View Full Version : Acura Integra
- EG suspension on DA??
- What's wrong with my friend's car?
- Is stock DA fuel pump good enough?
- where to buy new DA carpet?
- out with the old in with the new
- Double checking Ls\Vtec
- Convert RS(non VTEC) to Vtec
- what should i do to my head
- Type R rears...in DA
- Transmission question
- info. for so. cal people!
- OBD2 Distibutor work on OBD1 car?
- Compressor map help
- LSD question
- Fuel Pump.
- broke valve cover stud...need to retorque all bolts in camp cap/holder?
- Anyone ever use this ebay rad?
- Need help: cam shaft holders
- Swap legality in So Cali Questions:
- Going All Motor
- Fuel Problems
- how much boost can u run for a stock ls motor
- hi everyone :)
- STOLEN 95 TEG SOCAL, posting for friend
- replacing front window and weather stripping
- im buying some '00 tail lights:
- 2DR INTEGRA AXLE-BACK COMPATIBLE WITH 4DR INTEGRA??? HELP
- PIcs of my teg..let me know what u think???
- picutre
- H22A4 in Integra (need help)
- weird vtech acceleration sound
- Is a b17a1 oil pan the same as b16?
- Stolen SE MI
- best set-up for a DA!
- DA stock alarm
- 4-1 header removal in DA *pic*
- Good Or Bad Deal
- Car sound catalytic converter
- DA9 or DC2
- Stalling problems
- Problems with jdm integra non srs steering wheel....HELP!
- JDM B16A swap, Wiring nd o2 sensor. What pin is 1st o2 sensor?
- Jdm Radiator Support T-Bar
- my car is makin some wierd idling noise..
- Miracles Happen... but I am still pissed
- ecu location
- what to do next
- GaS TaNK!!! HELP
- JDM front end install pricing?
- how do you release the refrigerant from the a/c ?
- Car Running hot Need some suggestions.....
- Brake Rotor?
- Please Help JDM HID Headlights Fogging
- Ko3 in a 91 DA
- Question about about INSURANCE stuff....
- radiator support problems
- Head Gasket ?
- People with H22 Integra
- sunroof problem (searched already)
- a/c question
- Built B17 vs B18c
- complete gsr or gsr block with b16 head?
- does anyone know...(teg records)
- Do I need a new battery?
- Where should i get my transmission fluid changed at????????????
- gsr ecu on a b16
- why the hell won't you guys answer my Q's?
- new motor code!!!
- GSr throttle body sticky/ greasy? hard to open what to do?
- putting b16 head on gsr block...which headgasket do i use...timing belt..//etc,..
- can't open my rear hatch
- Hood driver side sticking out..?
- MAP. Code 3, lose wires etc.
- 94 Catalytic converter question?????
- A1 tranny
- Sparco racing harness connection points
- where's the coolant drain bolt on the engine block?
- Ignition Kit, What Are They?
- Maximum Boost Book Good or no Good?
- How do I remove the sunroof glass?
- Axle/Intermediate shaft question????? did search
- 92 LS door lock and window problems.......stumped
- sway bar?
- Pic Request: Championship White DA's (searched...)
- 02 civic seats in a dc4?
- lcas and stock sway?
- exhaust manifold work
- Replacing Power Steering Line Instructions and Tips
- Paint Job: Which Color for my db8?
- Anyone running a td05 turbo?
- Car wont start, I think its the alternator.....
- LS turbo cams
- doing my timing belt
- fly wh. tq spec
- Service Manual?
- Burning oil question
- Who do you email if there is a problem with the site?
- nox sensor with B20 swap in DA?
- deceleration backfire/hesitation problem??
- is this a good trade?
- helpp!! no tail lights, no gauge cluster
- 92 gsr b17...steady tapping in the head after 3k? ???
- Catch Can Setup *Have searched*
- ES Torque Mounts..
- Just bought 91 intega w\ JDM B20 swap...have some ?'s please help!
- Car is a little smokey while running?
- wheres the classified section?
- Before and after!!!
- Opening a sunroof manually, Integra
- what should I replace when pulling my head?
- wierd screechy noise?!
- is OBX and Skunk2 stage 1 the same in specs??????
- ebay resonator fitment issue
- High beams adjustment??!!
- my hatch latch or something is squeky
- purple integra???
- headlight polishing
- Anyone have the Sir-g non srs steering wheel?
- greddy boost gauge??
- HELP NO POWER!!
