View Full Version : Acura Integra
- Input with NON-VTEC motor with old VTEC harness
- white 98 rs
- better air flow/ Muffler ???
- Whats a good ride for my 91 teg??
- Thinking of selling my Teg, how much $ ?
- need code read help serious mind boggler
- RSX seats into my DC2
- NEED Help ASAP just Swap in a Ls-v, now wont start up!
- J32A exposed to elements for 4 months...
- swaping b18a1 to b18b1 on a 93 integra
- low oil pressure, oil on hood, oil smell
- leather to cloth swap?
- auto to manual swap help!!
- will the antenna still go up and down if I switch to another OEM deck?
- what do my 94 ls teggy worth?
- Starter help
- Will 17x7.5 +48 fit on my teg with 2.5 drop?
- progress rear sway questions...
- 2KRacing.com we are a new Sponsor, Great to be here!
- please help! squeal from front pass. side of car.
- low intake temp
- stubborn crank bolt
- 2001 dc2 abs system into a 95 db8 question...
- GSR 5th gear pops out
- head studs
- What is this plug??? **PICS**
- What kind of spark plug for my mild build GSR?
- opinion to get skunk2 mani
- What is my car worth?
- what is this called?
- JDM GSR TIMING BELT AND WATER PUMP
- help me understand turbo...
- New integra,95 se
- engine assembly lube replacement
- should i use ITR LMA??
- Manual steering rack for 91 integra.
- Need help installing CD deck
- obd2 to obd1
- brake rotor, and pad recommendations!!
- I need torque specs on b series trans....!!!!!!
- Quick ? Will a B18C1 tranny fit a B18A1 engine?
- car loosing coolant and overheating...
- horrible idle problem among other things
- ITB for a B18A1
- Gas Reading Question?
- is this rhd or lhd vent
- Tune up for Integra GSR
- how to swap and obd2 into an obd0
- ys1 trans
- hydro gears in cable casing?????
- Difference in OBD1 and OBD2 dizzy
- need help identifying this part
- 91 integra -Need help
- CALI BAR QUESTION
- B16 tranny or maybe 4.7 final drive in my GSR
- 96 integra help
- code 23 on gsr
- Is this true, lost car title
- obd-2 ecu conversion
- b18 swap.
- i have abs trouble
- MSD into an 97 GSR. Need Help & Advice ??
- Possible fuel injection problem? 91 LS
- how much a stock hood is
- No title should i still buy it
- 88 integra motor options
- 8mm bolt broke off my FITV.... how to fix?
- Fender liners needed?
- Water in engine... is tranny still good?
- random question about exhaust
- DC4 Question!
- Cranks put wont start, 97 integra auto
- heater core delete.. problem help
- GSR Crank Pulley on B20 Crank?
- 00 LS blows alternator/vss fuse when it shifts
- A/C control 1 and 2 don't work, 3 and 4 work fine (fan speed control unit?)
- Weird problem no start
- keep it or lose it ? Cat vs Megen resonator?
- UCA's Question
- how far will 1258$ go ?
- gsr head on ls block?
- Need help with wire placement!
- need new tranny
- How do u take off corner lens?
- Which model DC had the checkered floor mats and rear trunk carpet?
- **ECU Harness** HELP
- EK suspension fit DC?
- Jdm front end anyone have a writeup on the install???
- grrr oil leaks
- maintenance required light
- Help please.
- Just got 5 ABS codes!
- Is this 95 Integra worth $2100
- Blox TB Idle Problem
- some parts i picked for my beater
- dc2 antenna
- what 2 do about o2 sensors
- 93 gs-r harness?
- Ecu problems
- how long do stock clutchs last integra rs 1998
- squeacking from fuel pump
- need opinion on paint
- hood threads stripped
- JDM Chassis Badge Integra DC2
- LS vs. GSR ::: Catalytic Converter / Exhaust Lengths
- gsx versus INtegra
- Help!!Need a fuse box diagram
- JDM FRONT LIP
- How much would you pay for this integra...
- are the dizzys year specific on a da>?
- Help pleaseeeeeeee
- timming
- Help finding Integra hood Lining???
- Starting to put money into car...
- Removing the floor, how?
- 94-01 integra driver window motors all the same?
- dc2 b20vtec- installing arp rod bolts
- Spoon Engine?
- Odd tranny noise.
- Exhaust gasket
- Wierd Transmission Grinding?
- Speed sensor wiring please help !
- b16a motor swap ???'s
- Is it worth it>?
- another b20vtec question.....
- help with wiring for 92 GSR
- b18b turbo...ls/vtec or just b18b turbo?
- car shakes alot when started after sitting overnight help!!!!
