View Full Version : Acura Integra
- jdm amber corners....98-01 integra
- Big Brakes
- exhaust question..
- 95 GSR antenna problem
- Can you run JRSC reliably off the fmu?
- T1R Sports vs SPL Street muffler
- 98 Fuse Panel layout
- '97 B18B1 Wire Cover?
- cruise controll relocation after steering wheel install?
- GSR Swap in 1990 Integra
- YELLOW JDM FRONT INTEGRA STOLEN IN PASADENA, CA
- best clutch kit for ls tranny and drag kit, street use
- Help - Speedo off exactly 10mph
- can anyone help me install my vafc show my somekind of instruction list??
- where did our picture thread go?
- CRANKSHAFT HOLDER
- cable tranny help in socal....
- AC stopped working. Any advice?
- A/C is dumping water all over my feet
- omnipower Vs tein
- Thermal R&D Exhaust
- Clear something up
- HT Buddies I NEED YOUR TECHIE EXPERTISE
- Power Steering Fluid Flush??
- performance parts. please help.
- motor input
- Halo Lights
- CARFAX plz
- I'm back bitches!! Well kinda...
- New to the Integra forum...
- Swapping an OBD2 motor into an OBD1 car
- Throttle Body Studs?
- JDM itr headlights question
- Anyone know where I can get a PR3 Chip
- 2 quick opinion Q's on oil change and sticker
- looking for someone who sent me $16 for 90-91 itnegra bumper brackets from east coast
- what kinda sides are these?
- building gsr trans in georiga?
- Does a 94 GSR have a revlimiter?
- clutch question
- Gsr or LS!!!
- 99 GS or 95 GSR
- Can anyone help me with this?
- what is this part ?? *PIC*
- redline
- distributor rotor screw keeps coming out
- AC Recharge Psi?
- Installing New Air Bag
- Aftermarket throttle bodys, can't find good ones with TPS sensor??
- who makes a hondata style intake manifold gasket for a B18B/LS?
- JDM DC2 Carbon Fiber Lip
- is there a difference in crank pulley's?
- What transmission do I have, axle seals don't fit!
- power window motor question! need help!
- gsr auto tranny
- my revival of a 94 teg
- Surging, steady throttle and idle
- p73 pistons and rods for 160 is it worth it
- Where is the Picture Thread?
- tranny question
- Integra Tail Lights
- (Help) Noise coming from Intake when car is off.
- Help: Swapping Door Lock for a DA
- Anyone out there from alaska?
- Remanufactured Distributors?
- Skunk Stage 2 Cam Install
- Sparco Shortshifter
- just for kickz
- 8,000rpms and still kickin!
- tire size for my integra?
- what color are the plugs for IAB and IAC on a 98 GSR?
- Vin help on a gen 3
- Weak weak vtec
- Overheating Problem
- sanding down paint on a bumper
- Wiring for an engine disabler?
- Hatch Stuck, Shut
- theft question
- BBS, SRR, AEM, and more stuff for sale
- Ls rebuilt turbo camshaft what kind to install......please help....
- how do i post pics of my ride
- What will happen if you dont a a o2 sensor?
- antenna problem
- turbo boggin at 6k
- H-T Help me decide.... PAINT or BOOST ?
- Is this a good price on this exhaust??
- RSR.. sound? power? cost?
- Tranny conversion
- Windows...
- little overheating... max out radiator????
- GSR Cats
- best cai for a gsr?
- B18C GSR motor in a 4 door Integra!
- G2 Integra B16 Wont Rev Past 1.5K HELP!
- Overheated, Thermostat is prime suspect
- L CON TRACTION BARS.....WHERE?
- 195 50 15
- GSRs with 205/50/15 Please read...
- Need help!!!! Car Turns on Then Dies!!!!!!
- New Skunk2 manifold Pro Series Pics
- relocating oil filter
- ** Is this a good deal? Is it a good set-up? **
- VTEC Help...
- 96 civic lip on 01 integra would it fit?
- Power steering fights me
- CF HOOD FITMENT
- ABS Problem
- Post your teg
- usdm and jdm 5 lug question
- two fuel injector failed within a month ?
- oil pan?
- Got my T1R cat-back installed
- Hey 'Teg guys...What's this?
- 95 GSR
- New Eclipse...?
- High milage GSR worthy...?
- New DB8 in town. Send pics Please.
- jdm frontend fog cracked
- wtf? Core charge on a starter?
- ***********PLease help me, i have a problem!*************
- Help: Car Boggles/Temp. Gauge Rising when Air Conditioner is on.
- wheres classified??? at??
- misshift into 2nd...motor sounds fine but
- '93 GS Brake Problems
- AC isnt blowing cold air HELP!!!
