View Full Version : Acura Integra
- XTD Race Clutch from ebay seller Aimcoclutch--my experience
- Exhaust fitment
- Turbo Integra Questions
- 90-93 integra BB/MC question.....
- *******check this shit out********flywheel********please*********
- master brake cylinder...are 1994's and 1995's the same?
- hondata
- Exedy Stage 1
- GSR tranny and LS Tranny
- Looking for a new Minneapolis MN *** mechanic & tuner ***
- Fogging in JDM 1 Peice headlights.
- Ignition trouble.
- Motor swap question, need answer fast.
- How to check for original Engine???!??!
- How to take out the clock on a 2000 gs.
- ls nitrous time slips
- re-building a teg,would these 2 harnesses fit?
- car cover for integra?
- Trouble in 2nd gear
- track time gsr
- Horse power
- jdm front lip
- Lip
- My First Car
- to rebuild or not to rebuild my tranny
- hello honda tech im new!!!! need the 411 on stuff your car locations and whats hot and whats not
- Whoah! weird problem with electical power
- more horsepower??
- need to buy ls cable tranny
- rotor fitment
- gsr brakes
- JDM B16A --Power Steering Belt......
- Will a 90-91 Integra trunk hatch fit correctly on my 92 Integra???
- DA Power Window Trobles!!
- Will comptech icebox fit a non-comptech intake?
- ls/vtec or just straight ls
- Turbo gsr set up. What cams to get?
- gauge lights light up when i hit the brakes
- parts
- question plz
- Kill Switch
- A/C Belt install: now clicking noise???????????????????
- DA Armrest
- Some questions to all my 4 door owners,.
- Which will be the best upgrade to my bottom end??
- O2 Sensor Wiring Diagram Question
- 4 door integra rear section / EG
- Anyone use National Auto Transport to ship a car??
- dipstick question....
- how to paint taillights red
- trannie problems
- Recc. Headers
- Online OEM parts source - is Delray Acura ok?
- SIDE SKIRTS
- Decisions...
- LS SWAP
- ITR Wheel Hub Conversion
- Can the rear lense and turn signal split apart with oven trick like headlights for hid retrofit...?
- im lookin for sombody to do a hidro tranny conversin to my 91 integra
- Ricey!!!!???? Or no
- Opposite of poor mans type-r!!
- Recomanded things for cold air intake
- jdm itr ecu ????
- Can power doors work on my 90 ls integra manual ones.
- Leak down test
- AEM cold air intake
- torque spec help please- ball joints, tie rod and spindle nut.
- Which oil pump to use?
- how to remove windshield wiper motor cover ?
- How to: Remove ABS Module?
- Rewiring ground wires
- cleaning recaros
- jdm front?
- i've got a situation
- b16 in a 91 integra
- 9006 conversion?
- pe3 pistons in a ls or b20 block???
- clutch bearing help need!
- off topic: who owns the silver/gray 4dr turbo in Mclean VA???
- Timing
- Help Rhode Island peeps!
- Clutch has hella air in it when i step on it & wont go in gear?!
- How much would you say my car is worth? Pics Inside
- Buying Apex'i World Sport 2 universal, is the outlet offset to the left, right, or is it in the cent
- Radiator questions? pls help
- 94-97 orange bumper lights?
- LS Turbo Fuel Management questions.
- Skunk2 IM vacuum help
- integra ls in DFW area
- Color of HID bulbs for JDM HID headlights
- Very confused about wiring...please help
- What exhaust wont sound ricey and LOUD on an integra LS
- ***NEED INFO***
- omni coil overs work on DA and DC ?
- Angel Eyes!
- OBD 2 chip?
- Question about an arguement a friend and I had.
- Buy a new tranny or get mine rebuilt?
- car died tonight
- vtech controller?
- Automatic trans question
- New Full Catback Questions
- front sway bar?
- Rim size
- Carbon Coated Syncrhos
- what coil overs are a good deal for DAs ?
- Cam Gear Question?
- gsr blades and other gsr inquiries
- HELP! something about the new radiator
- can't idle on its own
- suspension help!!
- dash lights keep going out
- stock acura swap into b20
- NEED ADVICE!!!
- Need Some help with my turbo
- need help
- NX fogger! Is anyone running a 100 shot on stock internals.
- where can i get a good radiator for my gsr
- Big Tranny Question no one seems to be able to answer yet...
- LS-Turbos what plugs are you using?
- Skunk2 IM GSR Install
- gsr short shifter
- New, more questions
- breaks squeeking and car smalls..
