View Full Version : Acura Integra
- Starting problem PLEASE help!!
- Replacing Speedometer Cable DA Integra
- to gsr owners, has anyone connected your iabs w/a different vacuum solenoid?
- no spark?? coil and igniter replaced
- Bar/Ref/smog help
- Need help rebuilding gsr transmission
- No Spark Please help
- Knock Sensor OBD1 vs. OBD2 Question
- How to check motor?
- FEL-PRO HEADGASKET
- Built LSV, Vtec sputtering?
- GSR distributor help!!!
- question about power conversion
- Engine Misfiring?
- timing mark question
- Used the blinking light on the ECU to actually find a problem.
- Looking for a good front big brake kit?
- DDM Tuning HID KIT help???
- new to the fourm
- My 1st Build
- My Honda Story: Rags to "Riches"
- idle rpms
- just a quickie
- replace downpipe only for turbo manifold not na!?
- Where are you buying your OEM Acura parts?
- Brand new battery started car once, now nothing happens
- would a 94-97 carbon fiber lip fit a jdm type r front end?
- found parasitic draw but don't know which fuse it is (90 GS)
- No Spark issue. Lots of trouble shooting still nothing.
- starting issues
- almost losing control at high speeds..
- Op temperature issue!
- transmission help. gsr
- Battery dies the moment I use cigarette lighter, need some help.
- Bad steering rack symptoms?
- What is the best camshaft for my GSR?
- Clicking sound when turning with new axle
- GSR water outlet question
- Acura Integra stolen auburn/federal way, wa
- How to get checks axles?
- question, please help me
- Check engine light resets once car is off
- acura 92, what fits??
- Modding options
- Help: Lagg before car begins to crank.
- Now that its COLD weather = im getting slight grinding shifting into 3rd gear????!!
- Clutch release bearing?? not the same
- 1995 Integra Ls manual 1.8L won't start!!!!
- Correct radiator cap for da6 XSi
- Bought turbo Integra: Remove turbo and go NA or keep turbo system in?
- What causes the wheel to wobble?
- Some input on obd 0 and obd 1
- Question about gsr Block
- OBD1 CEL for no Catalytic Converter
- Intermittent no crank no start
- New Member
- 91 integra transmission slipping
- DA9 RTA BUSHING PART #?
- Fuse Keeps Burning Out Help!
- Quick wheel question/conformation.
- skunk2 pro2 cams...overkill?!?!
- Body flexing
- New to honda-tech! :D
- Clutch help please
- LF Torque Mount Rear Bolt Broken on 2000 GSR
- new member in vegas ^_^
- my 98 automatic integra got stolen and recovered but now SPEEDOMETER doesn't work!?
- My 91 DA gsr
- Tie Rod/alignment question
- which SS brake line to use?
- crankshaft pulley problem.
- Gsr "no spark"
- reinstalled distributor now no start
- My 1992 DA9
- oil pressure gauge not reading anything
- B18 Under-Hood Wiring Cheatsheet
- Problems after changing ECU
- Name this part!!! please
- dizzy problems
- Engine won't start
- o2 sensor wiring help 91 integra
- high idle at cold start
- car won't start, radio turns off when i turn on the headlights
- Semi-new to Honda-Tech!
- 96 teggy turns off during downshift
- Need clearification on a chassis code.
- No Tstat on crome?
- integra sir-g idle problem
- 2000 Integra LS - Misfire cyl 2 CEL.
- Mystery coolant leak: head gasket?
- Sqeauking noise coming from rear driver side suspension
- Hate electric problems, no spark
- Low stumbling idol and more - 1990 Integra GS
- Who's Strut Spring Compressor?
- Clutch adjustment (Hyd)
- Starter bad??
- B20 fluctuating idle + misfire
- Can't read this code! OBD1 Help!
- NodakDCteg's Integra Build
- Ukdm tailights for integra sedan??
- 1991 Integra No Start
- Need Advise.. B16/CTR Engine "tap""ting"
- 94 GSR Running without primary o2 sensor is it bad ?
- 98-01 integra paint jobs
- energy suspension bushings
- s2000 hid retrofit on integra
- integra needs a new swap LS vtec or type r ?
- V-TEC when cold
- 98 integra leaking water when it rains!
- New to this.. sort of
- 95 integra idling
- rearwheeldriveDA9
- 97-97 Integra ABS Light Help !!!
- Temp gauge goes to pegged?
- DC Igntion Switch
- B18c1 Ignition Question
- 1974 Mini with B18B, wiring questions.
- 94 integra 2 door wont lock from the inside.
- No start
- BRAKE light on cluster: on 91 integra
- Need help with limp mode please!!!!
- Td-24 U distributor question
- no fs thread?
- Messed up threads in the block coolant drain
- 5 lug question?
- Clutch bracket question - DA
- Need oil cooler bolt size ????