- 98 Front End Conversion
- buying a b18c5 but no VINS.. help!
- ebay turbo kitt???
- anyone use a duralast battery from autozone?
- Radiator/thermostats problems
- really weird starting problem
- I am new here
- Clutch Problems???
- new 99 gs owner with a fuel filter washer question
- ***** Cat heat shield necessary?
- What would you do?
- street racing accident
- Cracked Sleeve
- Just had 60k service done, and I think they didn't replace my transmission fluid.
- skunk2 intake manifo
- can u run a usdm p72 on a jdm b18c
- got my first teg last night!
- AC Question
- Recharging Air Conditioner
- the new guy
- re-charging
- turnin on vtec
- Shocks
- Know Any DIY on Vipet 791XV alarms? Know any tuning places?
- Squeaking Noise After Coilover Install (Searched)
- Total noob ass question
- Cel Codes, in trouble?
- waterpump fit question...b18a1
- g3 gsr im diapragm
- Engine Management + Clutch questions
- Just got a GSR!!!! Have some questions!!
- just joined the Integra world...
- Brakes Feel Funny
- Fluidyne Radiator
- WTF? Is it supposed to be crooked?
- Y80 And S80 GS-R transmissions
- honda GSR or not
- gsr turbo wrecked
- B18a Block and B16 Head
- The LS
- Diagnosis needed please: Rear wheel noise while spinning.
- ***JDMP72 ECU PINOUT SAME A USDM P72 ******
- O.Z. Superleggera 16x7 +37 on GSR
- hatch swap
- what's under the battery
- Engine Mount Question
- Question for First Gen b16 in DA owners.
- My Car ALL Detailed Up!
- obd1 head in an obd2 car
- integra mpg...
- turbo ls
- exhaust smoke ?
- 95 integra GSR transmission question
- ebay clutch
- intermittent starting problem with 92 LS
- what brand are stock ignition wires?
- I need some help with Cd player install, stereo Wiring diagram needed!.
- ITR clutch in a 95 GSR
- engine managment for my integra
- anyone have a bumper?
- mileage with ls engine w/gsr tranny..
- Motor Mounts
- LSv-tec and LS Turbo
- HELP....spark plug is full of oil....how bad is this?
- JUST BOUGHT NEW RIMS FOR MY DA. 5ZIGEN FN01R-C 15*7 WHAT SIZE TIRE SHOULD I GET.
- white spark plugs, do i need to take action?
- important internals to upgrade for a turbo setup?
- Lowering Car
- OT: Question about Cusco rear Strut Tower Bar
- DC5 steering wheel in DC2??
- Anyone with a B20?
- integra rear wiper
- n e body try arvin cat converters from autozone?
- Civic dash ... in an integra
- discolored headlights??
- NO SPARK HELP PLEASE
- lightspeed rear swaybar??
- Will a ITR DC2 wheel fit a DA Teg
- Tuned the car last night!!!
- car running funny
- 99 integra ecu code problem
- stroker ls vtec prices
- Integra beater blues.
- pulleys
- Anybody knows the spring rate of Eibach Sportline spring?
- Wont put another greddy on my car again.
- gasket and bolt size
- GSR ecu help!!!!!!!!!!!
- just bought another tegra
- how to detach shift linkage from the tranny
- Socal people i need your help
- full face ceramic clutch ?
- Emissions help.. HCs too high
- a/c fuse keeps blowing out
- bodykit
- Link: Any Gsr owners want to trade for my JDM ITR 4.785 lsd tranny? NORCAL
- identify these braided brake lines
- Got Jacked!!!!
- how rare is the Mugen exhaust for a DA?
- cam question
- GSR ecu with type r cams..good idea?
- would a wilwood brake kit for a 94-00 fit a 90-93 teg
- what kind of clucth do i have to put on a 96 gsr motor with a 91 ls tranny??
- what is a better trannie for my 94 gsr
- water leak passenger side help?
- Short ram intake
- 20 HORSEPOWER MODE CHIP
- NEED HELP IN TAMPA
- What car does this belong to?
- Rod bolts
- Gsr motor ?'s
- jdc itr and jdm non itr fog lights, are the same?
- Need motor for my shell...any ideas?
- by pass valve
- Cant Shift into Gears & Clutch is Soft
- obd-1 civic and obd-1 integra distributor ignitors the same?
- Cold Air Intake
- Pumping the Clutch..?! My friend is weird.
- how to tell the difference between dizzys?
- How long?
- need help with timing on a b18a1
- Weird noise when i rev
- wire harness ?
- flat black paint on a jdm teg (grilles)
- 2nd Gen GSR Header Length vs 3rd Gen GSR Header Length
