View Full Version : Acura Integra
- easy do it yourself way to turn off maintenance light?
- 89-89 integra trani?
- radiator hoses
- timing belt cover help
- rear bumper advice
- Anyone ever hear of 19mm rear sway subframe issues?
- da teg 1992
- so car wont start...
- jdm hid help!
- any one have a pic of GSR intake cam near distributor?
- how to time the cam's ??????????
- idling problem
- Wrong red?
- Need some help
- Curious if i over paid for my gs-r
- 1992 Integra GS fog light question. USDM
- IM BOUT TO INSTALL MY JDM
- random question
- How to fix the crack on the rear bumper
- JDM power folding mirrors...Need help!
- distributor trouble
- > JDM Chrome housing to Black housing headlights
- Input shaft bearing?
- Reverse ligth problem
- 94 integra exhaust ..I've been told that 3" is too big...
- issues going into first
- could it be anything serious
- what is this part called
- header cleanup
- Clutch question.
- jdm hid headlight question...
- whats a good price for a 97 integra gsr?
- integra axle same?
- To All Lowered DA's
- B18B1 rebuild questions
- valvetrain questions
- Auto lock clutch locks!
- i need help
- secondary o2 sensor replacing need wiring help asap!
- 93 da
- want to buy a turbo kit some questions
- Weight reduction???
- coil fitment question
- RHD INTEGRA CONVERSION QUESTON
- need some help
- I pulled off the timing valve cover and the timing belt felt a little loose between the two cam gear
- Rear Lip
- cant find a post
- Tokico illumina coilovers and shocks
- 1990 teggy, rhd conversion, 98 ls, not starting?
- hondata/vafc
- deleting the airbag.
- possible theft plot on my teg
- Is a FLEX pipe needed for after market headers...?
- GSR Axles
- it starts with 3 cylinders?
- wheel bearing install
- GREDDY TURBO KIT FOR 95 GSR??? GREDDY VS. EDELBROCK...
- Rear Trailing Arm Interchangability - HELP
- LS block on GSR head
- is lowering my car 3 inches too much?
- !!!!!!!!! :: Ateention GSR Owners READ THIS NOW!:: !!!!!!!!
- need info- hvac controls
- cleaned throttle body on '94 del sol S, now my gas mileage kinda sucks and hydrocarbon output is out
- flywheel/clutch
- how to clean out the head
- AEM Wide Band A/F gauge.... Question Please help
- CA Smog + Adjustable camgears exposed?
- front axle
- Sparkplug question
- something a little different
- Would like to remove ABS, need advice
- itr intake arm on a gsr throttle body
- trunk leak?
- help
- ls all motor
- seats
- NEED HELP!!!
- tranny question.
- Mike's DA9 Buildup
- need help ASAP!!
- weird leak
- Type R brakes
- GSR clutch
- Condensation in left headlights, 1996 GS-R. Do I have to remove bumper to fix this?
- DEAD Gsr
- HELP! IDLE JUMPING AND OVERHEATING IN MY DC2
- how to identify
- valve cover bolts?
- Problems With Downpipe
- DC's Build Thread
- 250 whp possible from jrsc?
- Integra Headlight Wiring?
- hey guys
- GS-R Harness Plug ?
- clutch?
- How much Litres do i use to replace my MTF?
- da problem.
- dc cluster in da
- Maint. required light flashing
- Ideas for my integra
- idle problems
- JDM fronters... I need help...
- gasket maker for throttle body gasket?
- need help asap on ls rocker arms
- P1359 CEL, Crankshaft Position Sensor Question
- wheel bearing?
- swap or turbo?
- 16x8 sport max 002 questions.
- help: my integra ls 95 would not start
- my 95 GSR teggy
- Fuel lines on Fuel Filter backwards = Bad Gas Mileage ?
- db8 ls/vtec or turbo?
- obd1 code 3, 5,9
- Sunroof problem
- One Fast Acura
- Another starting problem
- need help to get the codes???
- Ls wont rev past 3500rpm
- Suspension: Gsr vs Type R vs aftermarket
- Compression ????
- Stolen Integra story.....
- O2 Sensor
- real 92 gsr for sale
- old car, low cash, need faster accel
- Removing DA lower ball joint.
- Coolant level keeps going down every week or so?
- WTB: OEM Stock Integra GSR Shifter
- jdm front end...