- Motor mounts for DA?
- Boost
- Help!!! Soft Brakes
- Wheel bearing removal?
- headlight blowing
- Looking to buy an integra, couple questions
- Wouldn't mind any help..
- buying a turbo? wg? bov? manifold? intercooler?
- Power door lock relacation...
- brake problems....
- loose clutch springs
- Setup with Rocket m22s and JDM ITR pistons
- ls vtec question
- 91 GS Engine Missing
- B18A B18B Gaskets
- fuel pressure guage
- da gsr pic request
- Light Flickering
- 96 integra GSR stolen 6/21/05
- 17x7 +40 215/40/17 rubbing issue
- stock integra
- camber kit and suspension on gsr
- question for all you HT peeps about jdm front end
- CANT MAKE UP MIND!!!
- Oil pressure relief valve
- quiafe instaill question
- Width of an Integra?
- Anyone have rims 8'' or wider on their teg?
- vtec heads?
- whats the website for going turbo ?
- cl headlight conversion question
- da rims on dc?
- Crashed my teg today :( Think its fixable? ::56k good luck::
- trannie question???
- Clutch Decision
- Battery and catalic lights
- Adjusting clutch pedal freeplay
- USDM Integra Type R Transmission Install A.k.a.: Another pointless technical picture thread!
- JDM integra front clip parts:
- Some Questions about my new ls/vtec
- Vehivle Speed Sensor Question....
- Question: will this fit?!
- FS: King Engine Bearings (NIB) B18C [ PIX ]
- omnipower + brake lines
- Overheating problems, help!!
- Looking For G3 Powered Integra
- LSVTEC?/B20 CRVTEC..WHICH WOULD YOU DO AND WHY..WHATS THE PURPOSE FOR BUILDING A CRVTEC?ADVANTAGES O
- almost done turbo. block heater in the way. HELP!
- Stock Cat Length
- Moaning noise from front end?
- '95 GSR OBD1 ?
- how do i do this
- alternator? searched...
- need new tires, best place to order them online?
- swap INFO
- Wiring issue with Gsr to Rs swap...
- Spring Shop?
- electrical gremlins help please!!!!!
- Integra H22a Swap?
- who's running a JRCS set up? and whats your best time? and dnt be"SHY" to make comments
- BOV??
- VTEC question....
- electronic super chargers
- fan runs after carwash
- Budget all motor LS/vtec
- Are the stock GSR cams?
- What cars did you have before your Integra?
- want to buy or trade ,i need a b16 dohc vtec ,or a gsr head
- does map sensor have a fuse? im serious
- What makes Honda PS fluid different than generic? Seems like this is the answer
- compression test results.. #3 cylinder bad??
- fans do not run
- need help with my new setup and new pieces !!! important !!!
- what you guys think a reasonable price for a 1994 gsr is?
- need a gsr tranny
- Turbonator.
- ***Rear brake problems--HELP
- swapping swaybars? does the R fit the GSR or do you need application specific endlinks?
- Faulty 02
- 90-93 XSI door panel sticker...
- After basic bolt ons --Car running Rich.
- Can a Headgasket leak oil?
- Built LS block for LSVTEC
- power window!
- my cold air intake is whistling at 3000 rpm why?
- Apexi Exhausts question
- what size is the DB projectors?
- vafc2????
- will a rear strut bar from a DC/EG fit a DA?
- strange strut question
- ls intake install
- humming noise from passenger front wheel
- air filter?
- obd2 diagram needed
- second gen teg steering problems
- Exhaust problem.
- Softer or harder rates?
- The turbo teg is alive
- MONZA EXHAUST
- IM Sensors LS vs GSR
- Timing belt lose??
- anyone lookin for an integra??
- o2 sensor rubbing on shift linkage, help desired
- MAP sensor vacuum hookups for DA teg
- Help! Carfax Please!!!!
- Custom Turbo Questions.
- JDM third brake light
- jdm adjustable fpr
- Motor Bracket question
- What to do next to my GSR 97??? help plz
- TEIN SS
- stripped shifter stabilizer bolt
- RSX Steering wheel
- will b18a1 ls motor go in a 89 civic hatch???
- getting new hood, color codes?
- Car sometimes idles down and cuts off.
- need help w/ my lug nuts?
- ** Want to see trans build ***
- Exhaust Q for the Dc2
- MSD pro cap
- Exhaust/Header/Cat Question
- OEM Short Shifter
- Hows these compression numbers look?
- SEA FOAM
- 94 ls integra auto changing to 5spd question?
- Brake Pad Question?
