View Full Version : Acura Integra
- My Integra was killed today..
- Dash lights and outside light issues
- advice on strut choice for a da
- Integra Rear Trailing Arm Bushing
- Auto Integra
- Need Help with Part Number
- Will b18b1 in 1990 integra pass smog?
- 92 b18b intake manifold in 0bd0 integra
- 91 Teg battery relocation wont start.
- B18C1 experts...I need your help!
- making your own AC hardlines.
- swapped b18b1 for b18b engine need help with iat sensor
- help me!!!
- Fuel Feed Line Q
- Crank No Start
- Can someone answer this question for me please!!
- GSR starter wierd during compression test
- suddenly very sluggish low rpm
- Is it necessary to remove the bumper to get to the headlights?
- what's the trick to remove the factory power antenna on a 1991 integra..
- integra obd2 alternator pinout
- Steff
- Integra running sluggish
- What do you think of these gears?
- o2 sensor obd1 conversion
- OBD1 Engine with OBD2 Distributor
- Cars running sluggish! Help!!
- gen3 DB&-DB8 sound systems post them
- 1998 Integra LS to b20 swap
- B18C1 trans vs any other?
- Fuel Line Connection - Car to Pump
- No lights, no ding, no Ignition
- Bee R Rev Limiter Help Please?
- Help!! 92 integra
- What does this hose do?
- Cars running like crap!!
- Do all B18C1 engines do this?
- Car squeal while braking at low speeds.
- B18b coolant temp sensor
- B18b help!
- 95 acura integra issues
- 2001 integra radiator fans not coming on
- DIY: Rear Brake Caliper Rebuild
- Car is really messed up!! Please help!!
- HELP!! parking light issue
- vtec Solenoid valve
- VTEC not engaging after LSD Transmission installed!
- lsd conversion? or buy type-r
- Corner light goes on and off from bumps.
- diy jdm 98-01 dc tail lights
- Please help teggy fans
- Buy An Integra With A JDM b18c Already Installed?
- Coolant leaking from the rear of engine - 92 DA B18 LS non vtec
- Shifter tilted forward
- Clutch Pedal
- First Ride Integra GS-L shell
- Removing distributor rotor, without damaging coils.
- Alternator brushes or voltage regulator?
- integra cruise control
- 96 GSR cel p1362 code. Help!
- so I'm buying a ctr tranny
- headers nut torque spec and procedure
- 01 integra HELP!!!
- Antenna Replacement
- Valve help!!
- Automobile Magazine: Looking for a clean, 92-93 Integra GS-R
- What's this sound? *Video*
- wiring tuck help
- Oside-Bosch Injectors 1st test
- Strange start up
- quick struts n springs question
- so I'm buying a b18b1
- Integra 96 Cable to hydro
- 1995 integra ls trans won't shift into reverse
- Depin SRS plugs
- 1999 intera ABS code 54
- Engine stuttering on acceleration, only when warm, possible fuel issues?
- 92 DA9 car shuts off when I press down on the brake
- 90 B18A1 Code 14
- Will a bad ISB do any harm in the long run?
- Ls turbo build *need help
- 1993 DB2 slow "restore, build, project"
- exhaust
- NGK BKR6EK opinions
- Radio Fuse Blows everytime
- clutch and trans trouble shooting
- EG/Del Sol Steering Wheel on DC/DB?
- Clicking sound ? Not sure
- B20Vtec Chugging after deceleration
- Lsv ecu tuning
- Engine light on
- b18a1 intake manifold on b18b1 in DA
- plz help me. 95 integra underdash fuse box c915 plug
- help, 2000 gsr lurching problem
- OBD2B conversion
- transmission problems
- 1993 acura integra b20 vtec keeps jumping time
- Engine bolt question.
- Bent intake valves
- B20b/b18 vtec
- 1990 Integra idles high and low and shuts down coming to a stop.
- Clutch pedal problem after replacing CMC and CSC
- Looking for performance shop in SF East Bay
- Hytech Header Identification
- Skunk 2 P72 GSR Intake Piping Question
- Integra Sedan Mirrors
- 97 Ls under dash plug help!!!!???
- ABS/VSA light on after new abs sensors.
- LS integra For RSX-S
- 15x9 949 On DC2?
- JDM Type R steering wheel options
- ITR intake manifold
- 94 Rs Build?
- WTB: Integra GSR
- Clutch Pedal Sensor
- Temp. Gauge not working!:thud: (HELP!! Radiator started leaking:scared:)
- Integra is smoking a lot, help
- integra abs harness delete
- B18C1 manual, please help!
- LS VTEC IN SAN ANTONIO TEXAS
- Teg won't shut off completely
- GSR Making terrible sound! Help! (Short video)
- Car died while driving - no spark
- how many gaskets for the vtec solenoid?
