View Full Version : Acura Integra
- Corner Light Issue
- Placement of a jdm jaf badge on 96 integra
- Window washer tank
- B18c timing off after clutch replacement
- B20b motor questions?
- 95 Acura Integra LS
- 93 integra has abs but no abs light on dash?
- (relatively) cheap genuine honda gs-r oil pan
- Acura Integra 89 Questions
- Wheel Help!
- B20b swap into 98 gsr
- Possible timing off?
- What’s the difference between B20b and B20z
- B16 td-22u dizzy trouble
- Front Bumper
- key wont turn at all
- JDM Swap - OBD1 Catalytic converter compatability
- GSR OBD2+ OBD1 PARTS USED TOGETHER... HELP
- Reverse popping out of gear, Please Help!
- 90 integra lights
- i have a b16a motor with idle problem
- Fuse box left side under dash
- B18b1 rebuilt missing hardware
- Timing Belt parts
- LOW REV PROBLEM
- DC4 Track/Fun Build
- Cel code 14, help please
- 2001 gsr do it or not
- Exhaust manifold gsr 2001
- Integra Auto to manual
- Accord CL1 Spoiler on a 1994 Integra GS (Bug eye Integra)
- Error code on instrutement display
- No crank no start 1994 Acura Integra gsr 5 spd
- Should I get new bumpers or repaint factory bumpers for my integra?
- Limp mode troubleshooting/help
- Where to begin with a '99 Integra LS?
- Any possible way to use USDM Radiator support for the itr jdm front conversion?
- felpro permadry oil pan gasket
- about repair kit
- Automatic integra won't accelerate when In D.
- Integra bog issue.
- 95 Acura Integra LS 5 speed Starter not engaging with Key switch
- No power at Starter. Will not start. Everything else is good
- 1991 DA automatic seat belt problem
- Loud ticking/chatter on cold starts
- Straight pipe
- 01 GS suspension rebuild, go ITR suspenion?
- Does any one know where to get a power chamber style intake for 96gsr
- Can someone tell me what this noise is?
- Hood bra
- 01 Integra floormats & carpet
- Oh so sweet race car build writeup
- Oil light
- Fortune Auto 500 Series Coilover Review
- Best place to buy oem tune parts?
- Looking at first Integra - 94 gsr
- How much coolant do I need?
- $200 beater teg build
- Integra sedan wheel fitment
- Integra type r swap into ls automatic
- DB7 “Budget” Build Thread
- Exhaust help me determine my GSR exhaust
- Changing stereo ground to reduce interference from cig-lighter charger?
- 3000 RPM with check engine light
- Gsr Supertech spring & retainer ??? Valve lapping
- Need help with exhaust 97 Integra GSR!
- B18C1 Skunk2 Intake Manifold Plumbing
- B18A1 Coolant Pipe
- Need help Supertech Springs
- 1995 Integra Potential buyer
- Integra Hasn't Been Started in Over a Year
- B18C1 Thermostat case Compatibility
- Race wiring - No distributor spark
- Assistance request: 94 Integra B20B. Multiple issues w/ chipped ECU, Harness, etc
- Clunk noise and intermiten pulls when turning
- Header leak? Or wd40?
- 2000 boosted gsr with itr head and trans.
- My db1 92 integra problem, help please
- distributor dies after a week and a half
- BRAKE LINE SIZE 2001 ACURA INTEGR se
- Fel-Pel permadry oil pan gasket review?
- [97 GS] Help! Dropped a tank of some sort?!
- GSR Swap Smoking
- Engine stalls/dies on idle when warm
- B18B1 Oil leak Help please!
- B20v crank but no start
- 95 integra bogs out after launch
- GSR head what sensor hole is this?
- Acura RL 4 Pot Calipers On Integra
- Strange Cold Start Problem
- engine misfire
- Valve springs b18b1
- Ideas ?
- Turbo setups (200-215hp) for stock daily B18b1?
- Replace head gasket at timing
- DIY Changing Blower motor resistor (Vid Inside)
- Ghost - 95 GSR Trackday Build
- Da integra help
- Troubleshooting AC system
- I got a rod knock
- Integra won't fire up
- Acura Integra project
- GSR Trans ROUGH
- 1995 acura integra b18 leaking oil (new HG, new VCG)
- B20 vtec
- Annoying squeal help.
- 1999 Acura Integra Misfire
- 2000 Integra LS - P0141 code that I cannot diagnose per the FSM - HELP!
- I'm.lost. so D16A1 in my 1989 Acura Integra . Hatch. 2 door 5 speed. What transmissi
- need help buying struts
- Gsr b18c teggy cuts out at about 2lbs???
- 1990 acura integra stalls
- Power steering rattle?
- NEED HELP !!! ‼️‼️‼️ SWAP COMING‼️‼️
- Gsr trans with typeR motor
- Brake Lights stuck on
- Help Tracing a Wire
- GSR Air Cleaner Tube Replace
- Injector Wiring
- Trans problem, please help asap
- B18b1 timing belt troubles
- Could it be a bad fuel pump?
