View Full Version : Acura Integra
- CEL Code 22 On an LS WTF
- mant req. light came on?
- 99 P72 ecu
- REDLINE OIL "Water Wetter" does it work?
- halo housings
- Apex'i Power Intake fitment...
- WARNING! Car thieves in a 92-95 Civic Hatchback.
- dizzy question ??
- SWEET PY ......Switch back to 17's ???
- GIRL OR BOY?
- Would You Trade A Built B18B1 Turbo For A B18c
- Hidden integra feature?????
- Security Idea - inline fuse
- JDM thin side moldings
- Need Help- Engine Losing Performance
- LS turbo VS LS/VTEC turbo
- Broken steering column nut.. HELP
- My gsr waste too much gas...wtf why??
- A little regular maintanence on the teg + what u think of this caliper paint
- ***How do i know if i have ctr tranny?**** need help
- wat do i do now LOOK HELP..
- exhaust question
- HELLO EVERYONE
- Car stutters in Vtec
- 97 GSR DYNO AT SPEEDQUEST ILLINOIS
- were can i buy rear lip for 94 ls an a 4 door gsr
- ecu question.......
- JDM ITR rear lower control arms on DA?
- Question
- aftermarket moonroof question
- ecu code 45
- integra question.
- Idle problems
- Help with inner tie rod...'93 Teg....pictures!
- where are you guys buying gauge pods from?
- Quick ?... will a 99-01 GSR 4-wire o2 sensor fit on my 94 GSR w/o moddification?
- Come on Guys help me PLEASE!!
- dimension between the screws on type R wing
- I NEED A B16 HEAD CAN ANYONE HELP ME
- it's finally done! my dc2!
- So I threw a couple ABS codes.
- my GReddy SP is dying!!! suggestions?
- skunk2 s1 cams w/ portflow valvesprings and retainers
- jdm b18c1 throttle body???
- WHAT AXELS TO USE?
- first mods to my DA ?
- Proper tire size for 15"wheels?
- Whats a good VTEC engagement point for LS VTEC?
- MY SRS LIGHT IS ON
- B18C idle problems
- AEM intake silicon hose size
- gf's integra has 120k, replace trailing arm bushing??
- want to buy a DC2 teg
- TEIN S-Tech Springs
- catback exhaust
- Q about stock black paint colors between a 96 & 01 Integra
- stupid question
- horns not working
- Ls/Vtec!!!
- Gsr with Type r cams?
- Cam Gears...how much of a difference do they make
- ideal rear camber for daily driving
- Question!!!
- 98+ conversion on 96
- ITR header install?!?
- Matinence Req's Light
- Front crankseal gone so early ?
- STOLEN Optional sideskirt please help
- GSR Supercharged #'s
- ITR suspension or Aftermarket?
- is there a way to test ABS wheel sensors?
- Burning smell?
- Few questions for the expert...
- CEL 43 Fuel supply system and stumbles while cruising
- any B series PCV valve work?
- noise comming from rear wheel
- Itr lip with wtype side skits Anyone seen done?
- stolen integra out in 916 sacramento
- Ls or GSR ?
- washer camber trick
- skunk2 short shifter
- Can't Find Window Visors Anywhere!!!
- JDM front end conversion help
- A few pricing questions from a new member
- is it worth it?
- Question for B18B1 owners w/ Skunk 2 IM....
- Car doesn't like the humidity
- wut needs to be done to complete this swap?
- cams question ??
- S4C tranny, s80 release fork and throwout bearing?
- i wanna turbo my teg
- Anyone know where you can buy ALL amber 94-97 turn signals??..like the 98-01?
- Fueling problem...need an expert...turbocharged car.
- spoiler removal
- KYB AGX adjustable shocks
- QJ2 LSD is out of wat car?
- help my passenger axle snapped!!!
- Question about an all-motor GSR
- question regarding piston compression with GSR head
- main reason to get out of the honda game
- New distributor cap and rotor, and no spark
- Grade of oil for a LS integra?
- ITR Amber Cluster Idea
- ok..need help on cooling problem..
- NEED HELP ON TAKING MY HATCH OFF
- Teg suspension?
- Another Thievery attempt...
- Fuel leak problem??
- noob question about stainless steel......thanks
- dc2 guys with autometer air fuel gauge.... signal wire?
- Having trouble with oil loss
- Need advice with swapping gears into LS tranny
- crack in my injectors....whats it doing to them? and my motor?
- didi get scammed?
- tranny problem, no pressure
- p75 obd2a chip???
- turbo, supercharge, or Nitrous?
- will a 2dr exhaust fit a 4dr 94-up
- spark plug help
- Could alternator be the problem?