- skunk2 recoil adjustment
- Fuel return line??
- No start 91 LS
- 2000 gsr vss issues?
- Nexus 7 Tablet Install in DC2/4?
- B16a
- Integra parts for sale $1
- DC2 Comptech swaybar/brace kit question
- b20v setup need a good cams
- 15x8 +36 or 15x7 +35?
- Almost done. Hose and wiring diagrams?
- B18B1 Auto Trans on B18A1?
- Can you put in a ball joint with out a press?
- power steering help!!!
- Broken input bearing removal.
- map sensor testing
- Need some help
- 93 DA Shifting issues Auto- losing my mind
- Don't drill holes into your bumper for a license plate relocator!
- No spark, no code...i don't know what it is but i know what love is.
- temp gauge not working b18 swapped ef
- It goes where?
- obd0 to obd1 distributor plug swap?
- custom audio questions
- slave cylinder or hose is bad?
- HELP Rain Leak
- b18b1 DOHC timing
- How do I check for a bent valve
- 94 integra cv axles..
- 97 Integra GS with JDM B20B weird tick
- Can someone answer this question for me?!?
- motor hesitation problems NEED HELP!
- 1992 integra check engine light on?
- ls manual trans can it be reused
- throwing code 13? jumpy idle. please help
- 90 integra power windows
- Throttle Body?
- Starting a B18B1 Build With Little Experience "HELP"
- Hesitation when accelerating
- b20z2 block & gsr head fuel pressure
- which 90s honda/acura came with heated mirrors
- db8 rear defroster weaksauce any fix?
- Driveshaft Bracket Bolt
- Weird noise coming from my motor
- Spark plug filled with oil?
- Thinking about Jdm LS or B20 and would like input
- Best all purpose 15" tires. Quality and price point.
- D series integra exhaust
- Newbie CEL 6 and s4 light on
- Low compression test question
- Electrical Question (Sparks out of distributor)
- swaped a b18b1 for a b18 help!!
- Turbo Nippon Pistons? Full Floating
- funny noise and idle problem help!!
- main harness tuck
- Corroded ECU
- Cleaned throttle body and FITV? idle is different now
- Help wiring obd1 iacv into obd2 integra running obd2 iacv
- help motor ID
- Interior help & custom interior
- b18c1 82.mm ctr pistons skunk2 stage 2 cams
- Oil on underside of B18C1?
- Side Mount Sparco - DA
- Engine and transmission swap Atlanta
- 95 gsr turbo (ectune)
- 2000 GS Wont Start, see if you can follow my diagnosis!
- 01 integra starting help!!
- crank woodruff key QTY.
- why did my flywheel get a hot spot w/new clutch?
- ITR SRS wiring for 95 Integra?
- 99 Auto LS: Slight miss at idle, weird scratchy sound on slight acceleration, cel 71
- Noneed2hate's Integra Build
- No corner lights front or rear, with 1st or 2nd click of combination switch
- 92 integra smokes from here
- B 18B swap
- 91 integra tranny problems
- 91 integra Electric problems
- Question about brake fluid change and bleeding.
- how do you test a p28 ecu?
- obd 2 ecu question
- 98 LS shuts off while driving and idling
- b18b1 valves problems
- Timing help
- Car won't start after filling tank HELP!!
- 94 Acura Integra Power Mirrors Fuse?
- skid plate?
- Oil light coming on
- ITR suspension really worth it?
- READ CAREFULLY
- [Question] CTR and ITR header downpipes exchangeable?
- body work question. Be all end all for my tegg.
- b18c1 hot start/idle issue...
- Integra temperature needle reading low
- obd0 and obd1 icm the same??
- Crank no start problem. Integra b18b
- integra fuel pumps flow rates?
- Electric power steering
- Freon on my compressor
- integra ls trans knock/impact noise?
- omni clutch master cylinder
- idle dips on gsr
- obd2 dlc connector
- Rail & injectors
- ABS delete questions
- intake gasket help
- Light Wiring Problems
- NO VTEC. on 98-RS w/ITR swap.
- Help w/driver side OEM HID not working
- Priming engine after rebuild
- Simple fan jumper
- Rear LCA question bushing.
- Front Upper Arm Mount - ID this part, how to buy replacement?
- Diffrences between 1995 and 1998
- b16a1 in a da3
- Automatic Transmission Strength?
- alternator upgrade
- Catalytic Converter-looking Test Pipe?
- Opening connectors
- b18c trans fluid
- do dc2 type r headlights and bumper fit dc1?
- 94 LS
- Weird Start-up Issue
- Looking for Engine/Transmission Swap Advice
- gsr skunk2 intake vacuum port issue
- ebay valve cover gasket, good or bad?
- DC5 Brembo on DC2R... But wait, theres a catch.
