View Full Version : Acura Integra
- hey u guys does anyone in here has the jimfab motor mount
- Wierd eratic idle problem... suggestions
- No power at ignintion.*video*
- Ahh! Suspension...
- Ideas for cheap exhaust (Gen 2)
- Apexi gt spec vs Tsudo N1 catbacks
- making non honda seats fit in my teggy
- Tranny Problem, I NEED SYNCHRO and Bearings
- pic request:Da teg with black ADR GT sports
- What plug wires should I get for my GSR??
- Anyone have a JRSC'd LSVTEC?
- ECU code 91. Advice wanted
- Chrome Screws on ITR Valve Cover
- TDC is off ( timing belt replaacement )
- 15s or 16s for an Integra?
- 5 lug conversion
- fuel pump power
- 2000 GS-R
- a/c question
- Are the 1991-1993 integra GSRs as fast as the 1994-2001?
- OBD0-OBD1 Question
- somebody give me some input
- How much does a B17 sell for?
- brake upgrade question
- AC blower noise
- 96 Integra GSR Turbo How much is she worth? POLL
- So how do i get the Distributor Rotor off? I allready got the screw out the back of it.
- Will 96 LS dizzy work on my 93 teggy?
- Compression test results
- Inlet/Outlet of stock GSR cat
- Painted Stealies?
- where to buy an oil pan gasket
- Good Drive Axles for a Budget Builder
- I need a downpipe.
- 1994 Full LS Swap FOR SALE!!!!!
- AN-R Race Header
- GSR Redline
- EF mounts work in DA?
- Super Sonic BLUE Integra Pics (post here)
- They Stole My ECU(grim)
- LS tranny problems - please help.
- 90-91 RS LS GS question
- No idea what is wrong with my car!
- Brake Light is ON
- Integra Type-R Pistons in a B18b block/rods
- 80k = ?
- mf10L's on my champ white integ?
- integra third brake light
- missed 4th hit 9500
- urgent: b20vtec dc4 blowin white smoke
- Ignition
- JDM type r header doesn't fit a GSR?????
- Piston to valve clearance with CP 11:1 and skunk2 stage2 cams (pic inside)
- b18c1 or h22
- over heating problem (maybe)
- help! no power to deck and clock
- good used engine website?
- question about compatability of oem cd players
- vafc n throttle position
- Electrical Question - Cooling/Radiator Fans
- Engine Fan Relay Question
- Intermediate shaft
- power band b18
- Where can I get JimFab Products?
- wtb- 450dsm injectors, resistor box
- Heat shield removal
- removing molded sideskirt
- Integra LS issue
- civic si header
- Anyone Have Any Turbo Automatic Tranny Integra\Civic Video's?
- some free carfax for the first few fello teggers
- Voice Your opinion
- Pic request... FAL window
- 92-93 gsr gauges.
- Is my clutch master/slave cylinder going out?
- timing belt
- I have a Smart GSR. Did 60K Tune-up and loving it more.
- Help got V-tec problems!
- LS VTEC Intake System
- ITB's on LS VTEC
- Replacing a bushing yourself?
- Coolant bursting out of overflow...but not overflowing?!
- Combination of Camshafts?
- H Brace Install???
- rs wont start
- search is down!!! CODE 65
- 1999 GS Automatic Slams Gears?
- ITR CAI fit LS?
- Radiator
- Have a problem finding header gasket
- Search Down Throw Out Bearing Question
- groaning sound when making a left.
- search is down, wheel stud replacement easy?
- xtrac1---u out their???
- aftermarket obd2 b18b intake manifolds?
- maintenance light
- CAM GEAR HELP!!!!!!!!!!!
- How much power is too much for the street?
- how do i find a "short" in my electrical problems
- Integra Tein SS's Spring Rate
- Oem Civic shiftknob fit Integra?
- can civic type r pistons fit on a b8a1 block?
- Do the 98-01 gsr rims have a chromed face or a polished face?
- Future LS-turbo Problems?
- need help choosing an engine!!!
- My gsr got hit from underneath when i was up in the canyons yesterday. Causing damage. help
- thread pitch for screws (4x16) in center console?
- New to honda tech (check out my vids)
- GSR BLOCK VS B20 BLOCK
- alternator sound
- help me!! what can i do?!
- Vandals again!
- B18B NOT B18b1
- how can a k20a2 pass smog?
- 2001 GSR starter GRINDING?
- Where can i find the sivtec lip???
- Rear-ended without a trace!!!!
- gsr 4dr apexi n1 problem
- ebay headlights
- 97 leathers..
- DA Clutch Install
- Maybe Timing Belt Tensionor Problem?
- SoCal Tint Shop
- Turbo problem!
- Good price for this gsr?
- Help leaking water d16a1 1987 integra
- Give me your opinion on these wheels...
- B18c Block b16a Head...Good setup??
- H.I.D HELP!!!!!!!
