View Full Version : Acura Integra
- cut turn signals
- 97 ITR Master Cylinder on a 97 GSR Brake Booster?
- quick dc2 gauge question
- HELP taillights,cluster and fog light won't turn on
- anyone doing paint jobs in bay area?
- ITR header Q
- intermediate shaft/axle question
- H Series Tranny on to B series block
- Car pops out of 4th
- Horn not working
- 1988 integra brake caliper removal
- ►NEED HELP!!!! 1992 Integra GSR - Car shuts off when brakes are applied◄
- installing airbags
- Speedo/Odometer quit working, CEL, and jumpy idle??
- Apexi N1 ground clearance?
- obd2 car, obd1 engine, wiring mess.
- Godspeed Radiator Questions
- Need new tires, 2000 Integra, stock rims
- Huge dent in my 2000 GS-R, freakin jealous people
- Got my CD player jacked last night.
- help
- 96 Ls With 5 lug
- steelies ques.
- Round Civic Foglights on a 98-01 teg?
- coilovers
- Ls turbo or gsr turbo
- Tranny problems....
- Replacing pistons and rings or just replace the rings?
- Does a B20 take premium?
- Integra k20 swaps??
- brakes
- What gauge cluster do I have?
- No Catback, how loud? and how much power?
- ANY GOOD JUNKYARD IN BAY AREA (EASTBAY)
- HELP !!! cigarette lighter don't work (the fuse is fine)
- 94 Integra with B20 motor???
- what sensor is this 2prong on side of head obd0 pic up
- Back into garage wall
- Ac Problem
- Automatic Transmission problems??????
- Anyone know what tool to use for pushing piston on rear caliper?
- car temp is always really low
- Anyone rebuild their brake caliper before?
- which car is stronger
- my abs is making a weird noise
- ac compressor not spinning when ac is turned on
- need help with ls/vtec
- cleaning your gsr,rs,ls
- need help fast with b16a2 swap
- misfire/rpm drop in neutral?
- my gsr dyno results
- ls alternator n gsr alternator
- obd1, obd2 question
- cons of noisy valves?
- Would this work for adjusting the clutch?
- CTR Crank Pulley
- will this fit my car?
- What Honda center caps fit blades (~2.25 inch)?
- hids????
- VTEC CONTROLLERS INFO
- Brights stay on and fuel pump won't prime.
- So what can be done to a b18b stock
- do or where is the FITV on a 00 gsr?
- square motor
- draining year old gas from 00 gsr?
- ideas
- Help a Noob.....Safe a Life
- what is a exhaust test pipe
- can you change a car to AWD
- looking for a shell 95 and up
- crower cam shafts on .25 over itr pistons
- Supertech seals interchangeable?
- b18 iequus guage install?
- gsr shift linkage look strange to you?
- New to the ontegra forum. My experience with Royal Purple Sychromax
- fender splash shield bolts.
- Can't FIT Mugen rims on DA front assembly
- b17 rods & crank in ls block
- ECU difference?
- how much at acura dealer?
- Present
- B20 into DA driver side mount??
- Just Bought a New DA!!!! Check it outttt
- interchangeable springs
- will i still be able to use my skunk2 lower tie bar after installing ITR rear sway?
- transmission parts interchangeable
- help!!!!!!! distributor housing???????????
- A question reguarding JDM and USDM tail lights.
- 94 integra normal idle?
- Axle Nut
- modify a 95 integra
- GSR IAC on an LS Intake Manifold?
- VTec on a 2000 GS-R.....
- Is TPS for LS same as GSR?
- alternator bad?
- need help. i smell something burning
- Acura integra SIR-G JDM LPG hesitates on accelaration
- What color red is this?
- feelin Bad for Cali!!!!
- Questions about buying Koni Yellows / Ground Control suspension setup.
- need help
- Need Help with price
- nice lip?
- H22A LSD in my teg?
- exedy throw-out/pilot bearing question
- 96 Integra LS ECU problems - HELP please
- Need help please!!! Engine rev high
- New Clutch Installed, Engagement Questions??
- shifter moves 5-6inches when car is in gear
- wheel locks .. oem
- Comments or Constructive critisism
- I NEED HELP
- Installing a new (used) A/C compressor....
- Would you guys pay retail for a CLEAN low mileage gsr?
- Need some help.....front window wipers...
- need help
- Clean JDM Integra w/ K20A2
- HELP: My GSR doesn't start
- jacksonracing charger on da??
- ecu codes, try to read but engine light just stays on
- air fuel gauge
- Questions 4 gsr block/b16 head
- clutch help asap
- engine rebuilt.
