View Full Version : Acura Integra
- Brembo Rotors?
- Overheating problem... HELP...!!!!
- any1 else hate aicv's?
- Link to FS: Advans in 17x7.5, 4x100
- 16x7 rims, what size es100's should I get?
- Factory Acura Equalizer
- Critical decision making, I really need the help guys!
- 91 da suspension installation progress *finally, the day is here*
- need vin number checked
- smog question???
- Electrical Problem: Please Help
- where is the bottleneck in the stock cat?
- maryland members: i need a favor regarding a MD safety inspection for my car, will pay $$$
- Good Mechanic
- Smoke in certain gears?
- How to adjust Clutch point on a 94+ LS integra?
- nitrous
- will this IACV (idle air control valve) work in my '94 Integra GSR?
- brakes grinding in the rear
- Leaking Head
- 2001 Integra GS Coupe buildup for a buddy in Iraq--Writeup plus need suggestions!
- Lookin For 95' Integra GSR Rims
- b20/type r aluminum mount
- vertical doors not fitting?
- Brake master cylinder.
- Integra 1999 Transmission problem - help needed
- what brakes does 1990 rs integra come with in front?
- AC Condenser replacement?
- Rear Brake Lights Out?
- Need help identifing white container in front of car.
- gas funnel.
- Best Fluids...
- HELP wid header install
- ? Tanabe Super Med. Racing**already serached**
- Suggestions wanted for B18b engine.
- Hmmm....Code 13
- gasket matching?
- GRRR! 45???!!!
- hot wired fuel pump
- header and exhausts
- Full Coils from a DA fit on DC??
- Skunk2 valvetrain + turbo?
- cams
- engine for 90 integra
- shift point
- Tanabe Sustec Pro S-S Type II Coilover Kit
- Air noise from Illumina shocks
- ITR, CTR and '92 GSR Cam Specs?
- Need pic please
- Post your picture of your car and what coil-over suspenion you using
- WTB b18c1 shortblock
- Car cover
- suspension question
- Clutch issues when cold (95 GSR)
- intake manifold gasket
- My stock gsr dyno
- Shimming an LS tranmission?
- Can someone test this out for me? Spare key and Driver Door Lock.
- ECU Swap..????????????
- Help newbie decide how to improve 94 GS-R 4dr
- 94-97 front bumper question
- nut at the end of the axle.
- suspension question?
- pics of rear diffusers
- Alright so im driving &...BOOM!!!!
- B&M Short Shifter Question
- Help deciding on the teg's paint job
- engine problems?
- Can someone help?
- Intermittent Brake Light? (95 GSR)
- She's gone!
- OEM body parts source?
- weird noise from the front end
- Lurchy feeling + Smoke @ 6-8k rpms
- Stock GSR muffler size
- Nitrous? what shot?
- help about type-R muffler
- Anyone know where to get JDM ITR DC Fenders?
- Brake Question - '91 Integra LS
- Integra GS-R ABS Fluid question....
- Ls vtech or integra with no motor
- s2k antenna
- oil leak
- outlawengineering.com gasket set---I got one check it out! HELP! IAC
- FRAM Fuel Filter
- JDM Spec B20 OBD related questions.
- OEM kit clonage
- I want to treat my baby good.
- UNCAP your integra!
- eh..whats up with this integra??
- Will a 95 gsr leather seats front & back && door panel fit a 98 gsr?
- jdm headers and legal issues
- ED (88~91 Civic/CRX) steering rack in a DA?
- Ls ??
- CarFax Needed!!!!
- Doing a vavle adjustment, Need pics on step-by-step how to...!!!
- Racer Design Coilovers
- HEAD GASKET PROBLEMS????
- starting prob after AEM rail and regulator install...any ideas
- Avg. Oil Temp... i'm hitting 240F
- Brembo Brake kit
- Weird blinking noise and blinking lights whats the problem? Help please
- brembo drill slotted rotors...96 integra HELP
- what resonator to get?
- Super or Turbo..
- valve adjustment on my 01 LS
- Type R oil cooler install in a 2001 GSR ? yes I searched
- integra shift linkage help
- GSR brakes + ITR/JDM LCAs question.
- Type R oil pump
- b00st or S2k?
- installing shifter bushings???
- new fuel pump
- Haynes request
- Ignition Rotor (96 SE)
- SEE PIC.
- Ls/vtec success/and a question
- n00b question: can my stock exhuast handle headers?
- maybe it works PIC.
- DA Axles question
- what to do to get better weight distribution
- Newbie with 94 2DR Inetgra
- 98-01 foglight covers?
- B20 questions
- compression ratios?
- carsound cat worth it
- Anyone know where to buy Solex locks...
- New here, have a few questions
- Miss Hitting Help
- Replacing horn with car alarm siren/police siren?
