View Full Version : Acura Integra
- OEM Fog light burnt out... What to replace with?
- 6spd Tranny?
- Anti Lock Light
- apexi coil overs
- Any pics of a scattershield installed?
- Integra86-In need of lowering!
- Stud, bolt arrangement in exhaust/ intake manifolds
- Recommend ECU for following setup
- can somebdoy help? smog related
- Any DA owners with JDM headlights and HIDs?
- Exhaust fumes are noxious! Am I running rich?
- obd1 gsr and ls alternators the same?
- Whats springs do u like best, what would u buy or did buy?
- help: teg leakin coolant..
- 96 Teg SE
- Some more HID pictures....
- HOW COME I CAN'T POST ON ALL FORUMS? IT'S BEEN MORE THAN 15 DAYS!!!
- anybody who's had bad engine mounts....
- is this worth it??
- anyone have a gutted 4dr integra?
- paint side skirts to match burning red pearl color?
- My car is too low... what are some other options?
- intake
- Comptech = Good
- falken azenis
- cat back
- air filter cover removal?
- h22 ina integra
- koni shock owners
- obd2>1
- Need picture of stock GS-R engine bay...
- I searched, but still have a question about badge removal.
- Question about GSR price
- gsr rims
- Bitch Pin-Steering column Size--
- "Decent" exhaust for a GSR Sedan
- RSX shift nob on GSR
- WTF stupid blinker
- maintenance required light
- Tanabe Ultra Racing Medallion
- 2nd gen B18a block and head??????
- 2-good deals..which one better candidate
- just ran straight header on built gsr
- Does anyone know if an LS MSD cap will fit GSR?????
- Apexi N1 on GS-R sedan??
- RS pwr lock conversion
- oil leak on the oil pan is it dooable at home
- anyone who has changed their clutch on an integra .......
- wierd sound when driving
- good tuning shop in Atlanta, GA
- car prices?
- gsr getting old
- alternater
- i need a cat that will fit gsr sedan with i/h/e
- Cruise Control button for Nitrous Activation?
- rattle from catalytic converter ?
- Headlight fuse problem.
- Tranny Mount Help
- RS-R
- hmo
- Boosting my 95 LS
- problem with wiring o2 sensor!!
- Need to know how to wire JDM Front...Fogs.
- hoooray for weight reduction
- CAR WASH
- SIlencer
- Tranny Problem
- Which Cams would you recommend for me?`
- Wondering what 1/4 mile times you are getting out of 92-93 gsr?
- how fast with this setup?
- ITR swaybar endlinks revisited, how does this look?
- getting my ITR lip today... what part #'s do I need for install?
- will a 96-00 civic lower tie bar fit 98-00 integra?
- Outer transmission housing
- Need Integra Info.
- srr sway-tie bar combo
- IntegraV6 86
- Where to buy Mugen Knock off DC2 spoiler??
- Seattle area: car thefts common?
- Need help with Idle Control Valve
- JDM Type R header
- SEVERAL QUESTIONS for a LS-SE
- Phelonic Spacers
- Off idle stumble.WTF?
- Can i swap GReddy Gsr axle back for 5zigen LS Axle back ??
- look at these cams. (ITR?)
- bore my 1.8 to a 2.0 liter
- Check your tire pressure!!
- short shifter: single bend vs dual bend
- Give me an opinion guys...
- help with cam and cam gear
- Header
- need help on LS and H22
- Problem diagnosis
- Service Manual for 1990 Integra
- Installing Rear Bumper
- In-take for GS-R
- vis cf lip for 94-97 integra fit jdm front conversions?
- ACT stage 1 Clutch
- Spark plug question
- What Oil am I supposed to be using (Yes I searched)
- code 420 can anyone help with remedy?
- Buying a used JRSC need help if good condition?
- rpiracing.com
- Resetting ECU
- I'm haveing problems with occasional starting problems
- is it easy to adjust clutch?
- Rehoning Cylinder Walls
- what to do when you hit 40,000 miles
- 02 simulator sensor????????? where can i find
- ls/vtec, ls vtec, b18b (search friendly) how to guide
- got a pic?
- Post a pic of front ABS sensor PLEASE!!
- gsr head?
- Gutting cat converter
- I really really need your help with my gsr engine!!
- best rpm to shift b18c
- Wire diagram??? HELP Kill switch help. doing it for a freind
- piping size
- please verify that type R oil pump will fit on LS engine
- lower control arm bolt
- cats on its way out...
- code 43 please help!
- hey teg heads, p72 question
- will i run faster after my car timing is tuned
- Need Header suggestion
- header?
- no horn and srs light is on
- Honda Inspire (TL) front calipers, will they work?
- such thing as a bad street spark plug
- Do I need to replace washer after tranny fluid change?
- Rebuild Time what to do?
