View Full Version : Acura Integra
- Apexi World Sport II??
- those of you with HIDs...help
- grounding points
- watsup up with my ABS??
- what crap about these rims
- Short ram on, and I lost to an LS!
- JRSC Question
- Quick question....
- rs*r exmag exhaust tip size?
- RSR EX Mag Exhaust for 1994 GSR
- 89 Integra Rear Disc on Ej1
- Fair Price??
- help changing guage clustre and climate control lights.
- suspension ?
- will civic gsr piping fit my gsr
- ody??
- New car
- car won't turn over
- JRSC for gsr's Safe boost Pressure opinion?
- wounded duck noise.... hmm.... help!
- how many pounds are the stockwheels ona 96 integra ls
- type r brakes
- Anyone know the people in orange county, Laguna Niguel Area that own a Yellow R?
- will del sol rims fit GSR brakes??
- ground controls w/illuminas
- 92 acura B18A motor for sale
- help, car wont start
- CEL 76?
- Help with CEL 61
- where can i get white face guages?
- Over Reved engine qusetion....
- turbo question
- Integra under dash similar to 92-95 under dash?
- Whats the Best stock B-series Cable tranny with lsd?
- will the tranny work
- Know where to find?
- having a problem with my 98+ tails in my 94 LS
- F/S V-AFC I and TODA RACING LIGHTENED FLYWHEEL
- question bout lowering car?
- Computer help
- Paint code
- motor swap and exhaust question 1992 integra
- legend calipers
- A VTEC controller with this setup??
- Suspension question for tech's....
- 90-93 integra JDM side moldings
- new engine bay shots
- taking off rear view mirrors..how to?
- A suggestion which would benefit the Integra forum audience
- 1997 gsr dash into a 1992 ls with no gsr harness
- neuspeed sport
- codes 10 and 43
- Irratic Idle
- what kinda bulbs fit the jdm headlights for a 90 integra
- Can cam caps be bought individually?
- Any input on this crazy electrical prob I have??
- clutch or actual transmission problem?
- Radiator Bolt
- transmission
- Best way to put a switch panel where the DIN pocket is? Need ideas...
- indiglo gauge installation in no. VA/DC
- Post ur fastest 1/4 time in ur ls or lsvtec 3rd gen tegs
- Post Pics of Apexi N1 Catback Exhaust on '94-'00 Acura Integra GSR
- AEM Cold Air
- Part numbers?
- first drive in a gsr... some questions
- Cooling sys. problem
- What octane to put in my stock JDM GSR motor?
- how many guys running block gards
- just wondering... how do k20 and h22 swaps into tegs compare?
- how do i post my k20 swap?
- Problem grounding HID's
- Crank pulley bolt...need help
- usdm to jdm front end( made a lot of search)
- fiberglas interior
- exhaust manifold
- Pros/Cons .... can u help me out ???
- new pistons?
- quick question
- this belongs in the classifides but im just getting it out there please look...
- OBD0 to OBD1 conversion with auto tranny
- Wood shifter trim
- Do you know cam specs?
- how do i post an image
- i finally did it.. J's Racing STYLE Intake > 2nd gen.
- happy new year everyone!!
- help taking out abs and making my 94 teg non abs
- Can you reccomnd a Dealer with lots o' parts near PA?
- CEL 07-throttle angle
- Whats one thing u like about your car?
- Are you the owner of this Integra in Florida?
- headers
- S-T sway/tie combo with 2.5" exhaust
- 2004 LA Autoshow PICS - Media Day- See them before you even go
- HOOKUPS IMPORT-TEK ????
- help with steering
- how true is this?
- IAT sensor "Modification" This thing bullshit?
- how do i post pictures
- Bolts size for header?
- will i need new lightbulbs if i get a 98+ conversion?
- Anyone own Nippon wheels? How's the quality?
- Part No. for Magnaflow cat-back?
- accident
- Weird smell after getting on it
- exhaust question
- Please give input on this Tokico suspension kit
- need help with setup *lsvtec*
- Will a 3" LS short ram intake pipe fit an ITR?
- 94-97 NOPI oem style foglights???????????
- kinda rim and brake q
- Will 13" Wheels fit on a 94GSR
- quick question on spark plug gapping
- will a 94 gsr tranny fit fine in my car
- state referee fix it ticket
- paint.
- Fog Light Switch on 91 integra???? shut's off when high beams are on.
- OMG 270 for the DC 4-2-1
- Fuel and ECT instrument gauge Gremlins.. Please Help..
- Can someone provide me the part no.
- For those who are "slammed"...
- Got my AEM V2 Intake On my GSR!!! YA
- Radiator leak??
- Spoiler Plugs
- Buying a 93 GSR...
