View Full Version : Acura Integra
- losing pressure when applying my brakes
- 92 Teggy
- Is there conductive glue? Tint installer broke off the tabs for the rear defroster...
- RESONATOR
- increase your hp?
- how much should i charge?
- GSR MOTOR what should i do to it???
- Tips on removing intake manifold?
- Tranny scratch !!! PLEASE HELP
- da teg ???
- Wheel bearing or not?
- DC2 BUMPER SUPPORT
- Idle Problem, cant figure it out!
- Anyone running an exas exhaust?
- My auto teg is slipping
- Just bought 93 Integra....minor problems.
- Starting LS Project
- Can a GSR use a P28 ECU?
- Idle air control valve problem
- how much should I pay for a 93 Integra LS?
- Automatic to Manual Conversion For 91 Integra
- omni power lca's
- Would you guys buy turbo kits off Ebay?
- Horsepower loss?
- which brand's brake rotors is the greatest for 95 integra (F & R) ??????
- how much to pay for a 94 gs-r 4dr with 175k
- Important question... Can I use this piece from GSR 4 lug on JDM ITR 5 lug?
- I must have a HONDA again !!
- Anyone Ever reused a head Gasket?????????? Is this possible?????????
- Might be stupid but, Whats the difference?????????
- Mesh Rims
- HIDs - S2k retro / How-to write ups?
- d16 fuel rail on b18c
- vibration through brake pedal when cold?
- Diesel fuel in gas tank?????ASAP ASAP ASAP
- 90-93 integra pedal adjusting HELP!!!
- lucas oil stabilizer ?
- ok need your opinion on if its head gasket going
- JDM DC2 VIN removal
- Dented oil pan.. and .. turbo ...
- 96 LS motor in 91 teg
- Trouble Starting
- acura emblem
- oxy sensor wiring
- To high of compression?
- is it safe to pull after valve adjustment
- helms manual on CD?
- where is the fuel injection fuse?
- Wheel bearings?
- how to on hood
- Hola
- eBrake light...
- what kind of difrenence would it make with throttle body
- 1998 ABP LS (Good find?)
- cel but throwing no code
- muffler tip
- helms
- is the Type R tower strut bar a direct bolt on
- i need help
- How to... 94-97 front end on a 98-01
- Got 94 GSR Need some help w/ going all motor
- need new bushings, a little help?
- brake light stuck on?
- bent valves?
- any know where i can get an OEM side marker socket wires?
- Who's selling JDM integra Tailights? Can't seem to find the link (searched)
- Blowing smoke at WOT.
- When changing brake pads, what part of the caliper should be lubed?
- WHAT 2 DO!? which one?
- b18b.. fitv
- auto to manual Center shaft question?
- yO! I need sum help with my DA please...
- Upgrading headlight harness
- b16 head ls block
- looking for a B18C5 swap tips..
- whats the diff from the Aero Type R lip and the OEM Type R lip?
- steering/turn ration...
- Auto to manual swap.. do you have to have the hasport mount or like?
- b18a1 block...
- how hard is it to rebuild a tranny??
- i would like to go all motor, i need ideas...
- would a 2dr gsr headers fit a 4dr gsr
- how to fix the header bolt threadings from the head? =/
- Audio: RSX stock deck to 98 Integra
- advantages of throttle body
- weird problem when engaging in first gear aHHHH!
- N/A set up¿?¿?¿?¿
- Integra 96 LS front end
- 98 GSR stolen
- jdm itr cluster in gsr Q HELP!!!
- Momo Hub and Nardi
- I need the ignition diagram for a dc2..
- radiator fan doesnt turn off
- 98 Red GSR stolen, need help please
- Heater Core in a 93 Teg
- Good site to buy performance parts?
- On exhaust help
- '95 gsr idle issues
- Electrical Theory question.
- what do you think
- Do auto sound specialty store install sound dampening mats or spray-ons?
- LCA Question
- Hey guys.
- Immobilizer System light won't stop blinking...
- Oil level - hot or cold?
- Replacin Driver Window ??
- Rings? Need to figure this out!
- Is the civic si engine harness the same of the integra type r engine harness
- cel 22 vtec works tho whuts up?
- choices on racing clutch
- noob question. help me tho
- Tranny pops out of 5th gear
- 270 thousand miles. What should I do?
- Tail lights question... do these exist?
- i got a gsr 1999. wanted to know should i go all motor or turbo
- was^ any parts
- in need of knowledges
- could cold keep my car from starting?
- Does anyone here use Uberdata?
- DA9 Woes Help Appreciated
- im going vtec
- i have a horn question?
- still having vtec problem, can anyone help
- Rear brake question
- Engine Internals Question
- removing TAR Pics
- i dont know where to start
- o2 signal wire/ecu ground where are they???
