View Full Version : Acura Integra
- headers
- valve spring question
- Climate control 94 integra RS
- Which ECU to use with Type R Head
- deploying to okinawa (any info on parts stores?)
- any difference in gsr transmissions from 94-01?
- Is cam timing a problem for a 0.065" headgasket?
- speaker wire colors
- Low/no power steering assist
- GSR transmission problem HELP!!!
- h4h bulbs for jdm one piece
- A/C ... anyone selling thiers? :)
- 95 integra ls question (engine swap)
- extended lug
- tranny part question..
- Axel and suspension help question for 96 Ls
- Bought crossed battery terminals integra..
- Anyone put Volk Time Attack wheels on their G3 Integra?
- OBXR or JVT Racing Header?!
- fender gap bigger after suspension installation ???
- I am wondering if i should buy stilly i have si rims now. What are they worth
- Port and polish..worth it?
- cheapest decent set of springs/coilovers for DC/DB chassis
- What's the difference?
- Gas pedal no longer sitting right...
- Car Wont Go Into Reverse!?! Help?!?
- 13 inch wheel fit on Da ?
- help with turbo timer
- Weird idle problem?
- question for anyone with 4x114.3 conversion or anyone that knows something
- whats the best way for a b18b1?
- 00' integra w/a 18a1 swap, what should i do now?
- DB8 Roll Cage
- Question about Brake/Lamp Inspection - California
- 96 Integra LS going to OBD1 quick question.
- body control module
- the clutch system question
- Need Help on changing brake pad for Spoon Caliper
- dc2 Type R non-srs steering wheel.
- Type r head water outlet Question?!
- Integra Questons
- brake bleeder screw size?
- *HELP PLEASE* Steering rack issue
- 1998 GSR CATALYTIC CONVERTER PROBLEM!
- Think im selling it for too cheap?
- Car won't start!
- how do you rewire connector?
- FUEL CUT OFF! kill switch
- Parking lights dont work
- Is it safe to bore a b18c1 .25 over using 91 octane every day driving
- Integra Problems???
- transmission fluid change
- 96 INTEG CLOCK DONT WORK HELP !
- b18b in 91 integra help with pics
- h22a w/ LSD trans swap into integra
- hey an tuneup questin
- where to order pistons?
- ANYBODY GOT A PICTURE W/ 96-98 CIVIC FRONT END ON A 94-97 INTGERA 4DR SEDAN..........???????????????
- Can anyone help?
- question about carbon fiber fenders
- what are these rims
- TheReplacement: Pics...
- intake question
- car bogs, sputters, and shuts off all of a sudden.
- suspension question about my 95 gsr. ANd blinker question
- Exhaust Ticket
- what is this???
- just installed the ASR rear subframe brace...
- Internals
- 95 RS wireharness question... PLEASE HELP
- Accord foglights fit integra?
- Boosted LS?
- head code???
- idle jumps.
- gsr MC and booster
- Burning through a pretty hefty amt of oil..
- gsr aebs intake manifold
- Is this an LS or a GS??
- Any centrif. supercharged DA Integra's on here?
- after market aem intake ?
- H emblems on a Integra
- b16 crank pulley on b18c1, what ps belt?
- what throttle body gasket for jdm gsr ?
- plug wires
- cable tranny best combo
- vtec not kicking in
- any one ever see a s2k cluster in a DA??
- question about holly fuel pump?
- Car is whistling
- 91 integra ls, blew a rod, steps to change the block?
- some pics of my new password jdm kevlar intake
- OIL IN CYNLINDER 1 AND 4
- dc5 exhaust on integra
- B16 breaking up at 7400 RPMS
- needs pics quick
- Compression test Questions
- b18c1 gsr head scarring cams help
- Oil Pump Issues
- wheel bearing help?
- Last minute ?'s before head swap
- shaved bay
- too much wheel spin
- DIZZY ?
- I manage to do some crazy things.....
- camber kit installation.
- wire harness
- tranny problem or is it clutch?
- torque specs for drivers side mount to block?
- 99 GSR Motor Help!
- ONE PEICE HEADLIGHTS + hids curious?
- Possible Integra Purchase?? Need Opinions here
- broken motor/tranny mount cause bad caster?
- very important question...
- NEED A RECOMMENDED BODY SHOP IN MIAMI, FL
- SPOON POWERED MIRRORS any installation ideas?
- tries stalling when hit gas...
- jdm foglight switch................
- Got a weird problem?????????
- Need Your Oppinions
- H7 lights? confused
- Hoses
- Im outta ideas!! Temp gauge overheating?
- should I ...................
