what kind of gains with itr pistons alone?
Old Oct 22, 2002 | 11:01 AM
bocian's Avatar
Default what kind of gains with itr pistons alone?
i am pretty much stock except for clutch, intake and exhaust. i may be able to get a sweet deal on a set of itr pistons with rings. What potential gain am i looking at with these higher c/r pistons?
tia
Old Oct 22, 2002 | 12:31 PM
canuck-mx6's Avatar
Default Re: what kind of gains with itr pistons alone? (bocian)
probably none, you will be raising your compression 0.6 with no cams or other mods that can use the added compression.
Old Oct 22, 2002 | 12:32 PM
Mr. Softee's Avatar
Default Re: what kind of gains with itr pistons alone? (canuck-mx6)
in an ls like 4whp throughout the band. in a gsr maybe 1 or 2.
Old Oct 22, 2002 | 12:38 PM
Brandon Chun's Avatar
I know a guy who swapped Itr pistons into his gsr powered del sol, he dynoed 157.? with i/h/e +pistons.
Old Oct 23, 2002 | 06:03 AM
QCKGSR's Avatar
You will likely see gains of 1-4 hp depending on the effiency of your cylinder head.
Old Oct 23, 2002 | 08:44 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: what kind of gains with itr pistons alone? (QCKGSR)
Yep....unless you know how to do the work yourself, definitely not worth the install time/money.
Old Oct 23, 2002 | 10:54 AM
ingrate's Avatar
25 Year Member
in a GSR it'll be raised by over 1 full point
Old Oct 30, 2002 | 02:11 PM
blufke's Avatar
Default Re: what kind of gains with itr pistons alone? (In7egrity)
how would ctr int/exh cams effect a stock gsr motor?
mac_24_seven
11
Aug 7, 2007 02:31 PM
shomershavis
Aug 28, 2004 01:20 AM
Drian
Feb 22, 2004 09:24 PM
921.5CXEG
Apr 13, 2003 10:00 PM
JD_B18CDX
Jul 3, 2002 07:51 AM