- HID Retrofit in a '95 Integra
- 97 Acura Integra Gsr Help!!
- EGR valve
- Keep my B20b or B18a1
- Rear passenger camber
- Excessive egine vibration?
- Rear Mid Engine AWD V8 1990 Integra Build
- 2000 Integra Sedan B18C JDM swap
- Anyone replace seat belts at dealership lately for free?
- abs sensor
- changing brake line
- B17a powerband issue.
- 2000 Acura Integra gs
- Honda Relay Part
- Am i in the right place? 92 honda integra
- Jdm da6 suspension trouble
- B20vtec top end power band issue
- Radiator fan problem
- Front end swap
- DA Integra obd0 mpfi to dual carb swap?
- GSR blade 2018 price tag ???
- Hey guys new here. Need insight on an intermittent chatter
- Crank sensor? **Need help**
- what is this part
- Automatic 95 Acura Integra LS or SE type of oi oil do I use I live in Washington
- wiring difference
- Cooling system???
- 5volts going to yellow wire on ignition switch = key off..
- Vented moonroofs interchangeable with sliding only moonroofs?
- 1999 Integra OBD2A IAB A26 No Pin
- High mileage service recommendations, 180k+
- Need Help With Replacing Vapor Canister and Valve
- CEL on after hard pull.
- Fuel Pump NOT Priming - 95 Integra LS Special with Swap
- A/C Bracket issues? on b16 swap to 00 Integra
- How To: One Way of Using OEM Fuel Pump Hanger Upgraded Pump 10 Gauge Wire/Relay
- Exhaust work
- AC Compressor not kicking on
- B20b swap
- DYNO - Boosted LSVTEC
- 1991 transmission mount removal
- Front clip conversions
- cv joint renewal advice....
- 2000 Acura Integra ECM wiring harness Hacked!
- Door Jam Tag: Missing Information
- Noob Need Help
- 95 Acura Integra Idle Issue
- b18a2 'vtec like' noise
- Acura Integra 94 -01
- What year integra should I get?
- 1996 Acura Integra SE with gsr b18c1
- REPLACEMENT /DC2 Quarter Panels
- B20b high comp with gsr head, safest way to turbo.
- 89 Integra Cylinder Position Sensor
- distributor part
- Teg from hell...
- Windshield of a 95 Acura Integra LS
- Shift linkage bushings
- Timing Belt is due.
- B20 auto integra
- What causes this issue?
- High idle problem
- Extremely low compression?!
- 93 Integra GS-R DB2 #270040 Build Thread
- Removing Ignition Rotor
- Refrigerant for 96 Integra
- 01 integra GS-R dies when I hit the accelerater
- b18a1 npr standard piston rings gap
- plug soak
- Integra swap
- High idle
- Integra CEL help
- Lsv turbo want 350 to 400hp
- Diagnosing this problem from rear passenger wheel. Wheel won't free spin
- Car Theft Help?? 91 Teg
- Car jerks when switching gears, disengaging clutch
- Location of ECT Sensor 2001 Integra
- Car struttering in half throttle
- Dc1 Integra headake!!!!!!
- Integra engine headache
- ISB/Throwout Bearing/Grinding sound?
- Engine Code HELP
- TPS sensor Voltage Reading high
- Bought it Friday, blew it up Monday. Now let’s make it cool
- Horn fuse
- What Head is this? Type r or b16
- 94 Integra rs. Cranks but won’t start...
- Integra DB9 lower control arm fit Integra DA9
- started the car the other day had to replace the starter. now its doing it again
- B20Z swap into 97 DA
- 2000 Integra New Key/Programming
- 1991 Integra Passenger seat belt won't go up.
- Seat belt won't go up in my 1991 Integra.
- HELP! Cowl Retainers/nuts/clips part numbers - 1991 Integra sedan
- 97 Integra brake clearance issues
- Acura integra V6 J35 swap few issues...needing guidance.
- Am I screwed?
- 2000 Integra Coolant Leak!!!
- Too many backfires
- Ecu fuse keeps blowing!! Can someone please help me
- 1999 Integra LS non-vtec 1.8L DOHC fuel issues
- Why does my gas go by faster
- 2000 Integra Electrical issues
- Where is the Integra "piston soak" thread?
- Steering Shaking - ADHD friendly read
- No start issue after setting distributor timing
- Non starting issue.
- Where does this hose connect to?
- Integra issues
- G2 Teg Killing ECU's
- Need Motor swap help!!
- 2000 Acura integra
- Charles Lopez seems to be "Missing a belt".
- Does anyone know where I can find another one of these fuel sending unit floats
- Crank Fluctuation Sensor needed?
- Need quick answer- 91 integra
- can i change my door locks to something other than honda make, car keeps being broke
- Help!!1990 acura integra
- Can it be fixed? got rear ended yesterday.
- Question about DC header
- From Ls to Gsr coolant piping help!
- Is my tuning correct?
- my acura 95 wont start
- DC4_Dad’s 1997 Integra Build Thread
- Coolant Temp sender mating plug
- Click when hand cranking
- Aftermarket torque mount bracket?
