View Full Version : Acura Integra
- hey guys just installed ctr cams in gsr
- Making the 91 Teg a lil faster ??
- new+Jus bought a gsr
- ctr cam
- Has anyone used this......
- would bigger cams pass smog in california?
- install dizzy in a 91 DA?
- type-r pistons in B17
- RPM problems
- brain fart quick question
- pics of mugen front lip
- Need help, Swithcing mufflers?
- Painting Interior ??
- Help with cams...
- Friends integra CHECK ENGINE light on!!!! counted flashes what is it ???
- picks of da with rota subzeros?
- need opinion
- jdm itr oem hids
- changing degrees on skunk 2 cam gears
- Where is the fan relay on a 90-93 integra
- After i took off something out of my body and sound like i put new exhaust.
- Speedometer problem!
- laws in VA about what is legal and whats not
- Real 98 tailights or painted? I see uneven grooves on the turing lamp? wtf
- Im a NOOB Hate me if you want!
- exhaust piping...
- NGK V-Power Racing Spark Plugs
- anyone heard of a FEEL's intake for DC2???? need some help asap
- h22 integra major questions
- Cams and pisoton questions
- smog test - HC (ppm) at 15 mph almost failed
- Motor is ok to be in the cold?
- Stock times (gsr)
- pison/arm/ecu/crank questions..
- hey...say hello to the nOOb...
- pic request - 90-93 integra DA underhood emissions label
- Ran Latigo Canyon last night... accident pics.
- How can I find Honda parts numbers for my Acura Parts?
- Engine warms up really slow and makes noise until warmed up
- Hello i am new to this site. Need a bit help.....
- is 1.7 inch drop too much?? help plzz
- ponder ponder pondering
- strut tower bars
- Tranny prob need help
- ghost caught in london?
- what's the difference between headers?
- Detonation above 4000 RPM?
- vtec noting engaging...
- Car stop problem, need help!
- **Engine Bay Picture ** Where does this VAC line go?? please help!!
- Replacing engine on a 1992 Integra LS - need some feedback
- Jdm motor or not?... b18cstamp...
- 9.1 compression in a gsr with 80 shot nitrous
- I need a driverside 90 integra headlight immediately anybody?
- installing XSI seatbelts
- Hey fellas, here's my project car i
- OIL CHANGE!!
- Question on my gsr block: have stratches on sleeve
- what sae type oil should i use?
- Which wheels? A or B ???
- Rear Tie Bars!
- Car won't start.
- Integra LS Tubo'd - reliable? good for daily driving?
- Buying a 2000 integra ls, opinions?
- Experts only!!!
- jrsc with jdm final drive?
- wire harness?
- Need help!! ls/vtec integra
- Neone have a turbo kit 4 sale?
- need 1990 Integra Help
- Wheel Bolts
- Deciding on a Header
- new rough idle question
- Just got 88' teg for $500 today!!
- My whip
- problem with 3rd gear on DA
- ¿VAFC vs. SAFC?
- Anyone know what sideskirts these are...?
- 94-01 Integra suspension interchangeable with 96-00 Civic???
- fuel pump relay
- What is this part called? *pic*
- Problem with my GSR burning oil...
- air bag removal???!!!????
- blown head gasket?
- Will a 1998 SOHC Civic ECU work in a LS Teg W/ b18b?
- HELP with the Lsv
- HELP ME!!!!!!
- integra exhaust picture request
- bolt sizes on b series head
- exhaust
- Need Assistants w/DC Header Measurements
- i need help from anyone who can do a timing belt!!
- Hayame catbacks on Ebay
- really any diff. in header? 421 or 4-1 ?
- should i get gsr tranny??
- Can I remove emissions without too many problems? (95 GSR)
- Suspension is acting weird, any ideas?
- New 2000 GSR owner
- Which is the better header
- Calling on 98+ Integra GSR Guru(s)
- Can this be fixed/repaired?
- HELP!!!!
- **HOW TO**install rollcage?
- Cant believe how much miles I got on a tank
- I am new and trying to figure things out
- del sol exhaust on a LS?
- Iceman Coldair Intake and Bypass valve
- Coolant froze in engine HELP!
- need help on right side drive integra
- How fast is300 and are they turbo'd???
- **WANTED**TURBO PARTS
- Make my teg faster without paying an arm and a leg.
- LCA Bars on 1992 Acura Integra
- To those that have done with Toyota starter rebuild trick. a few questions
- How much for the whole JDM FRONT PROJECT??
- turbo or vtec
- Different Exhaust Sounds
- is there a way i can make my vtec pop harder
- LS Octane ??
- cel 14 41 IAT and IACV possibly put plugs backwards what did i fry
- 1993 gs-r b16 head?
- cam piston question LS
- civic seats into integra
- Light not coming on in Park
- JDM FOLDING MIRROR DIAGRAM
- Sun roof drain tube location?
