View Full Version : Acura Integra
- porting and polishing
- OT: Look at this con-artist...
- best turbo kit for a gs-r?
- 9500 red line
- suspension problems....
- Squeeky suspension
- Anyone looking for a 00 GSR????
- b18a on b18b
- NEED Help, where can i get a B-series turbo manifold???
- fiberglass hood f/s
- Fuel Regulator help
- ATTN: 00-01 gs-r's from 510, 415, 650, 408
- where can i find integ siR front bumper
- ls turbo or sc g-sr
- Need to make limiting straps or cables?
- Springs
- what do u guys think i would run in 1/4 mile?
- thin headgaskets for the b18b???
- Dunlop SP 9000
- Skunk2 Coilover install question?
- Who's black teg is that?
- Bondo on hole in hatch as a temp repair?
- Tokico Suspension
- Where should i sell my auto tranny? and how much should i expect from it?
- **Recharging AC**
- Will only the top stabilizer bar (upper bar of shift linkage) from an integra work in an integra or
- **ATTN: Boosted integs**
- **OE Qualitee Brembo rotors**
- **anyone try VGX brake pads?**
- Quick help. Bolt on rear shock wont budge, just bends.
- Who was that on the merrit this morning in CT????
- Automatic Trans To Manual Swap
- need help!!!!!!!!!
- TEIN HA install
- how to lube integra windows?
- oil question
- Neuspeed rear sway bar
- portflow valve train
- anyone runnin skunk 2 drag coils?
- wheels and tires?
- I can't drop my 60' HELP!
- need pics of Skunk2 manifold on 94+ LS...
- Integra LS needs engine swap help
- OBD II to OBD I conversion!
- Clutchnet. what stage for my teg?
- Spring Compressor question
- tune up ?
- Online Parts Dealers
- Fastbrakes Info
- Cool exhaust gas during idle?
- Whats that rubber thing that comes with new dis. cap
- My 2000 GSR motor. How do i make it a very fast NA motor. I got 4000$ to spend
- would this work??
- drag 3 equipted gsr's
- obd1 v obd2
- need a filter for aem cai
- interior question- clock
- !Photochop Please!
- !Photochop Please
- is 300f/300r groundcontrol spring rate ok?
- how much does an OEM O2 sensor and the wiring cost??
- B16a or b18c or b20?
- idle speed too low, idle screw all the way out
- o2 Sensors on a LS.........??
- CRV head on B18A, anything I have to worry about?
- will my tenzo r poke 10 fit on my friends accord 97?
- Easy Question...Just Want To Make Sure
- Need a brake light...
- cv joint ?
- So i got my RS*R back on..
- Good Muffler?
- squeaky clutch?
- What is the difference in a 94-97 Integra and a 98-01
- LS Injectors
- check engine light
- www.alljdm.com... good or bad??
- ID of common intake systems
- Where is a good place to find 0-60 and 1/4 times for all kinds of cars?
- what's the highest i can go in spring rates?
- 99 GSR in SoCal read
- Question about shift lever
- Got rear ended....again
- trap speed in gsr
- Electric Water Pump????
- intake, header, exhaust...what next?
- short ram or cold air
- gsr vs rsx base
- I cant find a two door gsr
- Installing shift light
- Re: Finally got my Skunk 2 Intake Manifold yesterday
- For all turbo peeps, please help
- Best set up for a GS-R for auto-X/road racing, a lil drag... that's staying AM??
- Crower Cams
- Whats the best oil to use for a GSR engine?
- quality coilovers.....GC/eibach, skunk2, etc etc.
- GC/eibach setup........550/650....streetable?
- HELP! Gauge lites went out!
- FYI, take your time to setup and tweak your adjustable suspensions
- Confused teg owner : (
- rev problems
- Help! Problem with FUEL FILTER...
- AEM FueL rail mounted FPR Bites the Big One
- rough idle on 90 automatic?
- stainles braided hoses
- Just sold my GSR!
- Hey GSR owner's a question for you?
- Color Code(s)
- need quick answer bout valves....
- So much for "Unbreakable" Auto Lock
- Uh oh...high pitched rattle
- SAFC panel I made for a friends teg
- 93 Gs-R HELP!!!!!!!!!!!
- waste of money..
- Cooling fan problems - please help
- Anyone got an OBDI-R Spec VTEC controller
- Pardon my stupidity.
- VAFC Throttle Output issue
- need some ideas for engine managment.
- what jack to get
- Where to buy Integra badge inlays? / Favorite online stores
- H22A lude engine into a 94 teg ls ?
- Will they fit?
- SD meet
- integra 2k factory fogs
- 96 GSR b pipe
- JDM Center Console Eliminator
- Adjustablity
- Shogun Power Tuner - interesting
- WW RS kit
- Badges!!!
