View Full Version : Acura Integra
- Where are the sunroof drain tubes on a '96 2 dr?
- need cheap exhaust please help!!
- kyb agx settings for a 2000 gsr
- My sun roof ripped off!?
- Is the MSD SCI-L really worth it?
- Comptech vs. Injen CAI
- info on the type-r hood plz.
- cel code 22 help...
- OMG! im soooo stupid! helppppp
- Wheels skip when they start to break loose....
- bearings??
- GSR Dashboard
- Philips 4300k HID kit, on sale!!!
- type r conversion (5lug and suspension?????)
- carbon fiber lip
- New brake suggestions???
- weight of ITR aluminium AC bracket
- JDM FEC Hid Or Non Hid
- did somethin a little new today
- Is this true?
- 91 teg wont stay started
- HELP!!! Fuse panel++ wont start, no fire!
- Ants in my Integra!!!
- What are some cheep horse power tricks for an 94 LS teg
- JDM Integra foglights 94-95...
- stench in the integra that will not go away!
- Does dynamat type material really help reduce outsdie noise?
- I need a part number...... please help
- Anyone have pic of an '87 Integra VECI label?
- What is this part for?
- engine lift spots
- tanabe pro ss coilover
- what do you need to build ls/vtec
- spark plug?..........yes another one
- 08/09 Headers Install
- what exactly does s port and polish do?
- whats the best route?
- Quick, need something from Greddy that i can print out saying that their exhaust is 50 state legal.
- how's INFINITY BASSLINK?
- hood weather strip...how to take off?
- CARFAX please??? (on a potential GSR)
- ebay intakes???
- my trunk is getting filled with water!!! help
- for those who have installed ES trailing arm bushings
- oil in coolant need some advise
- HydroLock questions
- so I found my timeslips from when I went to the track..
- bypass valve general questions
- Iceman question
- how do you know if a main relay is bad?
- integra b18 ECU on a B20B
- LS/VTEC knock sensor
- Limited Slip Differential Question...
- Dyno'd my GSR. Couple of questions.
- does anybody know how to replace the bulbs on m3 mirrors?
- Compression Test Results- good or bad?
- AEM CAI Rattling Noises
- VTEC or no VTEC
- Type R Rear Sway Bar Install Help!
- Factory alarm
- Winter Storage tips? Yes its winter here already!
- thermastat stuck open HELP questions
- What is your distance off of your alarm?
- California Car
- How much do GSR seats weigh
- Comptech Icebox...Whats in the box?
- Weight of Integra front cloth seats?
- Shift Boot removal
- Anyone with Velox VX-6R in 17" ?
- RSX gauge bulbs..
- NA setup, recommended exhaust diameter?
- quick question about integra/civic exhaust for the night owls.
- Front End Scrapage
- looking for a new exhaust for the teg, any thoughts?
- swapping front window?
- steering wheel shakes when i apply the breaks!?!?!?!
- Crower 404 nonvtec cams
- help me out
- help me out
- spoon or skunk2
- automatic transmission question
- 92 integra wont start
- Aftermarket steering wheel Question...
- RSX seats in a DC2
- Skunk2 IM and Intakes
- Got myself a theft recovery project(56k give it a shot)
- My Teg is shaking! need some help
- differences between obd1 and obd2???
- 2001 gsr swap in a 94 rs integra..!! need motor by tomorrow please help.
- clutch help...
- has anyone changed their shifter?
- G2 or G3?
- What's a good price for JDM ITR valve springs and retainers?
- Taillights
- JDM ITR steering wheel question? Horn?
- Someone tell me..
- 3 DYNO RUNS.....97 lbs/ft of torque !!!!!!
- 2000 GS-R or 03+ RSX type S?
- why cut the PCV valve?
- Hello everyone I'm a newbie need you opinions
- Picture update of my Integra.
- jdm headlights
- Lets see your sausage. :P
- Security System Horn Hookup
- 1989 ls engine auto
- vafc question
- OBD2 and test pipe
- What Manual Rack for 94 Teg?
- problem with my Diff or something ?? :(
- Can't find spoon style mirrors for a 98' integra 2dr
- LS/VTEC question
- help with selling my car
- ARP Torque Specifications
- Quick question
- Whats the diameter of the front sway bar ?
- oem clutch equivalent replacement?
- Downshifting Help
- how to make turn signals go fast
- Brake Line
- gsr ecu swap
- Worried about flywheel boltsing backing out...
- where can i buy or how can i make an apexi vafc black?
- obd0 to obd1
- Wipers quit in pouring rain, WTF?
