View Full Version : Acura Integra
- Need help finding import 1992 integra zx rear wheelhubs
- Shifter loose in every gear
- Oil Pressure Sending UNit Setup Brass Fittings
- New Transmission No Start
- 1999 Integra clutch pedal sinks to the floor
- What size or part # 90 elbow for PCV
- Integra LS 2001 Coolant Leak Problem
- replacing rubber bushings
- 99 Integra running too rich and backfiring
- 91 teg abs delete questions
- Can't shift into gear!!
- 1997 Acura Integra
- ‘94 LS looking to pick up
- 91 teg front hub can’t find
- Civic Wheels same Size as Integra ??
- Crank no start issue
- Rear Hatch Opener Troubleshooting Sharing (relay wiring)
- code P0303
- trouble shooting a no start condition
- 97 jdm type-r
- Integra Front Left Knuckle
- new to me 1999 Integra SE
- Which brand Axle for a GS-R?
- Need help
- Bait and swith parts at RockAuto?
- 1992 Integra LS Wiring
- Grease?
- Questions about rod bearing sizing B18b1 Rebuild
- GSR swap fluctuating/high idle
- Oil Pressure Gauge Recommendations
- Speed sensor bolt size
- 91 da9 b18b1
- GSR Trans Won’t Go Into Reverse
- 1990 integra weather stripping
- Ball joint wont stop spinning
- Oil Idiot Light stays on After Startup (Few secs)
- Cruise Control Connector Wires- Where is Connector and Color Wires that Hook Up??
- B20z swap into o1 teggy
- intgera ls 1998
- 2.5” High Flow Cat for 94 Integra
- Compression test reading 0-0-9-89?
- Fix j front
- Different jdm bumpers
- Factory B20 integra
- Hi everyone
- intermittent speedometer issues
- 1990 Integra very low idle
- b18c1 oil pump re-assembly
- Dyno’d my GSR
- windshield trim
- K24-Integra swap brakes/hub
- 91 teg Seems like it’s hitting fuel cut
- Fair price for my 99 GSR w/ b16a JDM swap
- Steering and Suspension components
- A/C wiring
- AEM methanol injection help.
- 1990 JDM DA7 Integra Power Steering Leak
- Another ABS delete questioning
- 1998 Integra ls with 2000 gsr harness
- 4th to 5th goes into third
- ITR OEM intake tube
- 93 Integra random loss of rpms and CEL without codes
- 94 integra odometer gears?
- Acura Integra price?
- Ticking noise
- B18a1 with b18c1 head
- 1993 acura integra not going into any gear while on
- 1995 b18b1 into 1996 rs integra motor swap
- Auto to Manual Swap Help
- Frankin trans bseries
- h22 dc2 needs help lean chugging idle bog acceleration
- Intermittent starting issue
- 1997 integra shell b18a1 swap
- How much should I expect to pay for a GSR? Is 6K good?
- Integra Turbo build
- DA9 Integra Manual Swap Axles
- B18C1 Vaccum lines, Evap removal?
- 98 JDM DC2 - KRAFTWERKS Rotrex c38-92 supercharger
- Anyone know how to disconnect the harnes from the hatch??
- Random squeaking in b20 (non v-tec)
- Can my b18b1 Handle turbo
- Oem Jdm fender clips to usdm oem fenders?
- '96 Integra LS temp issues
- Cruise Control Pigtail to Switch
- Is this fixable?
- eBay oil pan
- Weird No start.
- Integra shell
- Type r p73 ecu with gsr motor
- Chris' 1997 Acura Integra Build
- Seat Cover Recommendations
- Are all b18c gsr the same ?
- Glowshift vs. Autometer
- 2001 Acura Integra LS alarm
- Acura Integra GSR Swap VTEC
- Help!! Please help having misfire probems
- Turn signals and high beams turning off rpm and speed at cluster
- B20v swap in integra dc4
- Strange issues after replacing ICM
- Stolen 98 Integra LS
- Best OEM center armrest console switch options?
- What caused this? Burnt up oil or gas on pistons and valves
- Clutch Master Cylinder Suggestions
- Made terrible mistake
- DA Integra Electric VSS
- 95 B18 to vtec swap/ parts and cosmetics
- B20b with skunk2 intake manifold auto throttle cable trouble
- 91 Acura Integra LS won't start
- GSR - EVAP Purge Solenoid
- smogs check
- obd 0 to obd 1 conversion help
- I have a 1993 Acura integra LS automatic what Manual transmission will fit
- Help identifying this part
- Would 165/65/15 tires be a good idea?
- B20 vtec ecu??
- Steering Rack alternatives for a 1996 honda integra
- Shell good or bad
- GSR Spark Plug Gap - Conflicting Info?
- 96 integra Cooling fan only turns on when I turn on ac
- Turbo Adapter Fitting
- Voltage issue
- IN NEED OF ADVICE!!
- Clutch help
- Crank bearing confusion
- Help! Crankshaft pulley torque rotated the pulley clockwise
- need help with pilot bearing and clutch setup for my b16a build
- '97 integra, first and second grind and pop out of gear
- $300 Integra that could run
- Difference In Mounting ITR Red A Emblem vs Red TL Emblem?
