View Full Version : Acura Integra
- Used 94 base model teg, lots of issues TECH HELP PLZ!
- Solid cel, no start, new main relay????!!!!
- Bigger throttle body???
- integra b18c1 s2p2 cams video
- Integra have problem starting, no crank
- b18a1/b18b1
- TPS adjustment need help ASAP!!!!
- 94 teg cluster help
- Transmission Bearings?
- custom roofliner
- 91 DA, first build post and questions. Long Post
- 96 GSR Wont Start, or crank over
- Acura with no spark help
- lookin for eg or teg to buy
- Throttle Issue. Replace IM or What?
- 2000 GSR Help please
- White smoke out the exhaust only when gettin on it
- Spark Plugs & Air Filter for Stock GSR
- 01 Integra Code 8
- charcoal canister 3 way valve plug?
- would s2k lowering springs fit on my 95 teg?
- Need some advice on motor mounts issue
- coolant and vacuum hose diagram
- 86/87 Vacuum advance conversion possible?
- differences in head gaskets?
- 97 GSR Left Side Inboard CV Boot Throwing Grease
- jhpusa suspension?
- How hard should it be to turn a crank in a short block?
- Crank Fluctuation Code Help
- Just finished wiretuck, now no spark or fuel
- 93 Integra Shift Linkage
- Decisions/ Advice
- car bogs while driving
- power locks not working
- Integra won't start
- 98 GSR CRANK but NO START.. EVERYTHING CHECKS OUT.....
- Auto to 5spd swap help for 96 LS
- Should i change my front lip, side skirts and rear vlances or go ITR 5 lug ?
- My DC4
- 94 integra breather box/tubing probs
- About to lose my mind - Overheating..
- Help Muffler Spitting Water, Do You Know The Problm?
- shift linkage issue
- Help me choose color to paint my DA
- Troubleshooting AC system - Compressor clutch is good
- B16 cams on a b18c?
- Car not taking gas at filler neck and spitting it back out!
- Experts come in. 96' Teg Engine Overheated.
- another rattle thread (help me diagnose)
- New teg owner, need some help.
- Cluster Problems :/
- burning half quart of oil after 1500 miles
- no spark b18b1 possible bad coil?
- 1990 Integra GS 3-door DA9 front calipers
- Need some help wit my swap!!!
- Cusco Coilover Problem
- 98 Teg GS wire diagrams
- Vtec not working.
- Why is my gsr so slow ?
- Cam plug
- b20 vtec!
- No spark No fuel :(
- 91 Integra H22A swap
- B16 auto trans swap into auto 94 Integra- HELP NEEDED!!!
- Cut out while driving, won't start.
- AUTO TRANNY PROBLEM???????????????????????????
- b18a1 coolant/heater hose relocation
- flywheel and clutch
- good headgasket to get for a b18
- dumb mistake cam bridge bolt question
- Noob problems (cam seal, dizzy, valve cover gasket)
- b16a 2nd gen
- IM guessing its an electrical problem? 97' integra
- Will 225/40/18 fit on my 2000 integra gs?
- Low-Cost Upgarde options
- jumped timing, bent valves?
- 1999 gsr/ ls vtec - OBD2 connector wiring?
- New Wheels! 91' DA
- need help with a gsr build
- What cluster is this?
- B18C with LS rods & crank
- Whats my best option for Ca catalytic converter?
- dtc scanner must be plugged in for car to stay running??
- F2B integra GSR
- itr oil pump on gsr block
- integra gsr 70mm throttle body issue
- mounts
- How reliable will this be?
- Power Door Lock Control Module help
- Mishimoto fan for 96 integra good or bad?
- B series shifter linkage bushing question
- New Ride
- bought a b18c1 block, i have doubts
- ebay halo angel eye light output?
- 98 db8 side mirror glass installation questions!!!!
- 1997 Integra - What else attaches to the throttle body?
- How to find out how low/high my car needs?
- Wont go over 6300 rpm. 96 GS-R Teg.
- Ecu codes with step down
- 90-93 Integra-Cable S1/Y1 final drive into 99-00 Civic SI-Hydro Y21/S21/SC4 ??
- dxj's DA9 Build thread
- Odd dyno pulls
- boost...N/A...NO2
- Low budget drag car - what width spacers do I need to run 13'' rims?
- Rough Idle!!!!
- Car got keyed what's the best way to cover it up ?
- Ecu codes with step down harness
- Help with Electrical - RPM Dips
- Integra cheap
- 99 integra. wiring harness troubles
- 99 teg help
- 98 Integra GSR with P73 Type R ECU Starts and Dies Video Attached
- Help with a1 tranny and b18 block
- 1998 integra gsr issues with oil in spark plug.
- Stock 95 LS Engine Replacement Project Lots of Pictures
- Coilovers
- Breaklight switch issues
- 93 integra odometer lighting issues
- help! power windows wont work
- Car is being "limp"
- Friend's 1993 Integra RS
- help with oil control orifice!
- almost ready to give aircare in BC another try, advice needed.
