View Full Version : Acura Integra
- For those who have the 92-93 ys1 trannys
- B20 swap to integra won't start!
- 95 integra rs won't crank??
- Are fenders and good the same for 90-93?
- 96 GSR, In Memory Of A Friend
- Vtec oil squirters compatibility
- considering low mileage Integra
- Squeaky clutch problem SOLVED!
- 97 b18b swap in 90 integra
- msd external ignition coil
- Windshield washer bottle line location?
- DC2 build or swap
- car stalling shutting off with electric loads
- B20B identicfication...
- Throttle cable help!
- 200 Hp build help
- 2001 gsr cruise control
- OBD1 Intake Manifold Problem
- B18C2 Experts, help identify this part!
- 01 gsr starter probz
- I think it's gotten to me
- Drying water/condensation in headlight.
- 1998 Integra GSR CEL Swap Related
- Xenocron distributors
- Planning a 1000HP+ GSR Build
- rear part of engine cradle
- 2001 integra gsr water leak
- B20B Swap running lean
- Is there any interest in some near NOS 2nd gen integra seats (90-93)?
- DA JDM 1 piece headlights - rubber boots
- tail lights dont work
- OVerheating , Fan wont come on
- JDM DA5 ZC Carby need help
- 3,500 budget integra ls
- Which OE replacement clutch would you get?
- Motor Acura B18B
- Rattling Sound of Death! H4LP!
- Continuing to Concern Me
- Da exhaust
- erratic idle speed, 2000-1000 rpm, any adjustments??
- j series swap
- Help with bolt coming loose
- Flow master California Questions
- cranks but won't start, anyone have a good trouble tree?
- Ecu question here..
- Looking to buy a gsr, looking for some opinions
- Throttle body
- Integra spindle thread
- b20 bottom end b18b top end
- rebuild timing
- Choosing a Motor....
- 92 integra- power windows work with car off
- Help with Half shaft issue
- 91 battery light on below 2500RPM
- Low compression problems
- 1990 Acura integra Spindels and calipers for a 1990 Honda CRX swap??
- Damper fork, which torque
- 91B18A1 is a fuse on a red wire from battery stock?
- Timing belt replacement.
- Da suspension / Skunk2 / Lower forks need help/advice
- 91 LS 3dr, B18A1, what's belt deflection, new belt
- High oil pressure issue
- Misfiring issues
- What size is the halfshaft nut? 31mm?
- 91 brake bleed order?
- Silver 2001 type r?
- ACL Bearing Questions
- What is this part ?
- Rear control arm lca squeak/popping noise
- '89 Integra RS headlights won't close
- 1996 GSR O2 sensor help!
- Bringing a 1995 Integra back to life. Please help
- '96 Civic sedan B18b runs rich
- db7 suspension help
- Knock sensor harness
- Knock sensor plug
- Question about LS (DC4) seats
- High rpm sputtering?
- GSR dual bend shifter oem bushing?
- Oil missing?
- Map sensor please help!
- Breather Box Bolt
- Aftermarket exhaust to stock headers?
- p0420, primary o2?
- Which coil compressor?
- Aztec 92 gsr
- Broke my front windshield...
- Blueish whit smoke
- '97 Integra fob - one honks one doesn't
- 91 Acura Integra LS
- 1994 Acura Integra RS Build
- Got a 91 Integra LS 3 door... questions
- Good deal on Integra LS?
- Wheel Spacers
- Requirements For Doing k20 with Auto Trans into Integra
- Any Idea What it Would Take?
- Brake slipping?
- I Need help !
- building b18a1
- Gsr condenser fan help
- 1990 Integra condenser fan turns itself on
- New to hondas, ready for a project(progress thread)
- Car sputters at 3k rpm on 1st and 2nd gear
- Hood Scoop Integra?
- What should I use in my transmission?
- hey people need some opinions on what i found in my head today?
- GSR running issues.
- Plans for build
- 96 Integra LS what is this?
- 93 integra fuse problem
- rebuild b16a jdm need to know what haynes manual to buy for specs.
- opinion on this cooling setup for turbo.
- B18b Cam Seal Bolt
- ECT Sensor or Sending Unit?
- Back window visor or wing or nothing on 2001 blue integra
- 98 Integra Maintenance Required (Re-Calibrate) - Reprogram?
- 92 integra ac leak from high pressure switch
- OEM Fuel Lines
- loud valve train 2000 gsr stock rebuilt with 7000 miles
- Oil in Intake Mani
- Weather Strip?
- 5MT guru needed, clutch lever and pedal issues
- Something snapped and car won't t move
- 97 integra Ls/GSR overheating under boost pulled head pics below
- ebay headlight quality better now or before?
