View Full Version : Acura Integra
- ls or ls/v-tec
- should I change my fuel filter?
- Bogging Problem, throws CEL
- big brake upgrade kit for DA's
- F!@#!in Ay!!! Buying used car headaches...
- Leakin Teg
- breather on intake question
- Wheel Locks
- P72 experts needed *PIC* Help with identifying something
- top speed in 2nd
- Gas Tank Door Wont Open =(
- Dent in Header...could it cause bogging?
- Egine timing assistance
- greddy evo 1 vs greddy evo 2
- anyone here with neuspeed springs?
- gauge hook up question
- I think it's the clutch... but what do you guys think???!!!???
- ACT Prolite flywheel
- intake manifold on LS
- obd on a T/B matter?
- Skunk2 intake manifold and Aem fuel rail question!!
- Fuel pump kill switch....which wire?
- help w/ing...
- cv joint busted?
- What's the best vtec swap for my 1991 Acura Integra Rs?
- gen 1 b16a into 93 Ls problems
- GSR flywheel...worth it?
- anyone turbo'd?
- 2dr integra cf window switch install.
- Spoiler Question
- trunk length differences
- code 9 came back after new dizzy rotor and cap?
- SPOON BRAKES??
- tranny bolt/leak problem
- wanna-be LSD and traction bars
- Tein super street dampers?
- piston oil squiters, knock sensor
- the CALIFORNIA STATE REF wants to see ME????????????
- ls heads
- the question
- First Mods, Help me out, importing motor from Japan
- Skunk2 intake manifold, hose question
- Cruise Control Not Working...???
- install on driver side motor mount
- carbon fiber sun roof
- low compression in cylander 1...help!!
- Dc2 mid pipes
- AC took a shit!
- timing belt change
- Who to get sponser by?
- VOLKS!!!
- how too install jdm climate contol in g2 integra
- update on stolen car
- Which ECU?
- How can I find A19 pin on obd2 (97 gsr) ecu?
- Question about theft
- replacing a clutch
- codes 7,17,41,and 43
- LOOKING FOR LS TRANS/MOTOR/PARTS
- wet on passenger side
- DA dashboard
- passenger power window stopped working
- obd1 iacv
- PIC REQUEST!!
- I got Pulled over for fucking no reason!!
- Timing belt....
- www.team-integra.net
- Help me decide on a clutch!
- drag racing
- LS Distributor died - will GSR work to limp home?
- Amber Cluster/climate control?
- Fan won't turn off
- pulling the head
- Cd changer wiring routing.
- Just purchased p72 skunk2 chipped ECU...where are the power gains ?
- Integra Ashtray [ash tray]
- are all LS heads the same?
- ??? Value of this 97 Tegra LS ???
- Carbon fiber gauge bezel
- Lost power...Help!!
- OBDII Engine Code 22
- Question about intakes
- ANYONE know where i can get 1 of these RIMS.
- My Official JDM ITR headlight conversion thread.
- 99 gsr
- would a 98-01 gsr cluster be compatiable with a 94 gsr?
- Is it Ok to drive like this?
- what is the best decision for my motor
- NY Inspection Question
- what gauges recommended for ls/vtec
- Overheating?
- Main power fuse keeps blowing
- ITB setup CHEAP, MUST SELL QUICK
- coilovers: rough ride? sell?
- 2000 gsr cel on .Please help me fix,CEL codes
- Year to Year Differential Please
- Pics of my poor car after a "T-Bone" accident =(
- Buttonwillow 8/8 video
- would this tire fit in this rim!!!!!!!!!
- is it worth it getting a carbon fiber hood?
- type r suspension axels?
- Roll cage options?
- Ignition system- stock or upgrade
- Transmission
- smong help in stock 98 ls
- 95 vs. 98+???
- Sprint springs
- team DA's, i need you to do something for me real quick..
- Acura Integra Webs for sale
- question on 3 bar map for my LS
- ????HHHELP????? Electrical qeustion?????
- What tire pressure to use???
- can i run rc370 cc injectors in my stock ls?
- Do civics and integras use the same trailing arm?
- replacing secondary o2 sensor
- Smells Burn...Help !!!
- GSR price ranges
- Intake Manifold & Intakes
- ctr and itr suspension
- GSR vtec not working ? too lean ?
- need help for engine swap
- coil overs
- put my front on
- Help me pull my LS engine... *pix*
- fs.
- aem fuel rail and fpr question.
- Gas consumption> black smoke @ VTEC
- how to check engine light on an obo0 car???
- NEED HELP! Can't get the top strut mount bolt off. Need advise..
- i need a new clutch, think this is good?
- correct fuel pressure?
- Problem with the rear strut bolt
- first PERFORMANCE mod for the gizzer..
