View Full Version : Acura Integra
- Valve cover question please help!!!!!!
- Car Battery
- What kind kit is this...
- For those JDMI member still wondering...we're back online :-)
- Sigh... when will it end...
- b18A ECU on a B18B1
- GSR Timing Belt Tensioner
- Anyone used the Heddman/Chikara Header for a GSR?
- how do u stop coilovers from squeeking??
- Just installed the Icebox
- Alright so I'm brand new...
- 91-93 vs 94-01 ls..?
- My clock and Stereo is not working
- Shipping- Suggestions
- '00 Si stock radio in '98 Teg GS?
- ebrake ?
- Any deal with RevHigh Online before?
- high speed vibration
- Intsalling OEM Side Markers?
- Please help w/ forum!!!!
- will 93 gsr distributor work in 92ls???
- Help me out .... Just got a jdm b16 tranny and a.c.t. four puck clucth disk
- 2000 gsr warranty
- which all season tires??
- how many do work themselves?
- adding DC 4-2-1 CC header on LS motor with I/E, Gains? how much?
- painting valve cover quick question
- Need Help Loggin in!?
- 90-93 integra shakiness and vibration
- Introducing my self....
- General Question with very many Answers
- 93and back vs 94 and up MAP sensors
- lower tie bar?
- newgsrdriver's BIRTHDAY TODAY woohoo!!!
- Need help deciding..
- valve cover painting gunk
- Newbie Question ??? Difference between 95 and 96 GSR?
- dressing up the interior?
- Ne1 Ever Try This Looks Interesting
- How much do b18b complete swaps go for?
- Blown a fuse or something need help!
- NEW CAR
- What kind of TIRES do you guys recomend for an 01 GSR(Stock rims/suspen) ???
- Problem: I think my starter is going bad
- Tach/Vtec Not working well
- Help me get my heat workin!!
- Weird Question
- shaved my antenna, what should i use now
- b18A1 / b20B cam profiles
- Integra catalytic convertor
- car wont start
- Oem Replacement Parts
- Where did you buy your clutch?
- resale value for 98 gsr turbo??
- steering wheel help
- Door Panel Question - Rs non power door w/ power windows vs ITR/GSR
- High idle problem
- GS-R guys!......trade for an LS to boost????
- what is need to store my R
- Rod knock in cold weather ? only when starts up.
- Where do you guys shift on your LS motor?????
- Do i have all the parts necssary for a complete 5spd transmission swap?
- type r spoiler...
- Blah.. Ok, what gives? Car trouble ;(
- quick question
- need some pic help!! gsr blades on g2 tegs!!!
- CAN SOMEONE PLEASE...
- RS vs GSR or other integra trims
- Light Wheels = Light Steering?
- rpiracing.com?
- need JDM lights
- Building rear camber kit for a 93??
- b18c1 cheap
- Need some suggestions.
- how do u adjust the stiffness on tien HAs?
- Chattering sound coming from tranny???
- I'm facing a dilema - seaking opinions
- intake soft mount
- looking HID how-to post I saw in a clasified ad awhile back
- just installed s2k antenna, will it leak?
- GSR wheels fit 98 4 cycl. accord?
- Turbocharging a g3
- Overfilled Oil
- does the civic cams look right
- JDM swap legal in cali?
- fuel pressure on a b20 vtec
- difference b/t 94-95 head and 96+ head(LS)
- drivers side window switch not working
- did the search but are not satisfied.
- E brake light stays on in dash?
- buying new header what should i look for!?!
- fitting question about exhaust
- Types of locks.....
- Gsr rims almost stolen tonite!!
- How to install Hids?
- Help: Need Integra Radiator ASAP
- Lost control of my car today on I-95. Wanna know what I tried to do to regain control was correct
- apex n1 vs. thermal r&d
- Aiming the headlights on my integra?
- more problems
- i know a guy with a sleeper..
- Motor Swap 2nite. Get this...read more..I need help!!
- Good Header
- help what is code 22
- JDM p72 ECU vs USDM ECU
- quick snap shots of my integra
- what kind of motor oil for my 95 GS-R
- can a 89 jdm auto integra tranny work with a usdm 97 integra automatic?
- 97 GSR question
- vtec soliniod (sp) still leaking after replacing gasket!
- Gettin a teg!
- 99-00 Civic Si ecu in a 98 LS??
- Tires
- JDM Integra HID headlight question
- Help on brake setup on boosted car?
- interior trim and stereo removal, please help!
- side swiped
- F*%&in head bolt wont come loose
- best brake system?
- installed OBD harness and ECU, cannot get kick panel back on! HELP PLEASE!
- Bleeding clutch master cylinder
- What size cooler?
- Carbon Fiber gauge bezel for 98+ integra
- scratch on new headgasket.. is it defective?
- Q: Automatic transmission differences?? (B-series)
- AutoLock, how do you guys use yours???
