View Full Version : Acura Integra
- help!! inner axle isnt coming out)))) need it done by trm morning=.=
- Suggestions on Suspension....
- headlight bulb 9005 vs 9006
- registration help!!!!!!!!!
- Looking for a certian size intake filter!
- Those with stripped cargo area and/or rear seats HELP!!
- RSR Exmag Exhaust, Help
- Radio Code................
- 9005 gold bulbs
- OEM Sideskirts
- car alarms/ignition kill or whatever to prevent an integra to be stolen feedback!
- who has a DA with h22 swap
- Newbie
- B -SERIES MOTORS
- BSQ kit help, and other question on ITR sways
- how to install 94-97 fog lights????
- help meee
- DC2 Coilovers & Shocks on a DA?
- 95 ls shifter arm going to the bottom of your shifter
- Stock plug coldness?
- car putts when motor is on
- check engine light question
- ITR conversion
- antenna problem
- racing with automatic
- xs-engineering turbo kit
- Help with engine problem..Already searched.
- different injector clips?
- Would an LS/GS intake fir a Type R?
- 94 RS w/ 193k
- replacement 92 teg mount bushings
- Size of Clear Corner Bulb
- Weird sound
- whats the difference
- B16A intake manifold on GSR
- carb coming out of the exhaust question?
- Catch can setup.
- What's the difference between LS exhaust and Type R catback exhaust?
- EG/Del Sol lip fit DC?
- what can i do for a little more power out of my ls
- toyota scion vs. gsr
- will this intake fit into my LS?
- LS engine
- Good compression for a power adder?
- labor on motor mount inserts??
- STILL taking on water! Baffling!
- two problems...please help!
- 4x114 brake conversion
- Please help need info on engine bolt name pic inside
- gsr tranny in ls
- rear brake UPDATE..still have a q tho??????
- Car doesn't start sometimes
- Best spark plugs for ITR.
- GSR MANIFOLD ON AS B16 ?
- will 98-01 integra mirrors fit on a 95?
- My integras value
- Helms Manual Question
- new brakes but still scraping noise
- stock ls rods - how good are they?
- quick integra atf question
- 95 integra Ls b18b1 Into 92 integra Ls b18a1
- TYPE R CONVERSION
- Wierd overheating problem
- JDM front end conversion
- Can anyone run Carfax for me? please
- LS-T track times
- Header ?
- LS Trunk light
- I know, I know... It's been asked before... just getting fresh thoughts...
- how many integra's with b16 tranny??
- Question on VAFC II install!
- Valentine One Stealth Install Integra (Let's see 'em)
- transmision problem? help...plz
- AUTOMATIC swap
- Skunk 2 IM
- help w/ possible over cooling problem
- Need help: car bogging out
- were can i find some good stainless steel headers tht work an are not a brand idk.
- my friend is selling 310 injectors, will they fit my car???
- Idle problems on ls swap into civic hatch
- ABS problem
- Clutch Master Cylinder problem
- lower my car now weird sounds
- 3500 budget
- HELP! car won't start, recent mods= lightened flywheel, ACT clutch
- DA RS question
- 15x7 tire size: will these fit???
- Want a slight bit more power.
- help me identify a bar from integra gsr or maybe other model. engine compartment
- ctr pistons in a stock b18b1
- HELP: Car will not start!!!!
- NGK spark plug wires?
- how is this done? (exhaust)
- condensation in headlight...
- apexi powerfc question/info
- who can chip my p28 ecu?
- Locating intrgra brake fuse??
- Removing Led Wire off of Stock Spoiler
- unknown noise
- Finally fixed my vtec problem
- E-brake light on...ABS light follows shortly thereafter???
- what are the pulses per revolution on an 01 integra ls
- my mom's boyfriend has an 01 integra ls and wants to hook up a tach
- Integra 1999 GSR not passing smog at REF
- gsr oil pump
- 94gsr or 93 gsr ?
- sad day for my 95 GSR
- 3rd to 2nd (money shift)
- short shift problem
- help on gas tank!
- Coolant Flush?
- SOMEONE PLEASE HELP!
- front brake pads/rotor q...? NEED some OPINIONS
- Automatic to Manual Tansmission Conversion
- what is the lightest DA teg?
- throwing codes in a 91 integra
- a little help please
- will ITR Axles fit on my GSR?
- NOT VERY SURE
- ALLMOTOR18 hit me up!
- Oil level after oil change (Helms is unclear)
- Will an EG civic sedan axle back fit a DC hatchback?