- ? about CTR steering wheel
- Spark plugs
- gsr to si tranny swap!!!
- Where can I find a BLOCK GUARD for the B18B Motor
- Hondata help!
- B20 VTEC !
- what should i do next for my integra
- Compression test how to
- Lost case or still hope?
- ordered my suspension today
- Anyone know where to find STR dress up kits?????
- o2 sensors for obd1/obd2 cars
- Trading it in...
- ITR springs w/GSR shox, good idea?
- how can u tell the difference on the outside of the gsr ys1, and the b18a ys1?
- A/C hoses and Brackets-where i can get and how much?
- Street Fighter 2 Front For Sale In DFW TX or Houston
- Volk wheel? (different)
- Buying integra LS 94-97 need help
- A/C Line blew. Fixing it..
- 94 headunit install !!help!!
- Greddy SP vs DC Catback
- Important FYI: 98+ Conversion-Bumper Lense Bracket
- AC Problem
- size bolts for JDM ITR HEADER to CaT
- quaife diff. group buy still on
- Fuel pump...
- ctr intake cam or flywheel?
- B&m racing oil cooler???
- Someone please answer my QUESTION!
- flywheel??
- is there a difference between 94-97 and 98-01 headlights?
- DSR dyno meet???
- Ok guys need help deciding which gauges to buy DIGITAL OR ANALOG
- cost for a vtec head on a LS
- Where to place the RSM G-sensor
- Sway Bar
- 99 civ UR underdrive pully...fit teg?
- question: corner turn signal bulbs....
- will these fit on my 1990 integra Rs???
- Advantage of running P28 ECU vs. P72.
- intake manafold
- Is the USDM Type-R (bumper chin) spoiler and the JDM the same?
- Axle Back exhaust system.
- bay area machine shop
- Weird Idle just got more weird!!! WHAT??
- Bay Area Tegs Beware More Thefts
- stupid question.. but i gotta know..
- JDM Integra clock and ITR clock question...F/S?
- quieting down my exhaust system..how do i do it??
- Well looks like im getting the JDM Front end
- power gains i got a hoko up for tanabe exhaust
- went past redline
- Suspension
- Q about Stock GSR ITM's Sensors?
- Will a GSR valve cover fit on an LS head?
- can i lower when i have torsion bars on my 89 integra?
- anyone else make stiffer valve springs for LS other than crower?
- What size exhaust piping does your LS have??
- JDM ITR clock block off.
- Tire size question?
- Quick question??
- Under Dash fuse box(panel)
- Anyone have a 96 or newer integra fender lying around???
- ABS problem
- i have a problem
- adjusting ground control coilovers
- Bad Cat?
- polished/glazed problem. someone help me
- Integra Motor Mounts
- Suspension Help for SOLO II
- Integra Tech Help
- i don't wanna but i have to sell it
- Engine Rebuild USDM R piston.
- suspension gurus.
- clutch master cylinder bleed screw & valve
- Help! Brake Master Cylinder
- Rear Wiper Removal Question, Please Help!
- Post pics of 16inch Rota Circuit 8 if you got em!!!!
- Bars question
- What kind of headlight bulb to use in a DA one piece headlight?
- comptech sway bar and tie bar combo
- p30 ecu question.
- burning rich
- Where can I get the measurements on a .25 over CTR piston ?
- OBDII GSR ECU, what to do with the Knock Sensor ?
- teken: starter ?
- About to order Sparco Rev or Evo and rails. can you help me?
- obd2 vs obd1 gsr head?
- The difference on ctr cams and itr 2001 cams???
- Production Numbers for 2nd Gen GS-Rs
- need help!!!!!!!!!!
- Adjusting Fuel Pressure
- who here has ever had their itr head replaced
- Help, another GSR project or Type-R Project?
- Integra rake
- does o2 sensor CEL code cause ecu to run into limp mode?
- spoiler removal??
- Oil Pan Gasket, will a parts store have an alternative?
- Toda B's or C's.
- My exhuast is too loud!
- license plates
- question about vtec sound?
- Finished installing Neuspeed short shifter
- Skunk2 camber correction
- Brakes squeak AND running rich! (2parts.)
- very happy with my .48 cent camber investment
- Wings that do something > How much does the ITR wing help ?
- starters?
- What should I do? Problem with wheels rubbing.
- Spooooooooon!!! H/C/E?
- what do i need to install a used DC 4-2-1 header?
- head rebuild
- Belt Squeak
- what fans?
- HP for LS???
- Honda and Acura recalling 1.3 millions cars look inside.
- Gahh!! Weird Idle!
- New Exhaust...
- K&N Valve Cover breather male or female ?
