How do you get a perfect adjustment with hids on a integra......
i was wondering if you can adjust aftermarket hids on a integra or actually a jdm headligt so that it can be perfect.....not too high, not too low.....
is it possible that you can have that straight line that bmw/audis have on thier stock hids.....
and does the hid blubs make a difference? the b2r or b2p or something like that.....dont kno much about that.....
I know on the US front end there are 2 places for a Phillips screwdriver to fit in and adjust horizontal and vertical beam pattern. I'm not sure about the JDM headlight housing's but maybe? It's the same company and they're both projectors but I don't know, just guessing.
When you say the bulbs I think you mean D2R or D2S. More than likely you're using D2S bulbs because you have projector beams. They should be retrofitted on to a base to work with your 9006 bulb sockets now. If that's the case then it's not the bulbs you're using now. (Unless you have the HID housing JDM headlights which don't utilize 9006.)
Dont know about the JDM one piece, but on my Hid's for my car i just adjust them like you do on normal teg's.
DuNkiN
Aug 27, 2002 07:44 PM
