Where can i order gsr seats? (no craigslist)
- can someone tell me what this plug is?
- power window problems in DA's?
- DC seats in a DA?
- some problems
- ac button
- dc2 rear roof wing
- Will CTR or ITR cams pass smog in a GSR
- CEL jumper for 95 gsr
- need help with 2000 gsr oem exhaust!
- Weird Noise
- EBAY bumper, yay? nay?
- Blox Extended Studs
- Integra speedometer not accurate
- Suspension Help!!!
- wierd vibration in the front end... any ideas?
- can a full 96-97 jdm type-r engine be reffed into a 98 gsr?
- odd starting problem...
- removing sideskirts?
- fan questions
- OldSkoolDa91's 91 DA build thread
- which size cat?
- JDM Front Foglight Capsule Broke!
- b18b for sale cheap
- ls-v-tec
- engine that havent started for over a year
- oem optional lip kit
- pic request of smoked dc tail lights
- LS/Vtec Teggy
- Ecu questions
- I need some help, dont know what cam setup to run in me dc?? help!
- skunk knob help!!!
- What Kind of rims are these?
- Possible engine knock? (Engine noise)
- Fog Lights, Headunit, and Dash light NOT WOrking!?
- How to tell a USDM tranny from a JDM transmission??
- ABS light
- power steering???
- integra manual swap
- Seafoamed the GSR yest
- pic request. mugen m7s on integras
- help please!!!! car wont start
- What Are these Codes?
- 2000 Integra LS Transmission Problem
- two air filters in a stock DA???
- Which clutch to buy? stage 1,2,3
- is this the right b-pipe?
- fog light issue, searched but no help.
- stalling problem
- Function F1's or Blox Full Coils?!
- VALVE SEALS????
- electrically Going into Park problem when cold!!!
- d16Y5 install
