View Full Version : Acura Integra
- post pics of ur white teg or ne teg 98-01 wit wheels
- anyone got any ideas for a good, deep sounding, kinda quiet exhaust for my GSR?
- Relatively new to the forum, here is my teg.
- Can you read me..
- need help findind rhd DA
- STOLEN TEG in san jose
- Someone help please...Identify this ecu for me, I just bought it.
- 91 integra LS for sale
- what block would you go with on a gsr head ?????????????
- EVO VIII recaros in an integra?
- second car?
- steel valves?
- someone help please!
- will da fit civic 89
- I'm new, just wanted to say hello........"Hello"
- damn new headers are ruined!?
- will hids fit?
- Whats the difference between OBDI and OBDII
- DC2 SiR-G Fog Light
- Turbo or all motor
- Removing the air conditioner?
- 94 GS-R Temp Guage Concerns - Help Me Help A Friend
- water leaking out of muffler with white smoke....
- a GSR type S swap any sugesstions
- 97 gsr in a prelude
- droppin weight out of my gsr...
- Question about my JDM ECU with VAFC.
- valve seal retainer clearance issue!!!!!
- Cable Tranny help
- New to HT got a few ?'s
- Those with a DC JDM ITR 4-1 header
- Another nOOb
- OEM Rear Valance Installation...DIY Hardware?
- Pic Request: DA's With APEXi World Sport
- Shifting into reverse when driving in 4th gear
- Relay location
- 94 Integra wheel offset
- Hi-Flow Catalytic Cat Converter question or OEM
- clamp load rating for clutch
- scratching noise????
- 94-97 Integra ABS REMOVAL, help!
- MSD Mounting Question
- AXEL Question!!!
- Done installing my LS/VTEC
- New Wheel Pics: Konig Next / Prada Spec2 205/40/17
- Need help?
- 94-97 USDM headlights vrs JDM
- Need help with Set-up
- mugen lip for SALE!!! $80
- 13-14 second gsr? n/a
- GAB coilovers
- Do they sell front stock looking *oem* honda emblems for integras?
- How hard is it to replace a radiator?
- Grille-Tech Grilles
- gsr head problem
- Advice needed to make 300hp on JRSC setup!!
- primary o2 sensor question
- ECU's Pro guys take a look?
- Got into an accident with the Acura
- gsr problems
- 2 b20 questions in a 92 integra
- b16 in a teg
- JDM front end question
- Will 2000 Ls headers fit 1997 Gsr???
- Can a secondary O2 Sensor be used as a Primary?
- Warrenty on O2 Sensors? If installed like a few months ago?
- Gasket question
- Brake Boosters, Master Cylinders, what fits, what doesnt, ABS REMOVAL *pictures*
- Fuel Problem maybe?
- OK now that everyone posted their teg pics...which of you are from Jacksonville FL
- Built B18A, any advise?
- Broken Powdercoat/Rust on springs
- integ 2000: change automatic transmission filter and fluid
- integra 2000: moon roof gets stuck in cold weather...
- fail smog. What needs to be done?
- Throttle Body Plug?
- Help farmboy out with cylinder heads
- Pic Request! - DC2 ( silver ) with Circuit 8 Full Royal Sports Bronze
- Just got new clutch and sounds HORRIBLE!!
- DA Pics, whos got some?
- Cam question?
- tranny swap???????
- How do you know when your tranny is dying?
- new to honda -tech but not forums
- 98+ swap
- White smoke coming out of muffler...
- Upgraded distributor?
- RESONANT FREQUENCY
- ques! HOW do i tune a aftermarket intake manifold for my gsr
- What brand of manifold and downpipe let me keep A/C in integra GSR?
- Crazy question but is anyone runnin a b16a in there DC2
- Hazard Light Question?
- 160,000km maintainance, what's actually necessary and whats not?
- blown head gasket???...
- STOLEN RED GSR
- Jdm Front conversion ????
- Help with JDM GSR Swap ECU Error Codes 71-74
- Good deal on THIS GSR?
- lookin for a used trottle-body for my intek-manifold
- my gf's integra wont start unless.....
- ls vtec
- would a 94-01 acura integra strut bar fit on my 91 LS?
- ls skunk2 bogging need help
- old DA
- Gains of a Type R TB Over Stock GSr
- Anyone has picture on 1994+ integ with eibach sportlines drop?
- 89 crx springs on a da?
- Budget Five lug
- Itr cams into a b16
- mivec vs. vvtl-i vs. vtec
- RS*R EXHAUST
- turbo
- Integra LS Front Sway Bar Size?
- VTEC
- All motor, keep ls or swap?
- What model is a DB7?
- So my ball joint broke on the highway tonight (56K go away)
- Turn Signal won't cancel
- lights
- JDM PAINT
- JDM Front Clip
- need help instllng AEM pulley kit ???