- will 99 civic si exhaust fit integra gs-r
- turbo gsr
- someone wit a 98+ integra
- front bumper question
- quick ques
- GSR "Slanted" / broke! Anyone ever seen a crooked seat like this? How to fix?
- piggy back system
- GAUGE LIGHTING ISSUES!!:'(
- gsr build
- How to install GSR Leather seats in my DA??
- spoon integra
- ignition lock cylinder
- I have a exhaust question
- JDM Front End DC2 Owners Only
- fuel rail
- trying to go LS-V need a lil help
- Underdrive pulley??
- Crankshaft Position Sensor
- Rear Brake Pad Shims Needed
- 98 spec 4-1 jdm type r header
- Car pulls right and left
- problems with ecu and idle. PLEASE HELP!!!
- Running rich? Bad gas mileage and black on rear bumper.
- Need help deciding next move?!?!?! GSR or Type-R???
- LS-vtec, need more HP
- Kontico HP Shock and Spring Upgrade on 93 teg and stock 14" Rims
- Engine stalls at idle.......
- o2 sensor help
- need to know fittings
- searched..gas gauge problem after tranny swap.
- My car wont start? * searched
- interior panel help!!!
- Brake problem...help me out guys
- questions about a head
- Building my 98 gsr
- Putting in a SE interior (hot weather people help please)
- The convertor question
- Random Tech Hi-flow cat heat shield rattle?
- oem cruise control
- tire size
- integra wheel bearing and hub questions
- safe for manual swap?
- Fuel gauge problem
- Best place to buy aftermarket parts for my teg?
- power door lock question
- Roommate's Integra ALMOST stolen: Another testiment to the fuel pump disable!!
- Piston hitting spark plug?
- cam gear & camshaft experts please help me. picture inside.
- spark problem
- need antenna
- motor
- Quick Release Hub Lock
- P28 VTEC PINOUT
- integra ls brakes compared to a gsr
- jdm dc2 power folding mirror help
- quick question about shocks.
- Vote and Reply: All-Motor build Vs. Turbo for Daily Driving?
- Undescisive Choice on Battery
- Ignition Problems MSD Cap Please Help
- Headlight Delima
- Just bought a USDM foglight button and harness but will it work?
- to all es tuning oval muffler owners
- Seems like my oil is burning....
- will EF hasport b series mounts work in 92-93 da obd1 integra
- obd1 + cable to hydro conversion.
- gsr rear panels in LS
- help installing a 3rd brake light
- 2001 integra spoiler brake light unpluged how do i plug it back in
- Difference between Recaro SRD and Speed...
- What's the difference between OBD0 and OBD?
- da axles questions
- I just got a new teg (95 rs)
- look for that turbo muff
- Help. installed new MC and pedal sinks only when car is on.
- hid kits?
- integra ls w typer swap pull right under acceleration and left under braking
- Right front suspension squeak?
- popping noise braking = steering rack cylinder end replacement
- Volk te37's?
- b17 manifold V.S. b18c1 manifold, Are the bolt patterns different?
- whats more effective
- auto to manual swap...almost done..
- dc dash into a da????
- 3rd gear grinds
- 1990-1993 headlights in to 97 teg.
- CAR STOLEN IN FULLERTON in Orange County
- older vs newer
- please help, fuel/ vacuum lines off of intake mani.
- Complete OEM front end?
- B16 swap on 2001 integra..
- Autozone said o2 sensor or cat???
- Ob2 Obd1 Oil Pump Question
- for all you JDM ITR front end people
- warmed up motor and still 1500 rpms????
- OMG CAR DIED HELP!!!
- 2000 GSR Just rebuilt
- JDM conversion problem
- New to the GSR world
- idle screw won't turn???
- B-series oil pan
- Stock GSR fuel pump
- shottin for 650+whp
- HELP how to install cf roof cap
- GS-R Intake Manifold & Throttle Body Tubing
- Bouncing temperature on when i drive
- my baby killed by a pt cruiser.. =/
- Tire help
- Engine cannot rev pass 4000 rpms?
- cv axle with abs
- 91 integra. project soon.
- cat-back eshausts
- quick question on ls vtec
- Possible timing problem?
- E Brake light pops on when i shift.
- Is that a RHD DC2???
- B18b
- Painting Gauge Needles
- Clutch problem NEED HELP!
- Cluster removal on DA
- i have a thumping noise when i accelerate. can anyone tell me what it could be?
- Color Grey Chart
