View Full Version : Acura Integra
- gsr motor problems help please!!
- WTB: Type-R wing and HID's
- dual exhaust
- ls/vtec ecu problem
- springtech struts
- b18c1 with a p28 ecu, no IAB control, is it safe to drive around?
- need help with ecu code 43
- FS b18c1 parts
- help taking my head off
- superchargers?
- Hi! and First Question about Main Fuel Relay?
- eg seats into my DA
- some electrical issues on my gsR that been buggin me..
- windshield water hose got disconnected..need help!
- how to mount license plate???
- best oil for my scenario
- hoods.
- how to remove a Dash from a 96 Integra
- Valve Cover Bolt wont come out!!
- LS Vtec ....... help.................... INTAKE MANIFOLD PROBLEM :(
- High Idle at cold, low idle at warm, shaky
- DC LS Sunroof Factory Tint Removable?
- oem gsr tie bar red oem color
- Positive camber after accident
- need help!!!
- is changing of the expansion valve necessary?
- ? for those who have innovative mounts
- picture request : sunroof visor
- New here just sayin hey!
- why is my gsr-t fuel pressure leaning out
- Speedometer/Odometer question
- Name this Part please?
- b18c motor wit cable ls tranny
- Are GSR cams good for RS turbos?
- turbo, supercharge, all motor = which is more reliable
- Very Rough at Idle
- starting issues help
- anyone know where to get a good type r spoiler
- pulley kit on gsr
- does my engine sound healthy?
- 92-93 GSR'S - Cupholders
- average gas mileage for a 94+ teg auto
- will this header fit
- OEM Exhaust Compatibility...
- key ignition swaps anyone?
- axle trouble
- rod question
- piston ring question
- shifting
- Will ITR suspension fit on my 94 DC2?
- simple question
- tranny problem
- Cheapest Brake Caliper?
- HEY...New to HT...I have some questions about integra gs-r...
- so my car was stolen this morning
- Anyone looking for a buddy club seat?? I have one for sale
- Engine mounts ???
- tranny help???plz
- WINDOW
- dsm 450's on stock fuel pump?????
- DA Integra Build thread for LeMons Race.
- B20Z2 OBD2 in a OBD1 94 TEG; need wiring help
- low idle w/ A/C on
- DA 1 piece headlights?
- A Question about plastic timing belt covers (lower)
- Air leak from valve cover? Idle dropping very low when stopped
- is it possible to replace the pulley on the alternator?
- Lose power at 6k on b20b p75 1999 40,000 miles and broken in stg 2 exedy!!!
- GSR Shop Manual
- wont go into reverse...at all
- cylinder hone
- GSR knocking...not clicking = CV? Axles? PLEASE HELP!?!?!
- H22 injectors in a B18c1???
- Selling my 2000 Fully built turbo teg ls forcefully =/
- Selling my fully built sleeved turbo ls =/
- Will 96-00 civic lowering springs work on a 99 integra gsr?
- d16z6 header fit a d16a1
- stalling out after 4,000 RPM???
- done installing my sk2 tb.
- Automatic tranny flush questions
- Oil Filter Stud
- HelP Integra Cambering????
- Car will not start
- LF Oil cooler sandwich adapter
- Coilovers & my situtation
- Mugen ancillary radiator switch?
- vin numer?
- DA air conditioning question
- jdm front end help ???plz
- engine pull... won't come out... caught on drive belt??
- gsr supercharged 1/4 mile help?
- new to honda tech
- My 94 GS-R
- ? about speakers
- pulling engine ... must use rear mount?
- possible oil pan leak?
- tps sensor removal
- What gauges will fit?
- please help
- need help fast
- check engine light
- HID Questions: Do the ballast get hot?
- valve rocker arm
- skunk2 throttlebody install?
- jdm obd2 engine into a obd1 car
- Loose Steering
- how much would you pay for a 95 gsr 4 door?
- need some motor help
- black leather makes my car hot
- need help for folding mirrors
- HELP WITH SHOCKS
- fuel rail and injectors
- auto ls, car starts, idles @ 2k then dies
- DB1 cambering problems???
- CTR cams stamped with a K?
- HKS SPORT EXHAUST: CIVIC Si 88-91 on a da6
- can some pne plz help me with a wire tuck
- what will my 1/4 mile be with this setukp
- Quick ignition Question..
- 93 integra turning wheel hop WEIRD!!!!!
- where to buy a replacement door?
- starting problem
- Rota J-Mag On DC2
- Could some one please tell me what the stock fuel pump puts out on a 95 GSR???
