View Full Version : Acura Integra
- Anyone know if switching out the Leather seats in my 2000 GSR for Type R Seats would violate my leas
- Good bodyshop in Sacramento area?
- 2001 type r header
- -- how do you clean the headlight housing out after bulb explode? --
- Carfax Help . . .Please. . .
- best replacement transmission for integra gsr
- Movies
- Okay, Bay Area HT.com meet at speedring
- Valve Job?
- aftermarket crank pully
- replacing head, what do i need?
- ITR muffler with custom piping?
- 1992-1993 Integra GSR...got pics?
- how many quarts of oil does the Gsr consume?
- Thinking of upper front and rear which ones?
- Difference between 1 piece and 2 piece?
- I have a 98 GSR and I can't decide what exhaust don't want to loud what do I buy?
- HEEEEELLLLLPPP!!!
- Newbie just showing off his car. Tell mw what you think
- L.A. area people---Any of you guys and gals going to the meet at Area51 on Sunday??
- jdm sheet metal type r conversion kit
- header?
- Car died on the highway!! techs help!
- I Dusted a.........
- swapable throttle bodys
- How many HP will underdrive pulley free up ?
- oil leak
- spring rates -race car application
- check engine light
- H22a engine swap
- SMOKED A NEON..LOL
- upgraded ecu choices
- Does anybody know.....
- BETTER SOUND RACING MEDALLION OR APEXI NI?
- JDM Integra SiR
- 205/50/16 will this rub?
- anyone have a dyno of a spoon header on a GSR?
- Any stores sale Falken tires in Canada?
- VTEC problem, or so i think? Need Help
- Some body shops just don't know....
- what to buy
- Cam install in Va!
- Magnets in all oilpans?
- Options, Best Motoring and Initial D videos on sale *must see*
- Y21 tranny on a B18c opinions
- which gsrs here are making ~200whp NA?
- b16 pistons in a gsr engine
- a problem with not getting to normal engine temp
- What is/causes clutch chatter?
- Just wanna share one more guage pic: close up
- Crank pulley swap?
- anybody here running the jun3 cam kit?
- Question for the gearheads
- Front/rear strut bar install..need alignment?
- fomula one 16x7 with 40 offset
- 4dr rear door handles on a 2dr
- help radiator leak...
- Header/Exhaust install questions....
- Sparco Racing Harnesses on Stock GSR SEats?
- Anyone know where I can get an Integra Poster?
- OBD II question
- GSR leather seats/side bolster cracking
- Somethings leaking?¿?¿?
- G2 Idle problem (RPMs Fluctuate)
- CEL code 41: Primary Oxygen Sensor - Heater circuit malfunction ?
- 15" vs 16"
- Pulley - AEM or Others...quick tech
- what rpm does a b18b stop making power?
- 91 B16a Head on 94 Ls botom end?
- Suspension Question
- Modifying the stock GS-R header??
- Predicament: My 94RS with Sus+Rims or Bonestock 94 GS-R
- 200whp gsr... what 1/4 mile time possible?
- which tires
- catalytic converter engine light?
- more power
- Pictures of my mesh grill...
- Is this a GSR? Please help!
- Fello Bat Area Integra Owners Pls! Come out To my club event!
- Please help a friend with idle problems
- 94-97 GSR's slower than 98-01?
- Integra Exhaust Question...
- Cooling Problem
- Need Help on choosing Suspension
- How much HP?
- Does Anybody Know...
- How much work is it to rebuild a B18C1?
- what struts- recommendation
- Is there Much Difference in Launching w/ stock and with 17's
- how can u tell between JDM and USDM p72 ecu?
- ANOTHER TOPIC ON HEADERS,QUESTION FOR YOU GUYS
- Getting a bigger throttle body does that requir getting a bigger intake pipe to fit around the throt
- How do I get out the back side inside panel? (one around the spoeakers)
- Redline question
- can kyb agx's handle neuspeed full race springs?
- anyone know the diameter of the older style RSR exhaust?
- Broken Moonroof (or just the switch) on a 96 Integra LSpecial
- All people from california
- just hit 60,000 miles
- NEX Coilovers any good ?
- How to make my gsr quicker?? advance timming?
- which intake manifold?
- Advice on my motor ?
- burning oil?
- What Kind of Injectors can i use on my B18C1(GSR) engine? Prelude(H22A) works?
- all-motor LS
- Anyone with CarFax?
- Engine knocking over 3,000 RPMs HELP?!
- Adjusting the clutch pedal
- intake manifold?
- Honda-Tech Meet Part #3
- JDM GSR
- Whats that noise???
- I/E/H and 1/4 mile Question
- motor swap or not.
- 146,000 Miles?
- Putting the GS-R to sleep . . .
- post your c-west kit
- '97 Integra Wire Colors/Locations for Alarm?
- Why change the oil every 3 months?
- clutch chatter with ACT...
- have $450 what next?
- Installed my skunk2 cams over the weekend
- The 94-97 Integra headlights or the 98-01 Integra headlights?
- Cross drilled rotors owners..
- Vented Imoto hood need pins?
- HELP ME DECIDE!
