View Full Version : Acura Integra
- Suspension for drag vs. Suspension for autox
- tell me the difference...
- High Flow Cat???
- FS:2000 Acura Integra LS, NY State
- my first crash. .
- idleing problem
- Spoiler Plug sizes?
- Sunroof shakes upon opening...
- Creeking Clutch!!
- bump stops?
- Does anyone have 90-93 foglights for sale?
- MSD (Modified) Distributor Cap, worth the $$ over stock?
- Catback in California
- times for crower 403's
- Integra Tops The Most Stolen Cars List
- anti-lock brakes?
- Type R cluster in a 2nd gen?
- can anyone help me install my springs or sidemarkers in the bay area
- Im looking for Tires... opinions/expirences welcomed
- WTB: 94-01 Integra Replacement mirrors for spoon mirrors
- Can someone post this vid for me that was on here a while back?
- 94-97 OEM Fog Light Bulb?
- New Integra owner with some generic questions
- What distinguishes SIR-G from our Integras?
- intake has no sound
- Skunk2 Intake Manifold
- jdm sidemarkers
- ***Aus Teg Owner Pleas for Honda-Tech Users Help!***
- ls tranny?
- How can I tune my LS better?
- tranny problem
- Advised to get exhaust, cat, and header all at once...why??
- skunk2 coilovers, bottoming out?
- just got my ES sway bar bushing and bracket...
- weird idle when AC is on
- TWM shifter
- Color match? help
- quick clutch change question
- New news from the person scamming me
- 12v dash lighting?
- Pistons for boost?
- Anyone do a 03 si hatch attenna swap on 94-01 Integra?
- car dies out in the heat
- ACCEL THUNDERSPORT SPARKPLUG WIRES 8MM ?
- How to hook up a SAFC to a LS spoon ECU...
- Supercharger or Turbo... anyone????
- I got an idle problem... HELP!!!!
- car dilemma
- could one of you guys help me out with re-attaching a badge??
- stock piping measurements
- problem with breaks
- I have all night too *****!!!!!!!!!!!!!
- car wont idal right revs to 2000 rpm then drops to 1000 rpm..help
- why did you lock it Nick???
- Will a 2000 Integra GS-R take a 2002 Type S?? Both cars are stock........
- What causes a member to get banned???
- Is my tranny screwed?
- How high to rev?
- need info on 98+ conversion. I've got a 97 integra.
- CRUISE CONTROL and REAR DEFROST
- My b18C block.. just bore it a little and hone.. or resleeve and bore to a 2.0+
- B16A question
- online manual
- Ls misfire
- getting car on jackstands?
- Strut Questions??? Who has ever seen this before?
- help, trying to get 92 integra centre console out.. trying to install a short shifter..
- CHRISSSSSSSSS
- skunk2s - need some quick help before install
- pic
- Hey chris!!!!!!!!!!
- Question About the B&M Edge Short Shifter vs B&M Pro Edge SS.
- WTT: Immacualte Leather interior from my 99 GS-R for 95 and up GS-R cloth interior...
- car won't START??!!! help!
- Why is Tom Cruise only a Trial member???
- VAFC, car won't idle
- Help with plug wires...
- pistons for an lsvtec
- Ls question
- jdm yo!
- any experiences with revo camberkits?
- Advantages of the GS model..help plz
- would it be okay to change tranny fluid w/ only 2 jack stands?
- Salvage title...
- Which Coilovers should i get?
- Anyone using a VDO tach?
- Wheel offset for 95 GSR rims
- looking for a catback exhaust for a goodprice....
- rs-r or comptech
- Does anybody know anything about the WET sensors?
- awwful Screeching Noise
- B18B HEAD
- skunk2 p28 in 99 gsr with stock intake manifold bad or not????
- Norcal Bay Area Dyno Day!
- gsr cams and ctr cams? im newb!
- del sol coilovers?
- Catz 4500k HID Install, j00!
- 300zx calipers on integra's?
- Laws in California
- gsr ecu question
- just ordered skunk2 duelbend shotshift, skunk2 shiftnob, and energy shift bushings
- Guys i need some help
- gsr cams in b16a
- 4-2-1 or 4-1
- Looking for information
- 90 LS- Brake fluid leaking *NEED HELP PLEASE*
- My dyno results
- b18c bottom w/ b16a head.
- gsr tranny wieght
- Failed Emission test, what went wrong?
- Which spark plugs do u use?
- what bolts on for 2k LS?
- o2 sensor bad?
- JDM ITR question
- how do i know i need to change rear calipers?
- LS oil consumption rate
- Reputable site to purchase from?????
- RHD conversion
- what ecu is a p05?
- ITR Heads UP link
- Possible Oil problems!!! Need some help
- pulleys in an LS..
- how to take shift linkage off of my broken LS tranny????