- ls si race
- Dash light flckers....
- Help SRS
- What should I get?
- Ever wonder "where was my brain?" (story)
- Size of Integra Axels for a swap
- Whats better GSR or B16 tranny on an LS?
- Best spark plug for 94-97 teg LS?
- Factory Radio Pouch w/ door
- Buying a complete B18c5 swap ?
- Tips on cleaning inside of headlights?
- I'm new on Intgera so I need help
- oil burning smell?
- Charcoal Cannister
- B18C1 hesitation
- JDM ITR Rear Sway Bar (23mm) --> 94 GSR
- clutch :*( HELP
- H22 in a Teg?
- What should i do to my car to prepare for a 6 hour road trip?
- rattling from tranny?
- Vis carbon fiber spoon knockoff lip for jdm front conversions
- oem type R vs cai...feedback
- HID for 2000 GSR
- Which struts/shocks are better? ITR or KYB GR2's?
- Best headers & Cats out..
- shift light
- ANY GOOD HONDA TUNING SHOPS IN CONNECTICUT/MASS AREA ?
- DA jdm 1 piece headlights
- cams
- throttle tuned
- is there a such thing as a 92-93 obd1??
- skunk2 install review.
- spoon calipers on a gsr??
- New header for my teggy!
- popping noise ??????
- Is this a good price for a clutch?
- JDM Integra Fog Install? HELP!
- new paint questions?
- how do i?
- AEM V2 Users
- Aftermarket horns.... whos got them and which ones?
- Urgent Help needed
- Need an easy to install gauge....
- Starter Contacts
- injectors
- Oxidation on 94/95 Integras.
- Has anybody ever had bad luck with GM synchro or regret using it?
- JDMshit.com high flow (race?) cat. converter??
- OBD2 engine harness on OBD1 car
- USDM 94 GSR Cat..........SIMPLE QUESTION!
- ****B16 piston in LS motor....search has too many wrong info
- anyone have the tanabe Pro S-OCII's yet???
- header question
- Automatic Transmission shifting a little hard
- How do you clean a Spoon Air Filter?
- MagnaFlow Resonator....
- How big of a shot NITROUS can I run on a stock GSR motor?
- 98 Auto Test Pipe??
- b18b to spoon b18c spec s has anyone done this engine swap
- so my car got stolen tuesday night at menlo mall
- Where is a good place to buy those rubber caps for brake bleed valves?
- plugs for nos kit
- broke bolt in tranny casing (one of the mounts).. will i be ok?
- wiring
- thin head gasket question....
- B18b Versus b18a and b20
- Those w/ Trevor's Phillips HID kit, adapter harness problems?
- my motor is in 1000 pieces!
- what is wrong with this.
- syncros are out... how hard is it to fix?
- b18c1 headgasket help...
- Buddy Club Exhaust..
- teg people i need help
- how to remove power steering on a 93 ls
- HELP! My B18C bogs!!
- dual stage vs. single stage VTEC
- would anyone be interested in a honda-tech.com t-shirt group buy?
- quick b20 into teg question
- such thing as leaking head gasket on gsr?
- v-tec supercharge or turbocharge?
- Is my ingtera messed up or is it just slow
- SKUNK 2 VALVE SPRINGS/RETAINERS
- B18A1
- Where is the tranny mount on the 5-speed 90 integra?
- ------> BOLT BROKE on Rear Lower Control Arm.. Now What??
- gsr interior?
- how fast u think i am?
- just wondering go turbo or all motor
- best buy won't install remote start on my alarm becuz I'm 5 spd, wtf?
- Installing JDM OEM Fogs on DC2.
- ls/vtec
- A gsr, with intake, and exaust.. 1/4?
- What can I use to clean my AEM filter?
- ls turbo setup
- lower control arm bolts for integra
- Wondering on worth of my teg'
- engine change in the 94-01 integra models (stock)?
- 4th gen prelude front end on 98 ls?
- Spoon Style Mirrors in carbon fiber...
- Skunk2 Mega Power vs Apexi N1 exhaust ( 95 GSR sedan )
- Question about STATE INSPECTION.
- Building up a GSR for turbo or all motor
- what sensors are on a obd2 gsr IM?
- Picture of front ABS sensor?
- Clunking metal sound inside of rim/tire?
- OBD0 91 Integra Radiator Fan Control
- b16a or b18c1?
- Car broken into and *almost* stolen!!!
- Axle back exhaust ???
- Think I could File for a Total?
- abs problems
- ?Convert automatic obd1-p28 ecu to 5 speed?
- y'all seen the new AEBS gsr IM dyno sheets yet?
- is this GSR worth the asking price?
- Code 22 after VAFC install....
- With all the thieves out there is it WORTH having an Integra? My story inside =(
- gear ratio
- tire Q: stock 15" rim with yokohoma avs es100 sizing
