View Full Version : Acura Integra
- gsr head+type r block=??
- what to do 15s or 16s on a 4door integ?????
- how to install slr style mirros with blinkers
- how to install slr style mirrors with blinkers
- sea foam
- I need car fax
- where can i order a 3" exaust for my 95 gs-r?
- IS THIS A SIMPLE PROBLEM???
- integra rims size
- Tranny Options: My sistuations-PLEASE INPUT!
- Can some1 tell me the problem???
- Installing JDM climate control?
- i need help....something got damaged today please help
- Integra radiator support install?
- ...my teg, thought i would share cause it's my first honda...
- another tranny ?????
- can i clean the O2 sensor with Carb cleaner or something
- Water Pump Issues
- 92 DA pre-swap 2000 dc motor
- Project LS-turbo Engine Build (photos inside)
- BG-33P paint
- need help w/ smogging turbo gsr
- Neutral Sensor
- Damn oil pan
- new to the site wat up
- Interior Wiring
- Car died on me...suggestions as to what to check?
- need help
- Not the usual Special Ed. Question
- Protection against tow truck thefts
- where to get civic type R pistons
- Anyone have any spiffy mounting idea's for Some gauges? Post pics of some nice ideas!
- Anybody got a four door integra? AND coil over question...
- ITR LCA's and ITR shock/spring assembly in a DA, will it work?
- which coilovers?
- head bolts
- Will Del Sol wheels fit on a 90 Teg ?
- Removing motor.
- windows on integra??
- help me locate the 94-97 usdm thread
- looking for a cheap low boost turbo kit?????where to find
- Is it me or does my GSR get really bad gas milage?
- B18b1 club. Click on in.
- HELP!! MOTOR MOUNT
- head swap problem- help please
- quick questions
- some B18C ?'s
- learning to post pictures...
- Uberdata HELP - Installed Wideband, runnin rich!
- Cams questions
- places to buy crower
- Carbon Fiber Trunk locking mechanism..
- junkyard turbo guys?
- Is there something wrong with my car?
- Differences between headers
- I Need Your Help H-T Members
- 3 angle valve job...how much?
- Issues with tranny...
- replacing steering wheel...hard?
- tools needed for valve spring install
- sway bar vs rear lower tie bar
- CEL codes........
- d16a1
- What is a DB6
- radiator leak....and what I did to fix it !
- integra d16a1
- what's wrong with my car ????????????? won't run well
- Spring squeak
- quick head question.... quick answers are fine
- Semi-noob sayin' 'hi', ebay headlight concern...
- How much to hot tank and bore?
- Piston choice (brands)
- Wideband - HELP FAST PLZ!
- Alignment Shop in Las Vegas for Lowered Cars
- Please Help, elctronic choke?
- Stolen Acura in San Diego =(
- TDC sensor? please help!
- Mugen Twin Loop on turbo GSR????
- how much did it cost to....?
- Which guage pod?
- Radiator question
- tranny moves when down shifting...
- going to englishtown in 30 minutes...got a question
- how do you like you Ingalls camber kits? give it a rating? 1-10
- center pipe leak
- got 1G to spend and here are what i have in mind...need some advices
- d16 in ef hatch
- Parting out a Teggy
- VAFC tune
- wtb tan leather gsr seats 94 and up
- *****pleeez help. tranny problem. take a look. *****
- I need help asap!!!!!!!!!!
- GSR backpressure
- What size is the outlet diameter
- abs issues on my g3
- What do you guys think of my bottom end plans
- Map/baro CKT
- NEED - Rear spoiler LED!
- Need some info on itr trany.
- NEED a street disc clutch kit ACT ACT ACT! ASAP!
- Searched...Yonaka Coilovers?
- Anyone have new Si seats in their teg?
- looking for feedback
- ls dizzy an wiring harness on vtec
- LS/VTEC build question (pistons)
- RS*R ExMag Exhaust Questions
- Does GSR comes in Automatic? 2001 model.
- 94 integra foglights
- Honda Center Caps in Integra GSR Rims
- CODE 14 IACV Car Jerks Violently/Wont Idle
- jdmsh*t type r lip 98+...what material..?
- Eaten
- speedo needle bounces and sticks
- CEL Switch Mod
- exhaust spacer
- 93 teg radio console
- Lights
- gains with 97 itr cam?
- help with motor swap
- swap
- what would it take to make a 00 integra exhaust fit on a 95?
- Failed smog - BAD
- I think someone is trying to steal my car...
- NSX/ITR/Legend 2 piston big brake install...with pics. 11.1" rotors
- New to here - 91 Integra LS
- Power window switches?
