- half shaft
- problem with keys
- Type R spoiler?
- 96 ls wheel specs
- B16A Integra, How can I make it a NA low 14 sec car?
- Ebay turbo kits
- anyone know where i can get the motormount for manual conv.
- turbo or ls vtech
- Complete my 2.5" Exhaust system!
- E-Brake
- egr valve
- tranny not going into gear (just replaced slave and master cylinder) WAHTS WRONG!!!??
- Just another head gasket post (B18B1)
- help! video inside, no spark no start
- miantence check light on
- What size wheel do you like?
- I NEED TORQUE SPECS QUICK!
- OBD2 GSR in a 95 EG! HELP???
- hole in transmission case
- Suspesion
- 92 integra injectors arent firing! no power!
- vtec engages shitty
- looking for AEM EMS tuners in new england area
- decent coilovers wanted
- rpm shoots up then drops when let off gas
- swaping in a ls/vtec setup
- Cheapest wat to small my teg
- Windshield weather strip diagram or help with clipping it back on
- b17 help
- transmission noise
- Buddy Club rails EG--DC compatible?
- B20B help
- Engery Suspension Inserts Vs. HASport mounts
- Front and Rear Bumpers
- apexi gt spec question
- Some noob questions about dyno tuning
- I know I know...Car will not start.
- LS ac compressor on a gsr
- brake noises
- Hondata S300 Vtec Issue
- B-series crank case pulley
- POLL Gsr cams
- AZTEC GREEN INTEGRA GSR FOR SALE
- SMALL RADIATOR OR BIG???
- Pennzoil syncro mesh vs. Genuine Honda tranny oil. What would you recommend.
- need help asap not gages work in my car
- Ebay Steering Wheel Quick Release Hub
- Filling up Gas
- bolt patterns of b series engines?
- ls v-tec for my 1991
- EP3 axleback on a DC?
- JDM ITR front YELLOW Bulb in Headlights replaced /w Yellow H3 bulb.. not as bright? how to fix
- rsx seats in the integra
- SEARCH'd already found NOTHING>>>wiring side markers
- Head install doesnt run right....HELP
- DA HID one piece headlight
- 00 gsr wont pass insp.
- Repair or Scrap it???
- relays
- omnipower master cylinder issue
- all motor ls/ls vtec
- need help!!!
- anyone know where i can get this carbon fiber interior piece?
- Does 97-01 integra's have cabin filter? smells bad inside.
- Idle Problems
- Went To Auto Repair Shop And Got A Repair Estimate, Can't Decide If I Should Do It.
- pistons
- noob question
- integra w/ jdm h22 swap f/s
- PAinting my friends integra
- DA Fear and Loathing
- -------- NEED HELP QUICK !! ON STRUT BARS !!
- Lookin for a 98+ acura integra SHELL!!!!!
- gsr guage cluster need help
- another stupid "OMG the CEL when on". problem
- Replaced Distributor Cap and Rotor, car wont start... HELP!!!
- Fuel Relay?
- s-40 trans ????
- annoying Factory cd player?????
- 95 GSR Hard Gettin into to Gear at High RPM
- Installing a throttle body on a dc2 with a b16
- Is it better to have low compression for a jackson supercharger?
- stock 96 SE with b18b1 / lsvtec?
- jdm b18b using usdm wiring harness
- SERIOUS help needed ASAP!!!
- speed sensor?
- Coolant hoses keep bursting. Please help
- Scrapped DC 4-1 *PICS* will it affect performance?
- Help with gsr vacuum line pls!!!
- Muffler broken again
- Header on a 2000 LS
- 94 Ls 2 dr integra speaker size
- B18C5 in a GSi
- JDM front conversion
- integra db1 pics
- ITR Cluster help...
- Condensation in headlights?
- Gsr knock sensor WORK ON H23a prelude????????????????? please answer ASAP
- Where to buy quality OEM ( 98-01 ) headlights?
- Type R spoiler template where to drill holes?
- Hey i need some advice?
- Idle problem back again, replaced brake master cyl already
- brand new Exedy clutch, and weird noise
- GSR HEAD on B16 BLOCK?
- Does your sun roof leak?
- gsr rods...
- fluctuating idle while in P
- Koyo Radiator for GSR....
- GSR question
- spark plugs
- so what could this be
- need a lil help wit this question
- Huge rattle?
- Advice on setup
- HID question for DA owners or anyone else that might now
- Question a coil pack.
- ls cylinder head bolts reusable?
- obd0 to obd1
- popping noise at idle
- keyless entry for 95 integra
- Brakes
- integra auto to manual swap
- halo headlights
- Colors
- Redrilling (prelude vtec) rotors
- b18b1 turbo
- oil pump question?