- my wrecked Integra, bodywork, and 2000 Integra front end
- is g2ic down?
- new integra?
- anyone have greddy sp or sp2 pics on their car?
- Radiator fan problem
- Admin or Mod...please read
- Problem with my 2000 ls
- how high should i rev??
- ITR Cam'ers, valve springs/retainers needed?
- Those with 98-01 OEM/Type-R Lip
- Timing is weird?
- b18b valve adjustment
- 1992 acura interga B18A FOR SALE
- ported head now having idle problems.
- 90-93 jdm integra Xsi cluster?
- stereo install
- 86-89 Integra
- Someone Please carfax this LS for me.
- can anyone with a 96+ teg tell me wires for resistor box?
- Rear Skunk2 camber kit squeaking!! (Yes I've searched already)
- how much are 98-01 teg tail lights worth?
- dipstick tube popped out
- How do u like ur tein s tech's?
- Catz hid owners..
- lip kit help
- inner fender cover
- your opinion on what size tires!!!!
- Clutch Smells Funky
- 1991 INTEGRA SHOW CAR FOR SALE
- ls/vtec question
- what are the diff between 98-01 p72?
- Caravan...SoCal to C.Cali MEET
- A/F Ratio Gauge Help!!
- Stupid question ,but I need help
- Spring rates
- Gas smell????
- Integra 1992 RS
- Valve spring question
- swapped tranny locked up...fixable?
- How do the front seats come out in a teg?
- ecu???
- Worth the upgrade?
- 94 rs gsr swap????
- anybody running 195/60/15 with 1 or 1.2 inch drop??
- PR4 ECU
- New motor
- reverse light switch
- CTR piston question...
- Got some money...Which to get?
- 95 LS cat/ 94 gsr cat, same or different? How?
- f*ck'd header install...??
- body work in bay area help!!!
- HELP needed, starter wont turn! car wont start
- Ground control help....
- GUYS I NEED HELP QUICK!!!!!!!!!!!!!!!!!!!
- anyway to distinguish stock injectors?
- Integra Questions PLEASE HELP
- A pictorial of my car & its X-mas presents [broadband highly recommended]
- need a honda part number please.......
- ES or PROTHANE Motor Mount Inserts... for those of you who HAVE them, how do you like them? ? ? ? ?
- help with vafcII install. i only have one wire left to hook up
- make my integra fast
- what's this noise?
- Plans for my first gsr!
- Alrighty my integra brothers great info here
- Tips and advice needed for pulling/rebuilding engine
- Front End Messed Up - Body Experts Please Help
- Need CF lip for 90-91 DA Integra !!!
- Alternator Interchangeability
- cloth seats in a geezer?
- Installing cams without any other mods.
- jdm itr center counsel?
- dumb emmissions question
- Apexi AFC
- Turn Signals wont work
- New Member....How long before I can post in classifieds?
- any fellow integra owners have this problem?
- Another quick header question.
- alarm question
- amber tail lights help and info
- quick question about cf hood
- Strange Noise: Sounds like wheel bearing - suggestions?
- woul a jdm zc fit an 89 iintegra
- DRL on my integra
- I need someone in Fayettnam NC to put on a head gasket
- 90 integra ls cluster
- where to buy ground controls?
- will a 00 civic steering wheel fit ona 01 integra?
- 99 civic Si intake in a 00 LS?
- Nitrous Refills : good price in San Jose??
- who did the rear wiper removal on their integra?
- Struct bars
- Are b16a, b18a and b18b oil pans the same?
- Is anybodys LS tranny marked Y80?
- Starter Problems?
- list all the shit that rattles!
- Removing and plugging up rear wiper ***
- 94 B18b valve cover different 96 B18b valve cover?
- Dremel uses??
- Anyone ever get a high-pitched squeeking sound when engaging the clutch?
- hondata shift w/o lift?
- quick question: cupholder
- Wheel offset and Tire size?
- Downshifted from REDLINE 3rd to 2nd. Is any thing messed up???? if so what?
- What tire size to run on stock GS-R blades?
- Gonna remove the power steering the correct way
- hondabond = generic permatex?
- manual swap installation
- ITR swaybar bolts, where to buy?
- insert pictures on honda-tech
- Yoko es100's really only "summer tires"?
- how to install custom integra foglights
- rebuilding?
- spark plug help
- 3rd gen dash into 2nd gen
- Highest miles you've seen in a teg?
- Headlights dimming
- new clutch prob
- VAFC and GSR butterfly operation........
- idle at 5000 rpm!!!
- Radiators Question
- foglights done!! check it out
- anyone here have specific experience with code 1?
- Any one have pics of 98+ OEM Fogs with yellow bulbs?
- 4 door guage pods same as 2 door?
