View Full Version : Acura Integra
- header question [HELP]
- how many miles u guys get on a full tank?
- DA Rear seat removal.. Does anyone have instructions w/ pics
- '95 Integra: Door ajar indicator on gauge cluster staying on!
- Flooding?
- Car running good at idle however..
- Locked brake system!!
- 2000 Acura Integra LS (sedan) Can't turn key all the way
- b20 90 da swap help
- cap rotor and coil help
- water in my headlights. help
- High speed steering problem
- 92 da integra, was running good?
- 3 questions ! Who's got some answers ?
- stock 94-97 integra gsr exhaust manifold help!
- OBD2 to OBD1 conversion harness. Something doesn't look right. Help!
- will these tires last?
- Will a 2 1/2 inch converter work with my stock gsr pipe?
- Will this ecu work on my set up?
- help rpms out of control
- help window wont roll up
- integra type r armrest faded need help?
- Will JDM fenders Fit without JDM Radiator support?
- 98 gsr gauge cluster replacement.
- Is this a REAL OEM ITR 98-01 lip?
- Relocating Seats
- Modded 98 GSR won't start - Help!
- should i go obd1 on my 01 integra GSR
- Help!!! someone stole my Vin plate
- Da overheating after replaced with a fluidyne rad.....
- thread size and pitch
- jdm 97 ITR exhuast manifold, what's it worth. can't find squat
- how to adjust integra highbeams
- Engine stiffener
- Honda Steering Wheel
- anyone put eg catbacks on dc integra?
- Oil pressure gauge pod: 2000 GSR
- manual n auto tranny question...
- should I or not?
- jdm itr momo srs steering wheel which srs wire to what location on connector?
- driver side headlight is very dim????
- Please Help Me find Window Visors<<<<
- RSX seats in a Integra?
- B18C1 with skunk2 mani question
- GSR Intake air temperature sensor...
- Dc turns over, CEL flashes 5 times an stays on. wont start?
- C-pillar Will it fit a 2 door and 4 door?
- megan racing ajustable coilovers
- Mafunction indicator after car wash
- what is 2step take off??
- speedo cable
- Can i use 95 civic charcoal canister?
- hesitation problem
- thermostat question.
- I need those Acura diagrams
- paranoid question for tranny experts
- 96 jdm type r cluster into 96 gsr ?
- Ls/Vtec
- Uberdata Or Crome IM LOST
- k20 in a da..
- If you have stock shifter and knob, please measure for me
- help installing intake
- looking to buy a used b16 head what to look for?
- Strange idle problem *Video Inside*
- 90 da wont start!!help me out
- hit a curb car wont go
- Short Shifter Bad?
- Car is about to die out at stoplights
- hi flow cat
- b18a1 pistons with eagle rods? please help if u have info
- 94 Integra: How do you remove gauge cluster?
- Possible failure of automatic transmission? --
- will a evo2 cat back from a eg hatch fit on my dc integra
- stolen teg.
- question on DA sideskirts
- What Should I Do?
- Need help finding Secondary O2 Sensor for 98 GSR
- LS VTEC Oil Pump
- header installation tips?
- Aiming of the headlights
- ASR brace/swaybar with RedShift "modular" fitment.
- 95 GSR fails emissions w/ both ecus
- ls integra valve cover
- Integra not getting fuel
- ek skirts on dc
- DC Aligment specs
- ob1/obd0
- 91 Integra Having some problems please help!
- Read my spark plugs!
- Piston identification
- integra brakes question.
- Help me decide ,Evo 9 Recaro Seats!! $400
- how do i get my B18c block/ B16a2 head to higher compression?
- turbo stock integra
- need engine help. big time!
- Would like some input/help for my '98 GS-R rebuild (long)
- 2500 rev limit b18b1 swap
- 1990 integra for sale B16A swap
- Wieght diffrences between integra and civic
- Code 22
- batterie is dieing while my teg is off
- any good tuner's
- Shaking in Reverse
- Coilovers help needed
- valve stem seals removal
- Deciding on what i should get?
- 200hp out of a n/a gsr
- ls sputters when you gas it..help asap
- Need help with vtec on h22a turbo?????
- b18c boostin questions HELP
- s2k steering wheel on dc4?
- GSR Turbo---valvetrain suggestions??
- Motor Swap
- FPR Install question?
- Need some input quick!!!. Coil or igniter???
- Exhaust is really LOUD inside and drone on freeway sucks.
- Spark plugs arnt coming undone..help!
- B20B and my 96 integra , have some ?'s
- What do you guys think? (dc4 trade)
- Rattle and Noise Problems DA Integra
- kinda stuck...?