- quiet mufflers?
- If you live in GEORGIA and have a TURBOd TEG, I need your help.
- 1/4 Mile Times on DA
- Lowering problem
- Does the JDM Integra Si VTEC have sidemarkers on the fenders??
- Lookin' for a fender
- anyone ever try this crazy BS?
- do i really need a camber kit?
- question about DROPZONE product....
- how much horsepower
- New Here, sort of...
- Got Hot Wheels for my BDay from my wife.
- Replacing carpet
- Just hit 60,000 miles (how many miles do you drive a year?)
- Miles
- Where and how much would hydraulic lines run me?
- best cam shafts
- G3 Integra Dash Remove / Removal
- How often do you chagen your spark plug wires?
- I want to buy a Cat-Back exhaust for my '94' GS-R coupe
- ESPELIR springs
- how to identify H&R springs?
- 96 JDM teg
- No, it's Friday, please go away. [MAINT REQ Light]
- i just got him :)
- Need a little info on some wheels....
- o2 sensor affect fuel with safc?
- Ls v-tec
- Some new products from SEMA...
- performance clutches
- integra vinyl Q, tried appearance forum already
- Tail lights and paint.....
- Is this a good deal on 1990 integra?
- Is the ZC trans the same trans as the 86-89 integra trans?
- Alpha Male Performance Electric Superchargers for Honda engines....
- Had an accident...what now? (pics)
- DA9 DIY RAM AIR setup
- GM Syncromesh review
- Jdm or usdm Type-r.. how do I tell
- Good shop manual?
- Anyone who has ever dealt with tail + spoiler break lights on a 94+ tag, PLEASE HELP!
- has anyone ever had problems with the REVERSE GEAR?
- burning oil
- Where to find 98-01 oem side skirts? Help.
- obd1-obd2 integras
- new on H-T, saying hi....and here's my DA
- New OEM Honda filter for Integra?
- Koni Yellows/Eiback pro kit
- need help: headlight alignment
- need some suggestions for 90 teg.
- GSR OIL CAPACITY
- Does an LS intake arm the same as a ITR?
- Hand Brake problems
- Tips on theft prevention for my fellow teg owners
- Good deal for a 95 Gsr???
- Liquid Filled Gauges
- Integra LS Info
- Which performance bolt ons are worthwhile?
- My First Pic on HT!!
- Stupid wires????
- Advice... 94 LS-I/E GSR tranny, get lightened flywheel or not? read inside....
- h22 swap into LS teg
- alleged vtec problems
- Will a stock clutch grab an 8lb flywheel (ls teg)
- car stalls when car warms up???
- Where to buy helms manuals when helms is sold out ???
- Need some help guys
- toda cams
- ST 19mm Sway Bar tearouts?
- Mixing DOT3 + DOT4 fluids
- camber kit
- cooling fans
- JDM SiR-g Gauge Cluster - will this plug and play into my 94 Auto LS?
- cheap intake for GSR
- chip swap p28 to a p78
- what the best camshaflts for 92 integra gs-r B17A1?
- Adjustable Height Shocks ??
- squecky noise
- Look At this NEW intake Manifold!
- where can i get my cd player codes?
- Where can I find hatch support struts for a '00 with a factory wing?
- 2 problems: loud fuel pump and squishy noise coming from pass. side wheel well
- All motor LS Set up? Post here.
- Gen2 Integra Door Question
- cam identification
- where do i get gaskets and bolts
- Surging Idle
- Charcoal cannister
- upping the redline
- what should i get??
- tossin up cel 92
- yet another idle thread
- No idle. new head install crower 404s
- pumped!!
- Is there a difference between Ls and Gsr harnesses or is it plug and play
- N1 for DC4 on DC2
- GSR & Special edition
- stage 1 brand new skunk2 cams for sale.
- 4 pistons calipers any better?
- my interior light wont light up help....
- problems
- will 90-93 integra springs and struts fit a 94-01 integra?
- Integra Header with 2 1/4" collector.. anyone anyone..
- Will 90-93 teg rotors fit on 94-01 tegs?
- 92 civic hatch seats fit in a 95 gsr 4 door?
- checking cel codes
- Apex WS suspension
- How do I get this Integra Factory Stereo Out??
- GSR head assembly...
- Need help.....car seems to pull slower
- NEED HELP W/ SWAP !!!
- what size is the fitting in theoil pressure sender unit?? on ls block
- Exhaust ?
- 99 gsr head on my 90 gs. NEED HELP!!!
- tell me how this can be
- spring rate
- GSR Exhaust tips?
- OT: Butterfly Valve in 330Ci Tailpipe??
- flushing the transmission
- Car meet in NY every Thursday
- saw an interesting integra the other day...
- Question for those using a JDM ITR Cluster...
- How do you remove the gauge cluster?
- cleaning?
