- Can I swap stock seat upholstry?
- Question for you guys with upgraded rear sway bars
- Best Suspension Set up for Closest to Stock Ride Quality?
- where is the primary O2 sensor wire for 99integra gsr?
- Half Shaft wont go int Quaiffe.
- Power steering pump
- Where to buy a J's Racing style intake??
- camshaft key
- WTB: b18b...LOCAL....
- GSR Calipers? Bigger than RS/LS Calipers or no?
- code 8? help please
- catalytic converter
- Check engine light out of nowhere!!
- where can i find a better than stock trans.
- Tein Srpings?
- Definetely did a search, but I want to know the "REAL" reasons.
- TroubleShoot!!! Crankangle Sensor---> Need HELP!!!
- Really Expensive Integra
- Steering wheel
- is there a better option than stock for a 95 Ls tranny
- where can i get a helm manual?
- 1991 Acura Integra GS
- dc 4-1 headers
- Aluminium Lower Control Arms
- want some confirmation: TDC mark on pulley
- would these be good replacement LCA's
- Will a RSX or 4dr. GS-R muffler fit on a G3 Ls 2dr?
- repairing carbon fiber
- WHere is it???
- car stolen in georgia
- chipping auto ecu?
- Measure Window
- Swapping motors between Obd1 tegs, how much difference is there?
- Best strut bar for DA Integra
- quick disconnect steering wheels
- H&R OE Springs
- Crower Cams
- Steering wheel lock
- Feels like i have a flat tire but i dont what could it be???
- suspension setup
- shifting auto tranny?
- How do I make DSM 440 Injectors work in A 94 Integra?
- Need help pricing my car
- Help: Wheres the best place to get a starter for an integra.
- Can jumpstarting mess up a ignition system?
- 1995 Integra GSR ECU Pinout
- opinion? 95 ls/vtec trans, has gone bad what would you do?
- Can Somebody HELP with a Carfax Report?
- What do you guys think of ITR look-a-likes?
- 94 integra headunit wiring colors
- Los Angeles shops???????
- Look what I just picked up
- Endless vs. Project Mu
- oil leak?
- Skunk2 IM on a LS
- When rushing through a Valve Adjustment..
- Hondata Intake Manifold Gasket?
- Neuspeed Sports w/ Koni or Tokico?
- help on front strut assembly
- New keys
- Switched tires...now my car raised a little
- Will 94-01 G3 Integra Seats fit in My 91 Integra LS
- exhaust
- 94-97 vs 98-00 skirts help
- How much does a tune-up cost?
- integra offset question
- what's this god-awful rattle??
- Transmission question
- just reseted my ecu... weird idle now. help
- how high can a gsr rev to?
- maint light blinking
- decent valvetrain for ctr cams?
- What do you think about these?
- B18c5 LS-Vtec?
- ITR Springs
- What to expect from TEIN full coil over kits
- Building LS/VTEC
- relocating the ABS?
- problems with oversteer/uneven camber
- strange annoying noise 92 gsr
- purchased a 96 integra SE today. plan on upgrading it (suspension questions)
- DIY IC pipes pics inside....
- My teg's steering is off:please help
- jet v-force chip
- Uh-Oh Installation of the JIC's and Volk's
- can machine shops balance a crank pulley?
- Squealing Noise..related to ac ??
- Any body ever take their filter off the intake from the tree to traps?
- LS spark plug wires in a GSR?
- diff questions! Please help!
- 1st gen D16 transmissions
- any opinions on the best oil for the trans. 95 integra ls std
- need help ASAP: fuel pump kill switch
- NEUSPEED SofSport Springs
- Itr intake mani on b16a1
- Abnormal surging
- headers and mani..
- please help guys do any of you guys have step to step installation for koni yellows for 2000 integra
- Help i had an accident.
- gauge cluster question..
- b16 head on a b18 block
- good mechanic in Cleveland, OH?
- 95 GSR going LS swap.... wiring issues, Wait... what... why?
- broken belts.....
- pic request: DA integra transmission mount bracket
- Too many cams to choose from
- Abnormal revs?
- Price on 00 gsr rims
- Exedy organic clutch kit vs act street kit
- fuel pressure gauge??
- OMFG im soooo lucky kinda....
- Will shocks off of a 96-00 civic fit 94-01 integra?
- '00 si vs. gsr spark plugs?
- code 41..?
- Anyone ever heard of chasis tech coilovers?
- 94 integra gsr 450hp
- How rare are real CF Spoon Mirrors?
- question for everyone
- car wont rev past 3500rpm!!!!
- 98-01 GSR: Bad Exhaust Manifold?
- steering help needed
- H-T Please Help.. Smoke.. and Lots of it.
