View Full Version : Acura Integra
- wat gsr battery?
- stick with ngk's or try something new...
- 205/55/15s on stock gsr rims?
- Another what's my car worth thread?
- Carbotech
- What is the best I/H/E combo if i wanted to JRSC
- CAn someone run car fax for me?? thx
- Is this a big problem (pic inside)?
- where can i get this?
- Need torque specs quick! 98+ integra
- Best Integra reapir manual
- flywheel is loose
- Car got hit... help please
- power door lock wiring
- Comptech Springs
- need help wit a jdm type r cluster
- This years club name for NOPI is......
- Head Packages
- Dumb Q: Window Cranks ('90 LS)
- How much does the alignment change with me in the driver's seat?
- how much gas can an ls hold
- Wiring Diagram
- Car just got in an accident.
- shift boot replacement
- Brake & Wheel problems...
- What will get better gas mileage?
- ShadowDawn: Some clarification...
- Need Help keeping my NGK wires connected to dist.
- Fan Belt Help???
- What do you guys do?
- Need Help with Car Problem
- is p74 and p75 chip interchangeable?
- best performing i/h/c/e
- header with 2.5 collector
- Sport springs with highest rear spring rate?
- wheel
- clutch question????
- Help? Car bogs
- JDM power folding mirrors(Wiring help)
- exhaust questions
- quesiton about lower tie bar!
- type one exhaust info
- Eibach Pro-kit or H&R Sports?
- How do I change my picture?
- Other Integra forums?
- getting new tires tomorrow, which ones
- oxygen sensor
- Looking for Recommendations on HIDs For JDM HID Headlamps for Integra
- how much is a GSR head worth?
- worth it or not? opinions please
- Which sway bars?
- axel back?
- dc2 vs. eg/ek as a shell...
- Can I see pics of ITR and/or H&R OE spring setups?
- do i need to upgrade my fuel pump when swapping a b16a in my dx civic?
- where's the clutch cable??
- Clutch Problem...plz help
- What consists of a rebuild in the b18 motors...
- Everyone be sure to disconnect those electronic door locks
- E-brake Q.
- Short shifter question
- 96 integra tailights...is it possible to pop out the yellow turn signals?
- Headlight dirty....how to fix??
- Pic Request: G3 Integra with Eibach pro kit springs installed
- ITR rear sway bar + ITR lca's + what lower rear tie bar???
- Ecu and a couple other questions
- anyone with a fuel pressure gauge?
- Car show today in Berlin, CT
- Integra console part #
- painting stock GSR sides skirts to match?
- 94 GSR short Block on Ebay NO Reserve
- Who here uses the Crower 404 for non-vtec motors?
- Recomendations on Catbacks
- how far will GSR go once low fuel light comes on?
- itr intake valves?
- anyone ever went to repo or police auction for a 94-95 integra
- best exhaust
- high idling on cold start > 1500 rpm
- Anyone have a tanabe racing medallion on their car?
- LS/Vtec setup, what ALL do I need????
- All Motor Or Turbo a GSR?
- vtec engagement points
- Ebay Item Seem OK?
- gettin my windows tinted on tues!!! post pics so i know what percent to go w/
- CAI Install Question!!
- Sac. peeps I need your help....
- selling teg?
- Will Stock Seat Brakets Work On Tenzo R Race Seats????
- having trouble lowering my GCs
- does anyone have konig heliums
- Clear Corner Problem
- Increasing mile numbers on cluster?
- Who sells CarSound Cats
- Cooling fan not coming on in my turbo ls?
- Keyless Entry Remote
- venom control module?
- Stock exhaust diameter?
- 3rd brake light removal?
- Intake question
- where's the best place to dyno tune around MN?
- injen intakes
- 3rd gen integra help, Fast question
- 89 teg worth fixing up?
- Did the size of the seats ever change in the 3rd gen integra??
- skunk2 coilovers squeaking...
- How to remove rear hatch?
- Quick Question...
- Hot.......
- The blue 4 door integra on tv
- Stock GSR flywheel...worth anything?
- Just my Luck
- rod bearing colors??
- Cutting CAI
- from 2000 Acura TL HID kit --> Integra
- Best N2O kit for my RS?!
- Need Help (maintenance light)
- How to check coolant temp sensor?
- How to check/replace thermostat?
- GSR> Clutch making clicking noises during press & depress
- exedy clutch for 94 LS?
- SE73's
- Rear Spoiler Holes
- Floor mats for 1994 integra
- I am thinkin about gettin a 93 Teg...where can I find information on them?
- Gen 2 GSR tranny mated to a Ls block...