- How To: Turn your Clear Housing JDM Headlights to Black Housings for about $10
- B18b obd0 swap in 91 integra help! with PICS!
- please!! i need ur help!! with my clutch cable
- jdm front
- SPARKS FLY!!
- Looking for some input: DA Auto to Manual Swap - Complete 5 Spd Donor
- car wont start
- my b18b ls is running ruff!!!!
- Need some advice! Map senor problem or something else?
- form vs. function
- b20 into 96 integra
- Should i get aftermarket keepers for my head ???
- calling out all jdm front owners
- help with putting obd2 gsr engine into my obd1 94 integra
- When replacing suspension, which parts don't require re-alignment
- manual tranny into a auto car, what's all needed
- Coolant Leak Only on Cold Startup
- installation of hatch on 94-01 DC2???????????HELP??????
- usdm Type r vs JDM type r
- Car Surges?
- noob question about shocks
- Replacement Cat. Help.
- how much would you pay for ITR LSD Tranny
- DC2 integra dieting
- Ksport vs tein basics???
- bogging down and stalling problem *searched*
- honda acura badge
- WTB: OEM 98+ integra front clip
- Personal opinions!
- flywheel step height?
- Integra Midpipe Length...
- cable clutch problem
- anyone with a pic of auto manual tranny mount installed (DA)
- H22 in a DA
- stolen 1995 integra red LS philly area
- What kind of brakes to get?
- how many motor mounts???
- engine build?
- Car took an hour to start, please help!!!
- tsx retrofits finished last week, update :)
- oil leakage??
- 91 acura integra HID question
- state ref ticket!!...searched..no clear answer...look inside
- problems with fuel pump
- blox rear lca wow
- Driver side lower mount removal nightmare. help!!
- Integra OEM Body kits?
- need help. dont know what to do.
- 98 Integra GS OBD2 FuseBox
- Ice Box Intake
- ls block with type r internals standard pistons or oversized?
- Where to buy a replacement B18B??
- b17a vs b16a vs b18c head
- what bulbs would match jdm amber climate control?
- b20 vtec clearance
- seats
- gas mileage horrible!!! need help, putting canister back in!
- 91 LS integ swapped to a 95 GSR engine....
- My 90 Integra Has Issues I need HELP!
- Anyone have this problem with climate control.....
- suspension!
- CF Whale Penis intake ?
- Noob question on intakes
- must arp rod bolts for lsv
- Would the B16 crankshaft fit into a B17?
- valve cover questions
- integra gsr exhaust
- anyone?
- Short ram and Cold Air Sound?!
- b20vtec help..
- Noob Looking for a car Question
- itr valve springs and retainers?
- mixed feelings on my retrofit
- FMU instead of FPR?
- window
- RS vs. LS tanny...any difference???
- Help me pick my new pads
- check engine light/ misfire codes
- Remanufactured Axles vs. Aftermarket
- 91 Ignition problem? strange problem HELPZ!!
- Interchangeablitiy
- turbo vs. engine swap
- suspension HELP!!!!
- Looking for part number for bumper clips for jdm front dc2
- lowering car on stock shocks? 107k mi, 1.6 in drop
- Integra Cylinder head Codes?
- location of fuel pump fuse
- coilovers yet again
- B18B swap in 91 integra HELP!!
- Exedy Stage 1 vs OEM clutch
- Clutch rattle and shudder - time to replace?
- vtec not working?
- Looking to Buy and Build!!!
- GSR cams manual transmission and automatic transmission
- ITR aftermarket header fit B18B
- does anyone have a ES oval
- 90 gs with stock strughts with crapy sleave coil overs. Whats the easiest fix
- whats the stock right hight 1990 gs
- getting a DA needs ref please advise
- Injector Recommendations
- Changing My Connecting Rods??
- help..integra rear bumper
- teggy sidemarker install
- no heat comming out !!!!
- older honda's and HID Problems?...
- wiring bumper lights...da
- need to know quick
- Is a 95 integra GSR catback the same as a 94 integra rs?
- Timing belt / Water pump?
- AIR FILTER QUESTION ASAP
- Opinion on new seats to get
- Engine swap
- HEaders!!
- 2.5" drop H&R sports or whats best
- ls/vtec questions
- Read and let me know about this?
- Jdm b18c ecu question
- Installing Coil Sleeves on a DA?
- Bad Rubbing Sound! Help!??!
- DA manual rack bushing
- how will stock shocks hold up with lowering springs.
- da hell????
- Can i swap out Conneting Rods ??
- Front Bumper questions
- Conneting Rods ??
- what is the stock integra sway bar thickness???
- NEW HERE :)