- How many SSBP's GSR's were made?
- Where to get plastic adjusters for my illuminas?
- O2 sensor, Transmission, and Gas mileage questions.
- BIG oil issue!
- D4 Tranny Light
- Problems with clutch and car not starting
- car wont go into gears?
- Question about a rhd conversion
- Starting problem
- Anyone smog a car in CA with a JDM catalytic converter?
- 91 gs idles a little bit to low
- help on replacing headlights
- Integra drives normal but doesnt move when i gas it
- a question i have...
- cooling system trouble . Need HELP
- header, test pipe and which exhaust?
- arp head bolts?
- Safe to use Nos 75 shot (dry) on 99 GSR?
- Bunch of problems. Help me keep the car alive!
- b18a turbo or ls vtec help!!!!!!!
- Help revving problem!!!
- Neeed a header!!!!! Please help!
- Acura OEM Parts
- Integra has no power in any gear until about 4k rpms
- Del Sol Seats in CAD DA Integra
- Where is the oil fill plug on the trans? B series.
- stalls into neutral.. help!?
- brief knock
- DA Suspension Help
- skunk 2 header
- Car won't go into gear.. Help DA integra
- power to manual window conversion
- Wrong jack point, pushed up floorboards
- cut eibachs
- itr strut bar question
- Aftermarket crankshaft pulley
- Need help with brakes
- Should i buy it?
- Mismatched Windows! HELP!
- HELP i changed my timing belt now many problems
- HELP: I blew a motor, but I do have options...maybe.
- Battery Case
- Rear trailing arm bushing question.
- GSR cluster's interchangable?
- B18C block B16a2 head, it idles high after getting on it
- Is This A Good Ecu>?
- Alternator stud help
- 92 b16a2 integra swap help??
- HUGE WIRING PROBLEM need help integra gsr
- How do I service the VTEC solenoid?
- What lip is this?
- anyone ever had a pilot bearing come out
- White steame / pressure out of valve cover breather hole. Whats wrong
- RSR exhaust w/ stock DA tips?
- ► Creating a new topic? Choose a subject specific title.. Not ''help me asap''
- I need help
- 94 ls, rebuilt head, headgasket, ect... cranks but no start (SEARCHED)
- 95 special edition or gsr?
- 1994 GSR Tail Light Problem
- Need HELP!!!!ASAP
- Ground Control Limited edition or Koni style?
- 94-97 Lip
- Integra hood wont open and battery dead!
- cluster lights
- still getting the idle controll code
- heater question
- Need obd1 distributor
- Nned help!! Surging idle!!
- 92 gs-r steering problems......
- OBD2 swap into OBD1 car....
- ABS light is on.
- Prevent rust on wheelwells
- I need help!!!
- Exhaust setup. How will this sound?
- Is this car worth buying?? i need help!!! please
- 94 ls stumbles and lost all power
- stereo problesm with 95 gsr
- car wont start
- how to prep valve cover to repaint
- do all integra gsr come with lsd trnny?
- 96dsr/00si camber kits
- my dc2 is having some issues
- engine light code
- "DA" b20 question! mounts ><
- Q about upgrading front & rear swaybars
- how 2 install a skunk2 short shifter ?
- Best shock/spring combination for DA???
- Confused between ES OVAL TUNING MUFFLER or VIBRANT
- front end grinding noise... HELP!!!
- tranny rebuilt but some rattle + vibrate??
- RS*R exhaust
- performer x vs victor x
- New 94 GSR owner - stalling when hot issue?
- ls head on b16 bottom end
- 92 gsr jdm h22a ecu?
- B20 head on a B18B1
- Could this work to determine if my gsr trans has lsd
- 98 gsr tranny questions
- Heater wont cut off
- Would this be a fast and reliable LS INTEGRA?
- Will stock valves hold up?
- Low oil pressure light @ low idle
- 94 gsr wiring diagram
- No power to passenger side
- JDM front end does this sound legit?
- reliable place to get used parts in NH
- anyone use topline head bolts?
- IAB Removal DIY Request
- itr Lip
- JDM C1 into USDM G3
- My car fail emission help please paper pic included
- Cluster problem
- 1994 LS problems
- How the f to remove the FITV!?
- gsr intake manifolds
- What should i do to my GSR
- Good bushing kit for dail driven integra
- replaced alternator, no fix, please read
- B18C or B20
- oil leaks fro head?
- Air in coolant
- Strange Electrical Problem, Please help!
- B series starters-interchangeable?
- buddy club n+
- Seat belt buckles???
- lost 3rd and 4th gears?
- 99 integra on ef shocks/springs?
- gsr oil tank question