- Headlight Problem (of a different kind)
- Suspension install done - Have question
- Headlight problem part2!!
- How complicate would it be to swap an H22 motor....
- Dealer prices for maintenance and timing belt
- HELP!! my tanabe exhaust pipe broke in half!!
- Hmm.. Skunk2 cams???.. ITR cams???.. CTR cams???.. JUN cams???.. So many to choose from.....
- wat happend to avatars??
- Lowering
- Removing stock side sills?
- Integra Type R Parts For Sale
- Will 215/45/16 fit on 16x7 wheels?
- Camber problems... Fenders???
- Q's on Port&polish
- clutch change on 2nd gen
- gettin insurance $$$
- A few questions for those running ZEX nitrous kits.
- Looking for Suspension
- Suspension
- Largest 17" tires???
- cargo cover and clock, anybody??
- turboed teg guys, im going turbo what mods should i be doing for future?
- Oil on my spark plugs....is this a problem?
- "check engine light" went off suddenly???
- Gonna be a tough night fellas.
- 2nd gear grinding >> uh oh!
- Pics of your audio/video set ups.
- 94-97 and 98-99 Headlights
- Potenza S-03 or RE730? Any comment?
- Thermal Exhaust Questions! I know.... Another exhaust question
- Post pics of your 98-01 gsr "blades" painted
- What were the 3g Tegs like in 94 when they came out?
- Rear corner window installation help!!!!!
- Timing Belt Service + Valve adjustment = 4mpg increase!
- GSR w/ Type-R Exhaust
- Anyone here running Crower LS 403's ????
- Help me find a Roll Bar/Cage?!?!
- mugen fg360 steering wheel mount to momo hub??
- Anyone have pictures of HKS hiper exhaust on their car? thanks
- help: can someone please run a full carfax for me?
- Which clutch???
- How low can I go with stock shocks?
- exhaust questions
- F/S EF & DA Helms Manuals on CD
- NEED VALVE ADJUSTMENT?
- anyone looking for a gsr chassis?
- Differences between auto & manual Engines?
- S-AFC into Integra LS B18B1
- VTEC controller: Can i only hook up vtec control wires and not fuel control wires?
- Camber is a b*tch...
- SNAP RING
- help..guy at work here insists that my 91 teg cant be turbod stock
- Safe to run ITR cams with stock valve springs ?
- JDM integra headlights
- No Front Plate Fine in CA Raised???
- Why are there so many b16 projects?
- OT - anyone here have to go to small claims court
- how to remove screws in brake rotors?
- Best springs?
- Anyone have good brake pad/rotor reccomendations?
- I'm not asking for a GSR, I have an AUTO LS..and this is want I intend to do..
- Which engine in 1988 Integra
- Civic Si or Integra GSR..... --I think I'm losing my love for the GSR..
- Fujitsubo & Kakimoto Exhaust Question
- How much was 99 LS new in 99?
- JDM type-R with GSR pistons
- Arggghhh!!! Helms is SOOOO expensive
- Help ... pleeeese!!! Re-attaching hatch trim (under wiper)
- windshield wiper question....
- new rubber or cams?
- Adult Expo and Consumer Elec. show Pics here
- Whit is this all about???
- steering wheel hub same for 01 gsr and 99 civic??
- 90 LS Trans: Will a GSR clutch work??
- Headlights
- pics of front tower strut bar install with skunk2 itm
- what is a missing link in a turbo
- How to convert '99 LS to GS-R?
- tried to change brake pads today....
- 2G Integra/civic fuel pump ?
- What wheel is this a copy of?
- New Intake....amazing....and kill story
- Lowering
- Body kits
- You guys running copper or platinum plugs?
- B16A Engine
- rear bumper and tail lights sagging
- can someone run a carfax on this gsr for me?
- Car vibrates when breaking really hard....
- ATTN: MD/DC/VA People - Stolen Car
- Bridge Stone RE 730's $354 Installed..Looks like a good deal
- automatic to 5 spd?????
- power steering removal question
- Stock tach error
- i hate my LS tranny!!!!
- tanabe rm muffler+custom pipping vs. full tanabe rm exhaust
- Will 94-98 RSR exhaust fit on a 00 GSR?
- 2002 Tokyo Auto Salon
- squeeking sounds
- Remember the noise in my suspension???????
- Ever had this happen at the gas pump?
- Good place to buy your Honda/Acura parts....
- Wilwood/GS-R wheel clearance?
- what suspension setup
- GSR ECU
- How do you tell if just the block is in good condition??
- Suspension on a 87 integra
- I want to do a engine/motor swap. help!
- compression test
- cost of full auto tranny?
- question about warranty
- ANyone from Florida
- Konig Monsoon 16" look good on a 91 teg?, drop 1.5"
- Alternator pulley
- heeeeeeeeeelp meeeeeeeeee =(
- Toda pistons in a B18C block......worth it? or should I go with CTR pistons?
- Redone compression test and used a stock GSR as a comparison: Bad News Part 2
- does an exhaust need to break-in?
- help me install my iceman intake
- Extended Warranty?? Would you buy it?
- broken studs suck
- FastBrakes - 11.4" Rear Upgrade Installed
- GOING NUTS ......