- PLEASE HELP? Major brake problems
- whats the main differences in the 94-99 and 00-01??????
- car wouldn't start this morning, would only rotate
- header poll
- Console plugs
- Integra GSR waterpump question
- bottom end rebuild??? price????
- Hatch switch?
- Are the seats in the picture honda seats?
- Intermittent wipers not intermittent, 90 GS Sedan
- 99 gsr want to go turbo
- fan not going on!!!!!!!!
- 90 integra mounts
- ls or gs
- edelbrock Throttle body Help
- ========== ANYONE KNOW WHERE I CAN GET ...
- please help me (i want to find USA integra DB8 98-00 all red tail lamp ) parts number
- intermittent driveability problem
- Possible to install Civic dash in '98 Integra?
- 90 teg b16a swapped no spark
- Would this work? JDM exhaust fitment on gsr.
- CKP Sensor
- Coolant was changed and car overheated !!!!
- Theft of manual car with remote starter easier?
- What rpm do you guys show at 80 mph?
- 94-97 integra shell...
- General question on Apexi VAFC 2
- Hondata gasket
- What can I do about my rear defrost?
- ID a sensor for me
- how to open hatch from inside car??
- The lines on Oil Cooler on GSR
- HELP expert jdm HIDS 95 integra
- is this your da? so-cal
- New to the integra's need some help
- ebay headlights?
- Spoon N1 cat or no cat?
- guage cluster doesnt light up
- how do i aim the headlights
- Crankpulley/ Harmonic Balancer are they worth it do they cause damage?
- some header issues
- New swap No Start
- Testpipe--> Cat problem
- Dog+70 mph Integra=omg look wat happened to my baby...
- Complete Vtec Head B16 B18 OBDI
- does a itr spoiler line up with a gsr spoiler?????
- Redline Water Wetter
- what is a better header
- vtec malfuntioning
- Need Help Badly
- info on itr valve train
- header ?
- what kind of wheels are these?
- Eagle rod bolt tq specs
- clunk / pop ??? when breaking or accel --1991 integra--
- Starts hard in damp weather
- Rear Braks -94 LS
- Optional Sideskirts & Rear Valences Availability (Preapproved)
- Weird power problem
- sensor locations
- Is this strong enough?
- B18A1 running to rich, need help.
- front rotors and ABS BOLT.
- how much are new EBRAKE CABLES for ACURA INTEGRA.
- will 13" vx wheels fit a 92 Da?
- help pin pointing a hose name
- CRAP i put the valve seal on the wrong side...how to remove safely!?
- paint code
- how long will jackson supercharger last on b18b
- jackson supercharger on ls or turbo from ebay
- type r shifter
- B16A swap
- threw a couple codes
- Amazing story. Almost hydrolocked my car.
- Code 9
- Crank Pully
- does anyone know if 2dr mudflaps fit 4dr
- Part number for GSR thermostat?
- DC4 coil-overs from an EJ??
- idle issue...94 gsr
- Suspension question
- A/C help
- Driveshaft spin at idle
- Integra turbo Q's!!
- my Ls vid: first time using movie maker be easy
- My car broked. Never did this before....
- B18C DA9 Header (SEARCHED)
- smog relations i failed. need pass on monday 11/13/06
- paint removal help???
- Headlight problems
- what ecu should I get with a skunk 2 Intake manfold?
- another ys1 ?
- Take a look*
- Center Console- Heater Control Lighting
- I'm looking for an exhaust thread.
- 90 teg gs Intake Manifold question
- how do you put dc5r recaros into a dc2??
- Need help with the Escort Radar!!!!!!!!!!!
- Auto to Manual conversion is it worth it?
- did ls motors ever had knock sensors ?
- high idle after tune up
- need quick answer- is there a gasket inbetween the upper and lower exhaust manifold?
- urgent: negative battery cable causes car to honk
- cooler fan wont turn off?
- ALARM PROBLEM
- Need a new key for my Teg. Anyone work at an Acura dealer?
- LSD install
- I got Rear-Ended...AHHH!!! (pics)
- HOSE LINE FOR TURBO
- DA water temp gauge problems..
- Is there any difference between the interiors from the years 95 ls to 01 integras?
- HYDRO TO CABLE CONVERSION MOUNT HELP???????ASAP
- s
- Buying next Integra... Need Advice
- How to reset SRS light ----> DC2 integra
- Headers vibrating against oil pan.....
- y Rota pf45's on a black teg
- What lowering springs to use on my 96 LS?
- chrome taillights
- Wiring issues...plz help asap
- looking or an integra shell
- Radiator labor??
