View Full Version : Acura Integra
- how do I remove the center cap off my 94 GSR rims?
- Exhaust?
- Syncro mesh ???
- anybody with turbo G2 Integras? what kinda times are you doing?
- 81.25mm vs. 84.5mm and passing smog???
- Any peeps had front pain damage and had the front bumber repainted? pics?
- What's the name of the 1994-1995 Integra Red?
- Question for those of you with 93 GSR motors and trannies.
- Timing Question
- B-Series Gear Swapping
- are crower 402's good for 93 ls?
- suspension trade mine for stock plus cash
- local gsr tranny swap fast!!!
- About what should I run with these mods??
- Check out my clubs website
- Changing Fule Filter??
- Autocross a teg?
- what size injector and ecu to run on this na setup
- ACT 6 puck help!!
- Fuel me
- 1/4 time question?
- More boring questions about air filters...
- Electrical Questions.
- Possible Group Buy: JDM TYPE R Steering Wheel SRS
- What trannies do the B17a have, and the B18a?
- pros/cons of skunk2 manifold on gsr??
- Best non-synthetic oil?
- Motor Flush?
- rear wiper kit
- Need Engine Swap info
- Define: LS/VTEC.
- 4dr rear strut tower bar
- Hole in the Clear Coat
- skunk2 is looking for a guinea pig 00-01 gsr
- TEIN Super Street Dampers?
- Transmission Conversion
- where are the spark plug gasket located?
- Just bought a 2000 GSR
- strut tower bars
- ls/vtec head gasket question???
- skunk2 on an LS
- ride height differnce after replacing shocks?
- Rear Suspension Problem
- GSR Immobilizer..what was the first year?
- RS*R Help?
- How to tune AEM fuel regulator
- Which Setup For a 92-95 Civic H/B?? GS-R or H22A??
- taking out stock radio out of 95gsr
- What should i do??
- Fujitsubo, Feel's, Backyard Special
- Where can I buy those tiny light bulbs for the dash?
- rattling exhaust noise or something on a LS
- ITR rear sway bar with stock springs and shocks.
- Valve Adjustment
- Camber kits
- Removing valve cover.
- alternator
- Prelude 5 lug?
- MD body shops recomendations...
- Transmission Fluid
- Which Cams should I use?
- 4300K HID?
- Have ?s for those w/ Big Brakes.
- OEM Acura keyless entry/alarm........
- can anyone tell me where to get itr cams cheap on the net?
- tires question: is 225/50/15 too wide on stock gsr rims?
- Oil Catch Can?
- Body ?
- Ok who knows something about the new Tanabe Super Racing medalion
- Clutch tech question
- Sportlines on 98-01 integra?
- Weight of Stock GS-R wheel?
- CARLISLE!!!!!!!!!!!!!!!
- Pros/Cons
- What would my 1/4 times be?
- need alignment after type-r rear sway?
- LS/Vtec or No?
- Do I Need A Collector Flange?
- just installed exedy/cm flywheel
- Will B16A (JDM) cams work in B18A1 Engine?
- really stupid question bout rotating tires
- techies!
- Dyno Charts...
- converting non abs axles to abs..
- NEED ADVICE: Just got my comptech sway bar/ tie bar installed, some concerns and questions..
- DC header install...anyone?
- B20 drop in the integ
- How to install ITR Strut Bar?
- Tanabe G-Medallion or Racing Medalloin?
- Steering wheel cover
- looking for tires!
- VA Autocross....pics!!!
- Anyone know how to remove the rear seat?
- Need help in MN
- HKS Titanium Carbon Fiber Turbo Exhaust on DC2
- im new need help
- Water pump upgrade...do you need to???
- B16A Cams
- Dialing out overlap on cams
- Need B18c1 vacuum line diagram
- shocks for 93 teg?
- What cams you would pick for this set up
- What wire at ECU for O2 sensor
- Brakes
- Bay Area Meet
- leaking tranny fluid..
- all non-vtec owner's
- skunk2 intake manifold on gsr, which TB?
- blizzard + CAI eqipped GSR = fun fun!!
- Pics of my teg. G2.
- Redline MTL review
- Maintaince required light
- Need help on distributor ???
- Alright I/H/E now what???
- My idle solution with Crower 403's
- HELP CLUTCH QUESTIONS
- steering wheel shakes when braking @ high speed
- Borla XS universal muffler with custom piping?
- how hard for transmission swap?
- Tune up.
- Whats the brake upgrade that uses prelude/accord calipers and rotors??
- Cable B-series tranny question
- Taking the GSR out of storage.....
- Do it yourself camber....where does that washer go??
- who totaled their teg??
- WRX test drive: Impressions
- im the new integra brother! please welcome me with open arms...:-P
- oem type r bars on non type-r's??