- Integra Window Adjustment
- b18b timing belt and cam issues
- Help: Rear hub assembly issue
- God awful noise coming from passenger side (sound clip)
- gsr ticking sound driving me crazy
- b18b1 reving problem
- electrical issue
- Transmission problem?
- 96 integra evap/charcoal canister question
- FMU+FP gauge Help plz
- B18B1 Engine questions, for my 79 civic coupe
- Speed sensor problem
- installing SS brake lines on DA
- CV axles and clutch for '96 LS/VTec...
- no vtec
- Civic Catalytic Converter on DC
- 10a fr turn light fuse blowing
- mack_didthats's clover green ls (pic heavy!!!)
- Slight knock, need advice on rebuilding engine
- 93 integra
- HELP are All 98-2001 power steering pumps the same for obd2?
- re-pin drivers side PW and lock harness ???
- 94 GSR bogging and stalling
- Problem with stock idle, need guidance
- What tube is this? (I am in the middle of a head gasket replacement)
- tranny problem
- Question About Wishbone
- Beaks Reinforcement Kit?
- B series or 8 psi of turbo??
- 96 LS SUSPENSION
- B18b Coolant Problems
- gauge cluster lights instantly went out.
- Just got my 2nd Integra DA, what motor?
- need help with gsr engine noise????!!!
- Integra TCM/TCU. Which models have them?
- Integra Gsr Drank Water need advice
- car wont start when cold?
- 1989 honda integra zc idle issue
- Need some guidance
- Is it possible...
- rebuild?
- IACV not working?
- LS Running Rough(low compression/no spark?)
- A/c = vacuum leak?
- Integra DA gas smell sometimes
- ls vs gsr injectors
- Acura Integra 97 Ls Head gasket replaced issue!
- 2000 integra gs power shuts off while driving help!!
- harness diagram
- 2000 Integra LS manual *power issue*
- 99 gs hard time turning over and weird idle during warm up.
- Question: 97 Integra GSR Brake booster
- 94 LS Integra / New Tranny, New Clutch / No 4th or 5th
- Minor front end damage repair - crack in the bumper
- Just bought my first acura... cant decide what to do!
- Need Help Clearing CEL (b20 swap)
- Is my engine done?
- 90 integra hitting fuel cut?
- 1996 ls manual. Fix or sell?
- Brake dash light stays on dimly while driving
- CEL PO132 and PO505
- 1990 acura integra ls vtec
- Help b20z swap
- Battery cable sparks when connecting
- Questions on GSR with Catch Can bought
- Integra GSR Clutch/Flywheel Preference for DD.. Best Price
- What sleeves should i get?
- 1999 Integra, just got the car!
- Starter stays out in energized position!?!%*#!
- 93 gsr wiring issue
- drivier window issue need help
- JDMobsessed JDM front end ls
- clutch issues just looking for advice
- Boosted 97 LS-VTEC questions
- take off lugnuts from car?
- HELP!!! oil presure switch B20/vtec
- Rebuilding my b18 non vtec... Any pointers!
- gsr won't stay on
- Need opinions on purchasing 01 GSR B20 Turbo
- 96 Integra won't start and loses all power
- 97 ls head bolt question
- JDM Conversion
- window replacement?
- 92 acura integra ls vtec turbo
- 97 integra db8 rear seats fitment... Help
- 4-piston TL-S calipers on DA
- Integra GSR water leak into trunk - seam seal?
- NEED HELP STUMPED DA9 LS/vtec
- Honda-Tech heads needed ... B16b Type R in DC?
- How 2 Swap A 99 Gs-r into a 95 Ls Teggy?
- engine oil leak
- Stock b20 turbo?
- Tad bit of a predicament - Oil Squirters
- my integra wont hit vtec
- timing issue
- 30+ offset for track use?
- 97 Integra Gsr with Code 91 HELP !!!
- Complications with axle compatibility.!
- obdIIa gsr swap into obdIIb LS and speedometer is too fast
- Will EK ARC box fit my DC?
- heater, cig lighter and radio not working
- 96 integra wont start, need help with diagnosis
- Need help calibrating TPS/OBD1 GSR
- Whole Exhaust Piping cost?
- No more Idle with 70mm SK TB
- temp sensor acting up '90 DA9 GS
- Need Offset and rim size help
- Dear DA owners. Which OBD is 90-93 integras?
- Poor mans GSR ITR
- Aftermarket stereo issues..no power?
- Any downfalls of having 2.5" piping to a 3" inlet exhaust?
- help please..would advancing ignition timing to 18 deg cause engine pinging???
- 94' Teg Won't Start
- Coolant Leaked Inside Car/Passenger Side
- INTEGRA STOLEN IN SACRAMENTO, CA
- 1990 LS overheating...misfiring? fan?
- 91 GS hazards, seatbelts & IACV question.
- Need a name for a bracket
- ls vtec sandwich plate
- Whining noise while driving
- who here had used header wrap and the header actually lasted a while?
- Heater doesn't get hot
- cutting strut towers
