View Full Version : Acura Integra
- Any suggestions on a nav system fr my DC2, GSR
- LS/GSR Brackets? (AC & PS)
- cat back exhaust question
- toda headers
- Gsr cams b16 gears or gsr gears????
- swap transmission
- JDM/USDM blocks?
- whats the best turbo set up for a gsr?
- gsr not starting no spark? please help!!
- rsx cluster in a dc2
- how do u test to see if the distributor is good
- ? about Skunk2 intake manny!
- need help DB1 guys bumper?
- Common swap in 1990-1993 integras
- question about breaking the bolts on header/valve cover/etc.
- flickering oil light
- Sound inbetween shifts & going uphill?? help
- Engine oil overflow.
- help with headlights
- Cleaning fuel injectors?
- Integra repair question
- stock bore on a stock '96 B18C1
- Questions in regard to these pics
- Need help... 98 motor into a 95 shell... What's needed
- Chassis Flex
- Questions about compression testing.
- 5 lug on my DA??
- Looking for a place to fix a bent valve in Dallas/Houston
- exhaust question
- Help PLEASE!!! B18c idle
- 93 integra DA <How Low>
- Help with stain on paint...
- help with rhd throtel cable.
- Any way to fix faded paint?
- BlockFlush ?
- Ramdom ? but please look
- speed sensor ?
- Gauge Cluster went out after racing
- check engine need help?
- All B18B owners
- ITR sway bar on my GSR
- obd0 to obd1
- Engine bloging
- Piston Rings
- help: inspect my block b18a1
- please post times of swap integras with h22a
- which vtec head is best for ls
- engine is hot when its cold
- RPM tac going crazy!
- stolen...97 integra ls...la mesa san diego
- iab ?
- air coming out of intake manifold....
- 2000 acura integra
- Ecu Fuse problem?
- wats this engine???
- Terrible Dyno Numbers
- Compression Test Done..
- V TEC AFC HELP
- JDM fenderliners necessary?
- Window not working
- changed oil
- Plug on Vtec head question
- GSR "snail shell" manifold and boost
- A really noob question -- Better Illumination behind the cluster?
- few small little problems, hope someone can help
- Kteller stainless race 4-1 ITR replica header
- wheel size
- Cheapest Place for 4 wire universal o2 sensors
- what car should i buy? part 2
- Getting rid of my teggy
- car wont start, need help
- weird noise
- integra distribuor check/ test
- How much fluid for Automatic tranny?
- header vs. oem manifold
- need help please
- HELP PLEASE.....
- Post your GSR videos
- 96 GSR interior fuse box...I need the lables of each fuse...lost the cover for it!
- I hate cars from the north...
- replacing Synchro's....
- So I hydrolocked my DB8 today.
- I NEED MAD HELP!!!
- major hatch creeeeeeeeeeeeeek
- Cams selection need advise ASAP
- megan header
- WHAT MAKES V-TEC WORK
- need fast answer
- b&m install
- Hasport Mount Question
- cylinder head work
- rear wheel drive??????
- cel
- Running lean between shifts???
- LS vtech or GSR
- HID's... where do I begin?
- mystery clicking
- Acura integra Signal lights on body kit and paint.
- 98 integra lowering springs
- Skunk2 SS install problem...help...
- JDM GSR Flywheels
- ESP-net's new DA B series Front Torque/Mount Traction Bar System anyone try it?
- Help me find GT style mirrors for a DA.
- o2 sensor and hondata
- Random issues
- help with oil pan
- check engine light trouble
- Look what i found out!!!!!!!!!!!
- Compression test results, wtf to do next?
- How long am i going to see this
- power steering problem
- spark plugs
- Is anyone useing a phearable Ecu chip ?
- almost hydro lock, please help
- 92 DA W/ 5 LUG SWAP....wilwoods and nsx....
- AMS Oil
- S80 transmissions
- carb sticker?
- Advice on body repair on Acura 3-door Integra
- i need help
- what is wrong
- what COLOR wire for A/F gauge..
- good price for '95 DB8?!?...
- 98+ Integra foglight installation/mounting instruction.
- what color is this silver?
- Civic/Integra foglight Question.
- RPMs bouncing like a basketball!
- LS timing question
- integra buring coolant?
- Can someone explain to me what an Intake Manifold does?
- free up transmission
- Squeaking noise at idle when engine shakes back and forth
- Any of you on 205-50-15 with stock suspension?