- Thermostat
- Apexi WS2 or RS-R EXMAG
- Transmission Fluid
- 1995 LS Sunroof
- IS IT A GOOD DEAL?
- What do keepers do that u put in valve springs????
- has my rear motor mount failed?
- black smoke after catback exhaust install???
- BRAKE PADS for 99 GSR
- supertech pistons?
- rsr exmag
- 90 LS, trailing arm bushing part number?
- Conversion from Integra to Civic radiator@fan few questions
- Radiator
- need help!!! Type R engine in GSR
- turbo being weird
- To admin
- cars blwoing smoke once it hits v-tec but then stops for a while then does it again
- Exhaust valves, it's what's for dinner
- Lowering my DA9
- 94 Integra
- JDM LSD question
- 1990 Integra RS...no motor...100 bucks
- 95 integra ls coupe
- wtb ls supercharger kit
- for the people that run catless
- idle problems!
- steering wheel
- How to take apart DC tail light?
- how to remove brake/gas pedal
- OBD1 LS dizzy on OBD2 LS motor question.
- Best way to secure your Integra?
- injectors on a b20 obd1
- 99 gsr hard shifting..clutch?
- K20A Type R, H22A type S, B18C5 Type R, LS/VTEC????
- Apexi v-afc2
- help on where to get headlight bulbs?
- Turbo Timer or Compustar
- Antenna hole diameter for plug
- Ls b18b b20
- AEM Dry Filter?
- Buying aftermarket flyweel/clutch/pressure plate??
- Taking apart the transmission to re-seal?
- Disabling airbags.
- K&n Drop In airfilter
- Decided to buy a JDM ITR conversion
- Quick question
- LINELOCK anyone ever use one?
- breaking a timing belt??
- *cut* ITR AEM cai still work on 3rd gen integra?
- Why?
- **Updated**JDM front end Conversion Headlights Wiring Diagram
- ground wires, how to test?
- Newbie Needs Help Bad
- have a problem with my b18b1
- ITR H/E on LS? Any Benefit? Performance?
- Siemens or Denso injectors?
- S2000 Flywheel in GSR?
- Spark plugs and wires?
- GSR vs. Type-R.
- bye bye honda-tech..
- vtec head
- Possible in a 2nd Gen?
- just did a tune-up, #1 cylinder missing?
- Dome Lights Wont turn on
- Quick question about injectors.....need to know in the next 30 mins
- Engine Bogging upon engaging ignition
- CLOGGED CAT...
- weird electrical issues
- difference between gsr and ls radiator
- h22a swap!!
- help with skunk2 camber kit
- loss of power, new motor, kinda stumped
- Taking trim off the car
- What's best?
- Dash wiring harness needed
- dash vents
- turbo??
- Angel eyes/ Halos
- Help rear hatch
- HELP!!!!! 94 gsr
- H&R spring's 95 integra ???
- Yet another E-bay cat/back !
- rota circuit 8.
- NEED HELP WITH H22 SWAP
- Will this work?
- Shift light...odd problem, might be an easy fix.
- engine chokes when given gas
- colored acura badges
- HELP . Car die on highway..
- Question for People With Adjustable FPR's
- wuts this????
- scam or no?
- 94 GSR..... 7K in 3rd than slammed into 2nd HARD... HELP!!
- braking in new clutch and motor
- People with boosted DA's..
- thermastat maybe?
- looking for some budy that will trade rims ?????????????????????
- cams
- Valve adjustment tools...
- Lopey idle problem
- Car wont start?
- Clutch to tranny question
- Suspension Help
- Help! My Teggy doesn't start!
- Punk Ass kids!
- where is the VSS/ Alternator fuse?
- Tranny shot? or something else?
- Amber Light
- gsr and b16 rocker arms
- just did a compression test on my 95 ls...
- my clutch is broken...what is it?
- carbon fiber doors
- Exhaust
- Anything i should look for when buying a dc?
- Sounds like a WRX?? Lots of smoke
- help
- GS-R smoking during V-tec
- calipers for a da??
- Will a DC/EG lower tie bar fit a DA??????
- how to remove a 98-01 front bumper
- suspension
- Painted ValveCover, Can i sand down DOHC VTEC and honda??
- Code 20, Electronic load detector (ELD) need help fast!!!
- wheel vibration
- will an ITR radiator fit an LS?
- buddy club spec 2 low budget way
- How much is it worth....
- which is the better strut bar?
- anyone running ctr intake cam on gsr head?
