View Full Version : Acura Integra
- Anyone want OEM Integra fenders, front bumper, hood?
- my car was stolen last night!
- KYB shocks Vs Koni Sport Adjustables
- My Setup reliable?
- Cam followers?
- Does anyone know what a b17 is?
- Anybody need an ITR airbox?
- chipping rom help? p72
- need your advice
- Quality of this lip (pic inside) for 94-97 Teg
- cam gear settings?
- engine mounts 88-91 civic
- Si or GSR tranny for LS?
- sorry i tried to search need help dif b/w rs ls gs
- Oxidation on all 1994 Integras?..
- Muffler rattle
- needhelp on some good shocks?
- Serious Overheating Issue
- Will this work on my GSR?
- what ecu in 95 gsr??? p 28?
- Tranny Oil capacity on 95 GS-r
- What to buy with $550 for My Integra
- ITR AEM Intake
- sticking caliper
- g3 midpipe compared to g2 midpipe
- Will US ITR Header fit 90 teg with B16
- 2000 GS-R Header on 1990 LS enigne?
- rally sport??
- How do I install Carsound Cat and JG Header 2.5 collector? What should I do?
- Getting 95 GS-R......
- need help understanding fuel concept
- Just bought my first integra
- What does GSR stand for? GS? RS?
- Good mechanics/Shops in minneapolis/st. paul area?
- DA owners.....HELP
- how much should i pay for a used 98-up front bumper?
- Need some advice.
- My insurance went up!
- Windshield washer pump ?
- america's tire / discount tire have some cool guys.
- what should i do?
- Pictures
- brake master cylinder gsr/itr
- Installing Full Exhaust???
- Does the dealer sell Harnesses for the back of clusters?
- exahust system and piping for dc2 type s
- GSR or Camry v6?
- How do I get off these 2 bolts??? HELP QUICK PLEASE!
- compression leakdown test 96 Gs-r
- HELPPPPPPPPP on JDM conversion
- 2nd gen idle problems from 3k-10k no reving of motor
- Anyone need a car checked on Carfax?
- just replaced brake pads
- B20/LS crank on a GSR?
- Has Anyone Ever Pieced Togeather A B18c1, Thoughts and Opinons Wanted Please Read!!!
- how low would you go with a kit?
- What compression would i have with CTR or ITR pistons in my LS
- Gauge pods
- another weight question?
- My teg shakes at low rpms?!?!?!
- will a race clutch work with a stock pressure plate?
- Tail lights gaskets for 94-01 Integra
- suggestion on tires
- Rear Break Lights!!
- icebox/mugen intake size?
- Integra 96 Gsr question
- Looking for a ECU
- direct air
- spoon n1 from ek fit integras?
- how to fit aftermarket speakers
- is this right?
- poor mans type r
- which hid kit is good that can produce the whitest light..........?????????
- idle problem
- Level of difficulty to replace head gasket?
- OBX products! Any good??
- can someone run a carfax on a 95 GS-R please?
- whine when engine is cold, please help
- ECU's options for 99 LS
- For those interested, a great way to get rid of your rear wiper for about $1.00
- block number?
- Comming into the integra world, couple questions about performance upgrades
- quick question
- aftermaket header question
- jdm type r headlights
- Is a FPR worth it?
- Flooded 95 GSR
- Question about the AEM CAI!!!
- quick carsound cat question
- what would u go with
- check this out -- all you people with autolock/club
- Power Needed To Run 14.00 1/4
- Need some advice.
- Im shoping for a new car i have some ??'s
- Where do I count the Final Drive gear? 92-93 GSR B17A
- Outside & Inside Temperature Sensor and Display
- Having trouble disconnecting the rear wiper motor, please help.
- What Throttle Body to use with Skunk2 IM??
- Accident :( i GOt owned by Hit-and-Run Driver :(
- Tire decision help...
- Fake Type r shift knob weight?
- Injen CAI, does it use a k&n filter?
- extending itr b-pipe to fit on 98 gsr?
- thinking about going back up
- your opinion matters!
- shocks
- JDM OEM HID guys, help me out!!!!!!!
- HELP anyone that has done the S2k antenna conversion
- 90-93 tegs which year had gsr?
- comptech exhaust installed, low b-pipe/resonator!
- Looking a stock-looking performance suspension...
- Question about using CTR intake cam
- 90 teg rev/speed limit
- How bad are the theives in SC????
- will 2000 ITR steering wheel and passenger side airbag fit a 95 gsr??
- b18a/b na setup
- DC2 JDM Front End: New or Used
- finally bought my integra......yay...lol
- Whats the best tranny for an all motor LS? GSR/SI/Type R?
- Need Help My Integra Wont Go Into Gear
- new wheels
- I'm new here and have a question
- g3 exhaust on g2
- Anyone hear their ABS pump after starting their car???????????