- civic steering column?
- 4 door teg question?
- charging problem..
- How to change rear main seal on 88 integra
- obdi????
- My antenna broke
- maint required light is on for unknown reason
- stock gsr injectors any good?
- gsr water pump in LS
- Sway bars?
- 95 GS-R Factory Speed Limit?
- Cable clutch problem...help!
- Humming sound...
- H&R/KYB, HID, Comptech exhaust installed [PICS]
- OEM part numbers?
- Rear Seat Help
- Would JDM HONDA EK9 CIVIC TYPE R HELICAL LSD fit my 94 Ls tranny?
- Girlfriend bought a GSR, good deal? 1994 GSR
- just did my first break job, and im PISSED
- watch this vid.. tell me what u think about puff coming from my exhaust??
- Spring install trouble...HELP
- RSX- TYPES VS GSR
- Lovin' the GSR
- Just got alignment numbers...now what?
- engine does not start
- looking at a 96 gsr, quick question
- Coilovers vs Shocks
- cutting abs line for fun
- What does a mugen ecu do?
- some of my new fan wires are melting....
- DC2/DB8 Rear Trailing Arm
- know your machine shop before giving them work
- AC condensation leaking into passenger set
- need help chosing a turbo
- clutch replacement
- fuel rails purpose?
- JRSC and Comptech
- Integra Electrical problem
- brake noise
- is there any reason that AEM
- VIS CF Hood Question
- 16 inch Slipstreams, offset??
- what do u guys think 1/4
- Does anyone know how to remove tint?
- Whats the hottest plugs yall would suggest to run?
- opinion question: stock compression w/ upgraded valvetrain
- Gweird starting up of car.. any idea? plz help!!
- brake upgrade
- OEM Kit
- TB gets stuck
- Side Mirrors 94-97 swap to 89-93 Can it be done????
- Heavy Rain + Icebox = questions???
- How to identify intake/exhaust cam?
- grinding sound from under arm rest??
- damn car wont start....
- Price difference from a 94 and a 90
- Proactive
- that one bolt...
- stock GS-R stereo lights flickering?!!
- I hate stupid people who ask stupid questions.
- 97 GS-R hit a goddamn ditch and now my Front driver side wheel isnt aligned
- doing a zc tranny swap in a 89 crx I have questions PLEASE HELP!!!!!!!!
- This is what I think of rear LCA bolts......
- after market radiator that will fit stock fans...
- Q on making a custom cold air intake using stock intake
- Help!!!! My engine bay looks like ol' faithful.
- B18c cams vs. B17a cams...
- VSS
- 92 gsr tranny trouble
- sensor question...
- How to Wire JDM mirros
- Ditch my FMU for VAFC + 450s?
- Stock GSR Piston Size?
- cell code 22?
- removing breather from valve cover
- INJECTOR QUESTION H22 and B18c
- Going Price for Black Leather GSR seats?
- camber kit degree
- opinions on this ebay header
- Where in San Diego can I get cams installed?
- motor mount install story...
- TAKEN by HondaDepot...anyone else
- ITR shifter in a 2nd gen
- racing rod bearings?
- Which exhaust for best ground clearance?
- whats the diff.between ls and gsr brakes...
- NYC Garage Owns my jrsc GSR
- Proper way to reset OBD1 GS-R ECU?
- Integra LS Intake Temp. Sensor.
- Steering Wheel
- turbo kit
- Gas needle go to empty when engine off?
- abs light
- new exhaust...
- Where can I get a Apexi World Sport Catback Exhaust
- Dimming Dome Light?
- passenger side water leak (a/c related)
- best non-type r coilovers
- Power steering problem
- Quick question
- I need a picture of a gsr's firing order help please
- Oil pan drain valve?
- broke my timing belt
- Rod bearings
- back up sensor questions
- How to fix my passenger front side axel???
- Iam down to kill a theiv right now
- Lower Rear Tie Bar
- help bolts from under teg popped off
- turbo question...
- Anyone know where to get a fiber or carbon hatch for my DA?
- just got into this car thing and have a question
- Whats A Cam?
- data system v-tec controller
- GC vs Skunk2
- I know its been asked a million times but
- obd0 to obd1 NO spark!@!
- Integra seat question
- electrical headlight diagram
- How to tell an LS tranny from a GSR tranny?????
- Hydrolock questions :/
- parts needed to install 23 mm sway bar
- My b18c Dyno charts
- ITR Intake manifold on a b18c1 head will it work?
- emergency brake light and abs coming on.........
- JRSC on a GSR