- How much does a b18c1 wieght w/o tranny
- clutch problem
- AEM V2
- Attn: GSR owners w/cam gears
- is Heat sheild removal safe?
- ya quick suspension question
- how hard is it to change your rear left wheel senser for the ABS
- hondata
- koyo or fluidyne?
- Need some help.... (question)
- What are the dimensions for the pocket underneath the stereo?
- turbo is here!
- Did search. Trouble starting the gsr.
- Gsr Head and boost....or H22
- jdm folding mirrors how to?
- cat converter for itr headers
- CF Hoods from jdmshit.com
- will this fit?
- Trannys going bad
- door won't open 99 teg
- where can i get my IM ported in OC?
- why is my abs light staying on longer and longer
- whats better and quicker? b18c1 stock or b18c1 block with b16 head?
- heater issue need advice
- GSR P28 AND 972
- making your own exhaust questions (what pieces)
- tire rubbing fenderwell after puting suspension on
- 93 Integra LS/GS?
- Air/fuel gauge
- Gears stuck
- Problem
- i need help were can i get some cheap oem motor mounts from
- anyone have the jackson racing vtec controller?
- how much to repair front end??
- If you were too get a automatic Teg???
- 1992 Integra GSR question
- VTEC Controller
- What Clutch for a GS-R?
- what wires send....
- All Ground Control allen-head bolt's are stuck!
- 94 integra JDM folding mirrors
- DA gauge question....searched...no answer
- b16a nos teg ??????????????????????????????????????????????
- where can i get a sir lip for 94-97 teg
- driver's pwr window doesn't work. HELP!
- best and place to buy a ITR lip???
- what kind of difference getting your car tune
- Racing Disc Hubcap look
- Help Gutting
- JDM cluster question
- While re-installing my front seats I think I may have stripped a bolt... help.
- tranny swap
- i think it's a sensor. need 2nd opinion. what do u think?
- how much does acura charge for CEL inspection ?
- running lean on b20 vtec, yes or no?
- Perma-Dry??
- mugen chip
- Need help on wiring gauges for DC2!!
- Type R swap into an LS, GS, GSR?
- Is the 94 integra ls motor a good one?
- potential problems with the integra?
- would it be alright to run this chip?
- I HATE THEIVES!!
- Flywheel Machining for 90 teg
- LS, GS compression
- civic mirrors on integra?
- broken motor mount?
- where can i get this?
- car squeaks when turning haha
- 99 LS with ITR Head. what ecu???
- kaboom motor??
- Back End Rattle
- Another Check engine light after Seafoam ?
- ITR pistons on ls rods
- hmm what clutch goes with a YS1 and or Y1
- Where is the Water Temp Sensor Wire?
- 90-93 Integra power antenna fuse?
- Weird noise coming from my car when reversing???
- Broke off breather valve nipple, what should i do??
- Head light oxidation
- cel after swapping throttle bodies
- Brake light come on when cold?
- My project and Mod list
- What spark plug wires should i get??
- Hey my vtec boggs out sometimes???
- Finally an Integra!
- engine swapping
- Where to get screws for trunk panel?
- Dumb Question
- cooling fans wont turn off
- trade in 94 dc4 for '05 dc5-s or 05 srt4???
- anything bad to look for when buying a 96 gsr?
- moisture
- question about quick release steering wheels
- calling everying that has a z10 block girdle. are the dowel really nessary???
- Does my Integra have LSD?
- vents in hood, smell?
- Need Ls Trans <hydro>
- Help with Indiglo Gauge Install...RPM and MPH don't work!??
- need you guys expertise on this one!
- okae my mechanic cant even figure this one out...
- balancing weights on newly painted rims?
- battery question
- Fuel Pressure Gauge
- Reasons why you should do your own oil change.....
- GAS MILEAGE??????
- cops
- Beaks DC Quick-Swap Anit-Sway Bar kit????
- 93 integra 4dr alxe nut size
- power steering is acting weird
- need to know what to look for in an engine...
- Odometer and trip not working on 94 dc w/usdm itr guage cluster..
- Integra Performance question
- valves question
- air filter question
- Car doesnt start..battery or starter?
- is a type r and gsr fuel rail the same?
- PLEASE help my GSR setup
- passing emissions...tune with SAFC????
- Close to buying JRSC, last minute questions...
- SRS Light?
- skunk2 manifold with cams
- CF Hood without exhaust mani heat shield?
- Cams to prove point
- air/fuel guage reading?
- VSS: anyone hear of the tranny not spinning the VSS??? pleeeease help!!
- quick release
- Spring mounting rubber, do I need it? (pics inside)