- Apex'i VAFC problem -no vtec
- my options
- Dulling headlight's...what's the fix?!!
- Springs Making noise
- Gains From My New Exhaust
- need an iac valve where to buy
- True Life on MTV Street Racing
- Recommendations on Short Shifters better than DC Sports for Teg
- Real quick question
- center cap ?
- what parts to 'upbuild' a transmission?
- Turbo my LS or buy a RSX Type-S
- e-RAM electric superchargers
- pics of H&R race springs
- Converting to Synthetic Oil
- tech ? about integra on MTV "true life of a street racer"
- DIY A/F meter?
- Need help bleeding clutch....
- phantom grip
- Quick...give me some advise/suggestions
- Turbo Teg tranny swap COMPLETE!
- LSD for SI model??? {square peg in round hole?}
- Replacing hood prop
- intake vibrates engine ?
- Timing light/checking timing
- Rear section exhaust, stock mid-pipe???
- Foglights
- dreaded subframe tearout.
- just bought air fuel meter
- Negative camber?
- 17 in. wheels for sale or trade
- Which Camshafts to use with I/H/E 97 GSR
- V-tec conversion
- Adjusting Belts (Squeaking Noises)
- Adjust Belts (Squeaking Noises)
- Integra Models?
- whats needed for b16 in 93 teg
- Thought this might interest someone!
- bearings on the crank
- How much is this block worth?
- I Have no A/C.... can i take off the a/c fan on my turbo LS?
- Offset Question
- Lowering Specs for Coilovers
- DC header VS oem exhaust manifold
- Turbo pipe sizes for gsr
- Is my synchros going bad? Techs please help!
- Radiator fan not coming on in my turbo ls
- For those who bought Speedbleeders for their g3 teg
- Fender Removal help!
- How to Tell if you Need a New Cat?????
- need help with decision
- Oil change mess
- hmm what to get
- Problem with my G2 Teg...PLease help it won't start
- Anyone still using Mobil 1 oil after new formulation?
- List of manual rack conversion parts...
- External cameras setup
- Those with Intakes...
- 1/4 what gear are you in when its all over?
- <<< Understeer >>> ...I'm a confused person....
- H&R OE vs. ITR springs
- How much do you guys worry bout theft?
- Can someone Please get a carfax for me, this is my first car and i want it to be worth it
- wut are Breather?
- Clutch - this a bad sign?
- wut is a cheap good website to buy tires??
- The GSR dead zone ? Vtec slows me down... :(
- Some kind of tranny noise.. Please Help!
- HELP just went to the tracks...and car drives like crap now
- Anybody can run a Carfax for me?
- Coupon for Hot Import nights- ATL
- Tire Pressure
- Tranny Issues with Spoon Final Drive/LSD
- Header Scrapage
- Need help on ecu wiring.
- FS: camel tins, mandarin mint and twist flavors
- Fuel rail question....for B-series...
- So Cal Junk Yards with integra parts?
- fuel pump????
- Japanese spec b18b install
- horsepower gain
- cams
- How Do You Remove The Stock Integra Spoiler???????
- HELP..compressor problem..
- Defi Gauges?
- Newbie, What's up guys, some simple questions also.
- suspension help
- s-afc
- anyone have Apexi N1 exhaust on integra gsr
- squeeky clutch pedal, what was the fix?
- WingsWest body question...
- cams messin up forced induction??
- spring bolts, needed?
- CEL: Code 63
- 94 GSR, What type of camber kit to get?
- When Removing Rear Wiper on 95 Integra, How do you remove the arm? It won't come off!
- Dyno Tuned my car
- Burning oil
- oil change??question
- problem with 98 integra, suspension? pics inside
- how much is this swap worth?
- Next Mod
- civic integra compare
- B18b1 w/ VTEC or B18c1 w/vortech supercharger
- does 96-00 civic springs fit on 2000 integ ls?
- any suggestions for my 80,000 mile B18b1?
- Plugs an Plug wires.
- Spare key for a 2001?
- weight distribution on g3 integras?
- 88 (mite be 89) teg RS motor
- ITR JDM 23mm vs USDM 22mm questions
- Stage 3 Clutchmasters
- Engines Online
- how much is my gs-r worth???
- Changing Fuel Filter?????
- electric superchargers
- Who's intersted in a group buy on....
- air in a bottle
- GS-R and LS muffler fitment question---need answer quick
- wooohoooo....Type R 22mm swaybar installed last night
- differences between dynos??
- can a ls/gs/se equal a GSR ??
- reseting ecu
- 1/4 mile posts
- Anyone Know the percentage of the tint on the sunroof?