- best prices on jdm metal front?
- Comptech Springs?? why are they so cheap??
- Tick tick from car
- anyone willing to post Helms instructions on repalcing the cam seal?
- Blew the front right strut, have you tested and found the best?
- Acura Integra VIN decoder
- whats wrong with my motor?
- JDM Headlight Functions?
- JDM Conversion Welding and cutting
- How much should i pay for a OEM JDM Type R Front bumper?
- b20?
- alternate methods on relieving fuel pressure
- Was there a G2 model with OUT a sunroof?
- kg/mm springs??
- funny driving video
- When installing brake pads ( red stuff or Honda grease)?
- Integra Meet in South South Fla!!Palm Beach Area
- Question on fuel lines
- Boston-area Mechanics!! I need help!!!!!
- Brownish parking light problem SOLVED (superwhite users know what i mean)!!!
- type r header
- Another here's my timeslip topic!
- Just realized how cheap the plastic on our cars are
- 70mm Kakimoto R ITR cat back installed on 95 GSR, plus changed brake fluid.
- Stock Intake
- K&N Oil Filter
- WTB : 97 gsr mesh style rims
- Apex N1
- Anyone interested in trading a GSR/SI tranny for LS+$400 in DFW
- which blaster coil to get? 2, 3, or ss?
- Need help on installing itr lip!!!
- ticking after valve adjustment
- yellow bulbs
- Going synthetic After 75k miles
- aem alt&power steering w/unorthodox racing crank pulley combo
- Cam gear tuning and ignition timing? How to do both?
- Car wont start after valve cover removal
- Where can I find the stock relay on 92
- alignment after suspension install question
- Anyone know how to reprogram the factory alarm remote control?
- Remote Starter for Manual Transmission
- adjusting timing - need quick help please!
- Who's using A032R for AutoX?
- Will RSX seats fit in '01 GSR?
- Just installed my springs, what a difference!!
- Just want to say hello
- JRSC
- Apexi RSM wiring for GS/LS ecu
- alarm for my gsr
- ^^Need HeLP with RadiatoR fans^^
- jdm b16a integra ?
- cusco oil catch can
- is it worth swappin my engine?
- QUESTION: GSR distribotor & Valve latch
- Need some Help on Valve Adjustment
- need help. my tach is going mad
- I know what wheel to get.. need help on size!
- jacobs ice pak
- Need Help Quick Please w/spring install!
- Where to buy K&N RU-2820?
- BBK 70MM Throttle Body Install ...cable too short!!!
- Arghh!! Which belt goes where? (Putting together my motor)
- suspension help
- my timeslip...comments? suggestions?
- Dyno tuning in Bay Area?
- My somewhat stealth (quiet) exhuast
- oxidation
- WTB: black integ center console
- 3 Questions for 95 Teg
- Tranny fluid/ Problem need help
- Progressive CO, JIC Magic CO, or Koni Yellow/GC setup?
- How to remove rear seats. Need Urgent Help. TIA
- intake question......not one of those which is the best ones.
- Quick question! Need help asap please~
- need help quick
- Shorty
- How much whp from this setup?
- Rear Brake Problem (92 GSR)
- True/Complete Coilovers.....need help
- MSD install problem
- i need help
- heat shield rattle
- Need some pro help on clutch...plz
- aem big brake kit
- any milano red tegs with carbon hoods?
- does the '96 gsr have a moonroof?
- Are you satisfied with the reliability of your integra?
- apex'i ws pictures
- carbon fiber hood question
- Greddy turbo install instructions
- Whats your favorite tire in the size 205/40/17
- What does GSR stand for
- LS valve cover, which one is PCV valve?
- B16 in 91 Integra
- Friggin wiper anyway!
- OT: look at this......please dont let it be anyones car here!!
- How much tire pressure for 205/45/16?
- gsr vs. itr exhaust diameter
- Which bulbs for integra Hi-Beams
- GS-R four door
- Questions about swapping automatic to manual tranny
- integra wallpapers
- AEM CAI installment
- JDM ITR header....
- how to get rid of annoying brake squeeeeek??
- oil on plugs
- Need some advice .. involves service at a dealer..
- Is there a 02 on the header of 95 GSR??
- Help: Strange noise after installing DC Sports SS 4-1 header
- Which clutch kit to buy?
- B16A2 OBD1 ecu into a 95 gsr.....
- civic fog lights
- not much noise from my CAI?
- Quick/Easy helm manual question!
- just put in new clutch HELP!!
- DC LOWER TIE BAR&COMPTECH SWAY BAR
- Boston area parts shop?
- Seat squeaking..can some tell me how to fix it?
- gsr with b16 head?
- will skunk2 mod'd ecu for 90-91 ls work fine on 93 ls?
- Best Mod that you've done?
- Which would you choose?