- 1993 integra Si Cluster gauges not working
- Jrsc issues
- Need help looking for the other pair
- EVAP canister hook-up - Can't find 3rd hose
- B18a1 axles fit b18b1?
- Engine Replacement in low-mileage 00 GS-R
- 1990 Integra water leaks
- Little mods why my cars parked in the shed
- Help gsr misfires under load
- heater bypass- temp gauge bounces from c to normal
- swapping b18c limp mode
- i need professional advice and opinions please
- 00 integra ls alternator help
- Best Place For Kill Switch
- No tension on clutch lever- DA Integra
- Motor swap
- Turn Signal/Brakelight issue
- Aftermarket shifter question.
- Shock piston moving around in top hat. Knoi yellows
- 99 integra misfire codes
- 97 in a 94 possible?
- 92 integra rs, running really rich
- Weird Idle after cleaning IACV (Video attached)
- Are Integra and civic Obd1&2 icm interchangeable ?
- WTF did I just buy?
- Integra Swap Questions
- Quick header/exhaust question
- Brake lines & fuel lines rusted
- Answer my question?
- B20V ...need help
- AC Pressure Switch
- b18b1 ls head internal questions also acl rod,main bearing questions
- moisture barrier (doors)
- Looking a tubro kit for a b18b1 to do 6-8psi
- Year-Long Rebuild (hopefully)
- Fuel pump issue
- 1992 acura integra right brake Light problem
- How to replace side mirror glass?
- Gsr blinking check engine light
- b20 integra high idle issue
- Question on JDM front end conversion swap
- lsvtec coolant in oil problem
- Trans problems, stumped
- 95 gsr l turbo swap hose valve cover hose questions
- wire help
- What VTEC cyl head do i have!
- Looking for advice on My flood car
- OIL CATCH CAN BUNG SIZE FROM VALVE COVER SIDE TWO FEEDS NO RETURN
- Skunk2's LCA (Lower Control Arm)
- Swap issues
- 1990 acura integra AC help
- Factory Cupholder
- Radiator fan wire?
- IAT sensor has been a pain
- 97Integra LS for 1500? good deal?
- inside the cab wire tuck help? dc2
- No significant decrease in white smoke after valve seals changed
- i just picked up my first project 95 integraNEED HELP!!it has a GSR head b16a block
- obd2 distributor ICM question
- 93 integra gs wont crank, no noise at all
- 95 Integra GSR Speedo Needle stuck at 20 mph? Please help
- Coilover clunk noise- Integra ls 2000
- Budget integra
- Performance improvement
- Can someone please help with this.
- integra not idling help
- integra gsr misfire
- Breaking Down- Integra
- Weird Electrical Issue - Fusebox ignition hot
- Ash's NZ DA8 Xsi Build
- It won't start nor turn over
- Which Swap Is Best For Me
- Help need opinions
- Budget Boosted B18C1
- 92 integra vacuum hose locations?
- Fuel line replacement
- Cel Code 5
- High revving engine in 1991 LS
- someone with a 92 Integra please help me
- LS vtec
- Original db8 turbo build slow
- 92 Integra surging/high idle
- 90 Integra No Spark
- Why swap an LS?
- Countershaft nut...
- Steam/white smoke coming out of exhaust manifold
- Gsr humming at 80 mph
- Integra starting up problem
- 50k mi maintenence for DB8?
- 01 gsr busted ac line
- Fuel lines leaking
- Integra 2000 LS dual alternator setup
- Speedo sits at 50kph while parked?
- fresh build no start,please help!!
- Usdm type r lip?
- Wiper Cowl Removal-G3
- B20B VTEC
- Alignment?
- semi built GSR poor cranking no start electrical issue maybe?
- Can someone help me??
- Integra overheating
- Can someone answer this for me?
- 93 integra rs-r exhaust
- I think my integra keeps over heating..
- DA rear hubs and ARP studs
- Integra harness help
- Boosting my Integra
- Looking for part number on dc2 windshield molding
- 1990 Acura Integra GS will only run on 3 cylinders, is that safe?
- ecu fuse keeps blowing
- B18A1 shutting off randomly while driving...bad ICM?
- Transmission Help
- Rhd swap need help
- How did I mess up my daughter's Type R? Thanks for any recommendations.
- Transmission OIL out of 12mm Linkage support bar bolt
- Starter still clicks after replacing contacts
- P1457 Evap code Related to over filled gas tank? or strickly on the Canister side
- ls or gs-r springs?
- Iacv unplugged?
- help reading spark plugs
- 1990 Acura Integra GS cranking but no start Ignition Coil issue?
- main relay buzz
- 94 gsr idle surging
- Troubleshooting brakes remotely