- cracked window replacement/ and loose molding on window
- Shift linkage
- 1990-1993 tsudo n1.....any pics?
- TPS sensor
- engine?
- What offset is needed to run 15x8?
- intalling gauges
- IS THIS A GOOD DEAL?
- how to remove resonator from '96 Gs-R
- b20 trans. into integra???
- Im Worried...never had it happen before
- Questions about my new GSR
- Cylinder Wall Scatches :thumbdown:
- -Searched- Can't find step-by-step code diagnostic.
- Changing manual transmission fluid
- for sale integra 90 driver front fender
- what size brake booster does a da have
- tranny problems?
- head compression test
- Problem with MSD in my lv/vtec :(
- SUSPENSION MIX UP
- Twin Loop Muffler
- which seats?
- door and ignition keys.
- 99 GSR firing order NEED HELP FAST
- Shifter
- piston?
- anyone kno the name of this color
- 2000 Integra LS
- Will a ls or gsr exhaust fit on a gs?
- hasport cable to hydro conversion for da
- size of 01 integra ls exhaust???
- A/C pressure question HELP
- Will an STB from a 94-01 hatch fit a 94-01 sedan?
- HELP! MY 1992 ACURA ITEGRA IS LEAKING ANTIFREEZE...
- what temperture does the stock fan come on at?
- Re: There goes my Car crush by ontario cops For street racing
- engine removal guide?
- DA ls vs DA b20b
- this trial shit is killing me!!
- oem leather for a DA
- 1990 tailight fitment ?
- New JDM front, lots of pics, let me know what you think
- PARTING OUT: 1995 INTEGRA GSR DB8 4DR FOREST GREEN EVERYTHING
- All B-series tranny cases the same???
- transmission help
- how
- I think interga's Don't like me
- hey help me
- Which intake gives me the loud whistle noise at idle?
- Missing dowel pin on fidanza 7.5 lb
- Bumper
- What is it?!
- DC lowering springs on a DA??
- would anyone buy this motor
- Iridium vs. Platnium spark plugs: Is Iridium worth the extra $$$?
- catalytic converter to cat-back flange bolts (welded?)
- with vtec is the best...
- Quick Q: Buying Rims Offset Info.
- Koni spring?
- removal of integra abs part 2
- flushing and bleeding brake fluid.
- your opinion needed obd-0 to obd-1 full conversion
- 94 acura integra with 142k miles - buy or not?
- How to identify JDM GSR Motor ?
- Which head would be better?
- Help Me Buy A Integra
- power steering rack loop
- model specific catagories?
- DIY: Manual oil pressure gauge install
- I locked my keys in my Integra!
- Rear Sway Bar Bracket.... BROKEN ....How should I go about fixing?
- OMG!!!!!!!! drunk drivers FTL
- Nitrous Info!
- 92 INTEGRA CODE 16 RUNS LIKE %e^#@# HELP ME (searched for ever)
- Black 94 Integra GSR "STOLEN"
- oil pan gasket
- Just hit 200,000 this morning :)
- exedy Clutch slipping?
- Best cold air intake kit??
- question about engine install...
- Will a B16 header fit a 98 GSR new or stock?
- type r front lip installation
- Question
- quiet exhaust system!!??
- will DC four door side skirts fit on DA after i cut em down?
- black smoke when i floor it
- Bogging on accel. fouling plugs...
- possible VSS problem?
- BLOX Intake Manifold Fitment?
- 4 door integras
- Just a Few performance Questions
- 95 wiring harness
- the new guy
- Best vtec head for b20 vtec?
- air conditiiong replacement.
- help with motor position (leaning)
- check it out
- motor mount issues quick question?
- quick question??? Auto meter Short sweep electric guages???
- a few questions about performance
- WHAT FUSE
- Driving long distance any advice????
- strange noise coming from driver rear tirewell?
- front bumper bolts
- First day in Honda-Tech, First day with my 94 rs...big day
- maybe buying a 97 Integra LS
- Clutch problems?
- where can i find a clutch alignment tool
- car in limp mode HELP PLEASE FAST
- Idle prblem, even after replacing iacv
- 93 DA onepiece headlight bulbs? fresh paint...
- y is my integra runnin hot when i run the air conditioning
- CAms
- finally fixing my a/c
- How can I get exactly 200 hp from a 96 gsr?
- B16a2
- carbon fiber vinyl
- simple question bout94 b18b
- b16 Swap WIRING!
- Can Integra DOOR PANELS from a Sedan fit on a Integra Coupe? PLEASE HELP ! THanks!
- CEL & Service Connector wiring to ECU on 93 LS wiring harness for drag car
- type r conversion
- auto to manual swap help