- Polyurethane shifter bushings
- stopping car squatting??
- sputtering problem help!!!
- HELP--Getting CODE 13 on DA9
- Suspension/Wheel noise?
- SO-CAL((**((**((b20 vtec REfereeing????))**))CAlifornia
- Replacing fuel pump in 1991 integra gs?
- How do i get rid of the buzzing sound being made from my bumper becuase of my new CSF thick core rad
- OBDII usdm gsr with OBDI jdm gsr problems URGENT
- Gsr compression for cylinder #2 is low, help!!!
- does dc5 spoiler fit on dc2?
- Is B20 worth swaping?
- intake manifold porting write up
- Gsr shell...Good deal or not?
- b18c b18c1
- more quiet exhaust
- so long honda-tech
- wiring jdm front help
- e-brake light stays on?
- help on jdm front end
- swaping pistons
- so much road noise
- What should i use to cut my jdm itr heatshield?
- In need of a good tuner in the New England area!
- gauge cluster plastic sheild?
- please help!!!
- Gas cover/other cover under rear seat and hatch plug.
- 99 Civic Si Shiftlinkage
- quick release hub
- CAR STOLEN!!!..
- Question on body molding?...
- wing removal plug sizes ?? anyone
- sry again with teh rpm!!
- '90 Integra GS power seatbelts
- whats parts are interchangable between b16 itr pr3-4 and type-r gsr b18c1,b18c5
- where can i find lip kits for 98-01 DC. **searched**
- heads shot
- TURBO HELP
- Tires, Balence, Alignment and still a problem. Check it out
- oil filter question
- FOR SALE: 94-01 Integra RS/LS/GS AEM CAI *Brand New*
- cel engine codes? where to start
- how to instructions for gsr throttle body
- Healthy Engine???
- what do lower tie bars do?
- post picks of integs w/ HIDs
- which springs?
- 94 integra QUESTIONS
- Ground Controls for agx shocks, what other shocks can i get?
- where can i find these tailights???
- can 94+integra seats fit for a 91 integra?
- rear brake change problem
- How-To Drop motor from DA
- A/C Problem?
- quick ??
- 1991 Acura Integra Ls Crash Test
- parking light help?
- need an alarm system
- Write up for boost guage and a/f ratio guages by phantom?
- Rear Suspension Rattle
- Good Place To Order a Chip From ?
- ---getting soo p*ssed----
- Clutch and flywheel torque measurements for a 98 GSR
- Restore or New Shell
- Transmission Rebuild Kit for 95 Integra GSR
- 99 GSR Problem.
- Adapter to add stock oil cooler to '96 and up gsr's
- Will a V-AFC be sufficient to tune an LS/VTEC?
- Where can I find H4H Hid setup?
- ////JDM Fronts Chime In...NON HID Owners.. What HID Kit???////
- hondata not working?
- eBAY HID'S
- ? about LED's for the cluster.
- M3 mirror turn siganl wiring
- How to tell from a REAL JDM ITR header from FAKE?
- Clicking noises when i turn.
- Intake Question.
- honda civic hatch
- iTR shift boot
- ITR Water Pump in LS ??
- emmisions removal
- new to da teggy family website
- Mugen of SPOON chip?
- Quick questin bout my ls/vtec
- The Ultimate Street Integra!!!!
- Honda badge part number
- Brembo calipers from a DC5 work on a DA???
- Diff between GSR&LS IACV?
- which tranny??...
- Need a part #
- Installing DC Lower Tie Bar on G3 teg ?
- I need HELP w/ my GSR RADIATOR problem...
- syncro mesh
- hate to do this but...
- power window switch working backwards
- I'm looking at this Integra to trade my Stang for, whatchya think?
- will tires make a big difference in acceleration, handling and braking ?
- HOW MUCH BOOST???
- Its slow to you guys but its fast to me!!!
- timing belt?...
- what i need to put springs on by myself
- what would be your ideal set to build up a daily driving beast
- HEADER
- Want GSR Blades
- B16 bogging in low RPMs
- Need help ASAP, before I head to the shop in the morning! *pics*
- TYPERman2001, can u pls contact me
- Thinking about paying less tax to the DMV but...
- Aftermarket seat. How to stop the ringing?
- whitest headlights
- How do i reply, i'm anew member
- Do you guys think this worth it? need some suggestions
- 94 acura
- Ls headers on 00 GSR?