- Need help with block and head fitting
- B18c no start after head gasket
- Need help locating a coolant leak.
- B18B engine - no spark!
- Need help deciding what would be better financially wise
- Rear Lock Cylinder Retaining clip like Civics?
- Map Sensor connector not there, please help
- PS Return Hose Issue??
- Steering knuckle?
- Valve adjustment without special tool or angled feeler gauges?
- 92 inegra need help
- Turbo Half Size Radiator Overheat
- Crank Bearings Worn ??
- How to know if service check connector has been jumped succesfully on 1990 integra?
- Where To Source RHD Front Clips?
- 89 Integra Check Engine Light
- Da9 transmission torque bracket help
- PLEASE HELP 2001 ACURA INTEGRA GSR SEDAN
- Need some guidance in building my gsr for some better power
- Integra Mods
- TPS Will not Adjust to Specified Value
- 95 integra auto trans issues/ auto trans interchangeability.
- PVC Canister Troque Spec
- 1993 DA JDM integra strut identification
- 97 integra gsr ecu
- Spark plug wire OEM part number substitute for OBD0 DA9
- DA Billet Aluminum Quick Release Hood Hinges Interest
- Maybe a bad fuel pump?? Need some advice!
- Jdm bumper support work around
- Air box differences
- Are all the jdm integra front end parts inter changeable
- Acura Integra Lug Nut Issue
- Jdm radiator support
- Ordered LS Injectors, received ITR. Will it work?
- Acura Integra Cv Axle not going in all the way!
- LHD and RHD brake boosters? HELP! (DA Integra)
- Axle Trying Pop Out of Intermediate Shaft
- Please help! P0170 p0171
- Need help 94 Acura integra ls acg ig fuse blowing battery not showing on dash
- Selling my "total loss" dc2
- Acura integra differences GSR v. RS, GS, LS
- Is this 1990 DA9 a good idea to buy, or too risky?
- 93 Integra DB1 Gas Leak
- Manual swap help..94 integra
- Complete mess of a car! ( Mount issues, and electrical)
- Does indivia test pipe fit a 1993 Acura integra gs
- Fuel Pump Takes 5 Minutes To Prime First Time
- Boost leak / boost cut?
- 91 integra b20vtec horrible gas mileage per gallon
- 94 integra left door wire harness
- GSR partial throttle stumble/buck after restart
- So I just picked up a turbo integra 98 GS…. What does it have???
- 96 Integra running rough and bogging
- SoCal (Orange County) paint shops
- b17a1 to b16a2
- Need Help With Starter
- COMPRESSION
- HELP HORN
- What color is this smoke?
- About db8 sedan carbon roof
- Would a 1999 jdm crv b20 fwd tranny bolt up to a 1994 b18 engine
- Rattle / Clank Front end noise
- Cold start issue
- DOT B18C5 crate swap
- Looking for tips for obtaining and replacing the ECU / ECM on a 1992 Acura Integra RS
- K-Swap, B-Series Swap or Rebuild
- Won't Restart
- 1995 GSR smog fail 2 points
- ELD failure problem (fuse box confusion)
- 1990 Acura Integra LS (2nd gen)
- BALL JOINTS
- Integra Distrubtor Gear
- No fuel pressure
- Trying to go to premium gas
- Engine won't start after Distributor Rebuild
- I need help building my b18b1
- New head gasket has oil leak
- B18 tps isssues
- quarter panel window trim
- OIL PRESSURE SENSOR
- CV Axles and Transmission Compatibility
- Mysterious Knocking (01 4dr GS-R)
- Cross Compatibility Between Sedan And Coupe
- Just another K20 swapped GSR in Bay Area
- B20 Fuel rail on B18 manifold for B20 swap DC2
- 1991 Integra Misaligned Cam Gears
- Rear struts something looks wrong
- D16 engine swap to a 10 year old Acura integra b18b1engine
- Will the confetti's off another car bolt right into my 01 gs-r?
- Help, my teg won’t crank!
- AIRBAG FOR 93VTIR?
- Boosting my 1993 GSR b17a1
- Engine swapped, No spark now
- Ryane motorsports rotors
- Brake Pads
- Thoughts on this listing?
- 96-01 Prelude Seats in an 89-93 Acura Integra? Honda B-Series AC Compressor?
- COMPRESSION
- My 1989 Integra LS mt (pics) + clutch question
- Integra rubber hose replacement
- Repairing a Stolen Integra (1994 LS)
- About to take my 96 integra on a 900 mile trip, anything I should do before I go?
- Hatch glass swap...
- Fuel sender not sending fuel
- Built b20b swap EFI / ECU fuse keeps blowing
- Good Integra Shops in Bay Area?
- Manually moved crank pulley, now car won’t start
- 91 Integra b pipe?
- Does this sound okay?
- Need to confirm if B18C TDC Cams correctly aligned: Intake Cam looks diff from Exhaus
- Compression!?
- Trans issues with h22a2
- 95 integra inner and outer tie rod ends on a 91 integra?
- 00 integra b16
- B18C2 into GSI.
- 2000 integra LS wideband reading.
- 94 integra rpm gauge stop working