- need help on clay question!!!
- 60k mile maintenence for integra gsr help?
- 92-95 civic springs on a DA?
- head stamp
- Review my dyno graph
- How Fast are????.................
- Anyone know where to purchase a OEM pre cut full carpet kit for a 94 gs-r?
- header gaskets...5th gen accord
- Integra brake fitment question
- question about swap problems.
- FPR problem
- Just bought my RS
- WTB: LS throttle body with TPS if anyone has it
- what clutches are u guys useing?
- where can i buy sirg stuff from???
- obd1- obd2 converison harness
- With Same motor/trans, how much slower is 94 GS than a 91 Civic Hatch?
- Axel Removal, help me determine the damage...
- Suspension question
- Springs or Coilovers?
- Best way to change oil filter on integ???
- Brake fluid replacement.....how many reservoirs ?
- For you guys with ITR cams in your GSR
- Anybody heard of kakimoto exhaust???
- Type R exhaust system and header on a gsr
- Spring ??'s
- LS strutbrace?
- What size socket for the axle bolt and where do I buy it.
- what's up with my integ?
- having a hell of a time mating the K&N E-2427 to the stock intake arm
- performance diff from 15in to 17 rims?
- skunk2 manifold for a GS-R/ will the competh intake/ice box still fit .or the type r
- brakes
- hood pins?
- GSR has shorter gears that LS tranny right?
- radiator fan, denso and mitsuba(toyo), which is which?
- what fly wheel for a gsr
- NSX air box
- My buddy wants to run me..... what do u think???????
- A b18 AT to MT need help! I AM A NEWBIE
- a/c problem need help quick
- How F'd up is this?!!?
- Teg wont start
- dyno chart
- Brand New Teg' Owner!!!!
- cat/header size?
- Best way to take off surface rust on a header?
- aftermarket short throw heating up....
- Type R body kit
- 94-95 driver side floor mat bracket/holder
- intake manifold sensor for b18b
- SHIFTER WONT GO INTO GEAR
- WTB: integra center console, black, perfect cond.
- Vehicle Speed Sensor on LS integra
- gsr blocks?
- for anyone that has a dash mounted v-afc
- 1st gen b16 in my DA 90 ls -smog test
- CATZ HID kit installed (56K.....???)
- Pics of my crapped out clutch
- teg engine mount
- Stuttering on cold start
- Caught theifs messing with my integra today!!!(Long story)
- anyone heard of "Clutch specialties"?
- Just Got SCAMMED
- camber kits
- approx. what a ls shoudl run in the quarter
- ADVANTI RIMS FOR SALE !!!!! CHEAP !!!!
- TEIN Springs
- what should i do first?
- fluid maintenance
- Need Opinions....
- good place to buy tires
- AC Compressor Compatability
- vafc version 2?
- 22mm swaybar with OEM GSR endlinks
- Will comptech catback/exhaust fit..........
- where can i get a Apexi Ws exaust...
- installation for vtec controller
- long block vs short block
- What are some pros & cons for ITR cam in GSR?
- apexi v-afc install question help!!
- Will this LSD fit....
- ABS code
- Help, Check Engine light
- kyb agx's and kumho 712's review
- Converting from VW 2.0T to possibly GSR
- size piping
- new here. need help.
- What are the obvious signs I need a valve adjustment...?
- After two years of exile my auto ls integra is finally coming back to the tracks!
- Harness under passenger side seat?
- Civic radiator in Integra...again.
- what's wrong with this photo? :)
- Lookin at GSR tomarrow, need some help!
- pic request: 96-97 gsr under the hood
- Help With The Ls Engine Work
- ls throttle body switch
- If get my secondary butterfly's to stay open would......?
- Fluidyne + Stock A/C Fan?
- Radiators
- would you guys trade GSR blades for bronze circuit 8's?
- h22a in integra 90-93
- New Guy Here
- '87 Integra Idle Problem
- Integra brake line question?
- CEL Code 9 on '00 GSR w/ 37k miles
- Insurance Payout for Stolen Teg?
- Ls header work on gsr motor?
- axis neo 17x7 ?
- Are tokico blues good shocks?
- Look at what's in my lap
- For mntuner2!
- throttle body upgrade
- Diff between JDM and USDM ITR 98 cams?
- Kill switch
- ATTN: FalconGSR. Last time, I promise!
- Do dropzone make good coilovers and shocks?
- SAFC wiring
- Jdm Itr 98 Header
- DIY turbo for an ls
- GSR intake manifold on a 91 Integra?
- Camber Kits Which Ones The Best!!!
- s2000 muffler on a GSR!!!
- Daily driver clutch and flywheel replacement..
- 5zigen Corpse in 16''s
- CTR Pistons, JDM Type R Pistons, High Compression
- New brakes squealing?
