View Full Version : Acura Integra
- Ticking sound...
- Anyone have a helms manual for 95 teg?
- losing power?
- Got an RSR exmag full cat exhaust!
- IACV cleaning.
- combustion chamber rust*** please help
- Circuit 8's or Gt3's
- Quick Question
- Car runs rough with A/C on...
- b18c1 valve Adjustment Problems... :|
- 92 teg GSR cable tranny
- Loud engine noises
- *wireing harness for da with or with out (ABS) is it the same
- GS-R muffler
- Can't get my hood open
- B20 VTEC???
- STOLEN TEG IN MORENO VALLEY
- secondary buterflies
- Ignitor -> Short
- exhaust putting?
- Performance Shops In Indianapolis....
- DA suspension question
- Endyn Catch Can review...
- 92-93gsr or 99-00civic si
- hey im a da owner now
- suspension
- new engine
- What is the diameter of antenna hole in the fender, and wiper hole in window
- ITR gauges
- HOW do I REMOVE VOLK CENTER CAPS. QUICK NEED TO SELL RIGHT NOW!!
- b18
- 88 civic coilovers on 92 DA
- need help!!
- WTB.. anyone has an INTEGRA carbon fiber hood oem for sale??
- ultra PIMP MEDALION
- hows this combo
- Burning oil in a 93 Integra
- COLOR CODE REQUEST
- Turbonator!!!??? What!
- I BLEW MY MOTOR!!!!! AND I GOT QUESTIONS
- throttle body?
- how???
- bogging or hesistation problem
- Problems with 96 SE Integra - Please Help!
- Stuck Spark Plug
- break light problem (electrical)
- Car won't start...
- What year integra did this wheel come from??
- Obd / rebuild questions (keep)
- Old car, New problems.
- Color?
- Exhaust cutout, Good or Bad idea.
- PEAKBOOST TURBO KIT TECH QUESTION******
- Type R antennas
- whats better itr manifold for skunk 2 manifold
- AEM CAI for LS good for the skunk2 manifold on a b18c1?
- stock radio interchangeable from 3rd gen to 2nd gen?
- Looking for a cheap good turbo...
- fuel pumps...
- Overheating with A/C at Redlights.. HELP!
- GS-R exhaust system
- max power i can get out of an boosted ls with stock internals??
- ITR Engine Swap into Integra GSR
- b18a problems
- HELP Car sputters and Iam fed up!!!!
- HELP...A.S.A.P.
- tc sport cf hoods any good?
- how to put an ls right time..
- GSR EAGLE RODS
- ITR lip shipment
- about my teg
- VSS
- need help
- type r lip
- CAR CRANKS BUT WONT TURN ON-FUEL?
- Spring rates on coilovers. Who has what?
- FS: OEM optional kit for dc tegs
- Mouse Nest In The Heating System
- need help in socal on power windows
- digital RPM?
- o2 sensor problem again
- fuel pump cutoff clarification (yes i searched)
- painted my DC4's rims... comments?
- power antenna override........
- New header, New rattle...
- turbo manifold that retains my a/c
- help me find these parts please!
- OMG have you guys seen this!?!?!
- ICM or igniter?
- Fog light
- captiva blue
- will my header fit ?
- SRS light on! How do I turn it off...?
- Another Dead DC2!!!!!!!!!
- How is my Exhaust tip soo clean?
- Steering wheel question...please help!
- rainy day pics
- Jackson Racing B series Supercharger
- recirc / vent issues; help!
- Clutch Bleeding Questions
- JDM ITR bumper help
- DA wont start
- 94 Integra Radiator Fan Interchangeability
- question about how a/c fan operates, please help.
- im selling 94 integra ls
- APC coilovers any good?
- need color code or name... please help
- what other year teg or civic coilovers would fit in my 90 integra?
- reverse light switch
- engine wire harness
- 94 Integra A/C system - return line
- gsr vs. ls
- DA integra Problem.. Window is de-tracked & door opens from outside only..
- bulb type
- Rethinking my suspension set up
- immobiliser ??????
- tire size help w/ rota slipstreams (pic inside)
- Fuel Pressure Drop
- starting problems
- Gsr - Crvtec
- i need inspiration anyone has a k20 in a g2 teg..?if not what does it take..???
- FS: skunk 2 coilovers!!!
- DA suspension swap question
- worried:(
- need help with wiring
- Vtech ECU
- Does a 4-2-1 header take that much off the top end?