- need info on lock cylinders for 90' da
- fuel pressure regulators and wide bands what have you used and was it good?
- 91octane
- Idle Adjuster - Something you all should know about . . .
- TYPE R VS. DC Sports header....
- Wiring in my dash is all messed up!
- where does this hook up to?
- fpr or fuel rails yes or no
- Roof rack on a Da
- hks hi-power
- Tein SS not stiff enough for Auto X?
- Just picked up my 1995 GSR, temp won't climb past 1/4...doesn't warm up, HELP!
- eg sway bars fit dc?
- integra with rotas
- ITR fittment
- wut u guys think of these EBAY STRUT KIT
- How much Hp can I exp.
- how to remove ecu harness from a 94 gsr
- how can i remove power antanna for '90 da
- Pic request: Dessert sand metallic on DC2
- Suggest Need
- 95 gsr oil pan?
- Anybody know what this part is called??
- how do you retro fit s2k hid+projectors in g3 integ?
- How should I go about with this one!
- sound system help..
- Engine Management on LS/Turbo
- front fender replacement price?
- best cams
- Car won't go into gear when its started. Grinds...its like the clutch won't disengage.
- SAFC Question
- Insane rubbing... on 15's!
- CRV B20
- LS/auto shifter issue.
- why is the dc2 better then eg civics
- suspension question...
- What type of lip should i put on my 90 teg GS?
- Quick shift knob question?
- 9005 question
- 1994 Integras as good as newer models?
- Oil Leak and scraping noises
- Car bucks and sputters when i hit the gas hard.... whats the prob?
- Cold air intake for integra gsr.
- tranny clutch flywheel help???
- LS manifold question pr4 vs p75
- Antenna Removal
- AEM-B&M
- skunk2 cams on stock comression??
- Acura Warranty
- having trouble shifting
- which exhaust
- sure fire way to tell if a brake caliper is sticking?
- i need bumper
- Car Jacked in LA SD AREA?
- itr brake lines work on an ls?
- Question
- how to remove headlight buzzer from 95 GSR
- A Few Questions~!!!
- Can I safely bore to 84mm?? (ls block)
- will gsr water pump, timing belt, valve cover gasket fit?
- skunk2 stage 2 cams make power too high up?
- Bouncing Tach
- Exhaust Installation by shop
- Aftermarket Thermostat question
- Will a Honda dealer service my integra?
- Engine rebuild before & after pics
- 98+ Conversion on 94+ Integra
- question on b18c1 head
- Kind of a stupid question about stickers..
- What happened to the jdmgears website?
- what exhaust is better?
- ABS Help!
- my fuel pump is making a weird grind like noise...
- FS: AEM CAI pipe for 94 LS integra(details inside)
- ADJUSTABLE UCA CAMBER KIT! 2ND GEN...BY GOLDLINE...
- Exhaust Question - Please help
- Kuruma Motoring selling GC coilovers @ egay...legit?
- obd1 vs obd2
- Just got my first GSR!
- squeaky clutch
- BOOSTED integra Down pipe!!!! NEED 2.5" !
- B18B1Integra to B20B4Integra/OBD1 to OBD2
- PCV Valve on DA..
- 94 integra...LS where is the FI fuse?
- wth is going on with my car?
- Lowering my teg
- Lookin for a header...
- Too much fuel car won't start need help!
- question bout my ls
- Question about brake light.
- Accerlation problem
- Car doesnt heat up properly....over cooling problem???
- Anyone have pix of Darton Open Deck Sleeves?
- were can i find an hks hi power for a good price ppl any places u know
- Code 43, fuel supply system
- exhaust set up question
- Kumho Esta 712 or Falcon Ziex 512?
- exhaust questions
- looking for a rim repair shop in M.D. or east coast
- are these springs any good?
- idle problem...
- Weird Problem with Acceleration?
- Help!!!!!! with O2 sensor
- Replacing OEM Cam Seal
- Cat-back exhaust put on now exhaust rubs
- what is the differnce?? (transmission)
- ATF fluid change. searched archived and normal and came up w/ 2 threads..
- Cleaning Sunroof drains
- what is this?
- anyone with vafc
- door panel tweeter hole
- vaccume???
- Will DA rear strut bar fit the DC?
- Radiator - Core Support: Anyone ever try fixing / repairing one themselves?
- Mugen Oil Filters?
- ignition problem?
- Having problems,help me out yall
- Integra Timing - Need SCS Service Connector?
- power steering belt question ( please help )
- GSR TB ~~~~LS TB
- steering wheel cut because of the club
- Bought headers and cat, now to the muffler shop
- Gsr Skunk2 Intake manifold question
- Doesn't Pull after 3rd??? NEED SOME HELP