- Found automatic b18c from japan, what are the specs
- car stalls between 2k-3500k rpm for about a mile when first heats up??? HELP
- Please help!!!!!! Water in spark plug hole.
- Headgasket Question ...
- Radio Antenna won't go down anymore
- AHH I lost my only key.
- 90 teg trouble code
- 90 integra tranny HELPP!!??? put into gear and wont move even with clutch pushed
- I got cams. What else do I need?
- Will a bigger throttle body give me any gains?
- LS/vtec turbo
- Any suggestions??
- tuned my integra and it dies! help
- ::HELP:: Bubbles going into coolant overflow
- paintjob without engine bay
- what is needed
- This block anygood?
- aftermarket seats + stock brackets ?? HELP FITMENT
- plug wires 1,2,3,4 diagram for distributor cap, b18c1
- Need to identify this hose quick!
- Im trading my teg for ek with 98 motor
- Oil pressure light.....help!!
- ALMOST STOLEN
- why is my tail light fuse keep blowing??? help please
- OBD2b into OBD1 chassis question regarding CA smog
- Blox cams b18c
- feeler gauge question
- New Cat Info
- b20 questions for my Integra
- Where can I find a full type r exhaust?
- !!HELP!>92 DA TURNS OVER BUT WONT START!!
- Vtec will not work HELP
- *** what causes my tranny to pop out of 5th gear while on HWY?
- Horrible Grinding/Vibration from Shifter at high RPM's
- b18b1 tranny $ ??
- should i set my cam gears back to 0?
- exhaust manifold leak question
- What are Integra AC Lines Worth? Headliner?
- no vtec?
- no vtec
- HELP NEEDED: Car Will NOT Start After Swap
- Idleling problem
- no start problem, searched
- DA JDM headlight... changing fog light bulbs?
- Head Gasket?
- # 3 Cyl Temp High? Anyone else?
- fuel problem
- Transmission problem?
- torque specs
- Extended Wheel Studs
- CEL P1259
- Will this work
- oem radiator or alluminum
- Car shuts off and will not re-start after 15-20 mins of driving
- Cel code 09???
- Neutral Revs, In-gear will not?????
- Noise at at start up
- ...:: LOVEthatDC2's GSR Build Thread ((Slow Build))::...
- 98+ front end: side marker light blown out
- removing PS and AC belt
- decent price for parts installed?
- Wat Cams Are These
- b18c1 or c5
- my 4dr ls-se
- Teg gurus.. Ever broken down a B Series Engine? Name these parts! $
- ABS LIGHT QUESTION??
- J32A2 Integra
- Please help identify this shifter bushing!
- rear integra 5 lug conversion ?
- drag race results :(
- Clutch Master Cylinder/ Slave Cylinder
- b20b into 95 integra b18b
- Changing brake pads, piston not going back in
- DA rear trailing arms on a DC?
- Clutch issue, early engagement sometimes
- Can any of you from Bay, help me fix my jumper harness.
- Need help please,my 91 LS isnt starting after a head gasket and timing belt change
- Strange Rattling Sound
- weird tranny problem
- castrol edge better than mobil 1?
- help...about spark plugs..n it sputters..
- Integra Service Manual Help
- Looking for best tires for drag strip
- B18a1 Help
- custom guages
- lowering springs
- I have a starting problem on my B18C1 DA9 OBD0..
- Another "what exhaust" question
- HELP! Wiring Pinout for ITR Foglight Switch
- New owner of a 92 Integra
- Higher idle than usual / C.E.L. / Running Rich ?
- Driver's Water Leak
- fan stays on after ignition is turned off...
- exhaust sizing for 200whp?
- Performance For Auto Teg
- nylon plugs size for integra trunk help
- 94-01 LS clutch fitment?
- ITR and GSR front strut bar
- 99 Integra GSR, oil coming out from exhaust/muffler??
- SKunk2 exhaust set up issue
- Benens Lower Tie bar + Stock sway?
- 94-01 gs-r flywheel questions
- most all Integra Specs, 0-60, Horsepower stat
- B20 Swap
- electrical issue with GSR
- JDM 4-1 Headers collector question
- Power-chamber on b18b/a
- need help with b16 swap
- Lower strut bolts wont come off - 1990 integra
- i can't find the PCV on a 92 GSR
- B16A 92-95 (SiR-II) From Hmotors
- type r header on DA
- what tranny fluid would be the best
- broken valve cover
- TRAILING ARM BUSHING ISSUE NEED HELP
- PS removal...
- 205 40's
- PUDDLES IN MY 94 INTEGRA
- helper springs..?
- B18C gsr suddenly kicks vtec at 4500rpm
- lookin for a new harmonic balancer...
- Catback System Fitment for 2/4dr GSR
