View Full Version : Acura Integra
- FYI, parts you will need for Skunk2 intake manifold on b18c1
- ITR front and JDM ITR rear strut bars FS
- gen 2 side moldings question????
- whats you think
- those with a 97 gsr....please help me out
- Will accord coilovers fit a teg?
- Torque convertor in 95 LS the same as 98 LS?
- Where to get Broadway Mirror?
- DIY turbo: what is missing from this ????
- What to do with $1000
- Neuspeed Race drop
- QUESTIONS about my 94 GSR...
- gsr swap in a 2nd gen/ got a ?
- All amber signals for 94-97?
- just traded my hatch for a teg!
- its Winter again! To store, or not to store?
- Dayam!! Today must be my lucky day...
- Need pics and recommendations .. 92 GSR exhaust and springs
- Spoon Shift Knob Question
- Removal of rear bumper cover?
- Anyone with PHILIPS HID's and a DIGITAL camera, please HELP!!!
- dual exhaust?
- How to fix leaks in 2nd generation integra?
- 2G OEM Window "Ventshades"
- code
- ls-v vs gsx
- OK, im getting a teg..how many is TOO many miles?
- Disabling ABS
- cluster issues.....please help......
- Speciality Products Camber Kits
- skunk2 on 95 gsr with no header
- short shifter?
- who makes aftermarket JDM sideview mirrors for the 95-01 Integra?
- Tegra' help
- Maintence Required Light is on!!!!!! How do I turn it off???????????
- OBD1 dist required for OBD2 to OBD1 conversion?
- is it worth supercharging a LS ???
- Look what the UPS man brought today!!!!
- Hey, i'm new here
- rota subzero 15s or tenzo RS5 15s or 98 GSRs
- GSR sway bars
- Brake kit?
- What brakes do i use??
- DIY Stupid Mistakes!!!
- should i bore my gsr to 2.1 liter??
- hard to start the motor after parking it etc.? help me out! it hesitates to start up, with clucking
- Check my camber specs
- clutches
- ever have o2 sensor problems w/ no CEL?
- quick CEL question
- does anyone have pics of the tanabe racing medallion??
- Slave Cylinder is Toast... need part number.
- About to get a 96 GSR..
- SuperTrapp or Japanese aftermarket exhaust?
- timing advance
- new clutch master cylinder....now pedal is weak!!
- Tranny/Clutch problem
- alternate oil filter for integra
- oil filter for Prelude fit on Integra???
- What rims did the 97 GS-R come with?
- what about 2nd gen
- Check Engine Light
- My window slips
- JDM CTR seats into a GSR??
- Swapping teg rails to del sol seats? Any instructions?
- 3" cat back exhaust???
- Got a Code 7 (tps sensor) WTF? Help
- check engine light
- 14" Wheels on '94 GSR?
- GSR rear bracket
- LS Bottle fed ?
- Pictures on how to fix your loose window...
- Ls/vtec help
- Hey I need help with a 92-93 integra wiring chat
- 95 integra special edition $7000?
- How to tell the differnece between an ITR throttle body and a GSR throttle body?
- ATL meet
- More questions for those with turbos....
- Werid noise when turning steering wheel at start up
- My block is done? Now here's the Q...
- Removing Cruise control
- Energy Suspension Urethane Motor Mount Inserts
- Quick valve adjustment question!
- intake mani for b18b turbo?
- Dyno on Teg w/ CAI
- Pinstripe removal
- 96 RS Motor
- how do I post pics
- Hole in Left side door panel.
- 6500 too much to ask for a 94 teg rs???
- I have a strange question about a WRX muffler
- Hondata won't turn on ?
- Need Help on My Next Mod!!!!please
- Taking off oil cap while motor is running...
- Q on Hondata related to CELs
- How to replace the pcv valve on 94+gsr
- What type of braking system are you guys using?
- I need an advise
- 88 heater probs ....heeeeeeeeelp!!!!
- aquamist
- motor swaps
- what is the exact size of gsr's brake rotors, front and rear
- car idles very high when headlights are on
- bad fuel pump?
- question for Carsound cat owners
- conventional motor oil v.s. synthetic motor oil, what do you think?
- im a luder but becoming curious about integras..
- help!
- Will Acura Warranty this?
- difference between neuspeed konis and reg. koni yellows?
- Where's my ECU?? 89 Integra
- Whats this worth
- When you see water or white smoke from an exhaust
- sup im new wanted to intro myself
- Help? look inside
- my $5 diy catchcan
- Online Stores
- srs light
- looking for blade rims
- how much does an integra shell weight?
- Replacing damaged aerial
- Acronyms For Noobs Like Me
- Toast up for everyones help!!