- im gonana buy one , what is the diff btw integra gs vs ls?
- Is There any way to get all 4 headlights on when i have my low beams on?
- Popping front lower balljoints & other random observations
- map sensor
- tein basic's
- where to buy a radiator
- is there an auto gsr?
- When I apply Vac to the booster, wheels freeze
- what can i do to a gs. 140hp without forced induction?
- Found coolant in spark plug chamber???
- '94 Integra dead in water (electrical issue?)
- b20 head - b18 block completion
- Whats goin on?
- Alright rebuilt axles suck @$$, who sells new axles for a decent price?
- 1994 Integra LS Interior Color?
- Evo Exhaust
- do i need any upgrade my valvetrain? when i put light flywheel
- what could cause major top end loss?
- Cap and Rotor question for Integra....
- what part # k&n filter fits on a comptech ice intake kit with the icebox for 00 gsr
- Oh..Oh...Is this bad??
- map sensors
- spring and coilovers
- 92-93 GSR starter......????
- Tail/Corner Relay Lamps
- ls vtec POWER
- ANOTHER tps question
- Tein S-Tech vs Eibach Sportline vs Neuspeed Race (searched)
- Got my 62404 cams in today!!
- hey guys check this out!
- What's wrong with this ITR sway bar install (pics)?
- Integra Vs. Civic handeling
- tranny/clutch problems
- skunk2 exhaust?
- Flushing Transmission (MT)
- Simple Question - Which gauge wire to use?
- price sound fair???
- What is my squeak???
- Need advice on camber reading.
- CF hoods and hood pins
- Wiring MSD 6A to replace the ICM (Ignition Control Module - Igniter)
- Anyone got pic of there drop? around 2.0-2.5f?
- what computer to use for 1991 acura integra with a b16 vtec?
- 92 b18a1 into a 90 integra
- Cluster Lights wont work
- Which clutch and flywheel
- DA owners... battery relocation?
- hyper ground wire install on a LS engine
- EF/ED H&R Coilovers installed on a DA...sexy...do you think I need an alignment? (56k, umm...no)
- Pics Request: Rota Slipstream Bronze on DC2
- Comp-Tech Ice box
- Cam Advice B18b1 LS motor
- IAC and cel14 question
- p28 ecu w/ gsr... helpasaurus rex!
- lip crack...
- 94 gsr with engine problems
- Any1 have pics of a JRSC???
- tokico illumina setting Q. *searched also*
- Apex'i "power intake"?
- 94 GSR having trany problems?
- supercharger
- won't start....sometimes
- swap valve covers??
- Integra Overheating?!
- What is a b18c5 swap?
- Brake rebuild Grese? or Brake fluid?
- touge??
- Why is the vacuum so low?!
- help!!!
- clutch
- engine idle
- ecu pinout gsr
- LS/VTEC?
- 91 Integra, B18b, Super 60, TurboEDIT, 10PSI
- need help... how to take out the cd/cubby player on 98 integra
- what is a port
- Catalytic Converter or Straight Pipe
- weird harmonic sound..
- suggestion on a good suspenion setup...
- a/c mount problems
- comptech header finally installed
- need help with idle problem!!!!
- A/C Compressor, dried out?!
- PLEASE HELP ME!!
- DA to EF swap is it worth it?
- Help strut bar wont fit
- need help with removing old struts ........please getting desperate
- Annoying squeaks from rear of car (hatch)
- questions bout my own teg, can any one help me?
- WRITE UP: Cleaning those pestky foggy headlights (56k, just be patient)
- Had problems w/ AutoZone axles? Maybe this is why....
- Mugen intake install in a GSR (pic extensive)
- trouble clocking turbo
- Polyurethane bumpstops
- LS/VTEC turbo question
- Fuel Pressure?!
- brake caliper bolt
- sprint camber kit.. what do you guys think?
- OBX Fuel Regulator Any good???
- running rich for a long time bad for motor
- brembo vs. "no-name" brand cross-drilled/slotted rotors?
- 1990 Integra GS Swapped with GS-R Tranny
- Did Some XSI cars come with S1 or Y1 trannys?
- HELP: possible fluid leak from my power steering pump..... what to do??
- Im so confused.
- 5zigen exhaust???
- 94 gsr - does 02 sensor connect to header or cat?
- A quick question about the laws.
- 98+ Helms Scan Request...
- 94 LS B18 hop up?
- BIIIGG electrical problem, or so it seems
- cant get axle out trani PLEASE HELP ASAP
- veh speed sensor code anyone??
- ? about USED jdm front
- JDM fog light switch...clicks or doesn't click down
- Can anyone help with a rear windshield wiper problem?
- gains from LS bored to 2.0L (searched)
- Fog lights install??
- Speed sensor, Where is it at???
- difference between 90-91 and 92-93 Ys1 cable tranny's????