- automatic seatbelts stay in closed position
- recently bought DA rad fan diagnosis
- B18C Da6 build (Ireland)
- Acura poll on Facebook
- The GF Performance Chip ?? Bs or OK
- Correct fuse diagram?
- Weird overheating problem 91 integra
- Exedy stage 1 clutch vs comp clutch stage 2
- 96 integra ac refill...
- Help with nrg steering wheel setup!!
- Sunroof Issue
- Relocated fuel filter placement
- 93 integra ls brake lights not working
- 3rd and 4th gear not in middle of shift . pic inside
- 93 da gs
- integra 01 will not pass smog
- B17A1 92 Integra mods??
- fuel gauge problem and vent problem
- S2k Cluster fuel gauge Help in 96 integra LS
- Cars been sleeping for 8 months, what to check replace before start up
- DA with B18B ignition timing question
- d15b7 air intake on b18b
- idle surge
- Needed Hydro Ls Trans Parts
- 1992 Integra GSR ECU
- What Wheels and Offset on Your DA?
- 92 integra B18A1 firing issue
- 90-93 teg axles. Are left and right the identical?
- 92 ls harness question
- 96 RS, How do i test the fuel pump by jumping the main relay?
- Idle and Cooling Problem
- Intermittent Power Loss
- 1994 Integra Running light problem
- New build
- windshield molding
- Restoration thread. Need someone smarter than me to help!
- 2000 GSR no crank after timing belt replacement
- oem advon carbon fiber hood not shutting right
- Major Powerloss After Swap -GSR
- 91 teggy A/C help!!!!!!
- ignition timing issues da9 help plz
- Foglights
- Car wont start
- Transmission Not fully Disengaging
- 87 Integra - Extreme hesitation and lack of power on acceleration.
- Steering problem 95 Integra Ls!!!!
- quick question about electricity.
- 91 250 whp Bolt on possible
- 92 integra power window
- Quick question about a stock d15 integra
- b18c1 startup build advice
- H beam rods "magnitude" forged 4340, 600hp?
- Tps help problem
- What airbag is this and will it fit in my 99 Teg?
- INTEGRA WILL NOT START! HELP PLEASE!
- What Ecu Do Really I Need Help?
- Steering Wheel Hub Adapter
- Replacement Key
- Integra compression test
- outside door handle problem
- 92 integra power window swap
- Interior alternatives
- help? finally after driving with a stiff peddle for over a year...
- 91 da b20z vtec build
- 91 Ls.....Running Fan help....
- 96 DB7 Build
- Smog Help.
- Speedo cable came loose
- OBD2B to OBD2A motor? Ecu?
- Idle
- Bogging and what seems like no power in newly built motor
- Spark, Fuel, Turning over wont start. B18b1
- Neep help with my integra no spark
- 1997 acura integra sedan doesn't start after changing distrubutor
- 91 integra wont idle..rough start
- 93 teg ls problem
- 91 Integra w/ b18b swap bogging, bucking and loss of power below 3k rpm, help please
- Stripped block threads, rear block fitting
- Be-aware of yonaka products FAIL
- How to get 250whp in B18C DD?
- ABS Light. Tried pulling codes, checked fuses.
- 93 integra gs b18a1
- Timing belt keeps jumping intake cam teeth
- My 91 integra I need helppp!!!!
- Rear Bumper of a Coupe fit on a Sedan?
- integra dc weight reduction (post your weights/removals)
- P0130 issues
- 96 GS-R
- 95 Gsr cranks doesnt start
- OBD2A GSR swap into OBD2A Chassis
- Spring and shock installation
- quick help! vss sensor
- No Spark, Underdash harness issue.
- gsr crank specs
- DC4-R conversion
- INTEGRA FUEL SYSTEM HELP -6AN ???
- 98 Gsr Died
- b18c build need lil help
- Fuel but no spark
- Different types of DC Integra hatch?
- Integra Bumper differences
- new wrinkle on famous surging idle problem
- just bought a 97 teg ls need some n/a build ideas
- Neuspeed race springs(stupid question)
- What rails for aftermarket seats????
- Need opinion on Type R spoiler and Mugen Gen 1 spoiler
- Intake Manifold Broken. What's the best Solution.
- Help: Wheel Shaking Front Driver
- need some parts..... help????
- obd2 Distributor question
- b18b1 valve cover tap for oil catch can
- Denso starter solenoid rebuild failing soon after rebuild?
- Finally
- 96 Power Window Problems *Help me!*
- 91 integra No power to Main relay and will not turn over
- Sold my B18B, Need Insight on my Next Swap!!!!
- What type of engine oil does HT use?
- Is this 95 Integra LS a good deal?
- 94-97 wings west RS front lip w/ OEM fogs
- Integra hesitation/bogging issues
- RMF Narrow header put hole in my ac line
- GSR Catch Can install using block fittings question
- what half shaft do i need for my b16a in my 92 integra?
- b18b1 vc on a1
- Replaced clutch/flywheel, roaring noise
- ls vs gsr rods/pistons