- Snowed In
- LS for $2k with screwed up tranny.....(worth it?)
- anyone deal with http://www.4alterstart.com ???
- OEM Rear underbody spoiler question...
- n/e one have the black widow back end with two exhaust pipes...
- Need your help guys!!
- Canadian H-T Member's Help me out Please!!!!!!
- When is a camber kit needed?
- ECU Chips help
- Oil Leaking out of my engine, help please...
- DA suspention help
- 205 tires ok on stock gsr rims??
- Look at what I found on EBAY ;)
- wierd sound coming from the rear?
- Removed rear seats, is this illegal in any way?
- Any one using a Spoon flywheel?
- wheres the key charmer?
- fuel pump question...
- Would air in the cooling system prevent my engine from warming up?
- home made front lip?
- Those with stock itr springs, wheel gap?
- Irvine, CA area...G2 teg
- Interior Modification-I want to apply a new color.. what's the best way?
- What should I do?
- auto x
- which manifold is better?
- Type R Wing
- 5 lug practicality?
- Head Removal?
- KYB shocks
- '96 Special Edition wheel offset needed
- are my posts being removed?
- looking for a lip pic
- Beaks Install Pics Inside (Lots of Pics)
- SAFC "Normal Readings" - couldn't find with search
- tires to go with...
- integra color list
- which pedals don't require drilling?
- built head ?
- Reccomendations for new aftermarket clutches?????
- F@#$%^ snow!!! 14"-25" expecting!!!!
- Fuel Press. Reg.'s, Fuel Rails, Pumps, and Injectors
- Quick question please!!
- What should i do next that would be most beneficial!?
- Question about "axle back" exhausts..
- zex kit on high mile integra?
- Just Installed...
- will NOS benefit from a blockguard
- Clutch pedal problems, no pedal pressure, help...
- Bastard dealerships
- Transmission Bolt thread size?!?!?!
- First Gen Integra Swap...among other things
- Using snow as a jackstand!!
- Where to buy JDM power folding mirrors????
- how to install a Momo sterring wheel
- What does a stock 94-00 LS or GS run in the quarter mile?
- msd 2step
- I just wanted to say to all you HT peeps
- To those of you who converted your ECU to OBD1, please read....
- another stolen teg. . .
- Car Shakes More Than Usual At Start With Smell Of Gas....
- question for the mugen heads
- Cam gears or exhaust?
- Where can i get screwed??
- Just wonderin
- Info On 4dr GSR integras
- RS '94-'01?
- Change your fuel filters !!!
- How high can a stock gsr block rev to?
- Just installed ITR Cams
- Getting valve adjustment done.. Question
- Integra Xsi tranny
- oil filter
- Question on Tanabe Hyper Medallion
- what size are the 98-01 gsr swirl rims?
- length of stock muffler on g3
- Coolant leaking again
- do you like your ITR sway bar?
- *******HELP PLEASE*******
- Your thoughts on this 94' GSR I'm about to buy...
- drive ability with stage 3 cams
- what exhaust do you run on ur g2??
- whats the difference between b18b and b18b1?
- Quick question about rear-spoiler removal...What to do about the third hole?!?!
- 2g...frozen fuel line
- What front bumper is this?
- Help with ID of part on PGM-FI(TBI)
- problem with key lugnuts, could use some help.
- Honda Parts Catalogue
- HELP NOW!! skunk2 mani ?
- RS door panels.
- Sorry bout dumb wheel question
- new to board
- ls exhaust on gsr, how long of an extension?
- JDM Rear Tower Bar??
- phantom grip?
- will a 91 si ecu work on my 90 ls ?
- Synchro?
- ignition problem? key wont turn. anyone else have this before?
- Just installed my 4500 Catz HID.. and..
- Anyone have a link to the DIY intake (to install a K&N)?
- Anyone ever weigh a stock integra hood?
- belt squeak, ,
- 99 GSR bumper
- car wont start? havent had this problem before need some help?
- 2001 USDM ITR front end on my 95 GSR?
- JDM DC header question...
- Why Not Go Nitrous?
- Canadian Integra owners. . . . ?
- 1990 GS "A1" Tranny?
- dents
- Is 3 in. exhaust benificial to turbo only or also to superchargers?
- How do I...
- Anyone have GC Sleeves (and Springs) for Koni F/S?
- valve adjustment specs needed for 95+ gsr cams
- Ok, why is my car running so bad, Coult it be.....
- New Integra owner
- cheap place for dyno in southern cali, anyone knows?
- Need Help! Where can I buy a replacement bulb for one of my HID lights?
- someone explain to me how to do ls/vtec.
- nology ground strap
- Stroker Kit from Crower
- JDM itr rear sway bar
- Bilstein HD dampers
- gear lube questions
- Aluminum Exhaust?
