View Full Version : Acura Integra
- My Integra Build
- Gathers GPS?????????
- need help with my b16a
- da seat patterns?
- going all motor need help on parts list
- 96 Integra eating wheel bearings
- which would have more bragging rights?
- Timing Belt Change
- hytech replica header on da
- License plate mounting
- kevlar with beige interior?
- what could it be any help??please asap help??
- Problem with alternator....
- Integra coilovers compatible with civic?
- Low rpm vibration only,its gear based, help
- Unknown B series Camshafts, Toda?
- I have a 1992-1993 Bumper question
- coilover issue..need help
- Power steering pump
- what exhaust is right for me?
- POOR MANS TYPE R TIMING COVERS
- question about 95 gsr tranny??? please help...
- who needs a evap solenoid anyway?
- obd1 gsr motor into 99 obd2a ls
- iavc problems i think
- broken fuel rail studs
- B18c1 bends dipstick
- I will pay you to change my head gasket!!!
- Hose Identification please
- 93 w/ B18 not revving over 2k
- Second gear sounds like a bucket of bolts
- Fuel pump, Main relay, No spark = I need help quick!
- starting problems?
- B18c1 Compression Problem
- Looking for good Exhaust
- Suspension problem bad noise
- brake pedal going to floor..
- my integra b20 N/A build
- jdm SiR-G headlights interchangeable with jdm type r headlights?
- 4 door integra love
- RedWire starter relay sparked on metal.
- Fitting 17x8.5 on a DC2?
- help swaping out my LS motor
- 1st gen b16a swap problems in 92 integra
- Which a/c pipe is this?
- Wrecked my integra today :(
- 99 integra cluster problem
- 925 AREA MECHANIC WANTED
- Automatic Integra Performance
- engine harness help
- 1992 Acura Vigor brake problem
- No Compression aft reman head install 94 teg RS
- fuel pump grinding
- Si-Vtec Fogs...Real or Fake?
- i need the bolt size for the trailing arm bolts
- a/c and knocking sound
- Turbo GSR: ABS delete, engine bay shave/tuck and power steering tuck
- LS/Vtec question!?!
- Problem with '93 teg
- da & dc engine wire harness difference?
- converting front end
- 96 gsr what to do with it
- question on OEM lug nuts
- New clutch question/problem
- Temp Gauge going crazy
- Help diagnose this its driving me nuts.......
- what does a gsr 2001 sedan go for now a days?
- Turbo Gs-r failed emissions with too much NoX
- Bad Distributor????? in 1990 Acura Integra
- 01 gsr swap into 94 ls
- K Motor Forum
- better radio reception
- problem with passenger window : /
- front forks Qs
- DC2 to DA9 Steering Gearbox
- help..engine wont start after changin the radiator hoses..
- How to reset P72 in my '00 GS-R???
- d16z6 dc
- New Rod Bearings 1994 gsr
- ignition switch
- ecu help
- Are all B Series Injectors the same?
- DC door seals Part #?
- any pics of 4 door tegs on stock ITR shocks and springs?
- problems with exhaust sytem on da9
- Da Camber Kits On To DC?
- Let's Talk Radiators
- NEED HELP: 91 INTEGRA MY AXLES KEEP COMING LOOSE
- cel code 22 vtec oil pressure switch
- HELP: Car hesitates between 3000-5000RPM once warmed up
- Fan Not Turning On and AC not working
- Ls/vtec?
- Dice Ipod Integration kit for Integra (Problem)
- just a feeler for my rhd
- Leakdown results, bent valve?
- Integra GSR Noise Question..when revved
- B18A1 - Valve Spring Length
- jdm itr city light and corner lights dont come on when theyre supposed to??
- radiator questions
- Integra GSR doors on Integra RS
- No Spark.
- DA Trailing Arm Bushing!
- Keyless entry remote
- New to Honda, but not to tuning, 98 Integra
- 94 ls/vtec cooling problem
- b16a wot sputter
- JDM FRONT HELP!!!! AC lines
- Squeaking from rear while driving
- Value of 2001 GS-R
- 95 Gsr/ power steering/ lsv
- 96 DB7 4dr sunroof problems
- Auto Turbo Ls Integra
- after market parts
- HELP! which front sway bar link??
- alternator high output
- can anybody answer a question about my gsr?
- oil light
- computer shot?
- usdm gsr compression numbers
- LSVtec Teggy's Track Night at Cecil. *Vids inside*
- I love pulling engines apart...never know what youll find (Pics inside/input needed)
- Broke cam cap bolt
- Does anybody know where v-tech fluid goes?
- 97 gsr is bogging like it isnt getting enough fuel
- intake manifold question
- b20 questions
- Fuel System CEL(43) and then oil pressure light?
