View Full Version : Acura Integra
- advance timing
- CRAP! stupid tokico's
- GSR Mileage
- 1st gear squeaking
- vtec
- Jackson Racing Supercharger for '98 LS to '00 GSR
- Jdm frontend conversions on a gsr
- TPS/Code7 sensor?!...
- This sucks!
- GSR Throttle body?!..
- oem belt tensioner fit for all?
- Greddy Oil Filter Adaptor on a Vtec engine?
- TB question?!...
- Walbro Fuel Pump Problem...
- stock fuel pressure
- New clutch
- PIc of 2 inch drop 3rd gen
- GSR Tranny Diagram
- Gas tank size ?
- GSR ECU
- DB PROJECT 3...
- 93 DA LS: 185/180/185/195 Compression.. Ok?
- Is there any way I can get a shell only without the engine
- Wich cam gears go better on my B18
- 1995 Acura Integra RS ENGINE QUESTION
- bad idle
- lowering spings/shocks
- GSR
- Modifying stock GSR intake manifold?
- 1st TEG!!!! Wut to do to it?
- opinion on booste type R at 10lb
- will these headlights fit
- tail light gaskets
- FS:Turbo Kit
- 1992 integra for sale
- cutting hoods
- Does "O2 Sensor Heater" CEL code...effect my performance?
- Squeaking brakes?
- TSX HID IN AN INTEGRA QUESTION
- Why do OBD2 GSR's NOT come with a FITV?
- HOW TO TAKE ALARM OUT??!?!
- HX RIMS ON GSR?
- How do i check out the TPS on a acura integra 1990
- pistions question
- check engine light question?
- B16a2 Spoon Spark Plug Wires on a B18c1 ?
- Some Questions About My New Intefra....
- Need Help ASAP!
- Rear Hatch Spare tire cover... Fit a 4 door??
- ECU code 7 help!?...
- Iceman intake
- Need help on correct way to install harness
- Headlight oxidation How do i get rid of it?
- hondata s200????
- just got my lip
- check engine
- 02 extension ... now CEL light
- GSR motor into 2g integra, question...
- Car wont start....Have Spark,Fuel
- Crazy Question
- Ignitor interchangability
- b18a1 like new automatic tranny 4 sale
- wtb 92-93 gsr dash wiring harness
- help with A/C compressor
- seatbelt sensor in the teg how 2 rip it out nicely
- ECU reader?!..
- ECU problem..?!?
- GSR head build
- Auto and Manual Axles? Getting Mixed results...
- race clutch on cable tranny??
- How to take odometer out of old cluster and put into new one?
- Birthday Teg
- 93 - GS - head torque questions/head gasket change
- Bad Timing, Miss Fire? Please help
- GSR firing order diagram.
- DA horn
- should i trade my shocks and springs for this?
- Other than my O2 Sensor..what can make me run Rich?
- 12V Accessory? Fuse?
- itr wing or no itr wing?
- LS motor(P75) in a GSR frame(P72) - Problems?
- stock civic half radiator, overheating?
- vtec doesnt work!!! HELP
- ignition switch wires... Where do these wires go?
- different MY crank compatability?
- LS turbo or GSR swap please HELP
- DIY Timing Belt and Water Pump
- streering wheel question
- Knock sensor???
- car wont start
- new deck installed...no sound
- jdm front end conversion
- My Check Engine Light WOES!!!! Running Lean..Rich..I don't know!
- portflow inner valve springs
- Steal your car in 10sec.
- anyone using innovative billet motor mounts?
- GOOFY IDLE
- K24 In a 2000 DC2?
- thieves suck
- JDM ITR Non-SRS install on DC2 with quick release
- Spun Bearing: Repairable or Not Worth It?
- sensor help
- vtec problems
- Overheated...HELP!
- parts for 92 integra for sale or whole car
- i bought new keyless entry but i have no idea how to install
- used tokico illumina adjustments ( plz help )
- omni front camber kit help...
- gsr swap blowing smoke!
- slave cylinder???
- Where do you get your OEM replacement parts?
- Greddy Turbo timer mess up my ignition??
- about my teg..
- Weird Problem please help or my g/f wont give me IDB (her car)
- What kind of brake fluid for my clutch
- b17 vs b16 pistons... stock for stock?
- K20 SWAP INTO DC/DB INTEG
- ITR Conversion parts?
- da seatbelts need advice/help
- ANY ONE HAVE A DIAGRAM OF HOW THE HOSE GOES ON A B18c1 INTAKE MANIFOLD
- **THIEVES FOILED!!** SouthSide San Jose This Morning!!!