- what could the problem be
- switching to royal purple 10w30 synthetic on my 00 gsr
- best manual transmision oil??
- skunk 2 stage 2 cams
- cable to hydro tranny
- how much would a transmission cost?
- pops when i put it on D4....
- how to remove windshield
- Valve adjustment or bent valve???
- hey u guys were is the Maintenance required light buttom to reset it
- What is the best cat back exhaust?
- socal request: crankshaft pulley wrench
- take out cover under trunk
- ***paint check question***
- GSR Ecu question
- 92 Integra Guages in 91 Integra Cluster?
- AEM big brakes and 16" wheels (Rota in particular).
- Hazzard light wont stay on?
- turn singals
- power windows being gh3y
- Rplacing Axles and fluid on 5 spd tranny
- taking off intake manifold paper gasket [pita]
- Coolant loss, low compression rough idle
- Header-Cat dilemma
- kumhos avs or fuzion zri??!!
- What ITR parts could fit in a 94 Integra LS
- poly Urethane
- help identify these G2 mounts [3.5M pic]
- Engine Bay cleanin, hiding, a few questions
- d15 into 95 gsr
- Gs-R shocks and struts?
- need advice Ls/vtec or b16 swap on a DA
- Multiple Problems with my Integra
- Help plz!!! lol!! Which pin is o2 sensor on ecu!!
- Ignition ON/ no power.
- Ignition: if all tests passed, replace icm? why?
- kamikaze header?
- Where to find Tranny Tutorial 90 Teg
- ¿ rear brake conversion ?
my drivers side rear caliper has siezed TWICE and im pissed
i have read
- turn signal woes
- Please help!!! o2 sensor location
- need help intalling new window / motor
- Help LS vtec
- momo steering wheel question
- weapon-r intakes
- Leaky Clutch Master Cylinder?
- As much power out of the B18c1
- 94-01 OEM Shiftknob
- Window regulator
- weight of b18b flywheel?
- rattling noise?
- opinions on my situation
- Turbo question???
- What valve cover do you prefer?
- newbie..bought a 95 Integra RS need imput
- so cal only..who wants to take over my car payment it's a 01 silver gsr
- Power Washed engine bay 4 days ago and cel randomly comes on and goes away
- wtb: jdm frnt end metal or fiberglass
- need a windshield
- Need help with HUB removal!!
- ecu ???
- 16'' Rota GT-3 GAB replica red w/o tires
- Rerouted hood release 90-93 teg?
- window moldings / trim
- Searched: 95 valve cover on a 97
- Maintenance Required Light On.......Grrrrrrr
- Civic SI lip or Civic Type r lip on a DC2??
- Aftermarket 98-01 Bumpers on Ebay?
- radiator and fan
- already searched! anybody know where to find b18a1 ecu codes
- LS question
- mtf and plug wires
- checked a few things, but car still won't start. need some help...
- acura auto trannys
- Lower radiator hose... should it have a spring inside?
- ITR EXHAUST
- 92 GSR-Replaced dizzy, ICM, Main relay-NO Start??
- Looking for carbon fiber rear lip. DC2 94-97
- 91 Integra Startup Problem
- Please Advize !! It Won't Fit !!
- HELP! anyone with pics of the Chargespeed Type 3 Front Spoiler
- Ebay clutches?
- changing out my brake fluid to ATE Superblue...
- Is it easier to buy a chipped ECU w/out knock sensor for LS/VTEC?
- LS/VECH..Whats needed??
- light works
- throwing a CEL 7
- First time to the track with my ls
- New Suspension, YAY! But...
- how to tell the model?
- Semi Metallic Pads/Cold-Snowy Weather?
- 94 integ giving some problems
- 98-01 Front bumper off ebay?
- front bumper support and exhaust question
- Integra LS subframe?
- Anyone have a good picture of 97 up teg on tein s springs? Already searched.
- Need Help. Car Acting Strange
- water leak
- HID High beam for jdm front end hid housing headlights
- 714 OC HIT AND RUN, I NEED YOUR HELP!
- Smoking after transmission fluid change
- '01 Integra Type R Swaybar FS
- HOW TO SET TIMING
- P30 Pistons on LS question
- WTB: Integra GSR/ITR cable reel
- engine removal
- CURIOUS HOW MUCH A 99 B18c Block IS worth?
- Need help on fuel pressure
- NEED HELP BAD!!!! SOMETHING ELECTRICAL MAYBE!!!
- Just bought a 95 RS ...
- Black Oil ventilation box on the back of the block?
- Exhaust Problems
- GS-R Motor into an LS
- Dash Lights coming on when I push the Brake pedal! And not when lights are on.
- GS R header question
- need help with ABS
- Quick question about gsr catalitic converters
- my new DA
- loud rattling | chatter noise from engine bay | valve cover | under acceleration | load
- Anyone know where I can find this peice of the jdm front end??
- rear sub-frame repair