- porting exhaust manifold
- just installed skunk2 cams
- parking brake?
- Hey. Im new to Honda-Tech.
- having problems with clean gear shifts in a 95 integra ls
- Looking for a triple gauge pod for a 4dr Integra!
- "H" centercap for oem integra wheels
- CTR Header on a '94 GSR...good/bad? Opinions
- adjusting timing on LS. what should it be?
- ATTN Canadian Integra Owners...
- Need help asap!!
- cars dies out of nowhere!
- Mysterious oil loss
- JDM conversion Hood Latch Problem
- some help with coolent lines
- ITR sway bar + Beaks kit
- I like this set up...but what is the general opinion on..
- Is fixing a crank shaft oil leak at home ludacris?
- difference between obd 0 and obd 1?
- loud thunk when i let off the gas
- need some help with my GC/Konis
- Warranty question
- HELP
- What clutch for a 1st gen b16 tranny on my 93 b18a?
- EG Civic Suspension on 95 GSR...
- Will Civic TB fit a 94+ GSR?
- symptoms of bad stock fpr?
- ECU PROBLEM?
- Type-R shifter okay for 94-01 GSR?
- 88 Teg Dying
- Sqeeking brakes
- car is jerking need Help....
- Gsr vs ITR tranny?
- Car is lower on one side then the other :(
- HELP! 98 gsr motor into a 94ls
- check engine light - honda integra
- e55 bi-xenon
- multi angle valve job
- Define my needs [ Strut / Springs ]
- building a B series
- question about apexi ws2 exhaust
- Integra Master Cylinder.. I need a new one, get a OEM or is there some upgrades?
- auto to manual integras please help.
- Engine Bay
- How can I download or get a printer book of the parts?
- Anyone have experience with Clutchmasters?
- Free Fuel rail for Nothing,.......
- boost?
- oh no guys i lost my factory acura integra wheel locks
- I need your help about a Header
- bad hesitation and cylinders
- 91 teg Overheats!!! Help
- best place to buy jdm front end
- QUSTION???
- Throttle position sensor
- anyone know how to repair a dash?
- B16a1 Header?
- GSR swap with ls exhaust
- Trans Mount
- Azect sideskirts...size of rims?
- code 36???? wtf
- CEL light just came on #66.
- Just got some times for my 96 GSR let me know what you think
- What kinda wiring for a obd2 b18c in a 91 integra?
- Any diff in 15x7 and 15x6.5 for Slipstreams on a teg?
- Color of 95 Integra??
- under the axle exhaust?
- Ebay ECU question...
- Seafoam DIY Article w/ pics
- spoon ecu
- Rpm problem's Need Help?
- a/c install
- Can someone run a VIN for me
- Pics of a cf hatch or a FAL rear window for DA
- hondata help
- F- Series swap
- Interchangeable ECUs?
- This is the part number for a 2000 si..
- North jersey shop.
- Does anyone know about this RWD Integra?
- more problems (axles) :(
- B16 head the same like B18 head???
- where to buy a fender liner
- CTR header Q's
- When using nitrous would an inline fuel pump work?
- K-Sport coilovers...JDM and new to me....
- How do I become a member of this site.....All i wanna do is send instant messages!!!
- CEL
- headlights
- abs code 71
- is a hondata a good ecu
- best exhaust for a custom turbo kit t3/t4
- anyone still have Carfax access!!
- exhaust System
- So I ordered my shock and spring...
- HOW MUCH BOOST?
- Auto ATF feed and send.....
- Da conversion
- want to twin tubo a gsr
- White FiLm build up on headlights
- 2000+ GSR ECU Swap - stock to stock, IMMOBILIZER problems...
- Comptech ice box for DC2
- What's the best place to buy suspension components (GC and Konis)?
- 15x7 rim, on a DA? will it fit?
- GSR or Type R Cat?
- My new 94 Model Integra
- I NEED A 96+ GSR HEAD
- Looking for some help on piston rings
- spark plug wires....
- Best exhaust for a greddy Turbo kit
- timing belt
- Who has a White Type R and was on the 405 South last night and reved to my car? Anyone from here? Ma
- GSR block?
- diy icebox question
- Video of car after mods
- my car is fucked...? or is it? i have no idea... help me please@!!!!!!
- is integra gs-r same as ITR?
- Tranny Indentification
- S2K antenna on a DB1 easy or No?
- where to find realtime racing lip
- Which Bushing
- Help with all water leaks. Please.
- engine swap tips
- problem with lowering springs? uhm maybe raising springs?
- 98 GSR Clutch Question
- Cracking Noise Near Distributor
- gsr vacuum diagram
- Keystone OEM knockoff VS Honda OEM bumpers