- how much insurance pay for gsr
- wont start
- it oil pump light
- 1996 GS-R .: Lets build some boost !
- integra gsr is still in the top 3 most stolen cars in the us list.
- my car...
- Cable tranny questions
- another stolen NOVA R( well not exactly)
- BUILT H22 TURBO AND SLAMMED INTO A 1993 DA INTEGRA!!!!!!!!
- LS/VTEC Head studs?
- teg is eating wheel bearings
- Gaugecluster swap??
- a lot of fuel leaking outta my car.. HELP
- GSR intermittent power trouble
- Timing light on cam gears??
- obd-1 dizzy question
- thread request please
- 105 k too many miles for turbo?
- Civic D Series to Integra B Series turbo swap
- 92-93 GS-R production #s?
- brake pad question
- JDM ITR conversion
- WTT AEM CAI for SRI (tried posting elsewhere but couldn't)
- Need help with JDM B16a swap in XSi
- Vtec in a GSR question
- Having A/C Problems!!
- Help!! GSR Motor, Low Idle
- What's the Difference between 94-97 headlight and 98-01 headlight??
- gsr problems
- going back to all stock
- vibrant
- code 14?
- Catalyst System Efficiency Below Threshold?
- vtec doesnt work because of o2 sensor?
- CUTTING SRS WIRE ON CLUSTER? GOOD OR BAD?
- Intalling a new Edelbrock TB & IM and could use some tips
- B-Series or K-series.....????????
- Anyone put 'EK' full coilovers or shocks on their integra?
- Quick question ?
- Fog light question...
- Pulling motor..
- hey whats up to all the teg family
- "Battery" idiot light turning on.........
- motor lag? delay problem.
- Farewell Honda-Tech, hello VWVortex...
- which is more powerful
- DA Gauge Cluster Question?
- best performance
- Cluster Needle recalibration
- My tragic story - a parked Integra suffers tough luck
- 02 sensor extension.... Twisting wires together ok?
- clutch for k series
- its not relate to the integra forum but I need to ask a question.
- tach doesn't work
- Okay so what is the difference?
- JDM DOORS
- 93 integra brakes
- help !
- Integra 3rd Gen. Concept Sketches
- AC taking long time to get cold
- mounts for H22 in DA?
- speedometer problems
- 92iNTeGRa_GS's DA LUV!!!!LOOK PICS
- Whats involved in swapping doors?
- How hard is this to do
- HEADER FOR LS
- new alternator - NO A/C!!
- 88 teg choking out. Need help
- are the wood spare tire covers the same for 94-01?
- first electrical problem
- RPM needles moves Crazy...any ideas..
- Gsr Machine work
- will rsx coilovers fit integras
- 3rd Brake light questions!!!
- LS Alternator bracket question
- noob engine block question
- More Power
- bomz racing
- Quick Q - OBDII vs OBDI - AUTO -> MANUAL swap
- Suspension torque specs - DC4
- 98+ Front Bumper w/ 94-97 Headlights
- Turning over, not starting
- tranny problems
- 1990 Integra throwing code 13
- Auto to 5 speed wiring???
- --Help needed, won't start??
- GSR timing cover?
- 2000 Integra GSR...
- DC2 seats in a DB
- suggestions
- need info! i got an RS, with no sunroof, any way to have sunroof?
- help with arp bolts
- Projectors for retrofitting
- Clutch Grinding
- lowering the GSR
- Faster teg?
- Does the stock wing help any?
- What's up with this hookup on an 88 Integra?
- Hey New Member and New question
- front bumper and left headlight problem
- Lowering.
- Exhaust upgrade any suggestions?
- my new teg
- test pipe e for DA
- GSR distributor pics
- 1994 Integra Auto just plain slow?
- Axles???????
- GSR Skunk2 mani help asap!
- need to rebuilt
- exhaust problem
- Dim CEL #1
- WHAT AXLES TO USE FOR JDM ITR 5LUG CONVERSION ON MY INTEGRA..
- Two quick questions...
- ITR flywheel or lighter
- How many people are running mud flap
- plugs
- ***In the market for a new car, RSX-S or GSR?***
- Maintenance Light? ?
- how can you tell rear bumper is OEM? or replica?
- suspicious about my new GSR
- 1990 Integra vacuum diagram
- so my friend wrote off my teggy (pics)
- B20 boosting questions
- Burning up a lot of oil
- question
- B16 tranny on gsr?
- bad alarm/stereo install causing electrical problems?
- STOLEN- White LS 4 door San Antonio TX
- YAY MY FIRST GSR