- ZC Swap in 89' teg....need help!!
- thrust washers
- need help: cant ID my transmission
- ACURA integra Dead! need help. Solid light no spark no prime
- b18b swap, need help
- univeral rubber grommet
- Story behind CEL and what the problem may be?
- Put my DA to rest... =(
- steering wheel fitment
- in need
- skipping gear
- fuel filter?? where to put it- doing a complete wire tuck
- comfortable seats?
- Muffler Question for 1990 Integra
- drilled/slotted rotor question
- Car Died, Could it be the Alternator?
- ITR 5 lug in a 95 DC frame W/O ABS ?
- h22 intergra's where you at?
- B18A1 with ITR .10 over
- HID need some help G3 integ owners
- Tokico Illuminas vs Skunk2 Fullcoilover?
- Using a Type R oil pump on a B series engine?
- Shift boot
- apexi afc neo helppppppppppp
- Supercharger questions
- what is a dc1 integra?
- 2 question Power steering and AC removal and ticking noise
- GSR EXHAUST SENSORS....
- anybdy have front turn signals for sale
- Drivers Side suspension noise PLEASE HELP
- ebay HID kits
- b20 v tec????
- Will civic si struts and springs fit an LS integra?
- DA: Pics of 1.8in drop please
- Jumping Tach Needle
- How much is my dc2 worth?
- DA intercooler pipeing
- first time...
- question on integra ls parts swaping to GSR
- Intake Resonator 1995 gsr
- obd1/2 altenators
- Antenna Retraction Problem
- JDM Front End --- Which of the USDM bolts/nuts/parts are needed?
- stage 1 clutch
- Engine Swap 92 Integra LS
- I have a few questions. Please help.
- HELP! HOW DO I TAKE OFF MY REAR BUMPER!
- universal door locks any good?
- rhd wiring digram
- Parts ideas
- Car sits werid on H&R's and KYB AGX's
- WOO
- B18b SWAP. help? FcFrom hell please repost.
- i just bought a 1992 integra and my boy just bought a 1995 gsr and it hade some after market shocks
- Should I buy this GS-R?
- just got a jdm longblock, what should I do?
- e-brake senson going bad?
- tranny question
- when did the integra get a face lift? and diff tails?
- 4x114 Conversion onto GS-R
- nos 93 da
- Sound coming from Tranny
- suspention from a 1995 gsr to a 1992 ls
- DA9 Question
- Does the 3rd gen teggy lovers not have their own site?
- TP sensor on the TB
- gas mileage with A/C on
- Lower radiator hose not getting hot and car is OVERHEATING please help
- motor swap, need key?
- Need Suggestions On Suspension
- My integra.
- How do you repair damaged clearcoat on gsr wheels?
- Cylinder Head parts list??
- 94 gsr oem alarm system help!!!
- gs-r aftermarket carsound cat
- Shocks/Struts
- trouble selling because of jdm odometer
- Front Engine Mounts
- Doing an ITR Conversion.
- Why doesnt my door lock?
- Help.. Rear brakes squeeking sticking and wearing pads
- Searched, no luck, how to refill refrigerant in a DC?
- rev limit on stock a1 internals
- AC PROBLEM QUESTION ??????
- lsvtec turbo but need some advice
- Pricing for a used gsr?
- B20A5 HEAD ON A LS BLOCK
- Electrical problem - Gauge cluster/blinkers.
- street tune for b18c with ctr cams ?
- can this bumper be fix?
- difference between obd1 LS TB and obd2 LS TB
- Finally got my gsr
- what size allen wrench for gc coilovers
- Gauges
- car wont go into gear!!!!!
- all problems on my car fixed now watch me rip it :P
- Front end noise.
- Parking lights and turn blinkers on jdm side markers
- s2000 antenna on my 94 gsr teg how to install
- Installing piston help
- B18b trany needed please repost
- s2000 pads
- How do you take apart a jdm dc2 headlight?
- I want a 4-door teg!!!!!!
- help FAIL emission test !!!!!!
- Need width and lenth to install side markers on a db8
- side markers DA
- Radiator flush question
- will i pass smog??
- Please post pics of your lowered integra
- v-tec
- Turbo GSR (stock internals)
- light problem
- fuel cut off switch
- Is it worth it,just need opinions.
- hondata IM gasket
- H22A Integra
- GSR Idle problem...I searched..need help
- Question
- Clutch problem..
- how to separate the axle
- Decided to go Nitrous any Tips would Help
- help! gas pedal get stuck when in first gear
- which is the best radar detector?
- mfactory shift knob ?
- first post