- stock Clutch issues
- FI E/M FUSE KEEP ON BURNING
- ls(b18a1) into a 2.0 liter
- radio code
- Header Fitment Question
- CEL on, no code present. prize for the winner
- 90 Teg B18b swap wiring questions, UPDATED SEE 3rd post, shorter
- 86-89 vs 90-93 passenger side axle
- 99 gsr B20 vtec 6spd swap???
- db8 dome light problem
- 95 integra exhaust
- rear motor mount trouble.. an easier way maybe?
- Anyone Wire in universal O2 sensor?
- b18b1 cam seal issues
- integra type r front end w/c west front bumper
- DA Rack & Pinion Noise
- (16-18) Teens Post Your Integras
- Toe Adjustments
- Hi, Just bought a 2001 GS-R with 90k. First problem already :( Lost all brakes...
- power antenna problems..
- cylinder sensor
- DC ITR front bumper support issue and HID for non-hid lights?
- OEM or retrofitted H.I.D.'s?
- fuel pump size
- what's the best clutch on the market to buy?
- quick question regarding timing belt tension
- Which LCA work with stock Sway bar?
- NYC: 93 DA, need head gasket replaced; engine swap?
- ????'s on rebuild
- 99 LS tranny binding up?? please help.
- My first LS VTEC turbo build, need some help
- how to properly clean out gas tank
- do i need coolant lines going to the intake?
- obd2b to obd1 tach problems.ive searched
- i need name of part...
- DA and DC trailing arm the same?
- Please take me by the hand and show me............
- What would be the first modification?
- resistor box
- sudden shut down on freeway
- ran race fuel, CEL is now on, can't pull a code
- Oil Pressure Sensor Explained
- a/c evaporator core or heater core?
- Gauge Cluster Dies?
- ABS DELETE- now having problems
- IDLE IS JUMPY WHEN I PUSH THE GAS HELP!????
- abs wheel hubs on non-abs car?
- 97 GSR WONT IDLE Cheked/Cleaned out Almost Everything
- 2600-3000rpm exhaust noise
- oil in distributor cap
- 96 Integra - no spark
- I need this part number HELP
- Car will not prime!
- is my gsr head still goo i threw #4 rod due to hydrolock
- Exedy Clutch Kit
- Is the ignitor in the distributor the coil? or are they different?
- Whinning noise/PS went out!
- troubles with mt teg
- high idle lsvtec
- Pics of all 94+ integras on steelies.
- CEL code 9
- Weird clunking noise coming from left front
- Help! Problem with my tranny on my DA
- intermitted code 16
- B18A1 Block with B20 Head?
- Rabbits 01 DC4 build
- What is the OEM rotor specs for 93 Integra
- Rear caliper sticking
- so hows my top end look
- easiest way to remove rear mount
- Anyone have a clue what this could be, help??
- WHEN VTEC OPENS IT FALLS ON FACE!!
- DC Sports 4-1 or Comptech 4-2-1???
- Questions about a timing belt/ water pump/ headgasket!
- HELP: how do I check to see if a transmission is good or bad?
- rare blue dc2 tegs postem up!!!
- integra suspension install help
- 94 ls/vtec high idle
- Radiator overflow tank ?
- WHAT I hate about INTEgra's!
- just swapped new motor, having some issues
- b18 build for racecar
- Adjusting JDM Headlights
- Cheap rebuild ideas?
- passwordJDM 3point strut bar
- Abs light
- gsr overheating
- DA transmission question! help!
- spark plug gap
- Uncut Stainless braided brake lines?
- Anyone had their windshield replaced?
- could it be a fuel problem? "bogging"
- fire, no starting, throwing codes
- whats wrong with my GSR ???
- ITR tranny in DA, PROBLEM!
- removed the metal tube from valve cover.
- DA Traction Bar Question
- Headers for LS HELP!
- Motor mount question...
- JDM same as USDM Intake Manifold?
- front bumper removal
- GSR ECU?
- will b18a head fit on a b18b lock?
- bad tailight gasket?
- b18a1 help
- GSR harness problem
- Misfire code only with full tank of gas?
- Manual Rack question
- Type R headers fit 94 rs?
- Skunk2 manifold installed no runs like crap
- somebody hit teggy is it worth 2 fix or put a 4 sale on it
- sk2 mani on jdm b16 da
- Burning oil ? valve cover gasket ? Need HELP PLEASE ;(
- how to disable power antenna
- how much are oem itr lips going for???
- Which Radiator cap?
- Block Guard or NO Block Guard on gsr
- Storing A Car For 2 Years?
- JDM Front Clip
- What goes here?? thanks!!
- car lost power and started to bog on the way home. HELP!!
- 95 integra not starting
- Rev Limiter Problem, PLEASE HELP!