- 94 integra abs removal (searched w/ no answers)
- Stereo Wiring
- PLease help me fast
- Difference 'tween cheapy and name brand filter...
- water collecting in rear passenger side floor mats and puddle in trunk. N.E. Quick fixes
- Need some help
- how to get plastic cover
- Link to the how to protect your Integra from being stolen thread???v (searched a bunch)
- Header Question
- After compression check car isn't starting, no spark
- 15" rotas or 16"
- JDM Cluster, Hearder, Chipped ECU.
- Help fixing door handle.
- Post pics of YOUR gen 2 teg, NO COMMENTARY ONLY PICS
- jdm one piece head light wireing
- Exhaust Question "Searched"
- bad idle
- two part question on b18b head/block swap
- front seat removal?
- DA Exhaust Mani. Differences
- Tranny help in Minneapolis area
- will a gsr or itr throttle body fit on ls motor OBD1
- Obd1 gsr oil pump vs obd2 oil pump
- Question chip related
- Spoon N-1 Compatibility Issue with EK
- JDM ITR steering wheel INSTALL ???
- 94 ls and gsr exhaust same thing?
- Does my ignition coil look shot?
- Ignition timing problem, REALLY NEED HELP!
- Integra running light/ sidemarker? Help
- 2000 LS part question
- anyone know where to find wiring diagrams online?
- JDM ITR Strut Bar
- short ram intake
- Brake Master Cylinder Question???
- Location of prop valve?
- all motor GSR in the high 12's street car
- Need help on detaching the hatch.
- naming your car
- BENT headlights!!!
- GSR cylinder walls
- gsr intake manifold
- Any Ohio Tegs?
- should i reset ecu
- CR/vtec oil problem
- condensation in headlights???
- Exhaust Questions?
- headlight???
- Rear upper tower bar, Rear lower tie bar and ITR Rear sway bar too much?
- Rear upper tower bar, Rear lower tie bar and Sway bar too much?
- >>> Crankshaft pulley bolt removal..
- Is it just me or does my car get dirty too fast??
- Shocks for my 2000 gs
- What Integras are in GT4?
- Gas
- pic request
- GSR ???? HELP!!!
- Swapped 2000 type r cluster with jdm needles and 97 gauges into my 95 gsr gas gauge doesnt work prop
- AWD Integra
- fun fact
- how to install jdm window visors?!?!
- (did a search) idle problem
- Gsr Oil Leak, is it my headgasket???
- where 2 get aftermarket integra 02 sensors?
- pr4(ls) rods on p72(gsr) pistons
- Replica JDM bumpers
- removing sound deadiner from da
- zex T.P.S.
- how to paint the interior
- o2 sensors
- putting a b16 tranny on a ls block
- ~~~~~~~Need to adjust TPS back to factory, what is factory voltage~~~~~~~
- CEL question
- Noob Turbocharging Question...
- GS vs. LS
- Does anyone know how to install MSD Ignition to an Acura Integra GSR?
- For Tune-up, do you go to Acura or somewhere else and how much?
- OBD2 LS Cat...CARB and CA Smog Legal?
- GAHHHHH I just broke one of my brand new gauges
- I hear and feel vtec with aem short ram!!!
- aem intake and skunk 2 manifold
- Razo Gas Pedal
- So Cal storm got my car. Engine dead. help!
- Lighter Flywheel
- Crossmember damage 90 teg
- '91 Integ LS - IM vacuum hose goes nowhere - big pic inside (help!)
- Misfires on 01 GSR engine in EK Chassis
- Avon Tech M500 Tyres
- omni camber kit??
- QUESTION: about oem body kit for 94-97 tegs.
- broken stud on intake manifold. how to replace.
- need pics.
- do i need to switch out all my mods on my ls if iam putting a vtec block on it
- P28 in my gsr ---> Result: Solid CEL
- What size turbo?
- How do you guys think this will look?
- all motor rebuild
- 94-98 tail lights
- AEM CAI Question...DISAPPOINTED!
- hatch wont latch when it rains
- Glove box light wont stays on....
- b16 head or gsr head
- emissions
- trial user???
- Rims (because i can't post it in Wheels section)
- anyone here from fairfield county in CT
- best cams and pulleys??...
- car bogs down in the rain
- question about my engine....
- Anyone know what code this really is P1381, and how much it cost?
- Header for 99 gsr fit 01 gsr?
- my turbo da on ebay
- haveing propblems with tranny
- got the 93 :)
- Stolen red integra...
- any one have vaccum line pics for obd1 gsr integra
- HI NEW GUY HERE
- clutch question?
- vaccum lines
- Bad Compression on LS motor...
- COILOVER QUESTION???
- LCA question
- Torque mount nut snapped, IN THE CHASSIS
- s200 ecu, what does this mean?
- Salvage Title questions
- Part # of Distributor
- Skunk 2 vs toda vs buddy club
- anyone using adjustable springs?