- type R swap
- sale GSR motor
- Intercooler question for LS integra
- Vacuum Modulator
- Wiring for jdm dc2 healights?
- Any of you Integra guys want a Type R? Link, probably against the rules...
- STOLEN INSIDE MY TEG
- What Coilovers are everyone using?
- severe Overheating problem (noob question)
- cleaning my headlight???
- Bad Jerk When Moving
- 98-01 front clip
- SQEAKING PLEASE HELP
- overheating exhust
- ILLINOIS HONDA DRIVERS KEEP AN EYE ON YOUR CAR
- what kind of spark plugs?
- half way done with turboing my b18b, need some help people......
- header bolt broke
- For all you 11-inchers...
- Is it against the law to not have the third upper break light?
- 95 Integra GS-R stock SRS steering wheel to Type R non-Srs
- wtf.. i think its photoshop..
- Questions about HID lighting for integra
- i need a teg
- where to put a greedy catch can?
- Hatch light working when it wants to
- Getting Exedy organic clutch kit tomorrow.. should I resurface stock flywheel or get streetlite?
- 90-93 integra traction bars, z10eng vs full-race
- gsr jackson racing
- Pic request: OBDI ecu VS OBDII
- Racing Seats
- quick question about sticky stuff on botom of da
- WHP? Integra GSR 1998
- Got some new stuff for the DA
- Comptech Icebox on GSR stock arm?
- Transmission needed badly!!!
- LHD to RHD
- Block heater?
- How do you change/check your tranny fluid?
- Few weird things about new integra
- best tire for auto x?
- transmission question
- leaking clutch fluid, cant find where the leak is? wtf? somwhere near radiator
- Any Tuning Shops on Long Island???
- Is it worth it?
- Color of choice =] VOTE !
- Check engine light problem
- BREAK this down
- throttle body coolent bypass
- HP?
- Im new to HT, Come and welcome me
- SWAP
- Cotter pin size?
- 94 front on 2000 integra
- dc4 power steering, no power steering?
- Re-wiring fogs...DA
- looking for flywheel plate
- da intgras here
- Why you shouldnt bother with highflow cats
- difference between..
- integra pics
- Spark Plug Wires : pull out = OIL !!! HELP!!
- Boostin my Ls CAMS ?????
- Car shutting off, what could it be??
- Loud injectors....
- Just got my DC4 from garage today with B20 on it!!! crazzy power !!!
- Right Hand Drive Conversion
- Idle Control not norm....no codes appear
- new clutch and grinding?
- are obd1 cars faster than obd2 ?
- 98 GSR pricing
- Rethreading my gsr head?? exhaust manifold side stripped up the booty
- Wierd Idle?
- got a new dc4
- is there an Invidia exhaust for my '94 4DR GSR...?
- Seafoam Ruined my engine, HELP PLEASE
- Is there such a thing as an oversize conn rod bearing?
- 1994 gsr head , bad compression test, vtec feels like shit
- b18...
- about my boost LS
- Synchro mesh
- GSR with projectors?
- Individual throttle body question
- b20a6 with b18 head?
- Aftermarket LCA's and Comptech Sway/Tie Combo
- 00 acura integra gsr FOR SALE
- b18a head with crower valve train for sale
- anyone have probs with H&R's w/ koni yellows ?
- Quick b16a question?
- 15 inch heliums wheels for da
- Grounding kit
- NEEEEDD HELLPPP!!!!!!!!!!!!!!!!!!!!!!!
- 92 gsr power steering
- Smog HELP!
- What harness includes the connectors that connects to a clip on the radiator fan shroud for gsr
- 95 Integra GS-R Tokico and skunk 2 springs
- Cel code 1 need help !!
- AZ honda guys
- Color Code for Monte Carlo Blue
- H.I.D's+JDM headlights=MELT?
- will 99 civic coupe Corbeau racing seats fit my 00 gsr??
- How do I adjust 98+ headlights?
- WANTED TO BUY Integra SHELL TO DROP MY H22 IN
- Getting tein s springs, what shocks/strut should i get?
- Bad Caliper?
- 97 gsr muffler vs. 97 itr muffler
- RED carbon fiber?
- DC2 ABS difference between years? Size is different but are the wires the same?
- Front Fenders/Bumper
- Iceman Throttle Body....good or bad?
- Question about pistons?
- Thinking of going Turbo, what will i need b4 i get it?
- New
- rpm dropping
- 98-01 INTEGRA HEADLIGHT QUESTION!!!!!!
- Front end Sir-G or Type R ?!?
- Is this reasonable price???
- Radiator Hose install
- fuel filter on a da
- NEED HELP WITH MY INTEGRA VTI-R
- you think this turbo be to big for my gsr
- EF exhaust bolt up to DA?
