How to rechip an ECU?
Old Oct 23, 2002 | 03:18 PM
vtec69's Avatar
Default How to rechip an ECU?
I have a p28 with a mugen chip but that chip has no rev limiter and I need one. Is it difficult to rechip and ecu if you have a basic knowledge of wiring or is it diificult?
Does anyone have any detailed directions to do it or has anyone done it thereself?
Thanks
-Brian
Old Oct 23, 2002 | 03:28 PM
filetofit
Guest
Posts: n/a
Default Re: How to rechip an ECU? (vtec69)
If your ECU is already chipped with a Mugen program, most likely the person who chipped it soldered in a socket for the ROM chip in which case rechipping it is a piece of cake. Literally plug and play. Go to Hyperduck tuning or someone similar and buy a chip for your ECU that has the rev limit you want, open the ECU up, unplug the old ROM and plug in the new one.
Just make sure you take off your shoes and socks when you install it, I know it sounds funny but static electricity can destroy those chips and going barefoot will help ground out any static electricity you are carrying.
Old Oct 23, 2002 | 03:30 PM
vtec69's Avatar
Default Re: How to rechip an ECU? (filetofit)
with these chips can i still adjsut vtec with my vafc?
piatl7il77's Avatar
yeah make sure to ground yourself out. just touch pice of metal before you touch the chip
Old Oct 23, 2002 | 03:53 PM
vtec69's Avatar
Default Re: How to rechip an ECU? (piatl7il77)
what do you think about J's racing chip?
piatl7il77's Avatar
yes you can still adjust the vtec engagment point with your vafc. with a new chip
Old Oct 23, 2002 | 05:31 PM
brinks's Avatar
Thanks
-Brian
No wiring knowledge is required. Soldering experience is required and recommended. Since your ecu is chipped, it is likely socketed already. Someone with a stage4 hondata could probably burn you a copy of your chip with an adjusted rev limit.
panchlow
May 18, 2011 07:34 PM
trav39562
Jan 3, 2009 09:54 AM
Slow Egg
Mar 20, 2003 09:07 PM
vtec69
Oct 24, 2002 05:07 AM