- selling car and have no idea what to ask for it
- Chances ?
- Quick Question
- Where to buy Removable Steering Wheel?
- 94 Integra LS Valve Lash Specs
- I'm getting screwed on my motor install and don't know what to do!!!! PLEASE HELP!
- water leak into dash ***pics***
- major clutch problem, help needed
- Just take a min and look at this
- How much to ship a hood to Nashville ???
- Slick 50?
- What Rims Are These??
- Would This Fit On A 91 Front Bumper??
- What is the purpose of this? (transmission plug)
- those new JDM angled adjustable license plate mount
- Need help, confused!!
- squeaking noise when brake is pressed SOMETIMES!
- **unoffical license plate poll thread**
- Two questions - oil leak confirm and dirt problem? (pics)
- need one (1) B series 1.8L head bolt
- wtb evap/charcoal canister
- brake problem.
- quick question about valve adj tool
- Engine swap 86 Integra
- question about summer tires
- Front and rear springs? what is what?
- What part?
- help with exhaust
- can the clutch mess up your motor mounts?
- Where is the horn relay?
- Are these parts interchangable?
- JDM DC frontend on a DA,anyone done it?
- New car, want more power
- axel replacement
- Cars Vibrating/shaking!!!
- Popping noise during accel/brake
- Question to the fellow suspension Integra Nerds =0P ?
- Not sure what to do
- Brake lights stay on ???
- Quick Question
- OEM GSR intake
- White build-up on Gauge cluster!
- Front Wheel Hubs?
- ABS light on
- how i g0t ripped off almost $500 fixing the damn A/C
- 30 mph shift from 1 to 2nd (auto)
- sound system
- Dizzy replace?rebuilt?aftermarket?
- da springs
- where to buy paint...
- Milano Red Fade... ex(ple)tive this color!
- 97 Rear Lip Can It Fit In an 98 Rear Bumper?
- Who has steel braided brake lines?
- are integra's still a common target for car theives?
- gah forced induction help
- rear lip on gsr
- header: gap where it connects to test pipe
- cold air intakes
- valve cover gasket???
- B18A1
- help... tranny gone??
- Painting Integra Front Bumper ..
- what gears are n a gsr tranny?
- resinator
- jdm dc 4-1 on stock exhaust
- input needed on 97 integra
- selling parts
- Check Engine light???
- JDM Auto trans?
- Gauge cluster problems!
- how much should I sell my teg?
- Exactly how many slave/master cylinders are there?
- any one get pissed at their cavalier lately
- quarter panel replacement question!!
- BEWARE OF TYPERMAN2001!!!!
- coilover questions
- How to tell if header is on tight?
- stock ls axles
- exhaust question????????
- how do i tighten my AC belt and my Power Steering belt?
- WTB: 98+ front bumper, need some help finding one.
- 4door 94 exhaust suggestions
- integra people!
- catback exhaust... Any suggestions?
- gsr edel. mani. fit for b16?
- ~~~Post pics of ur painted 94 tail lights to look like 98+~~~
- b18c1 crank rotation prob.
- b18a or b18b?
- Which Hid kit is better? Any pics
- For Sale: Acura/Honda MAP sensor, NEW
- DA Speedometer Cable Squeek - How do i fix it?!?!?
- neuspeed springs for sale
- Just got an alignment and they told me I need a camber kit...
- 89' Integra coolant leak
- bushing kit for DA9. POLL
- Trying a motor build up just a few questions
- Question about Vtech dont know if hitting or not
- opinion on suspension
- Crackling Noise
- 90-93 INTEGRA with VTEC MOTORS | POST THOSE PICS
- What Starter is this ?
- Is the B18 good for n00bs?
- Replacing door key lock...
- Lifter?
- What are these for, where do I get them and for how much?
- Removing A/C neccessary for the DC?
- need new radiator suggestions
- Which sensor?
- 4-door cat-back
- front end rattle at low speeds
- Is there anything I should check/look while I have my dash out? (Blue to Black swap)
- lsvtec turbo...LS clutch kit or GSR clutch kit?
- intake manifold
- Auto to Manual = DA integra with DC obd2 block
- differences in 96-00 integra models?
- why motor always smells like gas..
- Can someone ID this rims for me plz~
- has anyone ever head of black traxx?
- polished calipers
- electrical burning smell
- rear wheel bearing help
- Ls Hydro Tranny
- jdm front end question