- Power Steering Pump Swap
- Custom Wiring for OEM fogs
- b16/ls exhaust mani
- Quick question on 90-93 teg armrest
- my shop burnt
- New to the honda world =)
- fast blinkers?
- wiring gauges and clear corner question
- Stolen DA 12/05/05 @PCC
- Dont have money for a B16 engine swap or turbo. What should I do?
- V-Tech beak y0 NECK son!
- 98+ front corner lenses brackets (conversion)
- do camber kits sqeak?
- How to take off steering wheel of a DA??
- Finally got money back from scammer
- MAX SAFE RPMs ON STOCK LS
- Help with headlights... PLEASE!!
- stripped valve cover nuts & studs
- my new 94 ls + more (pics)
- Best Way to Gain HP
- Aw yeaaahh, The sweet smell of emissions removal...
- OBD0 DA with B18B swap
- will 2000 GSR Distributor fit into my 95 gsr????
- GSR Question Continued...
- Crashed Teg, broke rotor, messed up wheel
- Timming belt change
- I NEED YOUR HELP!!!
- N1 with resonator
- Brake Problems
- Has anyone ever mounted RSX sideskirts on a 94-01 Integra?
- Idle issue
- Just got my bronze rotas group N
- Does Eibach make cutsom spring rates, if not who?
- New to Hondacura family hiya all
- Need help: Not getting enough power after rainy day
- 2000 integra stock radio replacement
- Well Guys Fairly new, but finally bought my 93 LS
- Looking for a DIY LSD install.
- oil leak under tranny? near flywheel cover. drips and drips of oil........ tranny or oil?
- Low Gas light
- Vibration, PLEASE HELP!!
- should I buy this car?
- USDM ITR gauge cluster install problems!
- What ECU would be better??
- seats
- POST DA PIX'S
- radiator fan dont come on, SEARCHED
- 4000 HP INTEGRA!
- is it possible to turn my maintenance light into a shift light?
- Shift Nob on Auto tranny ??
- need help with the skunk2 mani
- gsr cluster & sunroof for sale
- Draining 4door gas tanks
- my gsr is running like doo doo
- so the car is going to a shop....
- Stock Sway Bar sizes?
- JDM front USDM core support:
- post integra on spoon rims
- Strange 90-93 radiator leak problem, no overheating, fan only comes on with AC fan
- manual pedal install
- Head Gasket Issues
- Need urgent brake help! (bleeding brakes)
- Finally got it - 1994 LS
- B18C1 header on a DA
- B18c1 block with b16 head. How much power am i looking at?
- Pics of the DC4!!! Rota C10's
- vtec solenoid
- What's the cheapest/lowest prices for Ground Control/Koni yellow setups and where?
- sup
- obd2 valve cover conversion.. is it possible?
- secondary corner light bulb
- quick gsr iab question
- whats next for my integ
- installilng dash
- Idle problems after build
- Part number on Distributor housing.
- Potential quarter mile time?
- Part number for oem Integra Optional sides
- WTF!!!?
- skunk 2 manifold question
- Turbo a stock gsr?
- NGK Copper or NGK iridium...?
- Question regarding a DC2 Dash Foglight Button
- TYPE R dc2 spoiler on DB8
- plugs needed for b16 install in teg
- how much to replace a camshaft seal?
- i need some racing pedals *searched!*
- is it ok for my header to be touching my oil pan?, like i mean touching it with out no gap?
- AEM fuel rail on integra
- 99' White Acura Integra Stolen, Odenton MD
- Comfortable Springs
- Reading an ECU Code
- which gasket do i need
- Slim fan mounted....
- b18b dyno results..what the f@$k?
- ABS light on
- Calling all 92-93 Integra GS-R Owners!!!!
- AEM Power Pulleys
- intercooler...how big can you go?
- Header question
- 4000 hp teg!
- Intergra differences
- does a gsr have 2 different stages of v-tech
- Exedy Hyper Single...any Reviews?
- 93 4-door - dash and brake lights dont work
- DA alternator problems??
- DIRTY air filter question???? also, would you buy a 93 gsr?
- 2ND THEFT ATTEMPT ON MY GSR IN 3 DAYS!!! (san jose west)
- NEED HELP REAL BAD!! ENGINE MAKES WEIRD NOISE WHEN COLD..
- how long did your exedy stage one last?
- Tuning Help
- 90-93 Integra (DA) alternator removal?
- New To honda-tech
- Please Help - timing belt loose. tensioner problems *searched*
- SELLING 94 sedan GSR center console
- How much could i get for my GSR
- b16 vs b18
- Noises when braking
- What times in the 1/4 does b16 swaped 90 integra rs's run
- sorry cant post in FI, B series turbo kit for sale in southern cali
- BMW 330XI Side Markers on a 94+ Integra? Should I do it?
- Ideal tire for a 16x7" rim
- Used Search - no answers found - MOMO steering wheel in a DC2 w/SRS?
- Eibach springs/koni yellow combo ok???