- Ticked off that I couldn't put on my Omnipower suspension this weekend. AAARRGGHH!
- Do i have to buy new rpm guage if i do engine swap?
- problem with my emergency brake light
- need help finding out which engine is better for turbo?
- Car Stolen!!!!!!!!!!!!!! Long Island, NY
- Very weird problem
- Head question?
- Do you have to do anything special when you but a 94 gsr engine in to a 96 gsr?
- How light is your Integra and what did you do to get there?
- who makes aftermarket front lca's?
- Reliable turbo without tuning?
- grinding noise, think it's cv boot, help!
- 1995 Acura Integra LS broken lug nut screw
- advice please!
- basic gsr Q's
- how hard is it to put a 94 gsr engine in to a generation 2 integra
- skunk2 stage camshafts!!!
- lost the gsr last night
- Swapping Just the GSR Rotor and Caliper on a 98 Civic DX? Can it swap over
- P75 ecu ? is it OBDI or OBD II?
- Ractive Coilovers
- this is cool
- explosions between shifts i like how it souds but its this mean i have a problem apexi dunk exhaust
- big rims = loss in top end power?
- b17A1 into civic, what all do i need?
- 377bhp NA tuned Teg?
- what is the difference between LS, SI, & GSR catalytic converters?
- Where do you buy an idle valve/idle air stabalizer
- vtec prob
- should i sell my g2 integra?
- I dont know why its miss firing. can someone please help!
- CV Axle?
- rpm jumps to 2K when starting motor
- code 24
- Cams for turbo GSR
- LS Sleeper...R or not an R???
- help just put bigger (255lph walbro) fuel pump and having problems
- Loss of power after AEM Bypass valve installation
- aem v2 cai question
- Driving Without Filter On CAI
- carbon buildup and residue left by conventional oil
- 98' gsr..good deal??
- Anyone have that Hyper ground system or something similar??
- my 96 ls special wont pass smog so.....
- HELP... Getting new header
- Which header to get for my 94 LS w/ buddy club III random cat, crower 404's....
- header question
- How to tell a shock has blown
- horrible exhaust sound..need help
- VA Safety Insp.
- jerkyness on/off throttle
- does anyone know the spark plug gapping for a LS?
- Rebuilding B18c1...ITR Oil/Water Pumps?
- WTF is going on here??
- Anyone running a b18b with a JRSC? Anyone doing so with a auto tranny?
- 97 LS Idle Problem
- Car broken into.....
- 99 JDM ITR LSD on 94 Teg Si?
- my piping setup, any suggestion?
- 4 door GSR switch..
- ANNOYING sound system noise...
- What kind of Integra is this?
- piece together a nice turbo....
- i have a jdm type r headlight and its not leveled
- change light bulb now car wont start :S
- motor mounts
- Can a 94+ LS with turbo break 13's?
- Quick question
- Timing belt
- !! Suggestions for shops in San Diego for b18 rebuild??
- high temp paint need on spark plug cover??
- what's best exhaust for n.a. engine
- Another Integra Gone......
- help :)
- how to level 98+ headlights?
- 2 questions...
- Alignment with Type R Springs
- Can you install an LCA wrong? One side of the car sits lower now..
- 92 Gsr Parts
- TEIN dampers
- oem foglight installation?
- whats best for a type R lip?
- where to buy HID KIT ?
- im new to the integra DA family
- almost installed my header, then couldnt. I have a question...
- Do I have a gs-r tranny?!
- is my alternator dying?
- tranny truth
- ITR Clutch vs. the Competition
- New Driver.
- Whats the difference between a 90-91 and 92-93 header?
- I.A.C Motor sensor
- Integra Window Rattling When All The Way Down (search was a waste of time..)
- Saving an Auto Transmission??
- Loud Rattling Noise When Starting up car
- 94 integra ls built for turbo for sale $7k
- synthetic oil spill on timing belt ..Dangerous?
- Rpm goes to 0 at vtec crossover
- JUst installed new header and have question
- h22 supercharged?
- 92 integra rod bearing colors
- shifter is fucked after putting in bushings
- Hondata Intake Manifold gasket install this weekend
- Should i really be able to beat gsr's?
- direct fit cat for 98 Ls?
- del sol clutch with zc engine
- Car too low for alignment rack.. So I Adjusted the Toe myself !!
- The Phatest Integra's
- The best HIDS?
- Fuel pump / main relay problem?????????????? please????
- is there a way to find out your tru mileage???
- Clarifications on a radiator.
- code question
- OEM honda timing belts look cheap.. compared to goodyear
- newbie... got a 94 teg.. need a motor
- does anyone know where to find good diagram's online for part description?
- Rattling/vibratting SOund!!!!!!