- typeR strut bar
- . . . .Rear Strut Tower bars. . . .
- Md, Va, Dc sales?
- Pics of Koni install...
- force running cold
- oil change
- where in NYC, LI can i get a tap for stripped thread?
- check engine light #67
- Parts 4 sale !!!!!!!
- Please help me with a leak i found!!!
- who can get me a not so easy to get JDM part ? ? help
- plugs
- Are the :acura: center caps on the GS-R blade wheels...
- Will this work?
- Im 16...first car, integra or prelude?
- Shocks
- diy cai
- Benefits of Honda coolant/antifreeze?
- ANOTHER 9005 Silverstar conversion question... (sorry, I did a search)
- how much for a 94 gsr
- stolen car in dallas, tx (die thieves) pt2
- project vs. project
- Get a power lock alarm for your teggi
- Bad idle problem
- Quick Ignition Timing Question
- HKS hyper exhaust sound clip
- need a new clutch: itr or exedy?
- Anyone wanna suggest a set of good performance brake pads??
- Taking Out A/C.......Questions?????
- Spoon mirrors on a 90-93?
- ATTN: JCushing
- Any tips or Tricks to installing rear seats back in?
- Vin Number check please...
- mugen side skirts 2nd Gen
- Advancing timing how much is good?
- Going F'ing Crazy, Cant Decide
- Stock GSR Spoiler
- Still have my GS-R but i bought a new car
- Falken Azenis and Spoon Springs
- What else to replace/upgrade while head gasket is being replaced?
- Are ITR and GSR plug wires the same?
- Pros/Cons of putting a turbo on a 99 GSR
- anyone from atlanta up for a meet?
- Problems/Symptoms with Power Steering Failing...Help!
- jdm headlight wiring
- Member question
- another GSR bites the bust. Pics inside
- Steering wheel mechanical moan??
- difference b/w 3 door and 4 door gsr shifter and linkage
- Can someone show me a pic of a starter on a motor?
- USDM LS and ITR header the same?
- clutch master cylinder
- G Force T/A ???
- RPM Activated Wsitch Schematics
- j & s safeguard
- I know, I know...........
- Cheap HID's
- Car idles at 3000
- Best 205/50/15 Integra tire for under $70 bucks?
- what does this mean?
- installed my S2000 antenna today on my gsr
- Need help on deciding between two GS-R's
- will b16 alxes fit rs?
- Chalk one for integras
- how much of a difference did your headers make?
- help w/ vafc wiring problem, cel 3
- Has anyone here switched from KYB AGX's to Koni Yellows?
- How do u guys like the spoon radiator cap??
- Will 235-45-17 sized Tires fit.....??
- need help w/replacement of control arm
- Pics for archive: Stock OEM plug-Stock plugs with 60k
- anyone know where i can pick up a yellow H3 bulbs?
- HX wheels
- tubro for integra Ls
- Tires Rubbing
- Vafc or Safc with turbo?
- any gsrs with clutchmaster flywheels?
- OEM or NGK? which one!
- Sylvania Silverstars...blown
- JDM vs. RICE Who cares?
- Whats the differences between 1994-2000 teggies
- Christmas Goodies for the Teg
- Worst Mod Ever!
- Where can i get the airbag replacement tray for my DC?
- How low should i go?
- What does it take......
- tranny question
- Breakig in New Koni/Eibach springs
- TypeR suspension conversion
- Quick bumpstop question.
- Help removing filler bolt
- is it me OR...
- Stainless steel bolts and springs for exhaust mounting?
- Which H emblem for DC?
- 95 GSR mileage
- skunk2 man. for turbo or no??
- firing order of a 94 gsr
- Gut the Cat
- Bottom end buildup???
- Rear Engine Mount???
- ITR Floormats Groupbuy
- Is my battery running low?
- Pic request of stock GSR manifold
- Shipping Front Lip
- Use of Oil Question.
- VAFC uninstall Q's
- Has anyone ever purchased an extended warranty...
- importance of a dust boot?
- Will my stock ITR header fit on friend's LS?
- rear wheel well molding
- before i take the plunge into the turbo world......
- Need to replace brake light switch
- Need Info and Help on Smog in CA
- Just bought a 96 GSR. What now?
- what cams and header???
- how to get teg to give codes
- got slower =(
- White smoke= BAD????
- Who wants it
- how do you know if distributor is bad?
- broken bolt but front wheel control arm...
- Fitment
- type wiring harness problem
- PLEASE HELP....Underhood fusebox diagram (helms)
- new clutch?
- How do you remove the heat shield?
- new motor doesnt have crank pulley on it....should i replace with OE or aftermarket??