- Evaporator Thermo Switch
- I just purchased the MSD Power Ignition power Cap??????? Help
- What's the best bike rack for a 3rd gen? Don't want to scratch the paint or leave marks...
- help...Does anyone know where I can find a TOW HITCH for my 91 integra??
- GSR block, OEM oil cooler, how much oil ?
- B series axles.
- WTB: 2nd gen integra parts
- plug wire ???
- RSR Exmag axelback
- Gauging interest. 97 GS-R, unmolested, Phila area
- Del Sol Shift Linkage
- Quick header question
- Tachometers are off??
- Did i hydro-lock?
- 97 integra problem help plz
- Dc2 Freshly waxed
- Compression Test results.
- best shocks for eibach springs?
- Any benefit for changing the vtec off rpm on VAFC???
- Do you think this is a good deal for me to jump on?
- HELP~~~
- cleaning the iacv
- F/S / WTT for integra....
- Programming a 2-way
- 90 Ls head the same as a 94
- what is the Vtec change over in a B18C1??
- Hey, I'm new too...
- Ideas On New Rims??
- Questions about this clutch?
- Post up Black 94-01 integra pics
- integra electric entena
- Tein H-Tech Springs?
- Best sport spring kit.
- quick question
- Powershifting?
- Question on fuel kill switch
- motor
- 90-93 auto to 5sp tranny mount
- HX rims on a DA
- how much whp should show over stock wit a fidanza?
- Car whistles when you apply throttle... why?
- ls/vtec w/spoon headers
- weird noise
- I need your opinion on what clutch/flywheel/pressure plate to buy.
- spring recommendation?
- obd0 dizzy obd 1 ecu?
- DC center console and center compartment in DA, maybe even a dash swap?
- quick Q. vtec gsr
- sway bar
- will this even help my horsepower problem
- crappy idle
- cheapest way to squeeze all motor power out of a N/A b20
- Pulley Rubbing Sound...
- power window problem help!!
- clean dirt off rims
- gsr wanted, Colorado?
- If you were to do it again what would you mod different?
- Fusebox diagram for 98+ dc2 ?
- best spark plugs
- is it possable to cross drill OEM rotors
- Pressure Switch
- Which timing belt.. Match to bottom end? Correct?
- image host
- Portland - Seattle - TBAD - Integra Parts
- AC help please
- Dual core small radiator swap
- performance chip
- JG throttle body & TPS issue? Need help!!!
- Ravelco Anti-theft device...does it really work??
- vtec controler or programmed ECU for b17 92 GSR
- ecu p72 wirering problem 94 integ gsr
- B18c5 or B18c1 block?
- QUICK need help ?????????
- VOGUE SILVER 98 integra REAR BUMPER NEEDED (SOCAL PLEASE)
- Thermostat?
- mushy motor mounts?
- ROTA SLIPSTREAMS 16IN WHITE
- idle problems
- car shaking .. did a search
- 2000 GSR mounts
- after driving my moms 03 crapalier, ive come to appreciate my gsr a little more
- Vavle Ticking
- Venom intake Manifold
- currently installing jdm fogs: ground to chassie?
- Anyone in Rhode Island/Mass help me out?
- resealing valves on 96 GSR
- which acura rims for a DA is best ?
- Can anyone with greddy turbo kit post pics please inside
- steering wheel swap question
- First time at the 1/4
- 94 integra lowerings springs on stock shocks?
- do i need the avap sensor setup
- where to get DA JDM fenders..?
- B17 p61 ecu question!!
- clunking noise while under strain
- tie rod castle nut~not tightening
- Ticking from Engine Bay :(
- Comptech tie-bar questions...
- Radiator
- squeaky noise question
- cant stop belt squeeeeel!
- rubber for exhaust hangers..
- fidanza works on DA and DC right ?
- Cd Player
- Think I'm keeping my 1st gen, :)
- 92 LS in hatch
- Shift rod on tranny/shift linkagE?
- ****(CAR SHOW AND SALES)****
- Ideal fuel pressure?
- Whats the bulb size on the non HID jdm front
- GSR Engine wiring harness?
- looking for black integra 94-01 interior
- (NEW) whats up
- 98 Integra seems weaker than normal
- instrument panel lights out
- light weight flywheel warps?
- QUESTION BOUT SUPERCHARGER!!!!!!!!!!!
- ok fellas help a bro out
- Green/blue integra....Would it look good with gold/bronze rims?
- DART race block
- GSR sedan exhaust options!
- car wont stay runnin!!!!!!!
- Electric power steering...
- HELP ME OUT HERE
- any sound or video clips of 403s on a b18a/b ?
- Ignition Fuse wont stop blowing
- LS vtec
- Do DC2 coil overs fit DAs?
- how much for a fidanza lightweight?
- integra gsr interior fuse box diagram
